    4. Kein Update mehr möglich mit Node.js 16
    • mickym
      mickym Most Active @kimukao last edited by mickym
      Na die schaut eigentlich gut aus. auch wenn das mit dem prune nicht ganz bereinigt hat - liegt halt wahrscheinlich an irgendwelchen Adaptern.
        "name": "iobroker.inst",
        "version": "3.0.0",
        "private": true,
        "description": "Automate your Life",
        "engines": {
          "node": ">=10.0.0"
        "dependencies": {
          "iobroker.admin": "5.3.8",
          "iobroker.alexa2": "^3.11.2",
          "iobroker.alias-manager": "1.2.4",
          "iobroker.backitup": "2.4.9",
          "iobroker.daswetter": "3.1.2",
          "iobroker.deconz": "1.3.21",
          "iobroker.device-reminder": "1.2.9",
          "iobroker.discovery": "3.0.3",
          "iobroker.fritzdect": "^2.2.3",
          "iobroker.heos": "1.10.0",
          "iobroker.history": "1.11.1",
          "iobroker.ical": "1.12.1",
          "iobroker.icons-material-png": "^0.1.0",
          "iobroker.icons-material-svg": "^0.1.0",
          "iobroker.icons-mfd-svg": "1.1.0",
          "iobroker.icons-open-icon-library-png": "^0.1.2",
          "iobroker.icons-ultimate-png": "^1.0.1",
          "iobroker.influxdb": "2.6.3",
          "iobroker.javascript": "5.7.0",
          "iobroker.js-controller": "4.0.23",
          "iobroker.km200": "^2.0.3",
          "iobroker.lupusec": "^1.3.6",
          "iobroker.netatmo": "1.7.1",
          "iobroker.nuki-extended": "github:iobroker-community-adapters/ioBroker.nuki-extended#b303d4a823fcba09b4d3de04d1412c770f5c68b4",
          "iobroker.onvif": "^0.4.4",
          "iobroker.parcel": "github:TA2k/ioBroker.parcel#377864c5926b0e0d41c658640e3097152f86a9fd",
          "iobroker.pushover": "2.1.0",
          "iobroker.shelly": "5.3.2",
          "iobroker.simple-api": "2.7.0",
          "iobroker.smartcontrol": "^1.2.1",
          "iobroker.smartgarden": "2.0.0",
          "iobroker.socketio": "4.2.0",
          "iobroker.sonos": "2.1.7",
          "iobroker.sony-bravia": "1.0.3",
          "iobroker.synology": "2.1.7",
          "iobroker.telegram": "1.13.0",
          "iobroker.text2command": "2.2.1",
          "iobroker.tr-064": "4.2.16",
          "iobroker.trashschedule": "2.0.2",
          "iobroker.uv-protect": "0.3.5",
          "iobroker.vis": "1.4.15",
          "iobroker.vis-fancyswitch": "^1.1.0",
          "iobroker.vis-hqwidgets": "1.2.0",
          "iobroker.vis-icontwo": "^0.87.0",
          "iobroker.vis-inventwo": "^3.3.1",
          "iobroker.vis-material-advanced": "^1.7.2",
          "iobroker.vis-timeandweather": "^1.1.7",
          "iobroker.vis-weather": "^2.5.5",
          "iobroker.vw-connect": "0.0.50",
          "iobroker.web": "4.3.0",
          "iobroker.whatsapp-cmb": "0.2.2",
          "iobroker.yahka": "^0.13.1"
      Jetzt schau mal ob Du den iob starten kannst
      iob start
        kimukao @mickym last edited by
        @mickym said in Kein Update mehr möglich mit Node.js 16:
        YEESSSSS!!! Bin auf der Oberfläche und habe grade sogar den backitup Adapter aktualisiert. Scheint durchgelaufen zu sein.. Unglaublich!! Meine Lichtschalter funktionieren auch wieder, sitze nicht mehr im Dunkeln 🙂 WOW. You made my day! Wohin darf ich den Whiskey schicken?
