    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    • David G.
      David G. last edited by
      bei mir mag er das irgendwie nicht installieren.
      pi@pi:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
      Detected operating system as raspbian/bullseye.
      Checking for curl...
      Detected curl...
      Checking for gpg...
      Detected gpg...
      Running apt-get update... done.
      Installing apt-transport-https... done.
      Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.Importing packagecloud gpg key... done.
      The repository is setup! You can now install packages.
      pi@pi:~ $ sudo apt update                                          Ign:1 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Err:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
        404  Not Found [IP: 54.183.164.179 443]
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists... Done
      E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      pi@pi:~ $ sudo apt install speedtest
      Building dependency tree... Done
      E: Unable to locate package speedtest
      pi@pi:~ $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      GNU nano 5.4  /etc/apt/sources.list.d/nodesource.list            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nod>deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb>
        Thomas Braun Most Active @David G. last edited by
        @david-g
        uname -a
        cat /etc/apt/sources.list.d/nodesource.list
          Thomas Braun Most Active @David G. last edited by Thomas Braun
          @david-g
          Trag das mal so ein:
          echad@chet:~ $ cat /etc/apt/sources.list.d/ookla_speedtest-cli.list
          # this file was generated by packagecloud.io for
          # the repository at https://packagecloud.io/ookla/speedtest-cli
          deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
          deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
          echad@chet:~ $
          Also statt raspbian debian eintragen. Da ist das Installationsskript immer noch unsauber und passt nicht für Raspberry OS.
          • David G.
            David G. @Thomas Braun last edited by
            So klappt es,
            vielen Dank.
            Dann begebe ich mich nachher mal an das Skript.
            • David G.
              Habe mal eine ganz allgemeine Frage zum Skript.
              Die Datenpunkte werden ja im javascript.0 angelegt.
              Jetzt hab ich hier schon ein paar mal gelesen, dass man für eigene Datenpunkte eher den userdata.0 bevorzugen soll.
              Macht das für so ein Skript auch mehr Sinn?
                A Former User @David G. last edited by A Former User
                @david-g eigene Datenpunkte unter 0_userdata.0 haben den Vorteil, dass wenn du z.Bsp. die Javascript-Instanz loeschen wuerdest deine Datenpunkte erhalten bleibn, incl. History.. daher wenn moeglich, immer eigene Datenpunkte in userdata anlegen.
                Zeile 28 dann anstatt
                var datenpunkt = "Speedtest.";
                in
                var datenpunkt = "0_userdata.0.Speedtest.";
                • David G.
                  Habt ihr auch, dass das Skript mehrfach läuft, wenn ihr Änderungen vorgenommen habt?
                  Hatte 1-2 mal den shedule geändert und ein paar Server getestet.
                  Als die Testergebnisse dann viel zu gering waren habe ich im Log (und der History) gesehen, dass der Test innerhalb einer Sekunde 8 mal gestartet wird, regelmäßig.
                  liv-in-sky Negalein 2 Replies Last reply Reply Quote 0
                    liv-in-sky @David G. last edited by
                    @david-g starte die javascript instanz neu - evtl hängt da noch was im system
                    • Negalein
                      Negalein Global Moderator @David G. last edited by
                      @david-g sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                      Ja, gibt dazu ein Issue!
                      Häng dich dort auch ran.
                        guergen @Negalein last edited by guergen
                        Ich kann den Schlüssel nicht importieren:
                        +-▒▒{▒ϓ▒▒ N#9▒Z▒▒▒u▒T▒  ▒▒▒+▒}▒L▒(
                        ▒O;}▒yC^▒6▒MCl3▒▒▒GC▒ﵨ?a▒▒▒4▒▒▒~▒▒4ȻH.7▒.d▒*-bash: Syntaxfehler beim unerwarteten Symbol »|«
                        iob@iob:~$ PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTY
                        Danach kommt folgende Meldung:
                        iob@iob:~$ sudo apt update
                        OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                        OK:2 http://ftp.de.debian.org/debian bullseye InRelease
                        OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                        OK:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
                        Holen:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease [24,5 kB]
                        Fehl:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                        Paketlisten werden gelesen… Fertig
                        W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                        E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease« ist nicht signiert.
