    4. JavaScript
    5. Erster Versuch ein JSON zu erzeugen
    • Chris76e
      Chris76e @paul53 last edited by
      Da ist das selbe....
      00:43:45.727	info	javascript.0 (649) script.js.common.JSON.JASONSP: null
      00:43:45.728	info	javascript.0 (649) script.js.common.JSON.JASONSP: undefined
      const idTable = '0_userdata.0.JSON.Spülmaschiene'; // ID JSON-Tabelle
      const idStatus = 'homeconnect.0.011040388898000963.status.BSH_Common_Status_OperationState';
      const idProg = 'homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram';
      var table = [];
      if(getState(idTable).val) table = JSON.parse(getState(idTable).val);
      var obj = {};
      on(idStatus, function(dp) {
          if(dp.state.val == 'BSH.Common.EnumType.OperationState.Run') {
              obj.Start = formatDate(new Date(), 'DD.MM.YY hh:mm');
          } else if(dp.oldState.val == 'BSH.Common.EnumType.OperationState.Run') {
              obj.Programm = getObject(idProg).common.states[getState(idProg).val];
              obj.Ende = formatDate(new Date(), 'DD.MM.YY hh:mm');
              table.push(obj);
              if(table.length > 10) table.shift();
              setState(idTable, JSON.stringify(table), true);
              log(getState(idProg).val);
              log(getObject(idProg).common.states[getState(idProg).val]);
      • Chris76e
        Chris76e last edited by
        Vieleicht hilft das dir noch weiter, die Objektdaten von
          "type": "state",
          "common": {
            "name": "BSH_Common_Root_ActiveProgram",
            "type": "string",
            "role": "indicator",
            "write": true,
            "read": true,
            "states": {
              "Dishcare.Dishwasher.Program.Intensiv70": "Intensiv 70°",
              "Dishcare.Dishwasher.Program.Auto2": "Auto 45-65°",
              "Dishcare.Dishwasher.Program.Eco50": "Eco 50°",
              "Dishcare.Dishwasher.Program.Quick45": "Speed 45°",
              "Dishcare.Dishwasher.Program.PreRinse": "Vorspülen",
              "Dishcare.Dishwasher.Program.Quick65": "Speed 65°",
              "Dishcare.Dishwasher.Program.MachineCare": "Maschinenpflege"
            "custom": {
              "history.0": {
                "enabled": true,
                "aliasId": "",
                "debounceTime": 0,
                "blockTime": 0,
                "changesOnly": false,
                "changesRelogInterval": 0,
                "changesMinDelta": 0,
                "ignoreBelowNumber": "",
                "disableSkippedValueLogging": false,
                "retention": 31536000,
                "customRetentionDuration": 365,
                "maxLength": 10,
                "enableDebugLogs": false,
                "debounce": 0
          "native": {},
          "_id": "homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
          "from": "system.adapter.homeconnect.0",
          "user": "system.user.admin",
          "ts": 1662416101983
        • Chris76e
          Chris76e @paul53 last edited by Chris76e
          Bin jetzt einwenig weiter gekommen, wenn ich den DP
          homeconnect.0.011040388898000963.programs.selected.BSH_Common_Root_SelectedProgram
          nehme, dann wird der erkannt.
          Aber mit der Schleife ist nochwas nicht richtig. Hier werden Daten überschrieben
              "Start": "06.09.22 00:42",
              "Ende": "06.09.22 00:43"
              "Start": "06.09.22 09:25",
              "Ende": "06.09.22 09:25",
              "Programm": "Eco 50°"
              "Start": "06.09.22 09:28",
              "Ende": "06.09.22 09:28",
              "Programm": "Speed 45°"
          const idProg = 'homeconnect.0.011040388898000963.programs.selected.BSH_Common_Root_SelectedProgram';
          var table = [];
          var obj = {};
                  table.push(obj);
          Chris76e 1 Reply Last reply Reply Quote 0
          • Chris76e
            Chris76e @Chris76e last edited by Chris76e
            Habe vermutlich zuschnell das Programm am GS gestoppt.
            Habe es jetzt einwenig länger laufen lassen und dann wird richtig geschrieben.
                "Start": "06.09.22 10:09",
                "Programm": "Auto 45-65°",
                "Ende": "06.09.22 10:11"
                "Start": "06.09.22 10:13",
                "Programm": "Eco 50°",
                "Ende": "06.09.22 10:20"
            • Chris76e
              Kannst du dir nochmal bitte die schleife anschauen? Irgendwas stimmt da doch nicht.
