    4. Kein Update mehr möglich mit Node.js 16
      kimukao @mickym last edited by
      @mickym wie mache ich das? Sorry für die blöde Frage, bin Anfänger...
      • mickym
        mickym Most Active @kimukao last edited by
        @kimukao Na Du hast mir die doch gerade gepostet - die kannst doch nehmen:
        Ich hab die mal in den Formatter eingegeben und die schaut relativ gut aus:
          "name": "iobroker.inst",
          "version": "3.0.0",
          "private": true,
          "description": "Automate your Life",
          "engines": {
            "node": ">=10.0.0"
          "dependencies": {
            "iobroker.admin": "5.3.8",
            "iobroker.alexa2": "^3.11.2",
            "iobroker.alias-manager": "1.2.4",
            "iobroker.backitup": "2.4.9",
            "iobroker.daswetter": "3.1.2",
            "iobroker.deconz": "1.3.21",
            "iobroker.device-reminder": "1.2.9",
            "iobroker.discovery": "3.0.3",
            "iobroker.fritzdect": "^2.2.3",
            "iobroker.heos": "1.10.0",
            "iobroker.history": "1.11.1",
            "iobroker.ical": "1.12.1",
            "iobroker.icons-material-png": "^0.1.0",
            "iobroker.icons-material-svg": "^0.1.0",
            "iobroker.icons-mfd-svg": "1.1.0",
            "iobroker.icons-open-icon-library-png": "^0.1.2",
            "iobroker.icons-ultimate-png": "^1.0.1",
            "iobroker.influxdb": "2.6.3",
            "iobroker.javascript": "5.7.0",
            "iobroker.js-controller": "4.0.23",
            "iobroker.km200": "^2.0.3",
            "iobroker.lupusec": "^1.3.6",
            "iobroker.netatmo": "1.7.1",
            "iobroker.nuki-extended": "github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4",
            "iobroker.onvif": "^0.4.4",
            "iobroker.parcel": "github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd",
            "iobroker.pushover": "2.1.0",
            "iobroker.shelly": "5.3.2",
            "iobroker.simple-api": "2.7.0",
            "iobroker.smartcontrol": "^1.2.1",
            "iobroker.smartgarden": "2.0.0",
            "iobroker.socketio": "4.2.0",
            "iobroker.sonos": "2.1.7",
            "iobroker.sony-bravia": "1.0.3",
            "iobroker.synology": "2.1.7",
            "iobroker.telegram": "1.13.0",
            "iobroker.text2command": "2.2.1",
            "iobroker.tr-064": "4.2.16",
            "iobroker.trashschedule": "2.0.2",
            "iobroker.uv-protect": "0.3.5",
            "iobroker.vis": "1.4.15",
            "iobroker.vis-fancyswitch": "^1.1.0",
            "iobroker.vis-hqwidgets": "1.2.0",
            "iobroker.vis-icontwo": "^0.87.0",
            "iobroker.vis-inventwo": "^3.3.1",
            "iobroker.vis-material-advanced": "^1.7.2",
            "iobroker.vis-timeandweather": "^1.1.7",
            "iobroker.vis-weather": "^2.5.5",
            "iobroker.vw-connect": "0.0.50",
            "iobroker.web": "4.3.0",
            "iobroker.whatsapp-cmb": "0.2.2",
            "iobroker.yahka": "^0.13.1"
        • mickym
          mickym Most Active @mickym last edited by mickym
          @mickym
          Ansonsten machst einfach ne Kopie - nimmst das was ich gerade gepostet habe und speicherst das als neue package.json.
          iob stop
          cd /opt/iobroker
          mv package.json package.json.bak
          Dann
          nano package.json
          und den Inhalt aus meinem Posting einfügen und abspeichern.
            @mickym Danke - erledigt. Jetzt sieht's so aus:
            cd /opt/iobroker
            cat package.json
              "version": "3.0.0",
              "private": true,
              "engines": {
                "node": ">=10.0.0"
              "dependencies": {
            • mickym
              @kimukao Gut - dann also auf ins kalte Wasser.