                        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                        iob@iob:~$
                        Schreibe ich das in eine Zeile
                        iob@iob:~$ curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor~ | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                        Bekomme ich folgende Meldung:
                        Ungültige Option "--dearmor~"
                        (23) Failed writing body
                        Wo steckt der Fehler?
                          Thomas Braun Most Active @guergen last edited by
                          @guergen sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                          --dearmor~
                          Muss
                          --dearmor
                          lauten.
                            guergen @Thomas Braun last edited by
                            @thomas-braun Hmmmh... Endet auch in einem PuTTYPuTTY....
                              Thomas Braun Most Active @guergen last edited by Thomas Braun
                              @guergen
                              Hä?
                              curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                              Eingeben, vollständige Ein- und Ausgaben posten.
                                guergen @Thomas Braun last edited by guergen
                                @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                iob@iob:~$ curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                                `eO▒A▒▒ ~▒▒▒>▒▒▒▒0y6k▒▒▒y▒▒▒8▒#▒▒n▒▒-▒ޕ▒ޢz▒SYQ▒S▒▒▒▒▒▒▒▒▒▒\▒Ne5N▒▒▒o▒▒,K}▒▒▒▒7z lw▒ھ▒|▒▒k▒U▒▒▒x▒8▒E▒X͚▒z^▒gv▒8▒▒▒@J▒F▒8▒EǞP▒▒i'▒▒▒▒Q▒x▒~>X4�"A▒▒
                                ▒▒▒1▒▒▒5▒X▒▒▒,w▒▒▒R|▒Ɩq/▒▒▒s▒ՀMk3▒}8}▒*▒▒▒h▒ZX▒▒G▒▒▒▒"
                                ▒▒os+h 1N▒ۙ▒▒▒ʔ▒w▒_s▒▒▒B▒▒!▒▒ÿ▒▒▒▒▒▒▒▒[X)vz▒▒▒▒▒;▒[▒▒aސ▒▒▒!▒▒▒2▒畝▒=9א▒`[.▒▒+▒K▒cpp▒▒驧▒▒_▒w▒=▒▒>mk=@▒▒F▒x_▒Kcg▒▒▒▒▒▒D▒Q5'▒▒▒V▒▒▒]▒@Ji
                                r▒▒7}▒▒▒r▒▒7▒▒;▒▒uYV▒▒#-wx▒▒K▒▒;▒▒▒
                                ▒▒▒qyR#▒Sz▒8▒▒▒!▒▒▒ᝋ▒ ▒5▒phttps://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>▒N
                                8!▒%▒▒:~V▒,▒1▒9▒▒#▒▒`eO
                                        1▒9▒▒#▒▒▒▒▒H▒▒=i▒%▒▒8|▒▒T1h▒▒▒Ks'▒▒0▒e▒"▒m▒9▒▒Y;҅▒ġRq▒T▒r▒euڦ#Źʶ▒▒▒▒/▒▒▒▒▒&▒姑▒4ya▒▒B▒sA▒▒y▒T[▒b▒▒@▒e▒▒▒#*% S▒
                                ▒V
                                ▒▒2▒v}▒▒J-J▒▒? ▒.▒~▒▒b▒W▒B▒G▒▒bB▒z<▒▒▒Iȕ▒a7▒l▒▒▒R▒&4Oāu▒▒▒▒u▒▒=
                                ▒▒?▒&▒▒▒?▒֛]I▒t▒▒▒yXH+▒!▒▒t▒▒:▒▒Q▒F▒m▒0▒/▒O<▒▒H&▒▒sb▒▒▒d
        ▒▒Pa▒e}▒6▒▒U▒▒6▒▒▒▒[▒▒▒|6▒Y▒s▒▒▒▒&▒j'▒O▒▒Ht▒P▒$qo1̵L~▒0▒M▒!▒▒▒q▒,▒=-▒▒t▒▒Mf,͠▒)e▒Ę▒x▒s▒▒TK$▒▒>?aY▒)▒&▒▒▒▒▒▒▒▒▒G▒▒▒▒G▒▒ɴ▒hn▒▒P▒▒+TP▒▒.▒▒}2y        ▒,▒▒▒غ4▒"=▒
                                V▒ *ۗ[*▒a*▒▒t{cA;▒F▒6▒▒▒ǫ▒Eʡ
                                `eO▒:▒t▒#▒▒K~i▒▒▒SܫVDP▒▒W▒4*)}▒▒▒▒+3KI▒@p▒_▒▒
        ▒F˧֧▒Eu▒▒▒B=▒D▒´Gy▒v▒▒▒X▒s8▒▒.Zy▒oeh#▒▒▒▒▒R$▒▒(
                                ."▒c▒▒▒Q▒!SRjӣ▒▒0▒PP1EF▒▒H▒z2i'p▒V▒▒▒[>▒o▒Hw▒wat▒▒~?▒l)▒▒{t▒U~▒$▒)FC▒▒@▒▒r▒W▒▒▒1▒&▒e▒7▒ݡ▒▒W(J▒ `X▒U▒▒▒▒{m▒}▒@▒p▒▒▒▒4▒й▒N%1▒▒@0x`#
