    4. Kein Update mehr möglich mit Node.js 16
      kimukao @Thomas Braun last edited by kimukao
      iobroker upgrade admin@6.2.20 --debug
      This upgrade of "admin" will at least introduce the following changes:
      -> 6.2.20:
      Corrected GUI issues
      -> 6.2.19:
      Corrected some issues
      -> 6.2.18:
      Corrected GUI bugs on custom settings
      -> 6.2.17:
      Corrected GUI bug on intro tab
      -> 6.2.16:
      Corrected many GUI issues
      Added `stable` flag for repositories
      Added reset button for repositories
      Improved `writeFile` function for socket communication
      -> 6.2.14:
      Fix for OAuth2 authentication response success page
      -> 6.2.13:
      Corrected JSON config
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade admin from @5.3.8 to @6.2.20 now? [(y)es, (n)o]: y
      Update admin from @5.3.8 to @6.2.20
      host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.15.0
      Installing iobroker.admin@6.2.20... (System call)
      npm ERR! builtins is not a function
      npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T13_14_32_531Z-debug-0.log
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      host.raspberrypi Adapter "system.adapter.admin.0" is started
        Thomas Braun Most Active @kimukao last edited by
        @kimukao
        Ich kann dir nicht helfen.
          @thomas-braun Trotzdem danke, dass Du Dir so viel Zeit für mich genommen hast. Jemand anderes eine Idee?
          • mickym
            Wenn gar nichts mehr geht - und bevor ihr neu installiert - dann probiert halt meine Radikalmethode. 😉 -
            K mickym 2 Replies Last reply Reply Quote 0
              kimukao @mickym last edited by
              @mickym die da wäre..? Machst mich neugierig
              • mickym
                mickym Most Active @mickym last edited by mickym
                @mickym Wir können es probieren - aber wie gesagt - erst dann wenn Du sonst eh neu aufbauen müsstest oder wieder zurück kannst. 😉 Ich lösche immer das ganze node_modules Verzeichnis und lasse es komplett neu aufbauen. - Können wir zusammen durchgehen, wenn Du meinst dass man Dein System nicht mehr kaputter machen kann.
                Poste mal Deine package.json aus dem Verzeichnis: /opt/iobroker hier in code-tags-
                  @mickym ich schätze, das wäre meine einzige Chance.. im Moment läuft zwar alles stabil, ich kann aber nichts updaten, perspektivisch also "suboptimal"
                  • mickym
                    mickym Most Active @kimukao last edited by
                    @kimukao Kannst Du noch ein Image oder so ziehen - bevor ins kalte Wasser springen?
                      @mickym das letzte Backup wurde heute Nacht in die Dropbox geschrieben
                      Hier die package.json:
                      "name": "iobroker.inst",
                      "version": "3.0.0",
                      "private": true,
                      "description": "Automate your Life",
                      "engines": {
                      "node": ">=10.0.0"
                      "dependencies": {
                      "iobroker.js-controller": "stable",
                      "iobroker.admin": "stable",
                      "iobroker.discovery": "stable",
                      "iobroker.backitup": "stable"
                      Hab eben mal in meiner Verzweiflung den iobroker neuinstalliert - vermutlich deshalb nicht mehr viel drin...
                      • mickym
                        mickym Most Active @kimukao last edited by mickym
                        @kimukao Na dann hast Du schon versucht - neu zu installieren - da ist ja gar kein Adapter mehr drin. Mit der Neuinstallation hast Du nun natürlich alles weg gemacht und überschrieben. Kannst Du damit keine Adapter mehr installieren - die müssten ja jetzt alle weg sein. Hast Du noch ein Image - vor der Neuinstallation?
                          @mickym Sind alle noch da. Komisch - verstehe ich auch nicht... Hilf mir auf die Sprünge: ein Image ist das Backup? Hab ich in der Dropbox...
                          • mickym
                            @kimukao Nee kein Backup - sondern ein Abbild Deiner SD Karte. - aber egal. Das Deine Adapter noch leben - glaube ich wird mir der package.json - nach der Neuinstallation nicht mehr lange anhalten. Dann hast Du mit Deiner Neuinstallation leider die Information welche Adapter installiert waren überschrieben. Dann kannst Du nur noch mal versuchen - ein Backup zurückzuspielen.
                            Mach mal im
                            cd /opt/iobroker
                            npm list
                            K 2 Replies Last reply Reply Quote 0
                              @mickym said in Kein Update mehr möglich mit Node.js 16:
                              cd /opt/iobroker
                              npm list
                              cd /opt/iobroker
                              npm list
                              iobroker.inst@3.0.0 /opt/iobroker
                              ├── @apollon/iobroker-tools@0.2.0 extraneous
                              ├── @babel/code-frame@7.16.7 extraneous
                              ├── @babel/helper-validator-identifier@7.16.7 extraneous
                              ├── @babel/highlight@7.16.10 extraneous
                              ├── @babel/runtime@7.17.2 extraneous
                              ├── @frankjoke/myadapter@1.2.8 extraneous
                              ├── @homebridge/ciao@1.1.3 extraneous
                              ├── @influxdata/influxdb-client-apis@1.25.0 extraneous
                              ├── @influxdata/influxdb-client@1.25.0 extraneous
                              ├── @jimp/bmp@0.16.1 extraneous
                              ├── @jimp/core@0.16.1 extraneous
                              ├── @jimp/custom@0.16.1 extraneous
                              ├── @jimp/gif@0.16.1 extraneous
                              ├── @jimp/jpeg@0.16.1 extraneous
                              ├── @jimp/plugin-resize@0.16.1 extraneous
                              ├── @jimp/png@0.16.1 extraneous
                              ├── @jimp/tiff@0.16.1 extraneous
                              ├── @jimp/types@0.16.1 extraneous
                              ├── @jimp/utils@0.16.1 extraneous
                              ├── @jpgorganizer/utils@1.2.1 extraneous
                              ├── @leichtgewicht/ip-codec@2.0.3 extraneous
                              ├── @material/animation@7.0.0 extraneous
                              ├── @material/base@7.0.0 extraneous
                              ├── @material/button@7.0.0 extraneous
                              ├── @material/card@7.0.0 extraneous
                              ├── @material/density@7.0.0 extraneous
                              ├── @material/dom@7.0.0 extraneous
                              ├── @material/elevation@7.0.0 extraneous
                              ├── @material/feature-targeting@7.0.0 extraneous
                              ├── @material/ripple@7.0.0 extraneous
                              ├── @material/rtl@7.0.0 extraneous
                              ├── @material/shape@7.0.0 extraneous
                              ├── @material/switch@7.0.0 extraneous
                              ├── @material/theme@7.0.0 extraneous
                              ├── @material/touch-target@7.0.0 extraneous
                              ├── @material/typography@7.0.0 extraneous
                              ├── @nodelib/fs.scandir@2.1.5 extraneous
                              ├── @nodelib/fs.stat@2.0.5 extraneous
                              ├── @nodelib/fs.walk@1.2.8 extraneous
                              ├── @peculiar/asn1-schema@2.1.0 extraneous
                              ├── @peculiar/json-schema@1.1.12 extraneous
                              ├── @peculiar/webcrypto@1.3.2 extraneous
                              ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                              ├── @sindresorhus/is@4.4.0 extraneous
                              ├── @szmarczak/http-timer@4.0.6 extraneous
                              ├── @tootallnate/once@2.0.0 extraneous
                              ├── @types/asn1js@2.0.2 extraneous
                              ├── @types/bl@5.0.2 extraneous
                              ├── @types/cacheable-request@6.0.2 extraneous
                              ├── @types/caseless@0.12.2 extraneous
                              ├── @types/http-cache-semantics@4.0.1 extraneous
                              ├── @types/http-proxy@1.17.8 extraneous
                              ├── @types/jquery@3.5.14 extraneous
                              ├── @types/keyv@3.1.3 extraneous
                              ├── @types/lodash@4.14.179 extraneous
                              ├── @types/minimist@1.2.2 extraneous
                              ├── @types/normalize-package-data@2.4.1 extraneous
                              ├── @types/parse-json@4.0.0 extraneous
                              ├── @types/readable-stream@2.3.13 extraneous
                              ├── @types/request@2.48.8 extraneous
                              ├── @types/responselike@1.0.0 extraneous
                              ├── @types/sizzle@2.3.3 extraneous
                              ├── @types/tough-cookie@4.0.1 extraneous
                              ├── @types/web@0.0.55 extraneous
                              ├── abab@2.0.5 extraneous
                              ├── acorn-globals@6.0.0 extraneous
                              ├── acorn-walk@8.2.0 extraneous
                              ├── acorn@8.7.0 extraneous
                              ├── address@1.1.2 extraneous
                              ├── after@0.8.2 extraneous
                              ├── aggregate-error@3.1.0 extraneous
                              ├── alexa-cookie2@4.0.1 extraneous
                              ├── alexa-remote2@4.1.2 extraneous
                              ├── ansi-align@3.0.1 extraneous
                              ├── ansi-escapes@4.3.2 extraneous
                              ├── ansi-regex@2.1.1 extraneous
                              ├── any-base@1.1.0 extraneous
                              ├── any-observable@0.5.1 extraneous
                              ├── any-promise@1.3.0 extraneous
                              ├── aproba@1.2.0 extraneous
                              ├── are-we-there-yet@1.1.7 extraneous
                              ├── argparse@1.0.10 extraneous
                              ├── array-back@3.1.0 extraneous
                              ├── array-union@2.1.0 extraneous
                              ├── array.prototype.findindex@2.2.0 extraneous
                              ├── arraybuffer.slice@0.0.7 extraneous
                              ├── asn1js@2.3.2 extraneous
                              ├── ast-types@0.13.4 extraneous
                              ├── async-exit-hook@2.0.1 extraneous
                              ├── available-typed-arrays@1.0.5 extraneous
                              ├── backo2@1.0.2 extraneous
                              ├── base64-arraybuffer@0.1.4 extraneous
                              ├── base64id@2.0.0 extraneous
                              ├── better-assert@1.0.2 extraneous
                              ├── blob@0.0.5 extraneous
                              ├── bmp-js@0.1.0 extraneous
                              ├── bonjour-hap@3.6.3 extraneous
                              ├── boolbase@1.0.0 extraneous
                              ├── boxen@5.1.2 extraneous
                              ├── brace-expansion@1.1.11 extraneous
                              ├── browser-process-hrtime@1.0.0 extraneous
                              ├── buffer-equal@0.0.1 extraneous
                              ├── bufferhelper@0.2.1 extraneous
                              ├── buildcheck@0.0.3 extraneous
                              ├── builtins@1.0.3 extraneous
                              ├── cacheable-lookup@5.0.4 extraneous
                              ├── cacheable-request@7.0.2 extraneous
                              ├── callsites@3.1.0 extraneous
                              ├── camelcase-keys@6.2.2 extraneous
                              ├── camelcase@5.3.1 extraneous
                              ├── capitalize@2.0.4 extraneous
                              ├── chalk@2.4.2 extraneous
                              ├── chardet@0.7.0 extraneous
                              ├── cheerio-select@1.5.0 extraneous
                              ├── cheerio@1.0.0-rc.10 extraneous
                              ├── clean-stack@2.2.0 extraneous
                              ├── cli-boxes@2.2.1 extraneous
                              ├── cli-cursor@3.1.0 extraneous
                              ├── cli-truncate@0.2.1 extraneous
                              ├── cli-width@3.0.0 extraneous
                              ├── clone-response@1.0.2 extraneous
                              ├── cloneextend@0.0.3 extraneous
                              ├── coap-packet@0.1.14 extraneous
                              ├── coap@0.24.0 extraneous
                              ├── code-point-at@1.1.0 extraneous
                              ├── coffee-compiler@0.3.2 extraneous
                              ├── coffee-script@1.12.7 extraneous
                              ├── coiot-coap@1.0.0 extraneous
                              ├── command-line-args@5.2.1 extraneous
                              ├── command-line-usage@6.1.1 extraneous
                              ├── commander@6.2.1 extraneous
                              ├── commist@1.1.0 extraneous
                              ├── component-bind@1.0.0 extraneous
                              ├── component-emitter@1.3.0 extraneous
                              ├── component-inherit@0.0.3 extraneous
                              ├── concat-map@0.0.1 extraneous
                              ├── concat-stream@1.6.2 extraneous
                              ├── configstore@5.0.1 extraneous
                              ├── console-control-strings@1.1.0 extraneous
                              ├── copy-to@2.0.1 extraneous
                              ├── cosmiconfig@7.0.1 extraneous
                              ├── cpu-features@0.0.4 extraneous
                              ├── crypto-random-string@2.0.0 extraneous
                              ├── crypto@1.0.1 extraneous
                              ├── css-select@4.2.1 extraneous
                              ├── css-what@5.1.0 extraneous
                              ├── cssom@0.5.0 extraneous
                              ├── cssstyle@2.3.0 extraneous
                              ├── data-uri-to-buffer@3.0.1 extraneous
                              ├── data-urls@3.0.1 extraneous
                              ├── date-fns@1.30.1 extraneous
                              ├── decamelize-keys@1.1.0 extraneous