        Thomas Braun mickym 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @kimukao last edited by
          @kimukao
          iobroker update
          sagt nun?
            kimukao @Thomas Braun last edited by
            @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
            iobroker update
            pi@raspberrypi:~ $ iobroker update
            Used repository: stable
            Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
            Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
            Adapter    "alias-manager": 1.2.4    , installed 1.2.4
            Adapter    "backitup"     : 2.4.10   , installed 2.4.10
            Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
            Adapter    "device-reminder": 1.2.9  , installed 1.2.9
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
            Adapter    "heos"         : 1.10.0   , installed 1.10.0
            Adapter    "history"      : 2.2.0    , installed 1.11.1 [Updatable]
            Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "influxdb"     : 3.1.7    , installed 2.6.3  [Updatable]
            Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
            Adapter    "km200"        : 2.0.3    , installed 2.0.3
            Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
            Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
            Adapter    "nuki-extended": 2.3.1    , installed 2.4.0
            Adapter    "onvif"        : 0.4.4    , installed 0.4.4
            Adapter    "parcel"       : 0.0.20   , installed 0.0.15 [Updatable]
            Adapter    "pushover"     : 3.0.2    , installed 2.1.0  [Updatable]
            Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
            Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
            Adapter    "sonos"        : 2.2.3    , installed 2.1.7  [Updatable]
            Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.3  [Updatable]
            Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
            Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
            Adapter    "text2command" : 2.2.2    , installed 2.2.1  [Updatable]
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "trashschedule": 2.0.3    , installed 2.0.2  [Updatable]
            Adapter    "uv-protect"   : 0.3.6    , installed 0.3.5  [Updatable]
            Adapter    "vis"          : 1.4.15   , installed 1.4.15
            Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
            Adapter    "vis-icontwo"  : 0.89.0   , installed 0.87.0 [Updatable]
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vis-weather"  : 2.5.5    , installed 2.5.6
            Adapter    "vw-connect"   : 0.0.51   , installed 0.0.50 [Updatable]
            Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
            • mickym
              @kimukao Na dann scheint die Aktualisierung auch wieder zu klappen. ;)- Freut mich.
              Wichtig ist - wenn alles funktioniert - ein Image zu ziehen - wenn Dinge im System verkehrt sind, bekommst die über das backup nicht geregelt und musst eben wieder alles von vorne installieren. Vergiss SSD - mach ein Image auf Deinem Windowsrechner von der SD karte. 😉
                @kimukao
                Dann zieh die Adapter jetzt auf Stand.
                iobroker upgrade all -y
                Ich will jetzt nicht hochscrollen und suchen, aber hattest du npm separat angepackt / aktualisiert?
                  @mickym Nochmal tausend Dank, Du kannst Dir gar nicht vorstellen, wie ich mich freue!! Echt mega!! Hab nen Mac, aber da sollte man ja auch ein Image hinziehen können. Werde den Tipp befolgen. Für heute freue ich mich erstmal, dass es wieder läuft. Und die extraneous Hinweise kann ich ignorieren?
                    Thomas Braun Most Active @kimukao last edited by Thomas Braun
                    @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
                    Ja.
                    Oder nachdem alle Adapter aktualisiert wurden nochmal
                    cd /opt/iobroker
                    npm prune
                    K 2 Replies Last reply Reply Quote 0
                    • mickym
                      @kimukao Nun ja das kann man mit npm prune aufräumen - das kommt aber oft wieder wenn irgendwelche Adapter alte Module verwenden und die dann in einer bestimmten Version wieder installiert werden.Extraneous ist unbedenklich - sondern aus Sicht des npm Paketmanagers sind diese Pakete überflüssig - das Modul meint aber es bräuchte die.
                      Deswegen ist das was Thomas sagt- wie immer natürlich - goldrichtig. Alles updaten und dann mit npm prune nochmal aufräumen - und wenn dann noch was übrig ist - hast Du halt trotzdem irgendwo noch einen Verweis auf eine veraltetes Paket drin.
                        Ja.
                        cd /opt/iobroker
                        npm prune
                        Ziehe grade alle Updates. Auch Dir nochmal tausend Dank! Ihr seid echt klasse. Mega Forum! Danke, danke, danke. Freu mich 🙂
                        • mickym
                          @kimukao Wir hätten Dich ja beinahe schon aufgegeben - ich war auch kurz davor. 😉 - Insofern freuen wir uns mit Dir. 🙂
                            Zum Glück habt Ihr es nicht 🙂
                              @kimukao
                              Mich würde ja immer noch interessieren, wo die komische Installation von npm herkam. Bist du sicher, dass die nie per npm -g i npm oder sowas mal angepackt wurde?