              Es werden weiter Dopelte Einträge gemacht, bzw. alte Einträge überschrieben.
                  "Start": "06.09.22 09:49",
                  "Programm": "Intensiv 70°",
                  "Ende": "06.09.22 09:49"
                  "Start": "06.09.22 10:31",
                  "Ende": "06.09.22 15:08"
                paul53 @Chris76e last edited by
                @chris76e sagte: Es werden weiter Dopelte Einträge gemacht
                Das kann nur am Verhalten des Datenpunktes "homeconnect.0.011040388898000963.status.BSH_Common_Status_OperationState" liegen". Logge mal den Wert bei jedem Trigger-Ereignis.
                • Chris76e
                  Hier der Eintrag aus dem Log
                  1. Start war noch ohne log vom Ende
                  20:19:34.230	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Run
                  20:19:34.231	info	javascript.0 (649) script.js.common.JSON.JASONSP: Run
                  20:19:34.231	info	javascript.0 (649) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.MachineCare
                  20:19:34.231	info	javascript.0 (649) script.js.common.JSON.JASONSP: Maschinenpflege
                  20:27:19.463	info	javascript.0 (649) Stop script script.js.common.JSON.JASONSP
                  20:27:19.466	info	javascript.0 (649) Start javascript script.js.common.JSON.JASONSP
                  20:27:19.479	info	javascript.0 (649) script.js.common.JSON.JASONSP: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  20:28:02.079	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Run
                  20:28:02.081	info	javascript.0 (649) script.js.common.JSON.JASONSP: Run
                  20:28:02.082	info	javascript.0 (649) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.Quick45
                  20:28:02.082	info	javascript.0 (649) script.js.common.JSON.JASONSP: Speed 45°
                  20:30:16.619	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Aborting
                  20:30:16.619	info	javascript.0 (649) script.js.common.JSON.JASONSP: Aborting
                  20:32:02.233	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Run
                  20:32:02.234	info	javascript.0 (649) script.js.common.JSON.JASONSP: Run
                  20:32:02.234	info	javascript.0 (649) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.MachineCare
                  20:32:02.234	info	javascript.0 (649) script.js.common.JSON.JASONSP: Maschinenpflege
                  20:33:17.902	info	javascript.0 (649) script.js.common.JSON.JASONSP: BSH.Common.EnumType.OperationState.Aborting
                  20:33:17.902	info	javascript.0 (649) script.js.common.JSON.JASONSP: Aborting
                  Und so sieht die JSON aus
                      "Start": "06.09.22 20:19",
                      "Programm": "Maschinenpflege",
                      "Ende": "06.09.22 20:25"
                      "Start": "06.09.22 20:32",
                      "Ende": "06.09.22 20:33"
                  Hier stand auch mal zwischenzeitlich der Eintrag von 20:28 mit Speed 45°
                    paul53 @Chris76e last edited by paul53
                    @chris76e
                    Aus dem Log sehe ich, dass "Run" nur als kurzer Impuls gemeldet wird und danach das Programm, beendet durch "Aborting". Dann versuche es mal so:
                    // const idProg = 'homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram';
                    var table = [];
                    var obj = {};
                            obj.Programm = dp.common.states[dp.state.val];
                        } else if (dp.state.val == 'BSH.Common.EnumType.OperationState.Aborting') {
                            table.push(obj);
                    • Chris76e
                      Wo kommt jetzt der DP herr? Fehlt da nicht was?
                        @chris76e sagte: Wo kommt jetzt der DP herr?
                        Aus dem Trigger: Enthält den Zustand "laufendes Programm" nach "Run".
                        • Chris76e
                          Mit der Version wird nichts geschrieben, bekomme auch keine Fehlermeldung.
                            @chris76e sagte: Mit der Version wird nichts geschrieben
                            Wurde obj außerhalb des Triggers deklariert? Habe ich oben korrigiert.
                            • Chris76e
                              ist geändert, aber macht immer noch nichts.
                                @chris76e sagte: ist geändert, aber macht immer noch nichts.
                                @chris76e sagte in Erster Versuch ein JSON zu erzeugen:
                                Das ist wirklich der Wert des Trigger-Datenpunktes. Es sind zumindest zwei Log-Ausgaben. Logge mal nur den Trigger-Wert:
                                    log(dp.state.val);
                                Alle anderen Logs kommentiere aus.