              Wie gesagt zur Not - musst eh neu installieren.
              iob stop
              cd /opt/iobroker
              npm cache clean --force
              rm package-lock.json
              rm -rf node_modules
              dann mit ls -la Dein Verzeichnis zeigen.
                kimukao @mickym last edited by kimukao
                @mickym said in Kein Update mehr möglich mit Node.js 16:
                pi@raspberrypi:/opt/iobroker $ ls -la
                insgesamt 76
                drwxrwxrwx+  5 iobroker iobroker  4096  6. Sep 15:55 .
                drwxr-xr-x   3 root     root      4096  7. Feb 2022  ..
                drwxrwxr-x+  2 iobroker iobroker 28672  6. Sep 02:40 backups
                -rwxrwxrwx+  1 iobroker iobroker   919  6. Sep 14:36 INSTALLER_INFO.txt
                lrwxrwxrwx   1 iobroker iobroker    22  6. Sep 14:36 iob -> /opt/iobroker/iobroker
                -rwxrwxr-x+  1 iobroker iobroker   309  6. Sep 14:36 iobroker
                drwxrwxrwx+ 11 iobroker iobroker  4096  6. Sep 15:53 iobroker-data
                drwxrwxrwx+  2 iobroker iobroker  4096  6. Sep 15:51 log
                -rw-rwxr--+  1 iobroker iobroker   155  6. Sep 14:36 .npmrc
                -rw-rw-r--+  1 pi       pi        2239  6. Sep 15:48 package.json
                -rwxrwxrwx+  1 iobroker iobroker   284  6. Sep 14:36 package.json.bak
                -rwxrwxrwx+  1 iobroker iobroker  5693 17. Feb 2022  reinstall.js
                • mickym
                  @kimukao Gut dann hoffen wir mal das Beste:
                  npm install
                  wird hoffentlich eine Zeit dauern und anschließend wieder
                  npm list
                    npm install
                    pi@raspberrypi:/opt/iobroker $ npm install
                    npm ERR! builtins is not a function
                    npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T13_57_13_103Z-debug-0.log
                    • mickym
                      @kimukao Mach mal noch die Rechte:
                      sudo chown iobroker:iobroker package.json
                      und noch mal ls -la
                        pi@raspberrypi:/opt/iobroker $ sudo chown iobroker:iobroker package.json
                        insgesamt 76
                        -rw-rw-r--+  1 iobroker iobroker  2239  6. Sep 15:48 package.json
                        • mickym
                          @kimukao und nochmal in dem Verzeichnis
                          npm install
                            npm install
                            wieder das Gleiche:
                            npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T14_00_58_289Z-debug-0.log
                            • mickym
                              @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
                              Ich bin zwar glaub langsam am Ende - aber mach das halt mal
                              tail /home/iobroker/.npm/_logs/2022-09-06T14_00_58_289Z-debug-0.log
                                pi@raspberrypi:/opt/iobroker $ tail /home/iobroker/.npm/_logs/2022-09-06T14_00_58_289Z-debug-0.log
                                47 error builtins is not a function
                                48 verbose exit 1
                                49 timing npm Completed in 359ms
                                50 verbose unfinished npm timer reify 1662472858532
                                51 verbose unfinished npm timer reify:loadTrees 1662472858569
                                52 verbose unfinished npm timer idealTree:buildDeps 1662472858627
                                53 verbose unfinished npm timer idealTree:#root 1662472858629
                                54 verbose code 1
                                55 error A complete log of this run can be found in:
                                55 error     /home/iobroker/.npm/_logs/2022-09-06T14_00_58_289Z-debug-0.log
                                mickym Thomas Braun 2 Replies Last reply Reply Quote 0
                                • mickym
                                  mickym Most Active @kimukao last edited by mickym
                                  @kimukao So ich hab noch die Idee - dass die package.json im komprimieren Format arbeiten -
                                  mach mal
                                  nano package.json
                                  lösch dan alles raus und kopier das mal als Inhalt rein:
                                  {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=10.0.0"},"dependencies":{"iobroker.admin":"5.3.8","iobroker.alexa2":"^3.11.2","iobroker.alias-manager":"1.2.4","iobroker.backitup":"2.4.9","iobroker.daswetter":"3.1.2","iobroker.deconz":"1.3.21","iobroker.device-reminder":"1.2.9","iobroker.discovery":"3.0.3","iobroker.fritzdect":"^2.2.3","iobroker.heos":"1.10.0","iobroker.history":"1.11.1","iobroker.ical":"1.12.1","iobroker.icons-material-png":"^0.1.0","iobroker.icons-material-svg":"^0.1.0","iobroker.icons-mfd-svg":"1.1.0","iobroker.icons-open-icon-library-png":"^0.1.2","iobroker.icons-ultimate-png":"^1.0.1","iobroker.influxdb":"2.6.3","iobroker.javascript":"5.7.0","iobroker.js-controller":"4.0.23","iobroker.km200":"^2.0.3","iobroker.lupusec":"^1.3.6","iobroker.netatmo":"1.7.1","iobroker.nuki-extended":"github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4","iobroker.onvif":"^0.4.4","iobroker.parcel":"github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd","iobroker.pushover":"2.1.0","iobroker.shelly":"5.3.2","iobroker.simple-api":"2.7.0","iobroker.smartcontrol":"^1.2.1","iobroker.smartgarden":"2.0.0","iobroker.socketio":"4.2.0","iobroker.sonos":"2.1.7","iobroker.sony-bravia":"1.0.3","iobroker.synology":"2.1.7","iobroker.telegram":"1.13.0","iobroker.text2command":"2.2.1","iobroker.tr-064":"4.2.16","iobroker.trashschedule":"2.0.2","iobroker.uv-protect":"0.3.5","iobroker.vis":"1.4.15","iobroker.vis-fancyswitch":"^1.1.0","iobroker.vis-hqwidgets":"1.2.0","iobroker.vis-icontwo":"^0.87.0","iobroker.vis-inventwo":"^3.3.1","iobroker.vis-material-advanced":"^1.7.2","iobroker.vis-timeandweather":"^1.1.7","iobroker.vis-weather":"^2.5.5","iobroker.vw-connect":"0.0.50","iobroker.web":"4.3.0","iobroker.whatsapp-cmb":"0.2.2","iobroker.yahka":"^0.13.1"}}
