    4. Test Adapter enigma2 v1.2.x
      Flugschüler @Lucky_ESA last edited by Flugschüler
      @lucky_esa Ich hab auf debug gestellt und jetzt?
        Lucky_ESA Developer Most Active last edited by
        Du musst den kompletten Log posten und nicht nur die Fehlermeldungen.
          host.raspberrypi
          	2022-09-03 21:21:42.920	info	Restart adapter system.adapter.enigma2.0 because enabled
          host.raspberrypi
          	2022-09-03 21:21:42.919	error	instance system.adapter.enigma2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          enigma2.0
          	2022-09-03 21:21:42.776	debug	get movies from directory: /media/hdd/movie/
          enigma2.0
          	2022-09-03 21:21:41.843	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          enigma2.0
          	2022-09-03 21:21:41.842	info	terminating
          enigma2.0
          	2022-09-03 21:21:41.523	debug	evaluating response for command 'DEVICEINFO': {"e2deviceinfo":{"e2oeversion":["OE-Alliance 5.0"],"e2enigmaversion":["2022-09-01"],"e2distroversion":["openatv"],"e2imageversion":["7.0.20220903"],"e2driverdate":["20201218"],"e2webifversion":["OWIF 1.5.2"],"e2fpversion":["0"],"e2devicename":["UHD TRIO 4K"],"e2frontends":[{"e2frontend":[{"e2name":["Tuner A"],"e2model":["Si2166D (DVB-S2X)"]},{"e2name":["Tuner B"],"e2model":["ATBM7821 DVB-T2/C (DVB-T2)"]}]}],"e2network":[{"e2interface":[{"e2name":["eth0"],"e2mac":["d0:27:29:0f:87:39"],"e2dhcp":["False"],"e2ip":["192.168.1.150"],"e2gateway":["192.168.1.1"],"e2netmask":["255.255.255.0"]}]}],"e2hdds":[{"e2hdd":[{"e2model":["Generic(STORAGE DEVICE)"],"e2capacity":["59.6 GB"],"e2free":["-1 MB"],"e2mount":[""]},{"e2model":["ST925032(0AS)"],"e2capacity":["232.9 GB"],"e2free":["181.2 GB"],"e2mount":["/media/hdd"]}]}]}}
          enigma2.0
          	2022-09-03 21:21:41.515	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.514	debug	creating request for command 'NONE' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/getallservices')
          enigma2.0
          	2022-09-03 21:21:41.513	debug	updating movie list
          enigma2.0
          	2022-09-03 21:21:41.513	debug	evaluating response for command 'GETMOVIELIST': {"e2locations":{"e2location":["/media/hdd/movie/"]}}
          enigma2.0
          	2022-09-03 21:21:41.511	debug	evaluating response for command 'TIMERLIST': {"e2timerlist":"\n"}
          enigma2.0
          	2022-09-03 21:21:41.508	debug	evaluating response for command 'ISRECORD': {"e2timerlist":"\n"}
          enigma2.0
          	2022-09-03 21:21:41.506	error	Cannot read properties of undefined (reading 'e2eventlist')
          enigma2.0
          	2022-09-03 21:21:41.506	error	TypeError: Cannot read properties of undefined (reading 'e2eventlist') at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/main.js:521:40) at /opt/iobroker/node_modules/iobroker.enigma2/main.js:407:8 at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (node:events:513:28) at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:323:31)
          enigma2.0
          	2022-09-03 21:21:41.505	error	unhandled promise rejection: Cannot read properties of undefined (reading 'e2eventlist')
          enigma2.0
          	2022-09-03 21:21:41.504	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          enigma2.0
          	2022-09-03 21:21:41.502	debug	evaluating response for command 'GETCURRENT': {"html":{"head":[{"title":["Processing Failed"]}],"body":[{"b":["Processing Failed"]}]}}
          enigma2.0
          	2022-09-03 21:21:41.499	debug	Box Muted:true
          enigma2.0
          	2022-09-03 21:21:41.499	debug	Box Volume:50
          enigma2.0
          	2022-09-03 21:21:41.498	debug	evaluating response for command 'GETVOLUME': {"e2volume":{"e2result":["True"],"e2resulttext":["Status"],"e2current":["50"],"e2ismuted":["True"]}}
          enigma2.0
          	2022-09-03 21:21:41.487	debug	Box Sender:
          enigma2.0
          	2022-09-03 21:21:41.486	debug	evaluating response for command 'GETINFO': {"e2abouts":{"e2about":[{"e2oeversion":["OE-Alliance 5.0"],"e2enigmaversion":["2022-09-01"],"e2distroversion":["openatv"],"e2imageversion":["7.0.20220903"],"e2driverdate":["20201218"],"e2webifversion":["OWIF 1.5.2"],"e2fpversion":["0"],"e2model":["UHD TRIO 4K"],"e2lanmac":["d0:27:29:0f:87:39"],"e2landhcp":["False"],"e2lanip":["192.168.1.150"],"e2lanmask":["255.255.255.0"],"e2langw":["192.168.1.1"],"e2hddinfo":[{"model":["Generic(STORAGE DEVICE)"],"capacity":["59.6 GB"],"free":["-1 MB"],"mount":[""]}],"e2tunerinfo":[{"e2nim":[{"name":["Tuner A"],"type":["Si2166D (DVB-S2X)"],"live":[""],"rec":[""]},{"name":["Tuner B"],"type":["ATBM7821 DVB-T2/C (DVB-T2)"],"live":[""],"rec":[""]}]}],"e2servicename":[""],"e2servicenamespace":[""],"e2serviceaspect":["0"],"e2serviceprovider":[""],"e2videowidth":["0"],"e2videoheight":["0"],"e2servicevideosize":["0x0"],"e2apid":["0"],"e2vpid":["0"],"e2pcrpid":["0"],"e2pmtpid":["0"],"e2txtpid":["N/A"],"e2tsid":["0"],"e2onid":["0"],"e2sid":["0"]}]}}
