    4. Kein Update mehr möglich mit Node.js 16
      Thomas Braun Most Active @kimukao last edited by
      @kimukao
      Das geht noch weiter.
      'Bild Runter'-Taste
        kimukao @Thomas Braun last edited by
        @thomas-braun ah.. ok.. so sieht's im weiteren Verlauf aus:
        19 timing npm:load:configload Completed in 29ms
        20 timing npm:load:mkdirpcache Completed in 2ms
        21 timing npm:load:mkdirplogs Completed in 1ms
        22 verbose title npm install iobroker.backitup@2.4.10
        23 verbose argv "install" "--save-exact" "iobroker.backitup@2.4.10"
        24 timing npm:load:setTitle Completed in 4ms
        25 timing config:load:flatten Completed in 9ms
        26 timing npm:load:display Completed in 11ms
        27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
        28 verbose logfile /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
        29 timing npm:load:logFile Completed in 13ms
        30 timing npm:load:timers Completed in 1ms
        31 timing npm:load:configScope Completed in 0ms
        32 timing npm:load Completed in 63ms
        33 timing arborist:ctor Completed in 2ms
        34 silly logfile start cleaning logs, removing 2 files
        35 silly logfile done cleaning log files
        36 timing idealTree:init Completed in 3489ms
        37 timing idealTree Completed in 3494ms
        38 timing command:install Completed in 3530ms
        39 verbose stack TypeError: builtins is not a function
        39 verbose stack     at validate (/usr/lib/node_modules/npm/node_modules/validate-npm-package-name/lib/index.js:55:3)
        39 verbose stack     at Result.setName (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:129:17)
        39 verbose stack     at new Result (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:120:10)
        39 verbose stack     at resolve (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:57:15)
        39 verbose stack     at npa (/usr/lib/node_modules/npm/node_modules/npm-package-arg/lib/npa.js:51:10)
        39 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:542:50
        39 verbose stack     at Array.map (<anonymous>)
        39 verbose stack     at Arborist.[add] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:539:28)
        39 verbose stack     at Arborist.[applyUserRequestsToNode] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:510:23)
        39 verbose stack     at Arborist.[applyUserRequests] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:447:43)
        40 verbose cwd /opt/iobroker
        41 verbose Linux 5.15.61-v7l+
        42 verbose node v16.17.0
        43 verbose npm  v8.15.0
        44 error builtins is not a function
        45 verbose exit 1
        46 timing npm Completed in 3800ms
        47 verbose unfinished npm timer reify 1662463682151
        48 verbose unfinished npm timer reify:loadTrees 1662463682178
        49 verbose unfinished npm timer idealTree:userRequests 1662463685671
        50 verbose code 1
        51 error A complete log of this run can be found in:
        51 error     /home/iobroker/.npm/_logs/2022-09-06T11_28_01_889Z-debug-0.log
        (END)
          @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
          Keine Ahnung was das für ein Fehler ist und wo man den beheben könnte.
            @thomas-braun Oje. Würde dann nur eine Neuinstallation des iobrokers samt Einspielung eines Backups helfen? Oder liegt der Hund woanders begraben?
              @kimukao
              Ich weiß es nicht.
                @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
                Ich weiß es nicht.
                Trotzdem vielen Dank für die Hilfe. Dann hoffe ich, dass noch jemand eine Idee hat bevor ich alles platt mache...
                  Thomas Braun Most Active last edited by
                  @kimukao
                  Ich hab keinen Plan von JavaScript, aber hier:
                  https://flaviocopes.com/is-not-a-function/
                  schreibt jemand, dass da im Code irgendwo ein Semikolon fehlt.
                  Ich weiß nur nicht ob das beim Backitup dann zu suchen wäre oder doch woanders.
                  Andere Adapter lassen sich updaten?
                  K 2 Replies Last reply Reply Quote 0
                    @thomas-braun Leider lässt sich kein einziger Adapter updaten
                      kimukao @Thomas Braun last edited by kimukao
                      @thomas-braun Hab's mal durchprobiert. Interessant ist, dass jedes Mal vor dem Hinweis "exited with code 0" eine words.js Datei auftaucht. Hier am Beispiel des Discovery Adapters (lässt sich beliebig auf alle anderen Adapter übertragen):
                      $ iobroker upgrade discovery@3.0.5
                      Update discovery from @3.0.3 to @3.0.5
                      NPM version: 8.15.0
                      Installing iobroker.discovery@3.0.5... (System call)
                      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                      Process exited with code 0
                      Bedeutet das, dass das Einfügen eines Semikolons in die .js Dateien helfen würde? Wenn ja, wie mache ich das denn?
