    3. Entwicklung
    4. Poollab / Primelab integrieren
    • 100prznt
      100prznt @MiKKey last edited by
      @mikkey sagte in Poollab / Primelab integrieren:
      Bei der Installation passiert nichts.
      $ iobroker url https://github.com/100prznt/ioBroker.labcom --host IoBroker --debug
      install 100prznt/ioBroker.labcom#b6dc2782e6748c0c1d677e1d0a5a4c1fe1e68127
      NPM version: 6.14.16Installing 100prznt/ioBroker.labcom#b6dc2782e6748c0c1d677e1d0a5a4c1fe1e68127... (System call)
      So hab das jetzt mal auf einer jungfräulichen ioBroker Installation (Debian VM unter Proxmox) getestet. Funktioniert bei mir ohne Probleme.
      Zu beachten sind zwei Dinge.
      2. Der Installationsvorgang kann auch mal etwas länger dauern. Screenshot_Install_Complete.png
      $ iobroker url https://github.com/100prznt/ioBroker.labcom --host ioBroker-sandbox --debug
      NPM version: 6.14.17
      -- Zeit für Tee und Kaffee!!!1!11elf
      npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})+ iobroker.labcom@0.1.1added 4 packages from 8 contributors in 268.179s
      38 packages are looking for funding run `npm fund` for details
      upload [4] labcom.admin /opt/iobroker/node_modules/iobroker.labcom/admin/admin.d.ts admin.d.ts video/mp2t
      upload [3] labcom.admin /opt/iobroker/node_modules/iobroker.labcom/admin/index_m.html index_m.html text/html
      upload [2] labcom.admin /opt/iobroker/node_modules/iobroker.labcom/admin/logo.png logo.png image/png
      upload [1] labcom.admin /opt/iobroker/node_modules/iobroker.labcom/admin/style.css style.css text/css
      upload [0] labcom.admin /opt/iobroker/node_modules/iobroker.labcom/admin/words.js words.js application/javascript
      Process exited with code 0
      (3.) Kann der Adapter nach der Installation nicht gefunden werden, hilft ein Restart. Screenshot_Add_Instance.png
      Beste Grüße
      Elias
      timemachine3030 created this issue in axios/axios
      closed Hotfix: Prevent SSRF #3410
      • D3ltoroxp
        D3ltoroxp last edited by D3ltoroxp
        @100prznt Also ich habe das Teil heute zum ersten mal installiert, über Git und es hat auf Anhieb geklappt. Habe die ersten Messdaten da. Nur eins ist mir aufgefallen, das Datum von wann die Messung sein soll ist total daneben. Irgendwas mit 1970... 😬
        Hab aber allerdings die original Version genommen, die sah mir neuer aus.
        Hat denn wer eine nette Visualisierung dafür gebaut ? Oder die Daten irgendwie in Grafana eingebunden, damit man mal ein wenig sieht, wie das sich so verändert. Aussen Temp, Wasser Temp, usw. Würde mir da gern ein Diagramm dazu basteln, weiß aber noch gar nicht wie anfangen.
        100prznt 1 Reply Last reply Reply Quote 0
        • 100prznt
          100prznt @D3ltoroxp last edited by
          @d3ltoroxp sagte in Poollab / Primelab integrieren:
          Was meinst du mit "original Version"?
          Das mit dem Datum ist bekannt. Nach einem Reset wird die Uhr im PoolLAB auf 0 (1. Januar 1970, 00:00 Uhr UTC) gesetzt und erst NACH der ersten Synchronisierung mit der App korrekt gestellt. Daher haben die erstem Messungen (vor dem ersten Sync) einen falschen Zeitstempel.
          D3ltoroxp 1 Reply Last reply Reply Quote 1
          • D3ltoroxp
            D3ltoroxp @100prznt last edited by
            @100prznt Eh die von Lemonshok meinte ich. Oder die war zumindest neuer oder ? (2020) Dein Fork (2019)
            • 100prznt
              @d3ltoroxp
              Die Version von LemonShock hat den letzten Commit vom 26.06.2020. Auf diesen Stand habe ich meinen Fork aufgesetzt und den "Fehler" mit dem Datentyp korrigiert.
              Meine letzter Commit dazu ist vom 02.06.2021. (Und mein Erster vom 01.06.2021, 2019 hab ich da gar nichts gemacht 😉 )
              Hier die Historie:
              https://github.com/LemonShock/ioBroker.labcom/commits/master
              https://github.com/100prznt/ioBroker.labcom/commits/master
              Beste Grüße Elias
                JohnnyBahama last edited by JohnnyBahama
                Lässt sich bei mir leider auch nicht installieren. Der alte Adapter zieht keine Daten mehr, nachdem ich das Gerät upgedated habe.
                Nach dem x-ten Versuch ging es doch wieder.
                  steimi last edited by
                  Seit dem 2.9.2022 ab ca. 17:00 Uhr funktioniert der Abruf bei mir nicht mehr. Hat jemand das selbe Problem?
                  Anscheinend wurde was an der Cloud-Seite (API) von Labcam geändert. ?!
                  error: labcom.0 (497311) Error: Request failed with status code 405
                  Ich habe die Version 0.1.1 von @100prznt im Einsatz
                  100prznt 2 Replies Last reply Reply Quote 0
                  • 100prznt
                    100prznt @steimi last edited by
                    @steimi Ja, die LabCom Cloud wurde umgestellt. Ich gucke mal was ich machen kann.
                    • 100prznt
                      @steimi Funktioniert wieder.
