    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    • Negalein
      Negalein Global Moderator @Thomas Braun last edited by
      @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
      speedtest installieren? Das Repo passt ja nun.
      nega@ioBroker:~$ sudo apt install speedtest
      [sudo] password for nega:
      Reading package lists... Done
      Building dependency tree
      The following package was automatically installed and is no longer required:
        libllvm11
      Use 'sudo apt autoremove' to remove it.
      The following NEW packages will be installed:
        speedtest
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 0 B/1055 kB of archives.
      After this operation, 2549 kB of additional disk space will be used.
      (Reading database ... 36354 files and directories currently installed.)
      Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_amd64.deb ...
      Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
      dpkg: error processing archive /var/cache/apt/archives/speedtest_1.1.1.28-1.c732eb82cf_amd64.deb (--unpack):
       trying to overwrite '/usr/bin/speedtest', which is also in package speedtest-cli 2.1.2-2ubuntu0.20.04.1
      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      nega@ioBroker:~$ speedtest
      Retrieving speedtest.net configuration...
      Testing from Fonira Telekom GmbH (185.129.173.57)...
      Retrieving speedtest.net server list...
      Selecting best server based on ping...
      Hosted by Netprotect (Vienna) [214.89 km]: 13.237 ms
      Testing download speed................................................................................
      Download: 743.13 Mbit/s
      Testing upload speed......................................................................................................
      Upload: 429.67 Mbit/s
        Thomas Braun Most Active @Negalein last edited by Thomas Braun
        @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
        sudo apt remove speedtest-cli
        Damrak2022 Negalein 2 Replies Last reply Reply Quote 0
        • Damrak2022
          Damrak2022 @Thomas Braun last edited by
          @thomas-braun Okay, gemacht
          pi@homebridge:~ $ sudo apt full-upgrade
          Building dependency tree... Done
          Calculating upgrade... Done
          The following packages will be upgraded:
            nodejs
          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 23.3 MB of archives.
          After this operation, 31.2 MB of additional disk space will be used.
          Do you want to continue? [Y/n] y
          Get:1 https://deb.nodesource.com/node_14.x bullseye/main armhf nodejs armhf 14.19.1-deb-1nodesource1 [23.3 MB]
          Fetched 23.3 MB in 1s (15.6 MB/s)
          Reading changelogs... Done
          (Reading database ... 62196 files and directories currently installed.)
          Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_armhf.deb ...
          Unpacking nodejs (14.19.1-deb-1nodesource1) over (12.22.12-deb-1nodesource1) ...
          Setting up nodejs (14.19.1-deb-1nodesource1) ...
          Processing triggers for man-db (2.9.4-2) ...
          pi@homebridge:~ $ sudo apt install speedtest
          speedtest is already the newest version (1.1.1.28-1.c732eb82cf).
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          pi@homebridge:~ $
          • Negalein
            Merci, funktioniert! 🙂
            10:13:18.127	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest mit Server 5476 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
            10:13:37.909	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 92.81 MB/s | Upload: 94.15 MB/s | Ping: 10.806ms
               Speedtest by Ookla
                 Server: Energie AG Oberoesterreich Telekom GmbH - Gmunden (id = 5476)
                    ISP: Fonira Telekom GmbH
                Latency:    10.78 ms   (0.09 ms jitter)
               Download:   777.98 Mbps (data used: 846.2 MB )
                 Upload:   782.09 Mbps (data used: 850.7 MB )
            Packet Loss:     0.0%
             Result URL: https://www.speedtest.net/result/c/7bcefc71-fa63-4b37-8cc4-6515c2bd1a92
              @negalein
              Siehste, sogar ein Server aus Oberösterreich.
                ps1304 @Thomas Braun last edited by
                Danke für deinen Beitrag - ich habe nach der Webseite installiert und bekomme beim Befehl "sudo apt update" jetzt folgenden Fehler:
                E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/ubuntu impish Release« enthält keine Release-Datei.
                N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                Hast du nen Tipp?
                Gruß Peter
                  Thomas Braun Most Active @ps1304 last edited by Thomas Braun
                  @ps1304
                  Hab kein Ubuntu im Einsatz.
                  Aber offenbar bauen die keine Pakete für impish.
                  Könnte sein, dass hier nur für LTS-Versionen gebaut wird. Die Zwischenversionen leben ja nur 9 Monate.
                  Trag mal ausnahmsweise statt impish die Vorversion focal in die Datei
                  /etc/apt/sources.list.d/ookla_speedtest-cli.list ein.
                    @ps1304
                    Edit. Siehe oben.
                    Und daran denken, dass am 14.07.2022 Schluss ist mit 'impish'. Ich würde da auf die jetzt aktuelle LTS-Version wechseln.
                      super vielen Dank - der Tipp war schon mal gut !!! das Update mache ich gerade.
                      Gruß Peter
                      • David G.
                        David G. last edited by
                        bei mir mag er das irgendwie nicht installieren.