                              ├── decamelize@1.2.0 extraneous
                              ├── decimal.js@10.3.1 extraneous
                              ├── decompress-response@6.0.0 extraneous
                              ├── deep-equal@2.0.5 extraneous
                              ├── deep-extend@0.6.0 extraneous
                              ├── deep-is@0.1.4 extraneous
                              ├── default-user-agent@1.0.0 extraneous
                              ├── defer-to-connect@2.0.1 extraneous
                              ├── degenerator@3.0.2 extraneous
                              ├── del@6.0.0 extraneous
                              ├── delegates@1.0.0 extraneous
                              ├── depd@1.1.2 extraneous
                              ├── dev-null@0.1.1 extraneous
                              ├── dewpoint@1.0.0 extraneous
                              ├── digest-header@0.0.1 extraneous
                              ├── dir-glob@3.0.1 extraneous
                              ├── dom-serializer@1.3.2 extraneous
                              ├── dom-walk@0.1.2 extraneous
                              ├── domelementtype@2.2.0 extraneous
                              ├── domexception@4.0.0 extraneous
                              ├── domhandler@4.3.0 extraneous
                              ├── domutils@2.8.0 extraneous
                              ├── dot-prop@6.0.1 extraneous
                              ├── duplexer3@0.1.4 extraneous
                              ├── duplexify@4.1.2 extraneous
                              ├── elegant-spinner@1.0.1 extraneous
                              ├── engine.io-client@3.5.2 extraneous
                              ├── engine.io-parser@2.2.1 extraneous
                              ├── engine.io@3.5.0 extraneous
                              ├── entities@2.2.0 extraneous
                              ├── error-ex@1.3.2 extraneous
                              ├── es-abstract@1.20.1 extraneous
                              ├── es-get-iterator@1.1.2 extraneous
                              ├── es-shim-unscopables@1.0.0 extraneous
                              ├── es-to-primitive@1.2.1 extraneous
                              ├── escape-goat@3.0.0 extraneous
                              ├── escape-string-regexp@1.0.5 extraneous
                              ├── escodegen@2.0.0 extraneous
                              ├── esprima@4.0.1 extraneous
                              ├── estraverse@5.3.0 extraneous
                              ├── esutils@2.0.3 extraneous
                              ├── eventemitter3@4.0.7 extraneous
                              ├── exif-parser@0.1.12 extraneous
                              ├── expand-template@2.0.3 extraneous
                              ├── extend-shallow@2.0.1 extraneous
                              ├── external-editor@3.1.0 extraneous
                              ├── fast-glob@3.2.11 extraneous
                              ├── fast-levenshtein@2.0.6 extraneous
                              ├── fast-srp-hap@2.0.4 extraneous
                              ├── fastq@1.13.0 extraneous
                              ├── fastseries@2.0.0 extraneous
                              ├── figures@3.2.0 extraneous
                              ├── file-type@9.0.0 extraneous
                              ├── find-replace@3.0.0 extraneous
                              ├── find-up@5.0.0 extraneous
                              ├── foreach@2.0.5 extraneous
                              ├── formstream@1.1.1 extraneous
                              ├── fs.realpath@1.0.0 extraneous
                              ├── function.prototype.name@1.1.5 extraneous
                              ├── functions-have-names@1.2.3 extraneous
                              ├── futoin-hkdf@1.4.3 extraneous
                              ├── gauge@2.7.4 extraneous
                              ├── get-stream@5.2.0 extraneous
                              ├── get-symbol-description@1.0.0 extraneous
                              ├── get-uri@3.0.2 extraneous
                              ├── gifwrap@0.9.2 extraneous
                              ├── github-from-package@0.0.0 extraneous
                              ├── github-url-from-git@1.5.0 extraneous
                              ├── glob@7.2.0 extraneous
                              ├── global-dirs@2.1.0 extraneous
                              ├── global@4.4.0 extraneous
                              ├── globby@11.1.0 extraneous
                              ├── got@11.8.5 extraneous
                              ├── hap-nodejs@0.9.8 extraneous
                              ├── hard-rejection@2.1.0 extraneous
                              ├── has-ansi@2.0.0 extraneous
                              ├── has-bigints@1.0.2 extraneous
                              ├── has-binary@0.1.7 extraneous
                              ├── has-binary2@1.0.3 extraneous
                              ├── has-cors@1.1.0 extraneous
                              ├── has-flag@3.0.0 extraneous
                              ├── has-tostringtag@1.0.0 extraneous
                              ├── has-unicode@2.0.1 extraneous
                              ├── has-yarn@2.1.0 extraneous
                              ├── help-me@3.0.0 extraneous
                              ├── hosted-git-info@3.0.8 extraneous
                              ├── html-encoding-sniffer@3.0.0 extraneous
                              ├── html-entities@1.0.10 extraneous
                              ├── htmlparser2@6.1.0 extraneous
                              ├── http-cache-semantics@4.1.0 extraneous
                              ├── http-proxy-agent@5.0.0 extraneous
                              ├── http-proxy-middleware@2.0.4 extraneous
                              ├── http-proxy-response-rewrite@0.0.1 extraneous
                              ├── http-proxy@1.18.1 extraneous
                              ├── http2-wrapper@1.0.3 extraneous
                              ├── https@1.0.0 extraneous
                              ├── humanize-ms@1.2.1 extraneous
                              ├── ignore-walk@3.0.4 extraneous
                              ├── ignore@5.2.0 extraneous
                              ├── image-q@1.1.1 extraneous
                              ├── import-fresh@3.3.0 extraneous
                              ├── import-lazy@2.1.0 extraneous
                              ├── import-local@3.1.0 extraneous
                              ├── imurmurhash@0.1.4 extraneous
                              ├── indent-string@3.2.0 extraneous
                              ├── indexof@0.0.1 extraneous
                              ├── inflight@1.0.6 extraneous
                              ├── influx@4.2.3 extraneous
                              ├── ini@1.3.8 extraneous
                              ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                              ├── inquirer@7.3.3 extraneous
                              ├── internal-slot@1.0.3 extraneous
                              ├── invert-kv@1.0.0 extraneous
                              ├── iobroker.admin@5.3.8 invalid: "stable" from the root project
                              ├── iobroker.alexa2@3.11.2 extraneous
                              ├── iobroker.alias-manager@1.2.4 extraneous
                              ├── iobroker.backitup@2.4.9 invalid: "stable" from the root project
                              ├── iobroker.daswetter@3.1.2 extraneous
                              ├── iobroker.deconz@1.3.21 extraneous
                              ├── iobroker.device-reminder@1.2.9 extraneous
                              ├── iobroker.discovery@3.0.3 invalid: "stable" from the root project
                              ├── iobroker.fritzdect@2.2.3 extraneous
                              ├── iobroker.heos@1.10.0 extraneous
                              ├── iobroker.history@1.11.1 extraneous
                              ├── iobroker.ical@1.12.1 extraneous
                              ├── iobroker.icons-material-png@0.1.0 extraneous
                              ├── iobroker.icons-material-svg@0.1.0 extraneous
                              ├── iobroker.icons-mfd-svg@1.1.0 extraneous
                              ├── iobroker.icons-open-icon-library-png@0.1.2 extraneous
                              ├── iobroker.icons-ultimate-png@1.0.1 extraneous
                              ├── iobroker.influxdb@2.6.3 extraneous
                              ├── iobroker.javascript@5.7.0 extraneous
                              ├── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
                              ├── iobroker.km200@2.0.3 extraneous
                              ├── iobroker.lupusec@1.3.6 extraneous
                              ├── iobroker.netatmo@1.7.1 extraneous
                              ├── iobroker.nuki-extended@2.4.0 extraneous (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#b303d4a823fcba09b4d3de04d1412c770f5c68b4)
                              ├── iobroker.onvif@0.4.4 extraneous
                              ├── iobroker.parcel@0.0.15 extraneous (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#377864c5926b0e0d41c658640e3097152f86a9fd)
                              ├── iobroker.pushover@2.1.0 extraneous
                              ├── iobroker.shelly@5.3.2 extraneous
                              ├── iobroker.simple-api@2.7.0 extraneous
                              ├── iobroker.smartcontrol@1.2.1 extraneous
                              ├── iobroker.smartgarden@2.0.0 extraneous
                              ├── iobroker.socketio@4.2.0 extraneous
                              ├── iobroker.sonos@2.1.7 extraneous
                              ├── iobroker.sony-bravia@1.0.3 extraneous
                              ├── iobroker.synology@2.1.7 extraneous
                              ├── iobroker.telegram@1.13.0 extraneous
                              ├── iobroker.text2command@2.2.1 extraneous
                              ├── iobroker.tr-064@4.2.16 extraneous
                              ├── iobroker.trashschedule@2.0.2 extraneous
                              ├── iobroker.uv-protect@0.3.5 extraneous
                              ├── iobroker.vis-fancyswitch@1.1.0 extraneous
                              ├── iobroker.vis-hqwidgets@1.2.0 extraneous
                              ├── iobroker.vis-icontwo@0.87.0 extraneous
                              ├── iobroker.vis-inventwo@3.3.1 extraneous
                              ├── iobroker.vis-material-advanced@1.7.2 extraneous
                              ├── iobroker.vis-timeandweather@1.1.7 extraneous
                              ├── iobroker.vis-weather@2.5.5 extraneous
                              ├── iobroker.vis@1.4.15 extraneous
                              ├── iobroker.vw-connect@0.0.50 extraneous
                              ├── iobroker.web@4.3.0 extraneous
                              ├── iobroker.whatsapp-cmb@0.2.2 extraneous
                              ├── iobroker.ws.server@1.0.1 extraneous
                              ├── iobroker.ws@1.3.0 extraneous
                              ├── iobroker.yahka@0.13.1 extraneous
                              ├── is-arguments@1.1.1 extraneous
                              ├── is-bigint@1.0.4 extraneous
                              ├── is-boolean-object@1.1.2 extraneous
                              ├── is-callable@1.2.4 extraneous
                              ├── is-ci@2.0.0 extraneous
                              ├── is-core-module@2.8.1 extraneous
                              ├── is-date-object@1.0.5 extraneous
                              ├── is-docker@2.2.1 extraneous
                              ├── is-extendable@0.1.1 extraneous
                              ├── is-fullwidth-code-point@1.0.0 extraneous
                              ├── is-function@1.0.2 extraneous
                              ├── is-generator-function@1.0.10 extraneous
                              ├── is-installed-globally@0.3.2 extraneous
                              ├── is-interactive@1.0.0 extraneous
                              ├── is-map@2.0.2 extraneous
                              ├── is-negative-zero@2.0.2 extraneous
                              ├── is-npm@5.0.0 extraneous
                              ├── is-number-object@1.0.6 extraneous
                              ├── is-obj@2.0.0 extraneous
                              ├── is-observable@1.1.0 extraneous
                              ├── is-path-cwd@2.2.0 extraneous
                              ├── is-path-inside@3.0.3 extraneous
                              ├── is-plain-obj@3.0.0 extraneous
                              ├── is-potential-custom-element-name@1.0.1 extraneous
                              ├── is-promise@2.2.2 extraneous
                              ├── is-regex@1.1.4 extraneous
                              ├── is-scoped@2.1.0 extraneous
                              ├── is-set@2.0.2 extraneous
                              ├── is-shared-array-buffer@1.0.2 extraneous
                              ├── is-string@1.0.7 extraneous
                              ├── is-symbol@1.0.4 extraneous
                              ├── is-typed-array@1.1.8 extraneous
                              ├── is-unicode-supported@0.1.0 extraneous
                              ├── is-url-superb@4.0.0 extraneous
                              ├── is-weakmap@2.0.1 extraneous
                              ├── is-weakref@1.0.2 extraneous
                              ├── is-weakset@2.0.2 extraneous
                              ├── is-wsl@2.2.0 extraneous
                              ├── is-yarn-global@0.3.0 extraneous
                              ├── issue-regex@3.1.0 extraneous
                              ├── jpeg-js@0.4.2 extraneous
                              ├── js-rijndael@1.0.0 extraneous
                              ├── js-sdsl@2.1.4 extraneous
                              ├── js-tokens@4.0.0 extraneous
                              ├── js-yaml@3.14.1 extraneous
                              ├── jsdom@19.0.0 extraneous
                              ├── json-buffer@3.0.1 extraneous
                              ├── json-parse-even-better-errors@2.3.1 extraneous
                              ├── json3@3.3.2 extraneous
                              ├── jsonata@1.8.6 extraneous
                              ├── keyv@4.1.1 extraneous
                              ├── kind-of@6.0.3 extraneous
                              ├── latest-version@5.1.0 extraneous
                              ├── lcid@1.0.0 extraneous
                              ├── leven@2.1.0 extraneous
                              ├── levn@0.3.0 extraneous
                              ├── lines-and-columns@1.2.4 extraneous
                              ├── listr-input@0.2.1 extraneous
                              ├── listr-silent-renderer@1.1.1 extraneous
