    4. Test Netatmo 2.0.0 Alpha (GitHub)
    • Hot-Air-Balloon
      Hot-Air-Balloon @apollon77 last edited by Hot-Air-Balloon
      @apollon77 said in Test Netatmo 2.0.0 Alpha (GitHub):
      6.2.14 o
      I'm ready 4 testing 🙂
      Edit: Gefunden ...
      Die Daten sehen erstmal gut aus, ich blätter mal durch die Objekte.
      Kurzer Auszug:
      https://i.imgur.com/lOuZHsP.png
      https://i.imgur.com/lQEa2gb.png
      Authentifizierung muss ich noch testen
      Edit:
      netatmo.0
      	2022-09-07 19:08:20.044	info	Successfully authenticated with Netatmo with individual client-ID 62xxxx146
      netatmo.0
      	2022-09-07 19:08:19.845	info	Authenticating with Netatmo using individual client-ID 62xxxx146
      netatmo.0
      	2022-09-07 19:08:19.843	info	Using stored tokens to initialize ... {"access_token":"53xxxe59|8e6xxxx4e2","refresh_token":"53xxxxe59|4c0xxxxa192","scope":"read_station","client_id":"62xxx146"}
      netatmo.0
      	2022-09-07 19:08:19.805	info	starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
      netatmo.0
      	2022-09-07 19:08:14.412	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      netatmo.0
      	2022-09-07 19:08:14.409	info	terminating
      netatmo.0
      	2022-09-07 19:08:14.408	info	cleaned everything up...
      netatmo.0
      	2022-09-07 19:08:14.406	info	Got terminate signal TERMINATE_YOURSELF
      netatmo.0
      	2022-09-07 19:08:04.555	info	Successfully authenticated with Netatmo with individual client-ID 62xxxx146
      netatmo.0
      	2022-09-07 19:08:04.360	info	Authenticating with Netatmo using individual client-ID 62xxxx146
      netatmo.0
      	2022-09-07 19:08:04.358	info	Using stored tokens to initialize ... {"access_token":"53xxxx2e59|8e6xxxxb4e2","refresh_token":"53xxxxx2e59|4c0xxxx192","scope":"read_station","client_id":"62xxxx146"}
      netatmo.0
      	2022-09-07 19:08:04.320	info	starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
      netatmo.0
      	2022-09-07 19:07:59.366	error	DB closed
      netatmo.0
      	2022-09-07 19:07:59.365	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:757:14)
      netatmo.0
      	2022-09-07 19:07:59.355	error	unhandled promise rejection: DB closed
      netatmo.0
      	2022-09-07 19:07:59.354	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      netatmo.0
      	2022-09-07 19:07:58.836	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      netatmo.0
      	2022-09-07 19:07:58.834	info	terminating
      netatmo.0
      	2022-09-07 19:07:58.832	info	cleaned everything up...
      netatmo.0
      	2022-09-07 19:07:58.831	info	Got terminate signal TERMINATE_YOURSELF
      netatmo.0
      	2022-09-07 19:07:58.794	info	Update data in adapter configuration ... restarting ...
      netatmo.0
      	2022-09-07 19:07:58.792	info	Save OAuth data: {"access_token":"53xxxxx4e2","refresh_token":"53xxxxe59|4c0xxxxa192","scope":"read_station","client_id":"62xxx146"}
      Bin mir nicht sicher, ob das alles passt, aber cih habe beim Authentifizieren zumindest keine Fehlermeldung bekommen.
      Wenn ich noch was spezielles testen soll. Gerne melden !
        apollon77 @Hot-Air-Balloon last edited by
        @hot-air-balloon cool. Bitte einfach schauen ob alles tut wie es soll. Daten so aktualisiert werden wie es soll und. So. Und keine Fehler kommen. ;-)) nur ne “Station“ ist so bissl der easy Case 😉
        Hot-Air-Balloon 1 Reply Last reply Reply Quote 0
        • Hot-Air-Balloon
          Wenn du mir weitere Aktoren Sponsorst kann ich die auch testen 😄
          Ich melde mich, ob mir was auffällt.
            @hot-air-balloon hehe ... Danke!
              mrjeschke @apollon77 last edited by
              @apollon77
              Erster Eindruck: Perfekt👍
              Ich habe nur die Wetterstation, die läuft aber ohne Auffälligkeiten.
              • JohGre
                JohGre last edited by
                @apollon77 Soweit mal alles klar. Daten werden geholt. Habe die Station mit Außenmodul und zusätzliche 3 Innenmodule sowie Regen- und Windsensor.