                                ▒▒▒I3JA▒▒▒▒~▒▒L؈▒▒@)M؟3▒eNR~P▒c>9▒`0p▒▒▒"{▒▒▒▒)▒▒@▒▒
                                ▒�,▒▒▒▒+▒?▒▒:جw▒▒▒▒ld▒Ќ▒?´▒▒~BB▒ih▒D▒▒/▒▒V▒?s▒x▒▒D▒▒▒▒▒▒!▒)▒M▒֛'▒#_V▒7W▒▒▒zXyM'I(        H▒.!.▒F▒▒▒LZ▒\▒l{-O▒▒V▒z▒
                                 !▒%▒▒:~V▒,▒1▒9▒▒#▒▒`eO 1▒9▒▒#▒▒▒t
                                !▒7▒▒▒&▒▒"'▒a«▒mW`eO
                                        ▒a«▒mW+▒}V▒▒▒▒▒▒"}▒|Huw▒▒▒;&u;▒▒▒▒n1u▒▒▒▒B▒D▒▒▒▒Hi▒.▒&XjV▒~e_▒▒f^G▒▒▒]-▒▒
                                4r}▒▒OVӒ^'▒     Խ▒▒▒▒:)4\▒h▒▒▒Ϝ▒▒d▒Ҥ▒Yh▒▒1      ▒`▒▒▒▒b▒▒▒▒t▒TP▒d▒▒Yg^▒▒▒gB▒"Ļu a▒▒F^▒"▒=▒u▒;▒▒|n▒Y▒▒۬t5
        R▒▒V▒▒▒▒t▒▒▒▒▒▒V)=▒.▒xAA.r(3▒▒▒?▒▒?_d▒▒▒▒6▒▒▒▒▒▒V▒▒L▒▒ ▒V▒H▒l▒
                                ▒(▒Rּ▒/▒▒=▒^}▒▒$~ܪ▒C!Zw ▒▒TL▒▒g▒▒▒P▒[5k▒ ▒▒▒▒▒▒7[pk$H▒%E▒f▒U▒+▒▒)▒|叆▒춑▒\z.▒▒r▒▒װRШ▒B{t▒5▒▒t▒v;"▒5qI▒ TD▒f4▒▒á▒G▒▒▒r▒▒s▒▒▒=W▒h▒0Xi▒=^<;e▒▒▒S->▒▒▒0}Yk▒▒C▒i▒tr▒!▒Ώ▒▒▒m▒{▒t)ÛS▒▒  ▒▒▒ʯWaf▒r▒▒~z▒▒▒▒;▒▒,▒▒▒▒xd▒t▒▒QL▒²▒▒▒g9▒b^▒▒T▒▒x)▒%
                                ▒▒▒`▒&▒F▒▒$л▒▒g{▒l▒▒@▒+^G/@▒ݗ▒▒▒▒▒▒O▒cmG▒Q8{%▒▒>▒o▒a▒▒c5▒nTC{Ap▒h▒≈ɪ▒▒x▒B▒▒@(▒▒"▒Ƒ▒▒"▒$▒p▒▒▒▒▒i;`▒▒▒▒@▒W▒vgA▒-lBW▒8▒▒q▒▒(;▒▒▒۴զ▒is-▒▒▒▒^k▒^#u<▒y<▒▒▒)▒9▒I▒/▒l][▒ݱ~a"%{*Z▒
                                챔▒▒▒R▒y▒▒_▒▒9u[2▒▒▒j▒▒▒`▒▒/
                                ▒O;}▒yC^▒6▒MCl3▒▒▒GC▒ﵨ?a▒▒▒4▒▒▒~▒▒4ȻH.7▒.d▒*iob@iob:~$ PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTY^C
                                ▒V
                                Kann ich nur mit StRg "C" abbrechen
                                • SKB
                                  SKB Developer Most Active @guergen last edited by SKB
                                  @guergen Schau mal, ob dein Zeichensatz in Putty passt. Sieht mir schwer danach aus, als wenn dieser nicht stimmt 🙂
                                  https://seeseekey.net/archive/110592/#:~:text=Stattdessen muss bei PuTTY gesucht werden.&text=Um das Problem zu beheben,fehlerhaften Zeichen der Vergangenheit an.
                                    guergen @SKB last edited by guergen
                                    @skb Steht auf UTF-8
                                    Egtl. Richtig...
                                    Mit Iso-8859-15 wird es auch nicht besser
                                    Hat keiner eine Idee?
                                      @guergen
                                      locale
                                      sagt?
                                        iob@iob:~$ locale
                                        LANG=de_DE.UTF-8
                                        LANGUAGE=
                                        LC_CTYPE="de_DE.UTF-8"
                                        LC_NUMERIC="de_DE.UTF-8"
                                        LC_TIME="de_DE.UTF-8"
                                        LC_COLLATE="de_DE.UTF-8"
                                        LC_MONETARY="de_DE.UTF-8"
                                        LC_MESSAGES="de_DE.UTF-8"
                                        LC_PAPER="de_DE.UTF-8"
                                        LC_NAME="de_DE.UTF-8"