                        @kimukao
                        Mach es mit --debug-Option.
                        Sonst sieht man da genau gar nichts.
                          iobroker upgrade admin@6.2.20 --debug
                          This upgrade of "admin" will at least introduce the following changes:
                          -> 6.2.20:
                          Corrected GUI issues
                          -> 6.2.19:
                          Corrected some issues
                          -> 6.2.18:
                          Corrected GUI bugs on custom settings
                          -> 6.2.17:
                          Corrected GUI bug on intro tab
                          -> 6.2.16:
                          Corrected many GUI issues
                          Added `stable` flag for repositories
                          Added reset button for repositories
                          Improved `writeFile` function for socket communication
                          -> 6.2.14:
                          Fix for OAuth2 authentication response success page
                          -> 6.2.13:
                          Corrected JSON config
                          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                          Would you like to upgrade admin from @5.3.8 to @6.2.20 now? [(y)es, (n)o]: y
                          Update admin from @5.3.8 to @6.2.20
                          host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                          NPM version: 8.15.0
                          Installing iobroker.admin@6.2.20... (System call)
                          npm ERR! builtins is not a function
                          npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T13_14_32_531Z-debug-0.log
                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                          host.raspberrypi Adapter "system.adapter.admin.0" is started
                            @kimukao
                            Ich kann dir nicht helfen.
                              @thomas-braun Trotzdem danke, dass Du Dir so viel Zeit für mich genommen hast. Jemand anderes eine Idee?
                              • mickym
                                Wenn gar nichts mehr geht - und bevor ihr neu installiert - dann probiert halt meine Radikalmethode. 😉 -
                                K mickym 2 Replies Last reply Reply Quote 0
                                  kimukao @mickym last edited by
                                  @mickym die da wäre..? Machst mich neugierig
                                  • mickym
                                    mickym Most Active @mickym last edited by mickym
                                    @mickym Wir können es probieren - aber wie gesagt - erst dann wenn Du sonst eh neu aufbauen müsstest oder wieder zurück kannst. 😉 Ich lösche immer das ganze node_modules Verzeichnis und lasse es komplett neu aufbauen. - Können wir zusammen durchgehen, wenn Du meinst dass man Dein System nicht mehr kaputter machen kann.
                                    Poste mal Deine package.json aus dem Verzeichnis: /opt/iobroker hier in code-tags-
                                      @mickym ich schätze, das wäre meine einzige Chance.. im Moment läuft zwar alles stabil, ich kann aber nichts updaten, perspektivisch also "suboptimal"
                                      • mickym
                                        mickym Most Active @kimukao last edited by
                                        @kimukao Kannst Du noch ein Image oder so ziehen - bevor ins kalte Wasser springen?
                                          @mickym das letzte Backup wurde heute Nacht in die Dropbox geschrieben
                                          Hier die package.json:
                                          "name": "iobroker.inst",
                                          "version": "3.0.0",
                                          "private": true,
                                          "description": "Automate your Life",
                                          "engines": {
                                          "node": ">=10.0.0"
                                          "dependencies": {
                                          "iobroker.js-controller": "stable",
                                          "iobroker.admin": "stable",
                                          "iobroker.discovery": "stable",
                                          "iobroker.backitup": "stable"
                                          Hab eben mal in meiner Verzweiflung den iobroker neuinstalliert - vermutlich deshalb nicht mehr viel drin...
                                          • mickym
                                            mickym Most Active @kimukao last edited by mickym
                                            @kimukao Na dann hast Du schon versucht - neu zu installieren - da ist ja gar kein Adapter mehr drin. Mit der Neuinstallation hast Du nun natürlich alles weg gemacht und überschrieben. Kannst Du damit keine Adapter mehr installieren - die müssten ja jetzt alle weg sein. Hast Du noch ein Image - vor der Neuinstallation?
                                            node js
                                            16
                                            335
                                            39089