                              ├── listr-update-renderer@0.5.0 extraneous
                              ├── listr-verbose-renderer@0.5.0 extraneous
                              ├── listr@0.14.3 extraneous
                              ├── load-bmfont@1.4.1 extraneous
                              ├── loadsh@0.0.4 extraneous
                              ├── locate-path@6.0.0 extraneous
                              ├── lodash.camelcase@4.3.0 extraneous
                              ├── lodash.get@4.4.2 extraneous
                              ├── lodash.isequal@4.5.0 extraneous
                              ├── lodash.zip@4.2.0 extraneous
                              ├── log-symbols@4.1.0 extraneous
                              ├── log-update@2.3.0 extraneous
                              ├── lowercase-keys@2.0.0 extraneous
                              ├── macaddress@0.5.1 extraneous
                              ├── make-dir@3.1.0 extraneous
                              ├── map-age-cleaner@0.1.3 extraneous
                              ├── map-obj@4.3.0 extraneous
                              ├── meow@8.1.2 extraneous
                              ├── merge2@1.4.1 extraneous
                              ├── micromatch@4.0.4 extraneous
                              ├── mime@2.6.0 extraneous
                              ├── mimic-response@3.1.0 extraneous
                              ├── min-document@2.19.0 extraneous
                              ├── min-indent@1.0.1 extraneous
                              ├── minimatch@3.1.2 extraneous
                              ├── minimist-options@4.1.0 extraneous
                              ├── minimist@1.2.6 extraneous
                              ├── moment-timezone@0.5.34 extraneous
                              ├── mqtt-connection@4.1.0 extraneous
                              ├── mqtt-packet@6.10.0 extraneous
                              ├── mqtt@4.3.7 extraneous
                              ├── multicast-dns-service-types@1.1.0 extraneous
                              ├── multicast-dns@7.2.4 extraneous
                              ├── mz@2.7.0 extraneous
                              ├── napi-build-utils@1.0.2 extraneous
                              ├── nconf@0.10.0 extraneous
                              ├── nearest-color@0.4.4 extraneous
                              ├── new-github-release-url@1.0.0 extraneous
                              ├── ngeohash@0.6.3 extraneous
                              ├── nimble@0.0.2 extraneous
                              ├── node-addon-api@3.2.1 extraneous
                              ├── node-ical@0.15.1 extraneous
                              ├── node-inspect@2.0.0 extraneous
                              ├── node-persist@0.0.11 extraneous
                              ├── node-rest-client@3.1.1 extraneous
                              ├── node-telegram-bot-api@0.57.0 extraneous
                              ├── node-vibrant@3.1.6 extraneous
                              ├── noop-logger@0.1.1 extraneous
                              ├── normalize-package-data@3.0.3 extraneous
                              ├── normalize-url@6.1.0 extraneous
                              ├── np@7.6.1 extraneous
                              ├── npm-name@6.0.1 extraneous
                              ├── npmlog@4.1.2 extraneous
                              ├── nth-check@2.0.1 extraneous
                              ├── nuki-bridge-api@1.8.0 extraneous
                              ├── nuki-web-api@2.2.1 extraneous
                              ├── number-allocator@1.0.10 extraneous
                              ├── number-is-nan@1.0.1 extraneous
                              ├── nwsapi@2.2.0 extraneous
                              ├── object-assign@4.1.1 extraneous
                              ├── object-component@0.0.3 extraneous
                              ├── object-is@1.1.5 extraneous
                              ├── object.assign@4.1.2 extraneous
                              ├── omggif@1.0.10 extraneous
                              ├── onvif@0.6.5 extraneous
                              ├── open@7.4.2 extraneous
                              ├── optionator@0.8.3 extraneous
                              ├── options@0.0.6 extraneous
                              ├── org-regex@1.0.0 extraneous
                              ├── os-locale@1.4.0 extraneous
                              ├── os-name@1.0.3 extraneous
                              ├── os-tmpdir@1.0.2 extraneous
                              ├── ospath@1.2.2 extraneous
                              ├── osx-release@1.1.0 extraneous
                              ├── otplib@11.0.1 extraneous
                              ├── ow@0.21.0 extraneous
                              ├── p-cancelable@2.1.1 extraneous
                              ├── p-defer@1.0.0 extraneous
                              ├── p-event@4.2.0 extraneous
                              ├── p-finally@1.0.0 extraneous
                              ├── p-limit@2.3.0 extraneous
                              ├── p-locate@5.0.0 extraneous
                              ├── p-memoize@4.0.4 extraneous
                              ├── p-reflect@2.1.0 extraneous
                              ├── p-settle@4.1.1 extraneous
                              ├── p-timeout@4.1.0 extraneous
                              ├── p-try@2.2.0 extraneous
                              ├── pac-proxy-agent@5.0.0 extraneous
                              ├── pac-resolver@5.0.0 extraneous
                              ├── package-json@6.5.0 extraneous
                              ├── parent-module@1.0.1 extraneous
                              ├── parse-bmfont-ascii@1.0.6 extraneous
                              ├── parse-bmfont-binary@1.0.6 extraneous
                              ├── parse-bmfont-xml@1.1.4 extraneous
                              ├── parse-headers@2.0.4 extraneous
                              ├── parse-json@5.2.0 extraneous
                              ├── parse5-htmlparser2-tree-adapter@6.0.1 extraneous
                              ├── parse5@6.0.1 extraneous
                              ├── parsejson@0.0.3 extraneous
                              ├── parseqs@0.0.6 extraneous
                              ├── parseuri@0.0.6 extraneous
                              ├── path-exists@4.0.0 extraneous
                              ├── path-is-absolute@1.0.1 extraneous
                              ├── path-parse@1.0.7 extraneous
                              ├── path-type@4.0.0 extraneous
                              ├── phin@2.9.3 extraneous
                              ├── picocolors@1.0.0 extraneous
                              ├── ping@0.4.1 extraneous
                              ├── pixelmatch@4.0.2 extraneous
                              ├── pkg-dir@5.0.0 extraneous
                              ├── pluralize@8.0.0 extraneous
                              ├── pngjs@3.4.0 extraneous
                              ├── prelude-ls@1.1.2 extraneous
                              ├── prepend-http@2.0.0 extraneous
                              ├── process@0.11.10 extraneous
                              ├── proxy-agent@5.0.0 extraneous
                              ├── proxy-from-env@1.1.0 extraneous
                              ├── pupa@2.1.1 extraneous
                              ├── pushover-notifications@1.2.2 extraneous
                              ├── pvtsutils@1.2.2 extraneous
                              ├── pvutils@1.1.3 extraneous
                              ├── q@1.5.1 extraneous
                              ├── querystring@0.2.0 extraneous
                              ├── queue-microtask@1.2.3 extraneous
                              ├── quick-lru@5.1.1 extraneous
                              ├── rc@1.2.8 extraneous
                              ├── read-pkg-up@7.0.1 extraneous
                              ├── read-pkg@5.2.0 extraneous
                              ├── redent@3.0.0 extraneous
                              ├── reduce-flatten@2.0.0 extraneous
                              ├── regenerator-runtime@0.13.9 extraneous
                              ├── regexp.prototype.flags@1.4.3 extraneous
                              ├── registry-auth-token@4.2.1 extraneous
                              ├── registry-url@5.1.0 extraneous
                              ├── reinterval@1.1.0 extraneous
                              ├── request-promise-core@1.1.4 extraneous
                              ├── request-promise@4.2.6 extraneous
                              ├── resolve-alpn@1.2.1 extraneous
                              ├── resolve-cwd@3.0.0 extraneous
                              ├── resolve-from@4.0.0 extraneous
                              ├── resolve@1.22.0 extraneous
                              ├── responselike@2.0.0 extraneous
                              ├── restore-cursor@3.1.0 extraneous
                              ├── reusify@1.0.4 extraneous
                              ├── rfdc@1.3.0 extraneous
                              ├── rimraf@3.0.2 extraneous
                              ├── rrule@2.6.4 extraneous
                              ├── run-async@2.4.1 extraneous
                              ├── run-parallel@1.2.0 extraneous
                              ├── rxjs@6.6.7 extraneous
                              ├── sax@1.2.4 extraneous
                              ├── saxes@5.0.1 extraneous
                              ├── scoped-regex@2.1.0 extraneous
                              ├── secure-keys@1.0.0 extraneous
                              ├── semver-diff@3.1.1 extraneous
                              ├── set-blocking@2.0.0 extraneous
                              ├── sharp@0.25.4 extraneous
                              ├── shelly-iot@1.1.2 extraneous
                              ├── simple-concat@1.0.1 extraneous
                              ├── simple-get@4.0.1 extraneous
                              ├── simple-ssh@1.1.0 extraneous
                              ├── slash@3.0.0 extraneous
                              ├── slice-ansi@0.0.4 extraneous
                              ├── smart-buffer@4.2.0 extraneous
                              ├── socket.io-adapter@1.1.2 extraneous
                              ├── socket.io-client@2.4.0 extraneous
                              ├── socket.io-parser@3.4.1 extraneous
                              ├── socket.io@2.4.1 extraneous
                              ├── socks-proxy-agent@5.0.1 extraneous
                              ├── socks@2.6.2 extraneous
                              ├── socksv5@0.0.6 extraneous
                              ├── sonos-discovery@1.7.3 extraneous
                              ├── spdx-correct@3.1.1 extraneous
                              ├── spdx-exceptions@2.3.0 extraneous
                              ├── spdx-expression-parse@3.0.1 extraneous
                              ├── spdx-license-ids@3.0.11 extraneous
                              ├── split2@3.2.2 extraneous
                              ├── sprintf-js@1.0.3 extraneous
                              ├── ssh2@1.11.0 extraneous
                              ├── statuses@1.5.0 extraneous
                              ├── stealthy-require@1.1.1 extraneous
                              ├── stream-shift@1.0.1 extraneous
                              ├── string-width@1.0.2 extraneous
                              ├── string.prototype.trimend@1.0.5 extraneous
                              ├── string.prototype.trimstart@1.0.5 extraneous
                              ├── strip-ansi@3.0.1 extraneous
                              ├── strip-indent@3.0.0 extraneous
                              ├── strip-json-comments@2.0.1 extraneous
                              ├── suncalc2@1.8.1 extraneous
                              ├── supports-color@5.5.0 extraneous
                              ├── supports-hyperlinks@2.2.0 extraneous
                              ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                              ├── symbol-observable@3.0.0 extraneous
                              ├── symbol-tree@3.2.4 extraneous
                              ├── syno@3.0.0 extraneous (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                              ├── table-layout@1.0.2 extraneous
                              ├── tcp-ping@0.1.1 extraneous
                              ├── terminal-link@2.1.1 extraneous
                              ├── thenify-all@1.6.0 extraneous
                              ├── thenify@3.3.1 extraneous
                              ├── thirty-two@1.0.2 extraneous
                              ├── through2@2.0.5 extraneous
                              ├── thunky@1.1.0 extraneous
                              ├── timm@1.7.1 extraneous
                              ├── tinycolor2@1.4.2 extraneous
                              ├── tmp@0.0.33 extraneous
                              ├── to-array@0.1.4 extraneous
                              ├── to-readable-stream@2.1.0 extraneous
                              ├── tr-O64@0.2.4 extraneous
                              ├── traverse@0.6.6 extraneous
                              ├── trim-newlines@3.0.1 extraneous
                              ├── type-check@0.3.2 extraneous
                              ├── type-fest@0.21.3 extraneous
                              ├── typedarray-to-buffer@3.1.5 extraneous
                              ├── typedarray@0.0.6 extraneous
                              ├── typescript@4.7.2 extraneous
                              ├── typical@4.0.0 extraneous
                              ├── ultron@1.0.2 extraneous
                              ├── unbox-primitive@1.0.2 extraneous
                              ├── underscore@1.13.2 extraneous
                              ├── unescape@1.0.1 extraneous
                              ├── unique-string@2.0.0 extraneous
                              ├── update-notifier@5.1.0 extraneous
                              ├── url-parse-lax@3.0.0 extraneous
                              ├── url@0.11.0 extraneous
                              ├── urllib@2.38.0 extraneous
                              ├── utif@2.0.1 extraneous
                              ├── util@0.12.4 extraneous
                              ├── utility@1.17.0 extraneous
                              ├── vali-date@1.0.0 extraneous
                              ├── validate-npm-package-license@3.0.4 extraneous
                              ├── validate-npm-package-name@3.0.0 extraneous
                              ├── virtual-tsc@0.6.2 extraneous
                              ├── vm2@3.9.9 extraneous
                              ├── w3c-hr-time@1.0.2 extraneous
                              ├── w3c-xmlserializer@3.0.0 extraneous
                              ├── wake_on_lan@1.0.0 extraneous
                              ├── webcrypto-core@1.7.1 extraneous