                                        LC_ADDRESS="de_DE.UTF-8"
                                        LC_TELEPHONE="de_DE.UTF-8"
                                        LC_MEASUREMENT="de_DE.UTF-8"
                                        LC_IDENTIFICATION="de_DE.UTF-8"
                                        LC_ALL=
                                        iob@iob:~$
                                          m0uh last edited by m0uh
                                          code_textpi@raspberrypi:~ $ sudo apt update
                                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                          Hit:3 https://phoscon.de/apt/deconz buster InRelease
                                          Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                                          Hit:5 https://apt.hyperion-project.org buster InRelease
                                          Hit:6 https://repos.influxdata.com/debian buster InRelease
                                          Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease
                                          Hit:8 https://archive.raspbian.org/raspbian bullseye InRelease
                                          Hit:9 https://www.pivccu.de/piVCCU testing InRelease
                                          Ign:10 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                                          Err:11 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                                            404  Not Found [IP: 2600:1f1c:2e5:6901:914d:db70:ee4c:8e5f 443]
                                          pi@raspberrypi:~ $ sudo apt install speedtest
                                          pi@raspberrypi:~ $
                                          Scheinbar gibts kein File mehr über den Paketmanager? Any idea?
                                          EDIT:
                                          Hab mal in der sourceliste aus raspian -> debian gemacht und schon funktionierts
                                            Thomas Braun Most Active @m0uh last edited by Thomas Braun
                                            @m0uh
                                            Da ist auch sonst Chaos drin.
                                            Nie Releases mischen. Entweder ist das Buster oder Bullseye.
                                            Wenn das da jetzt bei dir ein 'Bullseye / Debian 11' ist
                                            (Prüfen mit
                                            cat /etc/debian_version
                                            stell das mit den drei Zeilen alles richtig:
                                            sudo sed -i 's/bullseye\/updates/bullseye-security/g' /etc/apt/sources.list
                                            sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
                                            sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*
                                            391
                                            72615
