    4. gelöst: Javascript Adapter 5.8.8
      Thomas Braun Most Active @frankthegreat last edited by Thomas Braun
      @frankthegreat
      https://forum.iobroker.net/topic/55678/node-js-16-x-neue-empfehlung-für-iobroker
      In 'meinem' HowTo (s. Signatur) gibt es auch noch ein paar Tips gerade in Bezug auf node16/npm8 und dessen neuem Format für die package*-Files.
      frankthegreat 1 Reply Last reply Reply Quote 0
      • frankthegreat
        frankthegreat @Thomas Braun last edited by
        @thomas-braun OK, danke.
        Mal schauen, ob ich es am WE schaffe 😎
          Beowolf last edited by
          Ich habe das Problem auch
          bei mir kommt die Meldung
          host.raspberrypi
          	2022-09-05 12:51:15.176	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          host.raspberrypi
          	2022-09-05 12:51:15.176	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.raspberrypi
          	2022-09-05 12:51:15.176	error	Caught by controller[0]: }
          host.raspberrypi
          	2022-09-05 12:51:15.176	error	Caught by controller[0]: requestPath: 'coffeescript'
          host.raspberrypi
          	2022-09-05 12:51:15.176	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) {
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
          host.raspberrypi
          	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
          host.raspberrypi
          	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
          host.raspberrypi
          	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
          host.raspberrypi
          	2022-09-05 12:51:15.174	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:364:19)
          host.raspberrypi
          	2022-09-05 12:51:15.174	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
          host.raspberrypi
          	2022-09-05 12:51:15.174	error	Caught by controller[0]: ^
          host.raspberrypi
          	2022-09-05 12:51:15.174	error	Caught by controller[0]: throw err;
          host.raspberrypi
          	2022-09-05 12:51:15.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:372
          Ich bin mir nicht sicher was ich machen soll.
            Thomas Braun Most Active @Beowolf last edited by
            @beowolf sagte in gelöst: Javascript Adapter 5.8.8:
            Welcher Befehl führte zu den Ausgaben?
            Welche nodejs-Version?
            sudo ln -s /usr/bin/node /usr/bin/nodejs
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            Welche Versionen der Adapter?
            iobroker update -i
              Beowolf @Thomas Braun last edited by
              Bei
              kommt
              pi@raspberrypi:/ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.17.0
              v16.17.0
              8.15.0
              pi
              OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
              OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
              Paketlisten werden gelesen… Fertig
              Abhängigkeitsbaum wird aufgebaut… Fertig
              Statusinformationen werden eingelesen… Fertig
              Alle Pakete sind aktuell.
              nodejs:
                Installiert:           16.17.0-deb-1nodesource1
                Installationskandidat: 16.17.0-deb-1nodesource1
                Versionstabelle:
               *** 16.17.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                      100 /var/lib/dpkg/status
                   14.20.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                   12.22.12~dfsg-1~deb11u1 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
              pi@raspberrypi:/ $
              Bei
              iobroker update -i
              kommt
              pi@raspberrypi:/ $ iobroker update -i
              Used repository: stable
              Adapter    "admin"        : 6.2.20   , installed 6.2.20
              Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
              Adapter    "alias-manager": 1.2.4    , installed 1.2.4
              Adapter    "backitup"     : 2.4.10   , installed 2.4.10
              Adapter    "discovery"    : 3.0.5    , installed 3.0.5
              Adapter    "email"        : 1.1.3    , installed 1.1.3
              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
              Adapter    "ical"         : 1.13.1   , installed 1.13.1
              Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
              Adapter    "info"         : 1.9.19   , installed 1.9.19
              Adapter    "iot"          : 1.11.8   , installed 1.11.8
              Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
              Adapter    "javascript"   : 6.0.0    , installed 6.0.0
              Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
              Adapter    "ping"         : 1.5.3    , installed 1.5.3
              Adapter    "pushover"     : 3.0.2    , installed 3.0.2
              Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
              Adapter    "vis"          : 1.4.15   , installed 1.4.15
              Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
              Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
              Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
              Adapter    "wled"         : 0.6.7    , installed 0.6.7
              pi@raspberrypi:/ $
                @thomas-braun sagte in gelöst: Javascript Adapter 5.8.8:
                Bei diesem
                  @beowolf
                  Stell dich in dein /home-Verzeichnis. Warum steht du da in / herum?
                  cd ~
                    Hast du das auch in / ausgeführt?