                              ├── whatwg-encoding@2.0.0 extraneous
                              ├── whatwg-mimetype@3.0.0 extraneous
                              ├── which-boxed-primitive@1.0.2 extraneous
                              ├── which-collection@1.0.1 extraneous
                              ├── which-pm-runs@1.1.0 extraneous
                              ├── which-typed-array@1.1.7 extraneous
                              ├── wide-align@1.1.5 extraneous
                              ├── widest-line@3.1.0 extraneous
                              ├── win-release@1.1.1 extraneous
                              ├── window-size@0.1.4 extraneous
                              ├── word-wrap@1.2.3 extraneous
                              ├── wordwrapjs@4.0.1 extraneous
                              ├── write-file-atomic@3.0.3 extraneous
                              ├── wtf-8@1.0.0 extraneous
                              ├── xdg-basedir@4.0.0 extraneous
                              ├── xhr@2.6.0 extraneous
                              ├── xml-flow@1.0.2 extraneous
                              ├── xml-name-validator@4.0.0 extraneous
                              ├── xml-parse-from-string@1.0.1 extraneous
                              ├── xml2js@0.4.23 extraneous
                              ├── xml2json-light@1.0.6 extraneous
                              ├── xmlbuilder@11.0.1 extraneous
                              ├── xmlchars@2.2.0 extraneous
                              ├── xmlhttprequest-ssl@1.6.3 extraneous
                              ├── xtend@4.0.2 extraneous
                              ├── yaml@1.10.2 extraneous
                              ├── yargs-parser@20.2.9 extraneous
                              ├── yeast@0.1.2 extraneous
                              └── yocto-queue@0.1.0 extraneous
                                @mickym und:
                                npm ERR! code ELSPROBLEMS
                                npm ERR! extraneous: @apollon/iobroker-tools@0.2.0 /opt/iobroker/node_modules/@apollon/iobroker-tools
                                npm ERR! extraneous: @babel/code-frame@7.16.7 /opt/iobroker/node_modules/@babel/code-frame
                                npm ERR! extraneous: @babel/helper-validator-identifier@7.16.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                                npm ERR! extraneous: @babel/highlight@7.16.10 /opt/iobroker/node_modules/@babel/highlight
                                npm ERR! extraneous: @babel/runtime@7.17.2 /opt/iobroker/node_modules/@babel/runtime
                                npm ERR! extraneous: @frankjoke/myadapter@1.2.8 /opt/iobroker/node_modules/@frankjoke/myadapter
                                npm ERR! extraneous: @homebridge/ciao@1.1.3 /opt/iobroker/node_modules/@homebridge/ciao
                                npm ERR! extraneous: @influxdata/influxdb-client-apis@1.25.0 /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
                                npm ERR! extraneous: @influxdata/influxdb-client@1.25.0 /opt/iobroker/node_modules/@influxdata/influxdb-client
                                npm ERR! extraneous: @jimp/bmp@0.16.1 /opt/iobroker/node_modules/@jimp/bmp
                                npm ERR! extraneous: @jimp/core@0.16.1 /opt/iobroker/node_modules/@jimp/core
                                npm ERR! extraneous: @jimp/custom@0.16.1 /opt/iobroker/node_modules/@jimp/custom
                                npm ERR! extraneous: @jimp/gif@0.16.1 /opt/iobroker/node_modules/@jimp/gif
                                npm ERR! extraneous: @jimp/jpeg@0.16.1 /opt/iobroker/node_modules/@jimp/jpeg
                                npm ERR! extraneous: @jimp/plugin-resize@0.16.1 /opt/iobroker/node_modules/@jimp/plugin-resize
                                npm ERR! extraneous: @jimp/png@0.16.1 /opt/iobroker/node_modules/@jimp/png
                                npm ERR! extraneous: @jimp/tiff@0.16.1 /opt/iobroker/node_modules/@jimp/tiff
                                npm ERR! extraneous: @jimp/types@0.16.1 /opt/iobroker/node_modules/@jimp/types
                                npm ERR! extraneous: @jimp/utils@0.16.1 /opt/iobroker/node_modules/@jimp/utils
                                npm ERR! extraneous: @jpgorganizer/utils@1.2.1 /opt/iobroker/node_modules/@jpgorganizer/utils
                                npm ERR! extraneous: @leichtgewicht/ip-codec@2.0.3 /opt/iobroker/node_modules/@leichtgewicht/ip-codec
                                npm ERR! extraneous: @material/animation@7.0.0 /opt/iobroker/node_modules/@material/animation
                                npm ERR! extraneous: @material/base@7.0.0 /opt/iobroker/node_modules/@material/base
                                npm ERR! extraneous: @material/button@7.0.0 /opt/iobroker/node_modules/@material/button
                                npm ERR! extraneous: @material/card@7.0.0 /opt/iobroker/node_modules/@material/card
                                npm ERR! extraneous: @material/density@7.0.0 /opt/iobroker/node_modules/@material/density
                                npm ERR! extraneous: @material/dom@7.0.0 /opt/iobroker/node_modules/@material/dom
                                npm ERR! extraneous: @material/elevation@7.0.0 /opt/iobroker/node_modules/@material/elevation
                                npm ERR! extraneous: @material/feature-targeting@7.0.0 /opt/iobroker/node_modules/@material/feature-targeting
                                npm ERR! extraneous: @material/ripple@7.0.0 /opt/iobroker/node_modules/@material/ripple
                                npm ERR! extraneous: @material/rtl@7.0.0 /opt/iobroker/node_modules/@material/rtl
                                npm ERR! extraneous: @material/shape@7.0.0 /opt/iobroker/node_modules/@material/shape
                                npm ERR! extraneous: @material/switch@7.0.0 /opt/iobroker/node_modules/@material/switch
                                npm ERR! extraneous: @material/theme@7.0.0 /opt/iobroker/node_modules/@material/theme
                                npm ERR! extraneous: @material/touch-target@7.0.0 /opt/iobroker/node_modules/@material/touch-target
                                npm ERR! extraneous: @material/typography@7.0.0 /opt/iobroker/node_modules/@material/typography
                                npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                                npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                                npm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                                npm ERR! extraneous: @peculiar/asn1-schema@2.1.0 /opt/iobroker/node_modules/@peculiar/asn1-schema
                                npm ERR! extraneous: @peculiar/json-schema@1.1.12 /opt/iobroker/node_modules/@peculiar/json-schema
                                npm ERR! extraneous: @peculiar/webcrypto@1.3.2 /opt/iobroker/node_modules/@peculiar/webcrypto
                                npm ERR! extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                                npm ERR! extraneous: @sindresorhus/is@4.4.0 /opt/iobroker/node_modules/@sindresorhus/is
                                npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                                npm ERR! extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                npm ERR! extraneous: @types/asn1js@2.0.2 /opt/iobroker/node_modules/@types/asn1js
                                npm ERR! extraneous: @types/bl@5.0.2 /opt/iobroker/node_modules/@types/bl
                                npm ERR! extraneous: @types/cacheable-request@6.0.2 /opt/iobroker/node_modules/@types/cacheable-request
                                npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                                npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
                                npm ERR! extraneous: @types/http-proxy@1.17.8 /opt/iobroker/node_modules/@types/http-proxy
                                npm ERR! extraneous: @types/jquery@3.5.14 /opt/iobroker/node_modules/@types/jquery
                                npm ERR! extraneous: @types/keyv@3.1.3 /opt/iobroker/node_modules/@types/keyv
                                npm ERR! extraneous: @types/lodash@4.14.179 /opt/iobroker/node_modules/@types/lodash
                                npm ERR! extraneous: @types/minimist@1.2.2 /opt/iobroker/node_modules/@types/minimist
                                npm ERR! extraneous: @types/normalize-package-data@2.4.1 /opt/iobroker/node_modules/@types/normalize-package-data
                                npm ERR! extraneous: @types/parse-json@4.0.0 /opt/iobroker/node_modules/@types/parse-json
                                npm ERR! extraneous: @types/readable-stream@2.3.13 /opt/iobroker/node_modules/@types/readable-stream
                                npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                                npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types/responselike
                                npm ERR! extraneous: @types/sizzle@2.3.3 /opt/iobroker/node_modules/@types/sizzle
                                npm ERR! extraneous: @types/tough-cookie@4.0.1 /opt/iobroker/node_modules/@types/tough-cookie
                                npm ERR! extraneous: @types/web@0.0.55 /opt/iobroker/node_modules/@types/web
                                npm ERR! extraneous: abab@2.0.5 /opt/iobroker/node_modules/abab
                                npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/acorn-globals
                                npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
                                npm ERR! extraneous: acorn@8.7.0 /opt/iobroker/node_modules/acorn
                                npm ERR! extraneous: address@1.1.2 /opt/iobroker/node_modules/address
                                npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
                                npm ERR! extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                                npm ERR! extraneous: alexa-cookie2@4.0.1 /opt/iobroker/node_modules/alexa-cookie2
                                npm ERR! extraneous: alexa-remote2@4.1.2 /opt/iobroker/node_modules/alexa-remote2
                                npm ERR! extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                                npm ERR! extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                                npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/ansi-regex
                                npm ERR! extraneous: any-base@1.1.0 /opt/iobroker/node_modules/any-base
                                npm ERR! extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                                npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
                                npm ERR! extraneous: aproba@1.2.0 /opt/iobroker/node_modules/aproba
                                npm ERR! extraneous: are-we-there-yet@1.1.7 /opt/iobroker/node_modules/are-we-there-yet
                                npm ERR! extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                                npm ERR! extraneous: array-back@3.1.0 /opt/iobroker/node_modules/array-back
                                npm ERR! extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                                npm ERR! extraneous: array.prototype.findindex@2.2.0 /opt/iobroker/node_modules/array.prototype.findindex
                                npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
                                npm ERR! extraneous: asn1js@2.3.2 /opt/iobroker/node_modules/asn1js
                                npm ERR! extraneous: ast-types@0.13.4 /opt/iobroker/node_modules/ast-types
                                npm ERR! extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                                npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/available-typed-arrays
                                npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
                                npm ERR! extraneous: base64-arraybuffer@0.1.4 /opt/iobroker/node_modules/base64-arraybuffer
                                npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
                                npm ERR! extraneous: better-assert@1.0.2 /opt/iobroker/node_modules/better-assert
                                npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
                                npm ERR! extraneous: bmp-js@0.1.0 /opt/iobroker/node_modules/bmp-js
                                npm ERR! extraneous: bonjour-hap@3.6.3 /opt/iobroker/node_modules/bonjour-hap
                                npm ERR! extraneous: boolbase@1.0.0 /opt/iobroker/node_modules/boolbase
                                npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                                npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
                                npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/browser-process-hrtime
                                npm ERR! extraneous: buffer-equal@0.0.1 /opt/iobroker/node_modules/buffer-equal
                                npm ERR! extraneous: bufferhelper@0.2.1 /opt/iobroker/node_modules/bufferhelper
                                npm ERR! extraneous: buildcheck@0.0.3 /opt/iobroker/node_modules/buildcheck
                                npm ERR! extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                                npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                                npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheable-request
                                npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                                npm ERR! extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                                npm ERR! extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                                npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                                npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/chalk
                                npm ERR! extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                                npm ERR! extraneous: cheerio-select@1.5.0 /opt/iobroker/node_modules/cheerio-select
                                npm ERR! extraneous: cheerio@1.0.0-rc.10 /opt/iobroker/node_modules/cheerio
                                npm ERR! extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                                npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                                npm ERR! extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                                npm ERR! extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                                npm ERR! extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                                npm ERR! extraneous: clone-response@1.0.2 /opt/iobroker/node_modules/clone-response