                                  dann nochmal schauen ob die Rechte stimmen:
                                  ls - la
                                  und nochmal:
                                  npm install
                                    Thomas Braun Most Active @kimukao last edited by
                                    NEBELALARM
                                    Könnte ein Fehler in /usr/lib/node_modules/npm/node_modules/builtins
                                    sein.
                                    Installier nodejs nochmal.
                                    iobroker stop
                                    sudo apt update
                                    sudo apt install --reinstall nodejs
                                    iobroker start
                                    mickym K 2 Replies Last reply Reply Quote 0
                                    • mickym
                                      mickym Most Active @Thomas Braun last edited by
                                      @thomas-braun Gute Idee. 🙂
                                        kimukao @Thomas Braun last edited by
                                        @thomas-braun Hab nodejs nochmal neu installiert und iobroker neu gestartet. Jetzt komme ich per Browser gar nicht mehr drauf
                                          Da ist ja auch nix mehr. Den Browser kannst du im Moment vergessen.
                                          cd /opt/iobroker
                                          npm install
                                            @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
                                            cd /opt/iobroker
                                            pi@raspberrypi:~ $ iobroker stop
                                            pi@raspberrypi:~ $ sudo apt update
                                            Holen:1 http://archive.raspberrypi.org/debian bullseye InRelease [23,7 kB]
                                            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                            OK:3 https://repos.influxdata.com/debian bullseye InRelease
                                            OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                            OK:5 https://packages.grafana.com/oss/deb stable InRelease
                                            OK:6 https://phoscon.de/apt/deconz bullseye InRelease
                                            Holen:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [297 kB]
                                            Es wurden 320 kB in 2 s geholt (192 kB/s).
                                            Paketlisten werden gelesen… Fertig
                                            Abhängigkeitsbaum wird aufgebaut… Fertig
                                            Statusinformationen werden eingelesen… Fertig
                                            Alle Pakete sind aktuell.
                                            pi@raspberrypi:~ $ sudo apt install --reinstall nodejs
                                            0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                            Es müssen 24,1 MB an Archiven heruntergeladen werden.
                                            Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                                            Holen:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.17.0-deb-1nodesource1 [24,1 MB]
                                            Es wurden 24,1 MB in 2 s geholt (15,2 MB/s).
                                            (Lese Datenbank ... 79694 Dateien und Verzeichnisse sind derzeit installiert.)
                                            Vorbereitung zum Entpacken von .../nodejs_16.17.0-deb-1nodesource1_armhf.deb ...
                                            Entpacken von nodejs (16.17.0-deb-1nodesource1) über (16.17.0-deb-1nodesource1) ...
                                            nodejs (16.17.0-deb-1nodesource1) wird eingerichtet ...
                                            Trigger für man-db (2.9.4-2) werden verarbeitet ...
                                            pi@raspberrypi:~ $ iobroker start
                                            pi@raspberrypi:~ $ cd /opt/iobroker
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T14_15_36_444Z-debug-0.log
                                            Thomas Braun mickym 2 Replies Last reply Reply Quote 0
                                            node js
                                            16
                                            335
                                            39149