          enigma2.0
          	2022-09-03 21:21:41.478	debug	message answer: Keine rechtzeitige Antwort
          enigma2.0
          	2022-09-03 21:21:41.477	debug	evaluating response for command 'MESSAGEANSWER': {"e2simplexmlresult":{"e2state":["False"],"e2statetext":["Keine rechtzeitige Antwort"]}}
          enigma2.0
          	2022-09-03 21:21:41.471	debug	Box Standby: true
          enigma2.0
          	2022-09-03 21:21:41.470	debug	evaluating response for command 'GETSTANDBY': {"e2powerstate":{"e2instandby":["\ntrue\t"]}}
          enigma2.0
          	2022-09-03 21:21:41.340	debug	evaluating response for command 'TIMERLIST': {"e2timerlist":"\n"}
          enigma2.0
          	2022-09-03 21:21:41.338	debug	evaluating response for command 'ISRECORD': {"e2timerlist":"\n"}
          enigma2.0
          	2022-09-03 21:21:41.335	error	Cannot read properties of undefined (reading 'e2eventlist')
          enigma2.0
          	2022-09-03 21:21:41.335	error	TypeError: Cannot read properties of undefined (reading 'e2eventlist') at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/main.js:521:40) at /opt/iobroker/node_modules/iobroker.enigma2/main.js:407:8 at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (node:events:513:28) at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:323:31)
          enigma2.0
          	2022-09-03 21:21:41.333	error	unhandled promise rejection: Cannot read properties of undefined (reading 'e2eventlist')
          enigma2.0
          	2022-09-03 21:21:41.333	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          enigma2.0
          	2022-09-03 21:21:41.330	debug	evaluating response for command 'GETCURRENT': {"html":{"head":[{"title":["Processing Failed"]}],"body":[{"b":["Processing Failed"]}]}}
          enigma2.0
          	2022-09-03 21:21:41.327	debug	Box Muted:true
          enigma2.0
          	2022-09-03 21:21:41.326	debug	Box Volume:50
          enigma2.0
          	2022-09-03 21:21:41.326	debug	evaluating response for command 'GETVOLUME': {"e2volume":{"e2result":["True"],"e2resulttext":["Status"],"e2current":["50"],"e2ismuted":["True"]}}
          enigma2.0
          	2022-09-03 21:21:41.323	debug	Box Sender:
          enigma2.0
          	2022-09-03 21:21:41.323	debug	evaluating response for command 'GETINFO': {"e2abouts":{"e2about":[{"e2oeversion":["OE-Alliance 5.0"],"e2enigmaversion":["2022-09-01"],"e2distroversion":["openatv"],"e2imageversion":["7.0.20220903"],"e2driverdate":["20201218"],"e2webifversion":["OWIF 1.5.2"],"e2fpversion":["0"],"e2model":["UHD TRIO 4K"],"e2lanmac":["d0:27:29:0f:87:39"],"e2landhcp":["False"],"e2lanip":["192.168.1.150"],"e2lanmask":["255.255.255.0"],"e2langw":["192.168.1.1"],"e2hddinfo":[{"model":["Generic(STORAGE DEVICE)"],"capacity":["59.6 GB"],"free":["-1 MB"],"mount":[""]}],"e2tunerinfo":[{"e2nim":[{"name":["Tuner A"],"type":["Si2166D (DVB-S2X)"],"live":[""],"rec":[""]},{"name":["Tuner B"],"type":["ATBM7821 DVB-T2/C (DVB-T2)"],"live":[""],"rec":[""]}]}],"e2servicename":[""],"e2servicenamespace":[""],"e2serviceaspect":["0"],"e2serviceprovider":[""],"e2videowidth":["0"],"e2videoheight":["0"],"e2servicevideosize":["0x0"],"e2apid":["0"],"e2vpid":["0"],"e2pcrpid":["0"],"e2pmtpid":["0"],"e2txtpid":["N/A"],"e2tsid":["0"],"e2onid":["0"],"e2sid":["0"]}]}}
          enigma2.0
          	2022-09-03 21:21:41.314	debug	message answer: Keine rechtzeitige Antwort
          enigma2.0
          	2022-09-03 21:21:41.313	debug	evaluating response for command 'MESSAGEANSWER': {"e2simplexmlresult":{"e2state":["False"],"e2statetext":["Keine rechtzeitige Antwort"]}}
          enigma2.0
          	2022-09-03 21:21:41.301	debug	Box Standby: true
          enigma2.0
          	2022-09-03 21:21:41.300	debug	evaluating response for command 'GETSTANDBY': {"e2powerstate":{"e2instandby":["\ntrue\t"]}}
          enigma2.0
          	2022-09-03 21:21:41.280	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.280	debug	creating request for command 'DEVICEINFO' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/deviceinfo')
          enigma2.0