                                npm ERR! extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                npm ERR! extraneous: coap-packet@0.1.14 /opt/iobroker/node_modules/coap-packet
                                npm ERR! extraneous: coap@0.24.0 /opt/iobroker/node_modules/coap
                                npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                                npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
                                npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
                                npm ERR! extraneous: coiot-coap@1.0.0 /opt/iobroker/node_modules/coiot-coap
                                npm ERR! extraneous: command-line-args@5.2.1 /opt/iobroker/node_modules/command-line-args
                                npm ERR! extraneous: command-line-usage@6.1.1 /opt/iobroker/node_modules/command-line-usage
                                npm ERR! extraneous: commander@6.2.1 /opt/iobroker/node_modules/commander
                                npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
                                npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
                                npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
                                npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
                                npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                                npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
                                npm ERR! extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                                npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                npm ERR! extraneous: copy-to@2.0.1 /opt/iobroker/node_modules/copy-to
                                npm ERR! extraneous: cosmiconfig@7.0.1 /opt/iobroker/node_modules/cosmiconfig
                                npm ERR! extraneous: cpu-features@0.0.4 /opt/iobroker/node_modules/cpu-features
                                npm ERR! extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                                npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
                                npm ERR! extraneous: css-select@4.2.1 /opt/iobroker/node_modules/css-select
                                npm ERR! extraneous: css-what@5.1.0 /opt/iobroker/node_modules/css-what
                                npm ERR! extraneous: cssom@0.5.0 /opt/iobroker/node_modules/cssom
                                npm ERR! extraneous: cssstyle@2.3.0 /opt/iobroker/node_modules/cssstyle
                                npm ERR! extraneous: data-uri-to-buffer@3.0.1 /opt/iobroker/node_modules/data-uri-to-buffer
                                npm ERR! extraneous: data-urls@3.0.1 /opt/iobroker/node_modules/data-urls
                                npm ERR! extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                                npm ERR! extraneous: decamelize-keys@1.1.0 /opt/iobroker/node_modules/decamelize-keys
                                npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
                                npm ERR! extraneous: decimal.js@10.3.1 /opt/iobroker/node_modules/decimal.js
                                npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                npm ERR! extraneous: deep-equal@2.0.5 /opt/iobroker/node_modules/deep-equal
                                npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                npm ERR! extraneous: default-user-agent@1.0.0 /opt/iobroker/node_modules/default-user-agent
                                npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                                npm ERR! extraneous: degenerator@3.0.2 /opt/iobroker/node_modules/degenerator
                                npm ERR! extraneous: del@6.0.0 /opt/iobroker/node_modules/del
                                npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                npm ERR! extraneous: depd@1.1.2 /opt/iobroker/node_modules/depd
                                npm ERR! extraneous: dev-null@0.1.1 /opt/iobroker/node_modules/dev-null
                                npm ERR! extraneous: dewpoint@1.0.0 /opt/iobroker/node_modules/dewpoint
                                npm ERR! extraneous: digest-header@0.0.1 /opt/iobroker/node_modules/digest-header
                                npm ERR! extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                                npm ERR! extraneous: dom-serializer@1.3.2 /opt/iobroker/node_modules/dom-serializer
                                npm ERR! extraneous: dom-walk@0.1.2 /opt/iobroker/node_modules/dom-walk
                                npm ERR! extraneous: domelementtype@2.2.0 /opt/iobroker/node_modules/domelementtype
                                npm ERR! extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                                npm ERR! extraneous: domhandler@4.3.0 /opt/iobroker/node_modules/domhandler
                                npm ERR! extraneous: domutils@2.8.0 /opt/iobroker/node_modules/domutils
                                npm ERR! extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                                npm ERR! extraneous: duplexer3@0.1.4 /opt/iobroker/node_modules/duplexer3
                                npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/duplexify
                                npm ERR! extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                                npm ERR! extraneous: engine.io-client@3.5.2 /opt/iobroker/node_modules/engine.io-client
                                npm ERR! extraneous: engine.io-parser@2.2.1 /opt/iobroker/node_modules/engine.io-parser
                                npm ERR! extraneous: engine.io@3.5.0 /opt/iobroker/node_modules/engine.io
                                npm ERR! extraneous: entities@2.2.0 /opt/iobroker/node_modules/entities
                                npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
                                npm ERR! extraneous: es-abstract@1.20.1 /opt/iobroker/node_modules/es-abstract
                                npm ERR! extraneous: es-get-iterator@1.1.2 /opt/iobroker/node_modules/es-get-iterator
                                npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
                                npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                npm ERR! extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                                npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/escape-string-regexp
                                npm ERR! extraneous: escodegen@2.0.0 /opt/iobroker/node_modules/escodegen
                                npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
                                npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse
                                npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/eventemitter3
                                npm ERR! extraneous: exif-parser@0.1.12 /opt/iobroker/node_modules/exif-parser
                                npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
                                npm ERR! extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                                npm ERR! extraneous: fast-glob@3.2.11 /opt/iobroker/node_modules/fast-glob
                                npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                npm ERR! extraneous: fast-srp-hap@2.0.4 /opt/iobroker/node_modules/fast-srp-hap
                                npm ERR! extraneous: fastq@1.13.0 /opt/iobroker/node_modules/fastq
                                npm ERR! extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                                npm ERR! extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                                npm ERR! extraneous: file-type@9.0.0 /opt/iobroker/node_modules/file-type
                                npm ERR! extraneous: find-replace@3.0.0 /opt/iobroker/node_modules/find-replace
                                npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                                npm ERR! extraneous: foreach@2.0.5 /opt/iobroker/node_modules/foreach
                                npm ERR! extraneous: formstream@1.1.1 /opt/iobroker/node_modules/formstream
                                npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                                npm ERR! extraneous: function.prototype.name@1.1.5 /opt/iobroker/node_modules/function.prototype.name
                                npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                npm ERR! extraneous: gauge@2.7.4 /opt/iobroker/node_modules/gauge
                                npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                                npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
                                npm ERR! extraneous: get-uri@3.0.2 /opt/iobroker/node_modules/get-uri
                                npm ERR! extraneous: gifwrap@0.9.2 /opt/iobroker/node_modules/gifwrap
                                npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                npm ERR! extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                                npm ERR! extraneous: glob@7.2.0 /opt/iobroker/node_modules/glob
                                npm ERR! extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                                npm ERR! extraneous: global@4.4.0 /opt/iobroker/node_modules/global
                                npm ERR! extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                                npm ERR! extraneous: got@11.8.5 /opt/iobroker/node_modules/got
                                npm ERR! extraneous: hap-nodejs@0.9.8 /opt/iobroker/node_modules/hap-nodejs
                                npm ERR! extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                                npm ERR! extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                                npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                npm ERR! extraneous: has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
                                npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
                                npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
                                npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/has-flag
                                npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/has-tostringtag
                                npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                npm ERR! extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                                npm ERR! extraneous: help-me@3.0.0 /opt/iobroker/node_modules/help-me
                                npm ERR! extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                                npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                npm ERR! extraneous: html-entities@1.0.10 /opt/iobroker/node_modules/html-entities
                                npm ERR! extraneous: htmlparser2@6.1.0 /opt/iobroker/node_modules/htmlparser2
                                npm ERR! extraneous: http-cache-semantics@4.1.0 /opt/iobroker/node_modules/http-cache-semantics
                                npm ERR! extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                npm ERR! extraneous: http-proxy-middleware@2.0.4 /opt/iobroker/node_modules/http-proxy-middleware
                                npm ERR! extraneous: http-proxy-response-rewrite@0.0.1 /opt/iobroker/node_modules/http-proxy-response-rewrite
                                npm ERR! extraneous: http-proxy@1.18.1 /opt/iobroker/node_modules/http-proxy
                                npm ERR! extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                                npm ERR! extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                npm ERR! extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                                npm ERR! extraneous: ignore@5.2.0 /opt/iobroker/node_modules/ignore
                                npm ERR! extraneous: image-q@1.1.1 /opt/iobroker/node_modules/image-q
                                npm ERR! extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                                npm ERR! extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                                npm ERR! extraneous: import-local@3.1.0 /opt/iobroker/node_modules/import-local
                                npm ERR! extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                                npm ERR! extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                                npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
                                npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                                npm ERR! extraneous: influx@4.2.3 /opt/iobroker/node_modules/influx
                                npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
                                npm ERR! extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                                npm ERR! extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                                npm ERR! extraneous: internal-slot@1.0.3 /opt/iobroker/node_modules/internal-slot
                                npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
                                npm ERR! invalid: iobroker.admin@5.3.8 /opt/iobroker/node_modules/iobroker.admin
                                npm ERR! extraneous: iobroker.alexa2@3.11.2 /opt/iobroker/node_modules/iobroker.alexa2
                                npm ERR! extraneous: iobroker.alias-manager@1.2.4 /opt/iobroker/node_modules/iobroker.alias-manager
                                npm ERR! invalid: iobroker.backitup@2.4.9 /opt/iobroker/node_modules/iobroker.backitup
                                npm ERR! extraneous: iobroker.daswetter@3.1.2 /opt/iobroker/node_modules/iobroker.daswetter
                                npm ERR! extraneous: iobroker.deconz@1.3.21 /opt/iobroker/node_modules/iobroker.deconz
                                npm ERR! extraneous: iobroker.device-reminder@1.2.9 /opt/iobroker/node_modules/iobroker.device-reminder
                                npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
                                npm ERR! extraneous: iobroker.fritzdect@2.2.3 /opt/iobroker/node_modules/iobroker.fritzdect
                                npm ERR! extraneous: iobroker.heos@1.10.0 /opt/iobroker/node_modules/iobroker.heos
