    4. gelöst: Javascript Adapter 5.8.8
      Beowolf last edited by
      Ich habe das Problem auch
      bei mir kommt die Meldung
      host.raspberrypi
      	2022-09-05 12:51:15.176	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.raspberrypi
      	2022-09-05 12:51:15.176	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      	2022-09-05 12:51:15.176	error	Caught by controller[0]: }
      host.raspberrypi
      	2022-09-05 12:51:15.176	error	Caught by controller[0]: requestPath: 'coffeescript'
      host.raspberrypi
      	2022-09-05 12:51:15.176	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) {
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
      host.raspberrypi
      	2022-09-05 12:51:15.175	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      host.raspberrypi
      	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
      host.raspberrypi
      	2022-09-05 12:51:15.174	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
      host.raspberrypi
      	2022-09-05 12:51:15.174	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:364:19)
      host.raspberrypi
      	2022-09-05 12:51:15.174	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
      host.raspberrypi
      	2022-09-05 12:51:15.174	error	Caught by controller[0]: ^
      host.raspberrypi
      	2022-09-05 12:51:15.174	error	Caught by controller[0]: throw err;
      host.raspberrypi
      	2022-09-05 12:51:15.173	error	Caught by controller[0]: node:internal/modules/cjs/loader:372
      Ich bin mir nicht sicher was ich machen soll.
        Thomas Braun Most Active @Beowolf last edited by
        @beowolf sagte in gelöst: Javascript Adapter 5.8.8:
        Welcher Befehl führte zu den Ausgaben?
        Welche nodejs-Version?
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Welche Versionen der Adapter?
        iobroker update -i
          Beowolf @Thomas Braun last edited by
          Bei
          kommt
          pi@raspberrypi:/ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.17.0
          v16.17.0
          8.15.0
          pi
          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
          OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
          Paketlisten werden gelesen… Fertig
          Abhängigkeitsbaum wird aufgebaut… Fertig
          Statusinformationen werden eingelesen… Fertig
          Alle Pakete sind aktuell.
          nodejs:
            Installiert:           16.17.0-deb-1nodesource1
            Installationskandidat: 16.17.0-deb-1nodesource1
            Versionstabelle:
           *** 16.17.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               14.20.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
               12.22.12~dfsg-1~deb11u1 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          pi@raspberrypi:/ $
          Bei
          iobroker update -i
          kommt
          pi@raspberrypi:/ $ iobroker update -i
          Used repository: stable
          Adapter    "admin"        : 6.2.20   , installed 6.2.20
          Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
          Adapter    "backitup"     : 2.4.10   , installed 2.4.10
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "email"        : 1.1.3    , installed 1.1.3
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "ical"         : 1.13.1   , installed 1.13.1
          Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.8   , installed 1.11.8
          Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
          Adapter    "javascript"   : 6.0.0    , installed 6.0.0
          Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pushover"     : 3.0.2    , installed 3.0.2
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "vis"          : 1.4.15   , installed 1.4.15
          Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
          Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
          Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          pi@raspberrypi:/ $
            @thomas-braun sagte in gelöst: Javascript Adapter 5.8.8:
            Bei diesem
              @beowolf
              Stell dich in dein /home-Verzeichnis. Warum steht du da in / herum?
              cd ~
                Hast du das auch in / ausgeführt?
                Bitte IMMER vollständige Ein- und Ausgaben inkl. login prompt zeigen, dann sieht man sowas direkt.
                  Habe es dort gemacht.
                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript/node_modules $ npm install --production
                  npm WARN config production Use `--omit=dev` instead.
                  > iobroker.javascript@6.0.0 postinstall
                  > node ./install/installTypings.js
                  Installing NodeJS typings...
                  latest @types: 18, installed node: 16
                  up to date, audited 107 packages in 12s
                  9 packages are looking for funding
                    run `npm fund` for details
                  found 0 vulnerabilities
                    Thomas Braun Most Active @Beowolf last edited by Thomas Braun
                    wäre richtig gewesen.
                    cd /opt/iobroker/node_modules/iobroker.javascript
                    npm install --omit=dev
                      Beowolf @Thomas Braun last edited by Beowolf
                      pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm install --production
                      up to date, audited 107 packages in 11s
                      Habe ich jetzt ein Problem, weil es im falschen Ordner war?
                        Gegebenenfalls später, ja.
                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.javascript $ npm install --omit=dev
                            cd /opt/iobroker
                            npm ls iobroker.javascript
                              pi@raspberrypi:/opt/iobroker $ npm ls iobroker.javascript
                              iobroker.inst@3.0.0 /opt/iobroker
                              └── iobroker.javascript@6.0.0
                                @beowolf
                                Passt.
                                npm ls
                                sagt?
                                  ├── @types/caseless@0.12.2 extraneous
                                  ├── @types/request@2.48.8 extraneous
                                  ├── @types/tough-cookie@4.0.2 extraneous
                                  ├── coffeescript@1.12.7 extraneous
                                  ├── iobroker.admin@6.2.20
                                  ├── iobroker.alexa2@3.11.2
                                  ├── iobroker.alias-manager@1.2.4
                                  ├── iobroker.backitup@2.4.10
                                  ├── iobroker.discovery@3.0.5
                                  ├── iobroker.email@1.1.3
                                  ├── iobroker.hm-rega@3.0.40
                                  ├── iobroker.hm-rpc@1.15.12
                                  ├── iobroker.ical@1.13.1
                                  ├── iobroker.influxdb@3.1.7
                                  ├── iobroker.info@1.9.19
                                  ├── iobroker.iot@1.11.8
                                  ├── iobroker.iqontrol@2.0.1
                                  ├── iobroker.javascript@6.0.0
                                  ├── iobroker.js-controller@4.0.23
                                  ├── iobroker.luftdaten@2.2.4
                                  ├── iobroker.mqtt@4.0.7
                                  ├── iobroker.ping@1.5.3
                                  ├── iobroker.pushover@3.0.2
                                  ├── iobroker.scenes@2.3.9
                                  ├── iobroker.simple-api@2.7.0
                                  ├── iobroker.sonoff@2.5.1
                                  ├── iobroker.vis-bars@0.1.4
                                  ├── iobroker.vis-canvas-gauges@0.1.5
                                  ├── iobroker.vis-fancyswitch@1.1.0
                                  ├── iobroker.vis-history@1.0.0
                                  ├── iobroker.vis-hqwidgets@1.2.0
                                  ├── iobroker.vis@1.4.15
                                  ├── iobroker.web@4.3.0
                                  ├── iobroker.wiffi-wz@2.2.1
                                  ├── iobroker.wled@0.6.7
                                  ├── jsonata@1.8.6 extraneous
                                  ├── node-inspect@2.0.0 extraneous
                                  ├── picocolors@1.0.0 extraneous
                                  ├── suncalc2@1.8.1 extraneous
                                  ├── typescript@4.7.4 extraneous
                                  ├── virtual-tsc@0.6.2 extraneous
                                  └── wake_on_lan@1.0.0 extraneous
                                    @beowolf
                                    Kannst du noch 'prunen', wenn du magst.
                                    npm prune
                                    Sieht aber sauber aus.
                                      npm prune
                                      pi@raspberrypi:/opt/iobroker $ npm prune
                                      removed 105 packages, and changed 1 package in 7s
                                      59 packages are looking for funding
                                        Läuft wieder.
                                        Danke für die Hilfe.
                                        1606
