    4. Kein Update mehr möglich mit Node.js 16
      kimukao @mickym last edited by
      @mickym said in Kein Update mehr möglich mit Node.js 16:
      tail /home/iobroker/.npm/_logs/2022-09-06T14_00_58_289Z-debug-0.log
      pi@raspberrypi:/opt/iobroker $ tail /home/iobroker/.npm/_logs/2022-09-06T14_00_58_289Z-debug-0.log
      47 error builtins is not a function
      48 verbose exit 1
      49 timing npm Completed in 359ms
      50 verbose unfinished npm timer reify 1662472858532
      51 verbose unfinished npm timer reify:loadTrees 1662472858569
      52 verbose unfinished npm timer idealTree:buildDeps 1662472858627
      53 verbose unfinished npm timer idealTree:#root 1662472858629
      54 verbose code 1
      55 error A complete log of this run can be found in:
      55 error     /home/iobroker/.npm/_logs/2022-09-06T14_00_58_289Z-debug-0.log
      mickym Thomas Braun 2 Replies Last reply Reply Quote 0
      • mickym
        mickym Most Active @kimukao last edited by mickym
        @kimukao So ich hab noch die Idee - dass die package.json im komprimieren Format arbeiten -
        mach mal
        nano package.json
        lösch dan alles raus und kopier das mal als Inhalt rein:
        {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=10.0.0"},"dependencies":{"iobroker.admin":"5.3.8","iobroker.alexa2":"^3.11.2","iobroker.alias-manager":"1.2.4","iobroker.backitup":"2.4.9","iobroker.daswetter":"3.1.2","iobroker.deconz":"1.3.21","iobroker.device-reminder":"1.2.9","iobroker.discovery":"3.0.3","iobroker.fritzdect":"^2.2.3","iobroker.heos":"1.10.0","iobroker.history":"1.11.1","iobroker.ical":"1.12.1","iobroker.icons-material-png":"^0.1.0","iobroker.icons-material-svg":"^0.1.0","iobroker.icons-mfd-svg":"1.1.0","iobroker.icons-open-icon-library-png":"^0.1.2","iobroker.icons-ultimate-png":"^1.0.1","iobroker.influxdb":"2.6.3","iobroker.javascript":"5.7.0","iobroker.js-controller":"4.0.23","iobroker.km200":"^2.0.3","iobroker.lupusec":"^1.3.6","iobroker.netatmo":"1.7.1","iobroker.nuki-extended":"github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4","iobroker.onvif":"^0.4.4","iobroker.parcel":"github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd","iobroker.pushover":"2.1.0","iobroker.shelly":"5.3.2","iobroker.simple-api":"2.7.0","iobroker.smartcontrol":"^1.2.1","iobroker.smartgarden":"2.0.0","iobroker.socketio":"4.2.0","iobroker.sonos":"2.1.7","iobroker.sony-bravia":"1.0.3","iobroker.synology":"2.1.7","iobroker.telegram":"1.13.0","iobroker.text2command":"2.2.1","iobroker.tr-064":"4.2.16","iobroker.trashschedule":"2.0.2","iobroker.uv-protect":"0.3.5","iobroker.vis":"1.4.15","iobroker.vis-fancyswitch":"^1.1.0","iobroker.vis-hqwidgets":"1.2.0","iobroker.vis-icontwo":"^0.87.0","iobroker.vis-inventwo":"^3.3.1","iobroker.vis-material-advanced":"^1.7.2","iobroker.vis-timeandweather":"^1.1.7","iobroker.vis-weather":"^2.5.5","iobroker.vw-connect":"0.0.50","iobroker.web":"4.3.0","iobroker.whatsapp-cmb":"0.2.2","iobroker.yahka":"^0.13.1"}}
        dann nochmal schauen ob die Rechte stimmen:
        ls - la
        und nochmal:
        npm install
          Thomas Braun Most Active @kimukao last edited by
          @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
          NEBELALARM
          Könnte ein Fehler in /usr/lib/node_modules/npm/node_modules/builtins
          sein.
          Installier nodejs nochmal.
          iobroker stop
          sudo apt update
          sudo apt install --reinstall nodejs
          iobroker start
          mickym K 2 Replies Last reply Reply Quote 0
          • mickym
            mickym Most Active @Thomas Braun last edited by
            @thomas-braun Gute Idee. 🙂
              kimukao @Thomas Braun last edited by
              @thomas-braun Hab nodejs nochmal neu installiert und iobroker neu gestartet. Jetzt komme ich per Browser gar nicht mehr drauf
                Da ist ja auch nix mehr. Den Browser kannst du im Moment vergessen.
                cd /opt/iobroker
                npm install
                  @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
                  cd /opt/iobroker
                  pi@raspberrypi:~ $ iobroker stop
                  pi@raspberrypi:~ $ sudo apt update
                  Holen:1 http://archive.raspberrypi.org/debian bullseye InRelease [23,7 kB]
                  OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  OK:3 https://repos.influxdata.com/debian bullseye InRelease
                  OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                  OK:5 https://packages.grafana.com/oss/deb stable InRelease
                  OK:6 https://phoscon.de/apt/deconz bullseye InRelease
                  Holen:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [297 kB]
                  Es wurden 320 kB in 2 s geholt (192 kB/s).