                                npm ERR! extraneous: iobroker.history@1.11.1 /opt/iobroker/node_modules/iobroker.history
                                npm ERR! extraneous: iobroker.ical@1.12.1 /opt/iobroker/node_modules/iobroker.ical
                                npm ERR! extraneous: iobroker.icons-material-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-png
                                npm ERR! extraneous: iobroker.icons-material-svg@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-svg
                                npm ERR! extraneous: iobroker.icons-mfd-svg@1.1.0 /opt/iobroker/node_modules/iobroker.icons-mfd-svg
                                npm ERR! extraneous: iobroker.icons-open-icon-library-png@0.1.2 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
                                npm ERR! extraneous: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
                                npm ERR! extraneous: iobroker.influxdb@2.6.3 /opt/iobroker/node_modules/iobroker.influxdb
                                npm ERR! extraneous: iobroker.javascript@5.7.0 /opt/iobroker/node_modules/iobroker.javascript
                                npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
                                npm ERR! extraneous: iobroker.km200@2.0.3 /opt/iobroker/node_modules/iobroker.km200
                                npm ERR! extraneous: iobroker.lupusec@1.3.6 /opt/iobroker/node_modules/iobroker.lupusec
                                npm ERR! extraneous: iobroker.netatmo@1.7.1 /opt/iobroker/node_modules/iobroker.netatmo
                                npm ERR! extraneous: iobroker.nuki-extended@2.4.0 /opt/iobroker/node_modules/iobroker.nuki-extended
                                npm ERR! extraneous: iobroker.onvif@0.4.4 /opt/iobroker/node_modules/iobroker.onvif
                                npm ERR! extraneous: iobroker.parcel@0.0.15 /opt/iobroker/node_modules/iobroker.parcel
                                npm ERR! extraneous: iobroker.pushover@2.1.0 /opt/iobroker/node_modules/iobroker.pushover
                                npm ERR! extraneous: iobroker.shelly@5.3.2 /opt/iobroker/node_modules/iobroker.shelly
                                npm ERR! extraneous: iobroker.simple-api@2.7.0 /opt/iobroker/node_modules/iobroker.simple-api
                                npm ERR! extraneous: iobroker.smartcontrol@1.2.1 /opt/iobroker/node_modules/iobroker.smartcontrol
                                npm ERR! extraneous: iobroker.smartgarden@2.0.0 /opt/iobroker/node_modules/iobroker.smartgarden
                                npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
                                npm ERR! extraneous: iobroker.sonos@2.1.7 /opt/iobroker/node_modules/iobroker.sonos
                                npm ERR! extraneous: iobroker.sony-bravia@1.0.3 /opt/iobroker/node_modules/iobroker.sony-bravia
                                npm ERR! extraneous: iobroker.synology@2.1.7 /opt/iobroker/node_modules/iobroker.synology
                                npm ERR! extraneous: iobroker.telegram@1.13.0 /opt/iobroker/node_modules/iobroker.telegram
                                npm ERR! extraneous: iobroker.text2command@2.2.1 /opt/iobroker/node_modules/iobroker.text2command
                                npm ERR! extraneous: iobroker.tr-064@4.2.16 /opt/iobroker/node_modules/iobroker.tr-064
                                npm ERR! extraneous: iobroker.trashschedule@2.0.2 /opt/iobroker/node_modules/iobroker.trashschedule
                                npm ERR! extraneous: iobroker.uv-protect@0.3.5 /opt/iobroker/node_modules/iobroker.uv-protect
                                npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
                                npm ERR! extraneous: iobroker.vis-hqwidgets@1.2.0 /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                                npm ERR! extraneous: iobroker.vis-icontwo@0.87.0 /opt/iobroker/node_modules/iobroker.vis-icontwo
                                npm ERR! extraneous: iobroker.vis-inventwo@3.3.1 /opt/iobroker/node_modules/iobroker.vis-inventwo
                                npm ERR! extraneous: iobroker.vis-material-advanced@1.7.2 /opt/iobroker/node_modules/iobroker.vis-material-advanced
                                npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                npm ERR! extraneous: iobroker.vis-weather@2.5.5 /opt/iobroker/node_modules/iobroker.vis-weather
                                npm ERR! extraneous: iobroker.vis@1.4.15 /opt/iobroker/node_modules/iobroker.vis
                                npm ERR! extraneous: iobroker.vw-connect@0.0.50 /opt/iobroker/node_modules/iobroker.vw-connect
                                npm ERR! extraneous: iobroker.web@4.3.0 /opt/iobroker/node_modules/iobroker.web
                                npm ERR! extraneous: iobroker.whatsapp-cmb@0.2.2 /opt/iobroker/node_modules/iobroker.whatsapp-cmb
                                npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
                                npm ERR! extraneous: iobroker.ws@1.3.0 /opt/iobroker/node_modules/iobroker.ws
                                npm ERR! extraneous: iobroker.yahka@0.13.1 /opt/iobroker/node_modules/iobroker.yahka
                                npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
                                npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                npm ERR! extraneous: is-callable@1.2.4 /opt/iobroker/node_modules/is-callable
                                npm ERR! extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                                npm ERR! extraneous: is-core-module@2.8.1 /opt/iobroker/node_modules/is-core-module
                                npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                npm ERR! extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                                npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
                                npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                npm ERR! extraneous: is-function@1.0.2 /opt/iobroker/node_modules/is-function
                                npm ERR! extraneous: is-generator-function@1.0.10 /opt/iobroker/node_modules/is-generator-function
                                npm ERR! extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                                npm ERR! extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                                npm ERR! extraneous: is-map@2.0.2 /opt/iobroker/node_modules/is-map
                                npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
                                npm ERR! extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                                npm ERR! extraneous: is-number-object@1.0.6 /opt/iobroker/node_modules/is-number-object
                                npm ERR! extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                                npm ERR! extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                                npm ERR! extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                                npm ERR! extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                                npm ERR! extraneous: is-plain-obj@3.0.0 /opt/iobroker/node_modules/is-plain-obj
                                npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                npm ERR! extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                                npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                npm ERR! extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                                npm ERR! extraneous: is-set@2.0.2 /opt/iobroker/node_modules/is-set
                                npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
                                npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                npm ERR! extraneous: is-typed-array@1.1.8 /opt/iobroker/node_modules/is-typed-array
                                npm ERR! extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                                npm ERR! extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                                npm ERR! extraneous: is-weakmap@2.0.1 /opt/iobroker/node_modules/is-weakmap
                                npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                npm ERR! extraneous: is-weakset@2.0.2 /opt/iobroker/node_modules/is-weakset
                                npm ERR! extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                                npm ERR! extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                                npm ERR! extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                                npm ERR! extraneous: jpeg-js@0.4.2 /opt/iobroker/node_modules/jpeg-js
                                npm ERR! extraneous: js-rijndael@1.0.0 /opt/iobroker/node_modules/js-rijndael
                                npm ERR! extraneous: js-sdsl@2.1.4 /opt/iobroker/node_modules/js-sdsl
                                npm ERR! extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                                npm ERR! extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/js-yaml
                                npm ERR! extraneous: jsdom@19.0.0 /opt/iobroker/node_modules/jsdom
                                npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                                npm ERR! extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                                npm ERR! extraneous: json3@3.3.2 /opt/iobroker/node_modules/json3
                                npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
                                npm ERR! extraneous: keyv@4.1.1 /opt/iobroker/node_modules/keyv
                                npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                                npm ERR! extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                                npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
                                npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                                npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                npm ERR! extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                                npm ERR! extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                                npm ERR! extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                                npm ERR! extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                                npm ERR! extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                                npm ERR! extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                                npm ERR! extraneous: load-bmfont@1.4.1 /opt/iobroker/node_modules/load-bmfont
                                npm ERR! extraneous: loadsh@0.0.4 /opt/iobroker/node_modules/loadsh
                                npm ERR! extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                                npm ERR! extraneous: lodash.camelcase@4.3.0 /opt/iobroker/node_modules/lodash.camelcase
                                npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
                                npm ERR! extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                                npm ERR! extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                                npm ERR! extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                                npm ERR! extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                                npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                                npm ERR! extraneous: macaddress@0.5.1 /opt/iobroker/node_modules/macaddress
                                npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                                npm ERR! extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                                npm ERR! extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                                npm ERR! extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                                npm ERR! extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                                npm ERR! extraneous: micromatch@4.0.4 /opt/iobroker/node_modules/micromatch
                                npm ERR! extraneous: mime@2.6.0 /opt/iobroker/node_modules/mime
                                npm ERR! extraneous: mimic-response@3.1.0 /opt/iobroker/node_modules/mimic-response
                                npm ERR! extraneous: min-document@2.19.0 /opt/iobroker/node_modules/min-document
                                npm ERR! extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                                npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/minimatch
                                npm ERR! extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                                npm ERR! extraneous: minimist@1.2.6 /opt/iobroker/node_modules/minimist
                                npm ERR! extraneous: moment-timezone@0.5.34 /opt/iobroker/node_modules/moment-timezone
                                npm ERR! extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                                npm ERR! extraneous: mqtt-packet@6.10.0 /opt/iobroker/node_modules/mqtt-packet
                                npm ERR! extraneous: mqtt@4.3.7 /opt/iobroker/node_modules/mqtt
                                npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types
                                npm ERR! extraneous: multicast-dns@7.2.4 /opt/iobroker/node_modules/multicast-dns
                                npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
                                npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                npm ERR! extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                                npm ERR! extraneous: nearest-color@0.4.4 /opt/iobroker/node_modules/nearest-color
                                npm ERR! extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                                npm ERR! extraneous: ngeohash@0.6.3 /opt/iobroker/node_modules/ngeohash
                                npm ERR! extraneous: nimble@0.0.2 /opt/iobroker/node_modules/nimble
                                npm ERR! extraneous: node-addon-api@3.2.1 /opt/iobroker/node_modules/node-addon-api
                                npm ERR! extraneous: node-ical@0.15.1 /opt/iobroker/node_modules/node-ical
                                npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                npm ERR! extraneous: node-rest-client@3.1.1 /opt/iobroker/node_modules/node-rest-client