                      Allerdings hat sich auch der LabCom Cloud Token geändert. Nach dem Update also einen neuen Token erzeugen und in die Adapter-Konfiguration übernehmen.
                      M 1 Reply Last reply Reply Quote 2
                      • Nashra
                        Hi, habe mal alle Datenpunkte gelöscht und neu anlegen lassen
                        Ergebnis:
                        labcom.0
                        	549294	2022-09-07 17:21:00.993	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_pH.measurement" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.993	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_Chlorine_Free.timestamp" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.991	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_Chlorine_Free.measurement" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.990	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_Chlorine_Total.timestamp" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.990	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_Chlorine_Total.measurement" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.990	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_Cyanuric_Acid.timestamp" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.990	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_Cyanuric_Acid.measurement" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.989	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_T_Alka.timestamp" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.989	info	State value to set for "labcom.0.accounts.Default_User.parameter.PL_T_Alka.measurement" has to be type "number" but received type "string"
                        labcom.0
                        	549294	2022-09-07 17:21:00.989	info	State value to set for "labcom.0.cloudaccount.lastchange" has to be type "number" but received type "string"
                        • 100prznt
                          100prznt @Nashra last edited by
                          @nashra Die Warnungen hatte ich bisher nur bei OR und UR Messungen.
                          Gucke ich mir auf jeden Fall nochmal an. Danke für den Hinweis.
                          • 100prznt
                            100prznt @100prznt last edited by
                            Läuft nun wieder, auch ohne Warnungen.
                            Messwerte werden ausschließlich als Zahl gespeichert. Bei OR und UR wird NaN an den Messwert-State übergeben.
                            Zusätzlich gibt es zu jedem Parameter einen Status State, dieser enthält eine Info ob das Ergebnis OR oder UR ist.
                            Zeitstempel werden als String gespeichert, der State ist jetzt auch vom Typ String.
                              MyMeyer @100prznt last edited by
                              @100prznt sagte in Poollab / Primelab integrieren:
                              Hallo ich habe den Token erneuert und neu im Adapter hinterlegt.
                              Bekommen aber immer noch diese Fehlermeldung:
                              labcom.0
                              2022-12-27 14:03:01.600 info Terminated (NO_ERROR): Without reason
                              labcom.0
                              2022-12-27 14:03:01.567 info cleaned everything up...
                              labcom.0
                              2022-12-27 14:03:01.563 error Error: Request failed with status code 404
                              labcom.0
                              2022-12-27 14:03:01.413 info LabCom adapter - started
                              labcom.0
                              2022-12-27 14:03:01.388 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v16.18.0, js-controller: 4.0.23
                              Woran liegt das ?
                                JohnnyBahama @100prznt last edited by
                                @100prznt Hab nun auch das Update gefahren. Die oben genannten meldungen erscheinen bei mir trotzdem.
                                • 4
                                  4immerjung last edited by
                                  Bei meinem PoolLab 1.0 habe ich den Adapter 0.1.6 von URL installiert und einen neuen API-Key generiert.
                                  Im iobroker Log werden 405er Fehler angezeigt (Method Not Allowed Error for Rest API).
                                  labcom.0 2023-07-14 22:56:02.518 info Terminated (NO_ERROR): Without reason
                                  labcom.0 2023-07-14 22:56:02.463 info cleaned everything up...
                                  labcom.0 2023-07-14 22:56:02.461 error Error: Request failed with status code 405
                                  labcom.0 2023-07-14 22:56:02.105 info LabCom adapter - started
                                  labcom.0 2023-07-14 22:56:02.055 info starting. Version 0.1.6 (non-npm: 100prznt/ioBroker.labcom#a4c93f8ead24f09c21fde7aad9e96c1c4b1bb712) in /opt/iobroker/node_modules/iobroker.labcom, node: v18.16.1, js-controller: 4.0.24
                                  Viele Grüße
                                  4ij
                                  Flexer 100prznt 2 Replies Last reply Reply Quote 0
                                  • Flexer
                                    Flexer @4immerjung last edited by
                                    Wollte gerade die selbe Problematik posten.
                                    Habe auch Fehler 405. ich habe mal den Abfrageintervall verlängert. Evtl hilft das?
                                    Flexer 1 Reply Last reply Reply Quote 0
                                    • Flexer
                                      Flexer @Flexer last edited by
                                      @lemonshock Hallo und guten Morgen. Betreust du noch den Adapter?
                                      Viele Grüsse Flexer
                                      • 100prznt
                                        100prznt @4immerjung last edited by
                                        @4immerjung Mit was für einem Intervall pullst du denn? Hab gerade nochmal alles getestet (mit 5 Minuten Intervall), läuft jetzt eine Stunde ohne Probleme.
                                        Ggf. kannst du ja nochmal einen neuen LabCom API Token erstellen.
                                        Beste Grüße Elias
                                        Flexer 4 2 Replies Last reply Reply Quote 0
                                        • Flexer
                                          Flexer @100prznt last edited by
                                          @100prznt Hatte den Adapter von git gezogen und der war standardmäßig auf 1 minute eingestellt. Hab das jetzt auf einmal alle 10 minuten gestellt.
                                          • 4
                                            4immerjung @100prznt last edited by
                                            @100prznt Ich hatte anfangs auch die 1 min. Standardintervall. Habe es heute auf 10 min. erhöht und bekomme die Werte. Sehr super! Danke!
                                            adapter chlor iobroker ph wert poollab primelab
                                            21
                                            106
                                            11865