                  Paketlisten werden gelesen… Fertig
                  Abhängigkeitsbaum wird aufgebaut… Fertig
                  Statusinformationen werden eingelesen… Fertig
                  Alle Pakete sind aktuell.
                  pi@raspberrypi:~ $ sudo apt install --reinstall nodejs
                  0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  Es müssen 24,1 MB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                  Holen:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.17.0-deb-1nodesource1 [24,1 MB]
                  Es wurden 24,1 MB in 2 s geholt (15,2 MB/s).
                  (Lese Datenbank ... 79694 Dateien und Verzeichnisse sind derzeit installiert.)
                  Vorbereitung zum Entpacken von .../nodejs_16.17.0-deb-1nodesource1_armhf.deb ...
                  Entpacken von nodejs (16.17.0-deb-1nodesource1) über (16.17.0-deb-1nodesource1) ...
                  nodejs (16.17.0-deb-1nodesource1) wird eingerichtet ...
                  Trigger für man-db (2.9.4-2) werden verarbeitet ...
                  pi@raspberrypi:~ $ iobroker start
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ npm install
                  npm ERR! builtins is not a function
                  npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T14_15_36_444Z-debug-0.log
                  Thomas Braun mickym 2 Replies Last reply Reply Quote 0
                    @kimukao
                    Ich fands eigentlich eine gute Idee... 🙂
                    Hat aber wohl nicht geklappt.
                    • mickym
                      @kimukao Hast Du denn meine komprimierte package.json verwendet?
                        @mickym noch nicht, ich scheitere grade daran, den alten Inhalt rauszulösechn.. muss jedes Zeichen einzeln entfernen, Markierung des ganzen Inhalts schaffe ich nicht.. oder gibt's da einen Trick?
                        • mickym
                          @kimukao Du kannst einfach mit CTRL+K - Zeile für Zeile löschen
                            @mickym ah danke - das Löschen hat geklappt. Der Rest leider nicht:
                            pi@raspberrypi:/opt/iobroker $ ls -la
                            insgesamt 76
                            drwxrwxrwx+  5 iobroker iobroker  4096  6. Sep 16:21 .
                            drwxr-xr-x   3 root     root      4096  7. Feb 2022  ..
                            drwxrwxr-x+  2 iobroker iobroker 28672  6. Sep 02:40 backups
                            -rwxrwxrwx+  1 iobroker iobroker   919  6. Sep 14:36 INSTALLER_INFO.txt
                            lrwxrwxrwx   1 iobroker iobroker    22  6. Sep 14:36 iob -> /opt/iobroker/iobroker
                            -rwxrwxr-x+  1 iobroker iobroker   309  6. Sep 14:36 iobroker
                            drwxrwxrwx+ 11 iobroker iobroker  4096  6. Sep 15:53 iobroker-data
                            drwxrwxrwx+  2 iobroker iobroker  4096  6. Sep 15:51 log
                            -rw-rwxr--+  1 iobroker iobroker   155  6. Sep 14:36 .npmrc
                            -rw-rw-r--+  1 iobroker iobroker  1890  6. Sep 16:21 package.json
                            -rwxrwxrwx+  1 iobroker iobroker   284  6. Sep 14:36 package.json.bak
                            -rwxrwxrwx+  1 iobroker iobroker  5693 17. Feb 2022  reinstall.js
                            npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T14_21_43_826Z-debug-0.log
                            • mickym
                              @kimukao Jetzt probieren wir noch eins, ob es an der package.json liegt. Wir haben ja noch die alte von Deiner Neuinstallation.
                              mv package.json package.json.bak2
                              mv package.json.bak package.json
                              npm install
                                pi@raspberrypi:/opt/iobroker $ mv package.json package.json.bak2
                                pi@raspberrypi:/opt/iobroker $ mv package.json.bak package.json
                                npm ERR!     /home/iobroker/.npm/_logs/2022-09-06T14_26_02_806Z-debug-0.log
                                • mickym
                                  @kimukao Und hast Du wirklich cache und alles gelöscht.
                                  Zeig nochmal
                                  npm cache clean --f
                                    npm cache clean --f
                                    pi@raspberrypi:/opt/iobroker $ npm cache clean --f
                                    npm WARN using --force Recommended protections disabled.
                                    • mickym
                                      @kimukao Gut und npm install geht wahrscheinlich immer noch nicht?
                                      Ich schau mal ob ich zu dem builtins Fehler nochwas finde - sonst - denke ich musst Du neu aufbauen und backup einspielen.
                                      K mickym 2 Replies Last reply Reply Quote 0
                                        Genau. Danke für die Hilfe! Wirklich Wahnsinn, dass Ihr Euch hier mit mir den Nachmittag um die Ohren schlagt. Sollte es noch eine Lösung geben wäre ich wirklich glücklich. Wenn nicht muss ich in den sauren Apfel beißen. Am besten mit neuem Datenträger von grundauf neu installieren? Mit Grafana, Deconz etcpp...?
                                        • mickym
                                          mickym Most Active @mickym last edited by mickym
                                          @mickym schau mal ob Du das installieren kannst:
                                          apt install builtins
                                            @mickym
                                            pi@raspberrypi:/opt/iobroker $ apt install builtins
                                            E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                            E: Erlangen der Sperre für die Dpkg-Oberfläche (/var/lib/dpkg/lock-frontend) nicht möglich; sind Sie root?
                                            node js
                                            16
                                            335
                                            39166