                                npm ERR! extraneous: node-telegram-bot-api@0.57.0 /opt/iobroker/node_modules/node-telegram-bot-api
                                npm ERR! extraneous: node-vibrant@3.1.6 /opt/iobroker/node_modules/node-vibrant
                                npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
                                npm ERR! extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                                npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                                npm ERR! extraneous: np@7.6.1 /opt/iobroker/node_modules/np
                                npm ERR! extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                                npm ERR! extraneous: npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
                                npm ERR! extraneous: nth-check@2.0.1 /opt/iobroker/node_modules/nth-check
                                npm ERR! extraneous: nuki-bridge-api@1.8.0 /opt/iobroker/node_modules/nuki-bridge-api
                                npm ERR! extraneous: nuki-web-api@2.2.1 /opt/iobroker/node_modules/nuki-web-api
                                npm ERR! extraneous: number-allocator@1.0.10 /opt/iobroker/node_modules/number-allocator
                                npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                                npm ERR! extraneous: nwsapi@2.2.0 /opt/iobroker/node_modules/nwsapi
                                npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                                npm ERR! extraneous: object-component@0.0.3 /opt/iobroker/node_modules/object-component
                                npm ERR! extraneous: object-is@1.1.5 /opt/iobroker/node_modules/object-is
                                npm ERR! extraneous: object.assign@4.1.2 /opt/iobroker/node_modules/object.assign
                                npm ERR! extraneous: omggif@1.0.10 /opt/iobroker/node_modules/omggif
                                npm ERR! extraneous: onvif@0.6.5 /opt/iobroker/node_modules/onvif
                                npm ERR! extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                                npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                npm ERR! extraneous: options@0.0.6 /opt/iobroker/node_modules/options
                                npm ERR! extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                                npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
                                npm ERR! extraneous: os-name@1.0.3 /opt/iobroker/node_modules/os-name
                                npm ERR! extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                                npm ERR! extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                                npm ERR! extraneous: osx-release@1.1.0 /opt/iobroker/node_modules/osx-release
                                npm ERR! extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                                npm ERR! extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                                npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                                npm ERR! extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                                npm ERR! extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                                npm ERR! extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                                npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                                npm ERR! extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                                npm ERR! extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                                npm ERR! extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                                npm ERR! extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                                npm ERR! extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                                npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                                npm ERR! extraneous: pac-proxy-agent@5.0.0 /opt/iobroker/node_modules/pac-proxy-agent
                                npm ERR! extraneous: pac-resolver@5.0.0 /opt/iobroker/node_modules/pac-resolver
                                npm ERR! extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                                npm ERR! extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                                npm ERR! extraneous: parse-bmfont-ascii@1.0.6 /opt/iobroker/node_modules/parse-bmfont-ascii
                                npm ERR! extraneous: parse-bmfont-binary@1.0.6 /opt/iobroker/node_modules/parse-bmfont-binary
                                npm ERR! extraneous: parse-bmfont-xml@1.1.4 /opt/iobroker/node_modules/parse-bmfont-xml
                                npm ERR! extraneous: parse-headers@2.0.4 /opt/iobroker/node_modules/parse-headers
                                npm ERR! extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                                npm ERR! extraneous: parse5-htmlparser2-tree-adapter@6.0.1 /opt/iobroker/node_modules/parse5-htmlparser2-tree-adapter
                                npm ERR! extraneous: parse5@6.0.1 /opt/iobroker/node_modules/parse5
                                npm ERR! extraneous: parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
                                npm ERR! extraneous: parseqs@0.0.6 /opt/iobroker/node_modules/parseqs
                                npm ERR! extraneous: parseuri@0.0.6 /opt/iobroker/node_modules/parseuri
                                npm ERR! extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                                npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                                npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                npm ERR! extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                                npm ERR! extraneous: phin@2.9.3 /opt/iobroker/node_modules/phin
                                npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                npm ERR! extraneous: ping@0.4.1 /opt/iobroker/node_modules/ping
                                npm ERR! extraneous: pixelmatch@4.0.2 /opt/iobroker/node_modules/pixelmatch
                                npm ERR! extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                                npm ERR! extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                                npm ERR! extraneous: pngjs@3.4.0 /opt/iobroker/node_modules/pngjs
                                npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                npm ERR! extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                                npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                                npm ERR! extraneous: proxy-agent@5.0.0 /opt/iobroker/node_modules/proxy-agent
                                npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                npm ERR! extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                                npm ERR! extraneous: pushover-notifications@1.2.2 /opt/iobroker/node_modules/pushover-notifications
                                npm ERR! extraneous: pvtsutils@1.2.2 /opt/iobroker/node_modules/pvtsutils
                                npm ERR! extraneous: pvutils@1.1.3 /opt/iobroker/node_modules/pvutils
                                npm ERR! extraneous: q@1.5.1 /opt/iobroker/node_modules/q
                                npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/querystring
                                npm ERR! extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                                npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                                npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                npm ERR! extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                                npm ERR! extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                                npm ERR! extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                                npm ERR! extraneous: reduce-flatten@2.0.0 /opt/iobroker/node_modules/reduce-flatten
                                npm ERR! extraneous: regenerator-runtime@0.13.9 /opt/iobroker/node_modules/regenerator-runtime
                                npm ERR! extraneous: regexp.prototype.flags@1.4.3 /opt/iobroker/node_modules/regexp.prototype.flags
                                npm ERR! extraneous: registry-auth-token@4.2.1 /opt/iobroker/node_modules/registry-auth-token
                                npm ERR! extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                                npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                                npm ERR! extraneous: request-promise-core@1.1.4 /opt/iobroker/node_modules/request-promise-core
                                npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
                                npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                                npm ERR! extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                                npm ERR! extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                                npm ERR! extraneous: resolve@1.22.0 /opt/iobroker/node_modules/resolve
                                npm ERR! extraneous: responselike@2.0.0 /opt/iobroker/node_modules/responselike
                                npm ERR! extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                                npm ERR! extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                                npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/rfdc
                                npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                                npm ERR! extraneous: rrule@2.6.4 /opt/iobroker/node_modules/rrule
                                npm ERR! extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                                npm ERR! extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                                npm ERR! extraneous: rxjs@6.6.7 /opt/iobroker/node_modules/rxjs
                                npm ERR! extraneous: sax@1.2.4 /opt/iobroker/node_modules/sax
                                npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/saxes
                                npm ERR! extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                                npm ERR! extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                                npm ERR! extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                                npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                                npm ERR! extraneous: sharp@0.25.4 /opt/iobroker/node_modules/sharp
                                npm ERR! extraneous: shelly-iot@1.1.2 /opt/iobroker/node_modules/shelly-iot
                                npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                npm ERR! extraneous: simple-get@4.0.1 /opt/iobroker/node_modules/simple-get
                                npm ERR! extraneous: simple-ssh@1.1.0 /opt/iobroker/node_modules/simple-ssh
                                npm ERR! extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                                npm ERR! extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                                npm ERR! extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                                npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
                                npm ERR! extraneous: socket.io-client@2.4.0 /opt/iobroker/node_modules/socket.io-client
                                npm ERR! extraneous: socket.io-parser@3.4.1 /opt/iobroker/node_modules/socket.io-parser
                                npm ERR! extraneous: socket.io@2.4.1 /opt/iobroker/node_modules/socket.io
                                npm ERR! extraneous: socks-proxy-agent@5.0.1 /opt/iobroker/node_modules/socks-proxy-agent
                                npm ERR! extraneous: socks@2.6.2 /opt/iobroker/node_modules/socks
                                npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                npm ERR! extraneous: sonos-discovery@1.7.3 /opt/iobroker/node_modules/sonos-discovery
                                npm ERR! extraneous: spdx-correct@3.1.1 /opt/iobroker/node_modules/spdx-correct
                                npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
                                npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/spdx-expression-parse
                                npm ERR! extraneous: spdx-license-ids@3.0.11 /opt/iobroker/node_modules/spdx-license-ids
                                npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/split2
                                npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/sprintf-js
                                npm ERR! extraneous: ssh2@1.11.0 /opt/iobroker/node_modules/ssh2
                                npm ERR! extraneous: statuses@1.5.0 /opt/iobroker/node_modules/statuses
                                npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
                                npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/stream-shift
                                npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/string-width
                                npm ERR! extraneous: string.prototype.trimend@1.0.5 /opt/iobroker/node_modules/string.prototype.trimend
                                npm ERR! extraneous: string.prototype.trimstart@1.0.5 /opt/iobroker/node_modules/string.prototype.trimstart
                                npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/strip-ansi
                                npm ERR! extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                                npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/supports-color
                                npm ERR! extraneous: supports-hyperlinks@2.2.0 /opt/iobroker/node_modules/supports-hyperlinks
                                npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                npm ERR! extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                                npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                npm ERR! extraneous: syno@3.0.0 /opt/iobroker/node_modules/syno
                                npm ERR! extraneous: table-layout@1.0.2 /opt/iobroker/node_modules/table-layout