                    Bitte IMMER vollständige Ein- und Ausgaben inkl. login prompt zeigen, dann sieht man sowas direkt.
                      Habe es dort gemacht.
                      pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ npm install --production
                      npm WARN config production Use `--omit=dev` instead.
                      > iobroker.javascript@6.0.0 postinstall
                      > node ./install/installTypings.js
                      Installing NodeJS typings...
                      latest @types: 18, installed node: 16
                      up to date, audited 107 packages in 12s
                      9 packages are looking for funding
                        run `npm fund` for details
                      found 0 vulnerabilities
                        Thomas Braun Most Active @Beowolf last edited by Thomas Braun
                        wäre richtig gewesen.
                        cd /opt/iobroker/node_modules/iobroker.javascript
                        npm install --omit=dev
                          Beowolf @Thomas Braun last edited by Beowolf
                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm install --production
                          up to date, audited 107 packages in 11s
                          Habe ich jetzt ein Problem, weil es im falschen Ordner war?
                            Gegebenenfalls später, ja.
                              pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm install --omit=dev
                                cd /opt/iobroker
                                npm ls iobroker.javascript
                                  pi@raspberrypi:/opt/iobroker $ npm ls iobroker.javascript
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  └── iobroker.javascript@6.0.0
                                    @beowolf
                                    Passt.
                                    npm ls
                                    sagt?
                                      ├── @types/caseless@0.12.2 extraneous
                                      ├── @types/request@2.48.8 extraneous
                                      ├── @types/tough-cookie@4.0.2 extraneous
                                      ├── coffeescript@1.12.7 extraneous
                                      ├── iobroker.admin@6.2.20
                                      ├── iobroker.alexa2@3.11.2
                                      ├── iobroker.alias-manager@1.2.4
                                      ├── iobroker.backitup@2.4.10
                                      ├── iobroker.discovery@3.0.5
                                      ├── iobroker.email@1.1.3
                                      ├── iobroker.hm-rega@3.0.40
                                      ├── iobroker.hm-rpc@1.15.12
                                      ├── iobroker.ical@1.13.1
                                      ├── iobroker.influxdb@3.1.7
                                      ├── iobroker.info@1.9.19
                                      ├── iobroker.iot@1.11.8
                                      ├── iobroker.iqontrol@2.0.1
                                      ├── iobroker.javascript@6.0.0
                                      ├── iobroker.js-controller@4.0.23
                                      ├── iobroker.luftdaten@2.2.4
                                      ├── iobroker.mqtt@4.0.7
                                      ├── iobroker.ping@1.5.3
                                      ├── iobroker.pushover@3.0.2
                                      ├── iobroker.scenes@2.3.9
                                      ├── iobroker.simple-api@2.7.0
                                      ├── iobroker.sonoff@2.5.1
                                      ├── iobroker.vis-bars@0.1.4
                                      ├── iobroker.vis-canvas-gauges@0.1.5
                                      ├── iobroker.vis-fancyswitch@1.1.0
                                      ├── iobroker.vis-history@1.0.0
                                      ├── iobroker.vis-hqwidgets@1.2.0
                                      ├── iobroker.vis@1.4.15
                                      ├── iobroker.web@4.3.0
                                      ├── iobroker.wiffi-wz@2.2.1
                                      ├── iobroker.wled@0.6.7
                                      ├── jsonata@1.8.6 extraneous
                                      ├── node-inspect@2.0.0 extraneous
                                      ├── picocolors@1.0.0 extraneous
                                      ├── suncalc2@1.8.1 extraneous
                                      ├── typescript@4.7.4 extraneous
                                      ├── virtual-tsc@0.6.2 extraneous
                                      └── wake_on_lan@1.0.0 extraneous
                                        @beowolf
                                        Kannst du noch 'prunen', wenn du magst.
                                        npm prune
                                        Sieht aber sauber aus.
                                          npm prune
                                          pi@raspberrypi:/opt/iobroker $ npm prune
                                          removed 105 packages, and changed 1 package in 7s
                                          59 packages are looking for funding
                                            Läuft wieder.
                                            Danke für die Hilfe.
                                            1606