          	2022-09-03 21:21:41.279	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.278	debug	creating request for command 'GETMOVIELIST' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/getlocations')
          enigma2.0
          	2022-09-03 21:21:41.277	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.277	debug	creating request for command 'TIMERLIST' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/timerlist')
          enigma2.0
          	2022-09-03 21:21:41.275	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.275	debug	creating request for command 'ISRECORD' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/timerlist')
          enigma2.0
          	2022-09-03 21:21:41.274	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.273	debug	creating request for command 'GETCURRENT' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/getcurrent')
          enigma2.0
          	2022-09-03 21:21:41.272	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.271	debug	creating request for command 'GETVOLUME' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/vol')
          enigma2.0
          	2022-09-03 21:21:41.270	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.270	debug	creating request for command 'GETINFO' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/about')
          enigma2.0
          	2022-09-03 21:21:41.268	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.267	debug	creating request for command 'MESSAGEANSWER' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/messageanswer?getanswer=now')
          enigma2.0
          	2022-09-03 21:21:41.266	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.265	debug	creating request for command 'GETSTANDBY' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/powerstate')
          enigma2.0
          	2022-09-03 21:21:41.264	info	enigma2 Verbunden!
          enigma2.0
          	2022-09-03 21:21:41.158	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.156	debug	creating request for command 'TIMERLIST' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/timerlist')
          enigma2.0
          	2022-09-03 21:21:41.153	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.152	debug	creating request for command 'ISRECORD' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/timerlist')
          enigma2.0
          	2022-09-03 21:21:41.149	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.147	debug	creating request for command 'GETCURRENT' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/getcurrent')
          enigma2.0
          	2022-09-03 21:21:41.145	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.144	debug	creating request for command 'GETVOLUME' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/vol')
          enigma2.0
          	2022-09-03 21:21:41.142	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.141	debug	creating request for command 'GETINFO' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/about')
          enigma2.0
          	2022-09-03 21:21:41.138	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.136	debug	creating request for command 'MESSAGEANSWER' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/messageanswer?getanswer=now')
          enigma2.0
          	2022-09-03 21:21:41.118	debug	using authorization with user 'root'
          enigma2.0
          	2022-09-03 21:21:41.105	debug	creating request for command 'GETSTANDBY' (deviceId: 1, host: 192.168.1.150, port: 80, path: '/web/powerstate')
          javascript.0
          	2022-09-03 21:21:36.709	info	script.js.Meine_Geräte.Anycubic_I3_Mega: 06. Anycubic i3 Mega Zähler zurücksetzen
          enigma2.0
          	2022-09-03 21:21:36.102	info	starting Polling every 5000 ms
          enigma2.0
          	2022-09-03 21:21:36.096	debug	config
          enigma2.0
          	2022-09-03 21:21:36.095	debug	config Username: root
          enigma2.0
          	2022-09-03 21:21:36.094	debug	config Port: 80
          enigma2.0
          	2022-09-03 21:21:36.093	debug	config IPAddress: 192.168.1.150
          enigma2.0
          	2022-09-03 21:21:36.047	info	starting. Version 1.3.4 (non-npm: Matten-Matten/ioBroker.enigma2#4198fa2049f66bb5eb274a24ae64f4fa3149065f) in /opt/iobroker/node_modules/iobroker.enigma2, node: v16.17.0, js-controller: 4.0.23
            Lucky_ESA Developer Most Active last edited by Lucky_ESA
            @flugschüler Damit kann man was anfangen. Es kommen keine Daten vom Receiver. Du benutzt root...Ändere mal deine Einstellungen im Receiver auf ohne Passwort-
            Den Fehler kann ich abfangen und einen Pullrequest einstellen (mache ich morgen).