                                npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
                                npm ERR! extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                                npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
                                npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
                                npm ERR! extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                                npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                npm ERR! extraneous: thunky@1.1.0 /opt/iobroker/node_modules/thunky
                                npm ERR! extraneous: timm@1.7.1 /opt/iobroker/node_modules/timm
                                npm ERR! extraneous: tinycolor2@1.4.2 /opt/iobroker/node_modules/tinycolor2
                                npm ERR! extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                                npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
                                npm ERR! extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                                npm ERR! extraneous: tr-O64@0.2.4 /opt/iobroker/node_modules/tr-O64
                                npm ERR! extraneous: traverse@0.6.6 /opt/iobroker/node_modules/traverse
                                npm ERR! extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                                npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                npm ERR! extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                                npm ERR! extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                                npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
                                npm ERR! extraneous: typescript@4.7.2 /opt/iobroker/node_modules/typescript
                                npm ERR! extraneous: typical@4.0.0 /opt/iobroker/node_modules/typical
                                npm ERR! extraneous: ultron@1.0.2 /opt/iobroker/node_modules/ultron
                                npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                npm ERR! extraneous: underscore@1.13.2 /opt/iobroker/node_modules/underscore
                                npm ERR! extraneous: unescape@1.0.1 /opt/iobroker/node_modules/unescape
                                npm ERR! extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                                npm ERR! extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                                npm ERR! extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                                npm ERR! extraneous: url@0.11.0 /opt/iobroker/node_modules/url
                                npm ERR! extraneous: urllib@2.38.0 /opt/iobroker/node_modules/urllib
                                npm ERR! extraneous: utif@2.0.1 /opt/iobroker/node_modules/utif
                                npm ERR! extraneous: util@0.12.4 /opt/iobroker/node_modules/util
                                npm ERR! extraneous: utility@1.17.0 /opt/iobroker/node_modules/utility
                                npm ERR! extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                                npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                                npm ERR! extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                                npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                npm ERR! extraneous: vm2@3.9.9 /opt/iobroker/node_modules/vm2
                                npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/w3c-hr-time
                                npm ERR! extraneous: w3c-xmlserializer@3.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                npm ERR! extraneous: webcrypto-core@1.7.1 /opt/iobroker/node_modules/webcrypto-core
                                npm ERR! extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                npm ERR! extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                npm ERR! extraneous: which-collection@1.0.1 /opt/iobroker/node_modules/which-collection
                                npm ERR! extraneous: which-pm-runs@1.1.0 /opt/iobroker/node_modules/which-pm-runs
                                npm ERR! extraneous: which-typed-array@1.1.7 /opt/iobroker/node_modules/which-typed-array
                                npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                npm ERR! extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                                npm ERR! extraneous: win-release@1.1.1 /opt/iobroker/node_modules/win-release
                                npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                                npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
                                npm ERR! extraneous: wordwrapjs@4.0.1 /opt/iobroker/node_modules/wordwrapjs
                                npm ERR! extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                                npm ERR! extraneous: wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
                                npm ERR! extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                                npm ERR! extraneous: xhr@2.6.0 /opt/iobroker/node_modules/xhr
                                npm ERR! extraneous: xml-flow@1.0.2 /opt/iobroker/node_modules/xml-flow
                                npm ERR! extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                npm ERR! extraneous: xml-parse-from-string@1.0.1 /opt/iobroker/node_modules/xml-parse-from-string
                                npm ERR! extraneous: xml2js@0.4.23 /opt/iobroker/node_modules/xml2js
                                npm ERR! extraneous: xml2json-light@1.0.6 /opt/iobroker/node_modules/xml2json-light
                                npm ERR! extraneous: xmlbuilder@11.0.1 /opt/iobroker/node_modules/xmlbuilder
                                npm ERR! extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                npm ERR! extraneous: xmlhttprequest-ssl@1.6.3 /opt/iobroker/node_modules/xmlhttprequest-ssl
                                npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
                                npm ERR! extraneous: yaml@1.10.2 /opt/iobroker/node_modules/yaml
                                npm ERR! extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                                npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
                                npm ERR! extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                                npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T13_33_59_784Z-debug-0.log
                                • mickym
                                  mickym Most Active @kimukao last edited by
                                  @kimukao Und nochmal in dem Verzeichnis Dein package.json - ich kanns nicht glauben.
                                  K Thomas Braun 2 Replies Last reply Reply Quote 0
                                    kimukao @mickym last edited by
                                    @mickym So sah die package.json übrigens vor der Neuinstallation aus:
                                    cd /opt/iobroker
                                    cat package.json
                                    {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=10.0.0"},"dependencies":{"iobroker.admin":"5.3.8","iobroker.alexa2":"^3.11.2","iobroker.alias-manager":"1.2.4","iobroker.backitup":"2.4.9","iobroker.daswetter":"3.1.2","iobroker.deconz":"1.3.21","iobroker.device-reminder":"1.2.9","iobroker.discovery":"3.0.3","iobroker.fritzdect":"^2.2.3","iobroker.heos":"1.10.0","iobroker.history":"1.11.1","iobroker.ical":"1.12.1","iobroker.icons-material-png":"^0.1.0","iobroker.icons-material-svg":"^0.1.0","iobroker.icons-mfd-svg":"1.1.0","iobroker.icons-open-icon-library-png":"^0.1.2","iobroker.icons-ultimate-png":"^1.0.1","iobroker.influxdb":"2.6.3","iobroker.javascript":"5.7.0","iobroker.js-controller":"4.0.23","iobroker.km200":"^2.0.3","iobroker.lupusec":"^1.3.6","iobroker.netatmo":"1.7.1","iobroker.nuki-extended":"github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4","iobroker.onvif":"^0.4.4","iobroker.parcel":"github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd","iobroker.pushover":"2.1.0","iobroker.shelly":"5.3.2","iobroker.simple-api":"2.7.0","iobroker.smartcontrol":"^1.2.1","iobroker.smartgarden":"2.0.0","iobroker.socketio":"4.2.0","iobroker.sonos":"2.1.7","iobroker.sony-bravia":"1.0.3","iobroker.synology":"2.1.7","iobroker.telegram":"1.13.0","iobroker.text2command":"2.2.1","iobroker.tr-064":"4.2.16","iobroker.trashschedule":"2.0.2","iobroker.uv-protect":"0.3.5","iobroker.vis":"1.4.15","iobroker.vis-fancyswitch":"^1.1.0","iobroker.vis-hqwidgets":"1.2.0","iobroker.vis-icontwo":"^0.87.0","iobroker.vis-inventwo":"^3.3.1","iobroker.vis-material-advanced":"^1.7.2","iobroker.vis-timeandweather":"^1.1.7","iobroker.vis-weather":"^2.5.5","iobroker.vw-connect":"0.0.50","iobroker.web":"4.3.0","iobroker.whatsapp-cmb":"0.2.2","iobroker.yahka":"^0.13.1"}}
                                      Thomas Braun Most Active @mickym last edited by
                                      Da liegt auch viel zu viel Zeug auf der ersten Ebene im Baum. Wie auch immer das in der Anzahl dort hingekommen ist.
                                      • mickym
                                        @kimukao Sehr gut 🙂 - dann sichere Dir mal die jetzige weg und sichere diese Datei wieder zurück.
                                          @mickym wie mache ich das? Sorry für die blöde Frage, bin Anfänger...
                                          • mickym
                                            @kimukao Na Du hast mir die doch gerade gepostet - die kannst doch nehmen:
                                            Ich hab die mal in den Formatter eingegeben und die schaut relativ gut aus:
                                              "name": "iobroker.inst",
                                              "version": "3.0.0",
                                              "private": true,
                                              "description": "Automate your Life",
                                              "engines": {
                                                "node": ">=10.0.0"
                                              "dependencies": {
                                                "iobroker.admin": "5.3.8",
                                                "iobroker.alexa2": "^3.11.2",
                                                "iobroker.alias-manager": "1.2.4",
                                                "iobroker.backitup": "2.4.9",
                                                "iobroker.daswetter": "3.1.2",
                                                "iobroker.deconz": "1.3.21",
                                                "iobroker.device-reminder": "1.2.9",
                                                "iobroker.discovery": "3.0.3",
                                                "iobroker.fritzdect": "^2.2.3",
                                                "iobroker.heos": "1.10.0",
                                                "iobroker.history": "1.11.1",
                                                "iobroker.ical": "1.12.1",
                                                "iobroker.icons-material-png": "^0.1.0",
                                                "iobroker.icons-material-svg": "^0.1.0",
                                                "iobroker.icons-mfd-svg": "1.1.0",
                                                "iobroker.icons-open-icon-library-png": "^0.1.2",
                                                "iobroker.icons-ultimate-png": "^1.0.1",
                                                "iobroker.influxdb": "2.6.3",
                                                "iobroker.javascript": "5.7.0",
                                                "iobroker.js-controller": "4.0.23",
                                                "iobroker.km200": "^2.0.3",
                                                "iobroker.lupusec": "^1.3.6",
                                                "iobroker.netatmo": "1.7.1",
                                                "iobroker.nuki-extended": "github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4",
                                                "iobroker.onvif": "^0.4.4",
                                                "iobroker.parcel": "github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd",
                                                "iobroker.pushover": "2.1.0",
                                                "iobroker.shelly": "5.3.2",
                                                "iobroker.simple-api": "2.7.0",
                                                "iobroker.smartcontrol": "^1.2.1",
                                                "iobroker.smartgarden": "2.0.0",
                                                "iobroker.socketio": "4.2.0",
                                                "iobroker.sonos": "2.1.7",
                                                "iobroker.sony-bravia": "1.0.3",
                                                "iobroker.synology": "2.1.7",
                                                "iobroker.telegram": "1.13.0",
                                                "iobroker.text2command": "2.2.1",
                                                "iobroker.tr-064": "4.2.16",
                                                "iobroker.trashschedule": "2.0.2",
                                                "iobroker.uv-protect": "0.3.5",
                                                "iobroker.vis": "1.4.15",
                                                "iobroker.vis-fancyswitch": "^1.1.0",
                                                "iobroker.vis-hqwidgets": "1.2.0",
                                                "iobroker.vis-icontwo": "^0.87.0",
                                                "iobroker.vis-inventwo": "^3.3.1",
                                                "iobroker.vis-material-advanced": "^1.7.2",
                                                "iobroker.vis-timeandweather": "^1.1.7",
                                                "iobroker.vis-weather": "^2.5.5",
                                                "iobroker.vw-connect": "0.0.50",
                                                "iobroker.web": "4.3.0",
                                                "iobroker.whatsapp-cmb": "0.2.2",
                                                "iobroker.yahka": "^0.13.1"
                                            node js
                                            16
                                            335
                                            39093