                                • Chris76e
                                  log sieht so aus
                                  23:48:20.661	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Ready
                                  23:48:25.593	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Run
                                  23:49:37.318	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Aborting
                                  23:50:02.051	info	javascript.0 (649) script.js.common.JSON.JASONTest: BSH.Common.EnumType.OperationState.Ready
                                  Wird aber nichts geschrieben
                                    @chris76e
                                    Habe mich hier durch die weiteren Logs täuschen lassen, da sie nicht gekennzeichnet sind.
                                    Weshalb das Skript doppelte Einträge erzeugt, erschließt sich mir bisher nicht. Deshalb erzeuge bitte Logs mit Datenpunkt-Kennung:
                                    const idAktiv = 'homeconnect.0.011040388898000963.programs.active.BSH_Common_Root_ActiveProgram';
                                    var table = [];
                                    var obj = {};
                                    on(idAktiv, function(dp) {
                                        log('Aktiv: ' + dp.state.val);
                                        log('gewählt: ' + getState(idProg).val);
                                        log('alter Status: ' + dp.oldState.val);
                                        log('neuer Status: ' + dp.state.val);
                                            table.push(obj);
                                    • Chris76e
                                      Hier der log von 2 Abgebrochenen Durchgänge:
                                      08:58:09.745	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Eco50
                                      08:58:09.745	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Ready
                                      08:58:09.746	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Run
                                      08:58:09.746	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.Eco50
                                      08:58:09.746	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Eco 50°
                                      08:58:09.918	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: Dishcare.Dishwasher.Program.Eco50
                                      09:00:36.446	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: null
                                      09:00:36.847	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Eco50
                                      09:00:36.847	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Run
                                      09:00:36.847	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Aborting
                                      09:01:03.132	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Eco50
                                      09:01:03.132	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Aborting
                                      09:01:03.133	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Ready
                                      09:09:34.041	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Quick65
                                      09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Ready
                                      09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Run
                                      09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Dishcare.Dishwasher.Program.Quick65
                                      09:09:34.042	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: Speed 65°
                                      09:09:34.107	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: Dishcare.Dishwasher.Program.Quick65
                                      09:10:56.316	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: aktiv: null
                                      09:10:56.480	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Quick65
                                      09:10:56.480	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Run
                                      09:10:56.480	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Aborting
                                      09:11:20.331	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: gewählt: Dishcare.Dishwasher.Program.Quick65
                                      09:11:20.332	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: alter Status: BSH.Common.EnumType.OperationState.Aborting
                                      09:11:20.332	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: neuer Status: BSH.Common.EnumType.OperationState.Ready
                                      So sieht die JSON nach dem 1. aus:
                                          "Start": "06.09.22 23:48",
                                          "Ende": "06.09.22 23:49"
                                          "Start": "07.09.22 08:58",
                                          "Ende": "07.09.22 09:00"
                                      und so nach dem 2.
                                          "Start": "07.09.22 09:09",
                                          "Programm": "Speed 65°",
                                          "Ende": "07.09.22 09:10"
                                        @chris76e
                                        Aus dem Log erkennt man, dass "ActiveProgram" zu Beginn und zu Ende triggert - am Ende mit Wert null. Damit kann man das Programm vereinfachen:
                                        // const idStatus = 'homeconnect.0.011040388898000963.status.BSH_Common_Status_OperationState';
                                        // const idProg = 'homeconnect.0.011040388898000963.programs.selected.BSH_Common_Root_SelectedProgram';
                                        var table = [];
                                        var obj = {};
                                            if(dp.state.val) {
                                                obj = {};
                                            } else {
                                        //        log(table);
                                                table.push(obj);
                                        //        log(table);
                                        • Chris76e
                                          Wird immer noch überschrieben....
                                          10:20:10.018	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'}]
                                          10:20:10.018	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 10:16','Programm':'Eco 50°','Ende':'07.09.22 10:20'}]
                                          10:23:40.013	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 10:21','Programm':'Eco 50°','Ende':'07.09.22 10:23'}]
                                          10:23:40.013	info	javascript.0 (3489476) script.js.common.JSON.JASONSP: [{'Start':'06.09.22 23:48','Programm':'Intensiv 70°','Ende':'06.09.22 23:49'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 09:09','Programm':'Speed 65°','Ende':'07.09.22 09:10'},{'Start':'07.09.22 10:21','Programm':'Eco 50°','Ende':'07.09.22 10:23'},{'Start':'07.09.22 10:21','Programm':'Eco 50°','Ende':'07.09.22 10:23'}]
                                            @chris76e sagte: Wird immer noch überschrieben....
                                            Muss ich noch mal schauen.
                                            2153