            Sieht nach einem Softwarefehler aus...
            Edit:
            Pullrequest
            Gruß//Lucky
              @lucky_esa Wo finde ich die Einstellung ohne Passwort ?
                Im WEBIF aber das bringt wohl nichts. Hier müsst ihr im openatv Forum fragen warum ihr bei http://192.168.xxx.xxx/web/getcurrent keine Daten bekommt.
                Ich kann leider nicht testen das ich mit allen 4 Boxen noch auf openatv 6.0 bin.
                Gruß//Lucky
                  @lucky_esa Kann man beim Adapter was ändern oder liegt es nur am Openatv?
                    @flugschüler Nach so einer Meldung würde ich sagen JA.
                    Gruß//Lucky
                      @lucky_esa Es lag an der OWIF 1.5.2. Die OWIF wurde bearbeitet. Receiver aktualisieren und alles müsste wieder funktionieren.
                      E B 2 Replies Last reply Reply Quote 0
                        el_malto @Flugschüler last edited by
                        @flugschüler jo wurde fiexed.
                        https://github.com/E2OpenPlugins/e2openplugin-OpenWebif/issues/1566#event-7322399962
                        420Dope created this issue in E2OpenPlugins/e2openplugin-OpenWebif
                        closed http://192.168.xxx.xxx/web/getcurrent no data #1566
                          biker1602 @Flugschüler last edited by
                          @flugschüler said in Test Adapter enigma2 v1.2.x:
                          Super es funktioniert wieder vielen Dank
                            Flopsi last edited by Flopsi
                            Funktioniert der Adapter noch ?
                            Glasfaser 1Topf 2 Replies Last reply Reply Quote 0
                            • Glasfaser
                              Glasfaser @Flopsi last edited by
                              @flopsi sagte in Test Adapter enigma2 v1.2.x:
                              Mehr hast du nicht an Infos ... als Frage .. oder ein Problem !?
                              • 1Topf
                                1Topf @Flopsi last edited by
                                Ja.
                                  Flopsi @Glasfaser last edited by Flopsi
                                  @glasfaser Nö aktuell nicht ich gucke mir den Adapter erstmal an
                                    australien last edited by
                                    Hallo Zusammen,
                                    ich hab mir nun fast den ganzen Threat angesehen, bekomme aber keine Lösung.
                                    Ich will aus dem Datenpunk enigma2.0.enigma2.CHANNEL_PICON das Picon in der Vis anzeigen lassen.
                                    Aber egal ob ich es mit dem Widget "image", "String img src" oder "html" mache, es bleibt weiß, wird nichts angezeigt.
                                    Wenn ich die url direkt in den Browser gebe, wird das richtige Logo angezeigt.
                                    Was mach ich falsch?
                                    Danke!
                                    • Glasfaser
                                      Glasfaser @australien last edited by
                                      @australien
                                      auch nicht so ... bzw. weiter unter steht auch noch etwas:
                                      https://forum.iobroker.net/post/321729
                                        australien @Glasfaser last edited by australien
                                        @glasfaser
                                        das hab ich auch schon gesehen, nur was ist das für ein Widget?
                                        Der Wald hat zu viele Bäume.
                                        • Glasfaser
                                          @australien sagte in Test Adapter enigma2 v1.2.x:
                                          Siehe hier ...
                                            @glasfaser
                                            das hab ich schon gesehe, bin aber neu bei iobroker, und kann damit nichts anfangen.
                                            Kann ich das irgenwo hinkopieren?
                                            Glasfaser 2 Replies Last reply Reply Quote 0
                                            adapter enigma2
                                            71
                                            640
                                            142125