                • JohGre
                  JohGre last edited by JohGre
                  @apollon77 Hatte eben den ersten Absturz des Adapters, läuft aber weiter. Soll ich den Loglevel auf Info stellen, derzeit bin ich nur im warn unterwegs.
                  2022-09-08 14:39:22.960 - error: netatmo.0 (19841) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2022-09-08 14:39:22.960 - error: netatmo.0 (19841) unhandled promise rejection: homesdata error: No response
                  2022-09-08 14:39:22.962 - error: netatmo.0 (19841) Error: homesdata error: No response
                  at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:98:19)
                  at Request._callback (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:1126:25)
                  at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                  at Request.emit (node:events:513:28)
                  at Request.emit (node:domain:489:12)
                  at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
                  at ClientRequest.emit (node:events:525:35)
                  at ClientRequest.emit (node:domain:489:12)
                  at TLSSocket.socketErrorListener (node:_http_client:481:9)
                  at TLSSocket.emit (node:events:513:28)
                  2022-09-08 14:39:22.963 - error: netatmo.0 (19841) homesdata error: No response
                  2022-09-08 14:39:22.974 - warn: netatmo.0 (19841) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2022-09-08 14:39:33.072 - error: host.VM-Slave Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                  2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: Error: homesdata error: No response
                  2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:98:19)
                  2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:1126:25)
                  2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                  2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.emit (node:events:513:28)
                  2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.emit (node:domain:489:12)
                  2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
                  2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at ClientRequest.emit (node:events:525:35)
                  2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at ClientRequest.emit (node:domain:489:12)
                  2022-09-08 14:39:33.077 - error: host.VM-Slave Caught by controller[1]: at TLSSocket.socketErrorListener (node:_http_client:481:9)
                  2022-09-08 14:39:33.077 - error: host.VM-Slave Caught by controller[1]: at TLSSocket.emit (node:events:513:28)
                  2022-09-08 14:39:33.077 - error: host.VM-Slave instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    Shadowhunter23 last edited by
                    Installiert, soweit keine Probleme.
                    Innen-, Außen- und Regensensor
                    • O
                      oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                      @apollon77
                      Ich habe vier Stationen...
                        apollon77 @JohGre last edited by
                        @johgre bitte nochmal von github updaten. Da gab es mal keinen response. Da hatte ich gestern Abend noch was gefixt.
                          apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
                          @ofbeqnpolkkl6mby5e13 und auch alles ok? Ist die Objekt Struktur auch sinnvoll so wie Sie jetzt ist?
                          O 2 Replies Last reply Reply Quote 0
                          • O
                            @apollon77
                            Gute Frage, es wäre ein riesen Aufwand, die ganzen Aliase anzupassen, bei so vielen Modulen...
                            Müsste mir erst wieder ein Testsystem erstellen...
                            Im Moment leider wenig Zeit...
                            • O
                              oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
                              @apollon77
                              Puh... wenn man zwei Module mit der Bezeichnung Badezimmer hat, weiß man jetzt nicht mehr, welches welches ist (Obergeschoss, Erdgeschoss)... es muss unbedingt erst nach Station unterschieden werden!
                              Und das crashed nach dem Konfigurieren:
                              2022-09-08 22:44:35.676  - info: netatmo.0 (3932) starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo#4fc7576c43e782e34bf464b63196a4af85a242d1) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
                              2022-09-08 22:44:35.722  - info: netatmo.0 (3932) Authenticating with Netatmo using individual client-ID xxx
                              2022-09-08 22:44:35.724  - warn: netatmo.0 (3932) API Error: Please Authenticate manually once using the Admin UI of this instance.
                              2022-09-08 22:47:26.586  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                              2022-09-08 22:47:31.624  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                              2022-09-08 22:47:36.631  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                              2022-09-08 22:47:41.691  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                              2022-09-08 22:47:53.588  - info: netatmo.0 (3932) Successfully authenticated with Netatmo with individual client-ID xxx
                              2022-09-08 22:47:53.597  - info: netatmo.0 (3932) Save OAuth data: {"access_token":"xxx","refresh_token":"xxx","scope":"read_station","client_id":"xxx"}
                              2022-09-08 22:47:53.623  - info: netatmo.0 (3932) Update data in adapter configuration ... restarting ...
                              2022-09-08 22:47:53.659  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 (force=false, process=true)
                              2022-09-08 22:47:53.668  - info: netatmo.0 (3932) Got terminate signal TERMINATE_YOURSELF
                              2022-09-08 22:47:53.667  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 send kill signal
                              2022-09-08 22:47:53.671  - info: netatmo.0 (3932) cleaned everything up...