                                cd /opt/iobroker
                                npm prune
                                pi@raspberrypi:/opt/iobroker $ npm list
                                iobroker.inst@3.0.0 /opt/iobroker
                                ├── iobroker.admin@6.2.20
                                ├── iobroker.alexa2@3.19.7
                                ├── iobroker.alias-manager@1.2.4
                                ├── iobroker.backitup@2.4.10
                                ├── iobroker.daswetter@3.1.2
                                ├── iobroker.deconz@1.3.21
                                ├── iobroker.device-reminder@1.2.9
                                ├── iobroker.discovery@3.0.5
                                ├── iobroker.fritzdect@2.2.3
                                ├── iobroker.heos@1.10.0
                                ├── iobroker.history@2.2.0
                                ├── iobroker.ical@1.13.1
                                ├── iobroker.icons-material-png@0.1.0
                                ├── iobroker.icons-material-svg@0.1.0
                                ├── iobroker.icons-mfd-svg@1.1.0
                                ├── iobroker.icons-open-icon-library-png@0.1.2
                                ├── iobroker.icons-ultimate-png@1.0.1
                                ├── iobroker.influxdb@3.1.7
                                ├── iobroker.javascript@6.0.0
                                ├── iobroker.js-controller@4.0.23
                                ├── iobroker.km200@2.0.3
                                ├── iobroker.lupusec@1.3.6
                                ├── iobroker.netatmo@1.7.1
                                ├── iobroker.nuki-extended@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#b303d4a823fcba09b4d3de04d1412c770f5c68b4)
                                ├── iobroker.onvif@0.4.4
                                ├── iobroker.parcel@0.0.20
                                ├── iobroker.pushover@3.0.2
                                ├── iobroker.shelly@6.0.0
                                ├── iobroker.simple-api@2.7.0
                                ├── iobroker.smartcontrol@1.2.1
                                ├── iobroker.smartgarden@2.0.0
                                ├── iobroker.socketio@4.2.0
                                ├── iobroker.sonos@2.2.3
                                ├── iobroker.sony-bravia@1.0.9
                                ├── iobroker.synology@2.1.9
                                ├── iobroker.telegram@1.14.1
                                ├── iobroker.text2command@2.2.2
                                ├── iobroker.tr-064@4.2.16
                                ├── iobroker.trashschedule@2.0.3
                                ├── iobroker.uv-protect@0.3.6
                                ├── iobroker.vis-fancyswitch@1.1.0
                                ├── iobroker.vis-hqwidgets@1.2.0
                                ├── iobroker.vis-icontwo@0.89.0
                                ├── iobroker.vis-inventwo@3.3.3
                                ├── iobroker.vis-material-advanced@1.7.2
                                ├── iobroker.vis-timeandweather@1.2.2
                                ├── iobroker.vis-weather@2.5.6
                                ├── iobroker.vis@1.4.15
                                ├── iobroker.vw-connect@0.0.51
                                ├── iobroker.web@4.3.0
                                ├── iobroker.whatsapp-cmb@0.2.2
                                └── iobroker.yahka@0.13.1
                                • mickym
                                  @kimukao Ich kann Dir nur raten - mach trotzdem ein Image - gerade wenn Du soviel anderes Zeug noch installiert hast. Ich habe auch mal neu aufgebaut - habe nicht so viel - aber mich hat das 2 Tage gekostet. Es gibt ja meist nicht nur den iobroker auf dem System - sondern auch noch andere Dinge.
                                  • mickym
                                    cd /opt/iobroker
                                    npm prune
                                    Aber die Frage von @Thomas-Braun solltest vielleicht nochmal durch den Kopf gehen lassen, dass Du das halt nicht mehr wieder machst.
                                      Nicht, dass ich wüsste. Aber garantieren kann ich bei meinem Kenntnisstand für nichts...
                                        Das mache ich auf jeden Fall. Danke! Der Schock war lehrreich...
                                          kimukao @kimukao last edited by kimukao
                                          (hat sich erledigt)
                                          node js
                                          16
                                          335
                                          38054