                        pi@pi:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                        Detected operating system as raspbian/bullseye.
                        Checking for curl...
                        Detected curl...
                        Checking for gpg...
                        Detected gpg...
                        Running apt-get update... done.
                        Installing apt-transport-https... done.
                        Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.Importing packagecloud gpg key... done.
                        The repository is setup! You can now install packages.
                        pi@pi:~ $ sudo apt update                                          Ign:1 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Err:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                          404  Not Found [IP: 54.183.164.179 443]
                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                        E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
                        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                        N: See apt-secure(8) manpage for repository creation and user configuration details.
                        pi@pi:~ $ sudo apt install speedtest
                        E: Unable to locate package speedtest
                        pi@pi:~ $ lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Raspbian
                        Description:    Raspbian GNU/Linux 11 (bullseye)
                        Release:        11
                        Codename:       bullseye
                        GNU nano 5.4  /etc/apt/sources.list.d/nodesource.list            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nod>deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb>
                          Thomas Braun Most Active @David G. last edited by
                          @david-g
                          uname -a
                          cat /etc/apt/sources.list.d/nodesource.list
                            Thomas Braun Most Active @David G. last edited by Thomas Braun
                            @david-g
                            Trag das mal so ein:
                            echad@chet:~ $ cat /etc/apt/sources.list.d/ookla_speedtest-cli.list
                            # this file was generated by packagecloud.io for
                            # the repository at https://packagecloud.io/ookla/speedtest-cli
                            deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                            deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                            echad@chet:~ $
                            Also statt raspbian debian eintragen. Da ist das Installationsskript immer noch unsauber und passt nicht für Raspberry OS.
                            • David G.
                              David G. @Thomas Braun last edited by
                              So klappt es,
                              vielen Dank.
                              Dann begebe ich mich nachher mal an das Skript.
                              • David G.
                                Habe mal eine ganz allgemeine Frage zum Skript.
                                Die Datenpunkte werden ja im javascript.0 angelegt.
                                Jetzt hab ich hier schon ein paar mal gelesen, dass man für eigene Datenpunkte eher den userdata.0 bevorzugen soll.
                                Macht das für so ein Skript auch mehr Sinn?
                                  A Former User @David G. last edited by A Former User
                                  @david-g eigene Datenpunkte unter 0_userdata.0 haben den Vorteil, dass wenn du z.Bsp. die Javascript-Instanz loeschen wuerdest deine Datenpunkte erhalten bleibn, incl. History.. daher wenn moeglich, immer eigene Datenpunkte in userdata anlegen.
                                  Zeile 28 dann anstatt
                                  var datenpunkt = "Speedtest.";
                                  in
                                  var datenpunkt = "0_userdata.0.Speedtest.";
                                  • David G.
                                    Habt ihr auch, dass das Skript mehrfach läuft, wenn ihr Änderungen vorgenommen habt?
                                    Hatte 1-2 mal den shedule geändert und ein paar Server getestet.
                                    Als die Testergebnisse dann viel zu gering waren habe ich im Log (und der History) gesehen, dass der Test innerhalb einer Sekunde 8 mal gestartet wird, regelmäßig.
                                    liv-in-sky Negalein 2 Replies Last reply Reply Quote 0
                                      liv-in-sky @David G. last edited by
                                      @david-g starte die javascript instanz neu - evtl hängt da noch was im system
                                      • Negalein
                                        Negalein Global Moderator @David G. last edited by
                                        @david-g sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                        Ja, gibt dazu ein Issue!
                                        Häng dich dort auch ran.
                                          guergen @Negalein last edited by guergen
                                          Ich kann den Schlüssel nicht importieren:
                                          +-▒▒{▒ϓ▒▒ N#9▒Z▒▒▒u▒T▒  ▒▒▒+▒}▒L▒(
                                          ▒O;}▒yC^▒6▒MCl3▒▒▒GC▒ﵨ?a▒▒▒4▒▒▒~▒▒4ȻH.7▒.d▒*-bash: Syntaxfehler beim unerwarteten Symbol »|«
                                          iob@iob:~$ PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTY
                                          Danach kommt folgende Meldung:
                                          iob@iob:~$ sudo apt update
                                          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                                          OK:2 http://ftp.de.debian.org/debian bullseye InRelease
                                          OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          OK:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
                                          Holen:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease [24,5 kB]
                                          Fehl:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                                          Paketlisten werden gelesen… Fertig
                                          W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                                          E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease« ist nicht signiert.
                                          iob@iob:~$
                                          Schreibe ich das in eine Zeile
                                          iob@iob:~$ curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor~ | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                                          Bekomme ich folgende Meldung:
                                          Ungültige Option "--dearmor~"
                                          (23) Failed writing body
                                          Wo steckt der Fehler?
                                            Thomas Braun Most Active @guergen last edited by
                                            @guergen sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                            --dearmor~
                                            Muss
                                            --dearmor
                                            lauten.
                                            391
                                            72611