                              2022-09-08 22:47:53.673  - info: netatmo.0 (3932) terminating
                              2022-09-08 22:47:53.677  - info: netatmo.0 (3932) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-09-08 22:47:54.196  - warn: netatmo.0 (3932) Could not perform strict object check of state netatmo.0.5e85b1dc9da0e8304e2becfc.70-ee-50-06-97-ea.Temperature.TemperatureMin: DB closed
                              2022-09-08 22:47:54.197  - warn: netatmo.0 (3932) get state error: Connection is closed.
                              2022-09-08 22:47:54.200  - error: netatmo.0 (3932) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2022-09-08 22:47:54.201  - error: netatmo.0 (3932) unhandled promise rejection: DB closed
                              2022-09-08 22:47:54.572  - error: netatmo.0 (3932) Error: DB closed
                                  at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                  at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                  at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40)
                                  at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
                              2022-09-08 22:47:54.573  - error: netatmo.0 (3932) DB closed
                              2022-09-08 22:47:54.673  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 killing pid 3932
                              2022-09-08 22:47:54.688  - info: host.iobroker-test instance system.adapter.netatmo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-09-08 22:47:56.703  - info: host.iobroker-test instance system.adapter.netatmo.0 started with pid 4117
                              2022-09-08 22:47:58.928  - info: netatmo.0 (4117) starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo#4fc7576c43e782e34bf464b63196a4af85a242d1) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
                              2022-09-08 22:47:58.985  - info: netatmo.0 (4117) Using stored tokens to initialize ... {"access_token":"xxx","refresh_token":"xxx","scope":"read_station","client_id":"xxx"}
                              2022-09-08 22:47:58.987  - info: netatmo.0 (4117) Authenticating with Netatmo using individual client-ID xxx
                              2022-09-08 22:47:59.245  - info: netatmo.0 (4117) Successfully authenticated with Netatmo with individual client-ID xxx
                                @ofbeqnpolkkl6mby5e13 Ok, dann bitte vollständiges Debug Log mir per E-Mails senden und genau beschreiben was das issue ist.
                                An Sich sollte die struktur homeID.moduleId.weiteres sein, damit sollte an sich doch jede Station ne andere Module die haben oder? Früher war es doch dann aber schlimmer weil früher alle "Badezimmer" in eins geworfen wurden und damit hattest Du doch gar keine unterscheidung oder?
                                Zu dem "crash" ... Am ENde kein Crash sondern ein restart nach Konfigänderung. ja der DB fehler ist anzusehen
                                • O
                                  @apollon77
                                  Bisher:
                                  Alt
                                  v2.0.0
                                  Neu
                                    @ofbeqnpolkkl6mby5e13 ja ok ist mehr. Über die Objektnamens hast du das gleiche ja. Wo waren denn Module wie Nordseite und so bisher? Nur unter Haus. Richtig?
                                    • O
                                      @apollon77
                                      Nein, die sind unter den zugehörigen Stationen.
                                      Unter Haus ist nichts Brauchbares:
                                      Vielleicht sollte ich das näher erklären, da du selbst ja keine Station besitzt:
                                      Pro Station können maximal 3 Innenmodule, 1 Außenmodul, 1 Windmesser und 1 Regenmesser angeschlossen werden. Wenn man also mehr als 3 zusätzliche Innenmodule benötigt (die Stationen selbst dienen auch als Innenmodul!), dann braucht man eine weitere Station, die nun wieder u. a. auch ein Außenmodul mitbringt. Daher Nord- und Südseite.
                                      Bei der neuen Struktur kann man nun nicht mehr erkennen, zu welchen Stationen z. B. Badezimmer gehört.
                                        @ofbeqnpolkkl6mby5e13 ok. Damit volles debug log bitte. Muss schauen wie das auf der datenebene aussieht.
                                          Schimi last edited by Schimi
                                          Ich finde die Ordnerstruktur besser als vorher... Gerade wen man mal die Bezeichnung ändert sollte es nun ja trotzdem "gleich" bleiben 🙂
                                          Da ich noch nicht "klingeln" darf (die kleine schläft 🙂 ), kann ich nur dazusagen das der Name der Klingel nicht übernommen wird?
                                          edit
                                          Bekomme das im Log... vielleicht liegt da der Fehler beim "Namen"
                                          netatmo.0
                                          2022-09-11 15:35:05.075	warn	Object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                          apollon77 2 Replies Last reply Reply Quote 0
                                          • JohGre
                                            Bei mir läuft der Adapter nun seit 4 Tagen ohne Probleme. Finde auch das die Ordnerstruktur besser ist. War zwar einmal etwas Aufwand bzgl. der Scripte anpassen, aber halb so wild. Jetzt ist ja dann Ruhe damit.
                                            31.7k
                                            79.8k
                                            100
                                            7785
