    4. [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana
      dering @Smidl last edited by dering
        ChristianK last edited by
        PVAnzeige.png Irgend etwas stimmt hier doch nicht. Warum bekomm ich einen - Hausverbrauch?
          Chris87 @ChristianK last edited by
          @christiank
          Servus,
          Setz den wert mal auf "Unsigned 16bit (Big Endian), dann sieht es schon anders aus 😉
          / Chris
            ChristianK @Chris87 last edited by
            @chris87Danke 🙂 oh man... das wars. Im SolarEdge Modbus Regsiter Mapping steht int16.
            Gibts ein Register für die LG Batterie?
              Chris87 last edited by Chris87
              hier mal meine Liste (alle SF Umrechnungen enthalten, keine seperate Umrechnung notwendig) :
              _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
              102787	Batterie_Gesamtleistung		Wh	floatsw	2	1	0		level		true	false	false	false
              102833	Batterie_Volt		V	floatsw	2	1	0		level		true	false	false	false
              102835	Batterie_Ampare		A	floatsw	2	1	0		level		true	false	false	false
              102837	Leistung_Batterie		W	floatsw	2	1	0		value		true	false	false	false
              102851	Batt_SOH		%	floatsw	2	1	0		value		true	false	false	false
              102853	Batterieladestand		%	floatsw	2	1	0		level		true	false	false	false
              103237	Storage_Control_Mode_RW	0 – Disabled,1 – Maximize Self Consumption, 4 – Remote Control –		uint16be	1	1	0		level		true	false	false	false
              103238	Storage_AC_Charge_Policy_RW	0 – Disable, 1 – Always allowed , 2 – Fixed Energy Limit –		uint16be	1	1	0		level		true	false	false	false
              103241	Storage_Backup_Reserved_Setting_RW			floatsw	2	1	0		level		true	false	false	false
              103243	Storage_Charge_Discharge_Default_Mode_RW 	0Off, 1Charge excess PV power only, 2Charge from PV first, before producing power to the AC., 3Charge from PV+AC according to the max battery power., 4Maximize export – discharge battery to meet max inverter AC limit, 5Discharge to meet loads consumption. Discharging to the grid is not allowed., 7Maximize self-consumption		uint16be	1	1	0		level		true	false	false	false
              103244	Remote_Control_Command_Timeout_RW		Sec	uint32sw	2	1	0		level		true	false	false	false
              103246	Remote_Control_Command_Mode_RW			uint16be	1	1	0		level		true	false	false	false
              103247	Remote_Control_Charge_Limit_RW		W	floatsw	2	1	0		level		true	false	false	false
              103249	Remote_Control_Command_Discharge_Limit_RW		W	floatsw	2	1	0		level		true	false	false	false
              40001	C_SunSpec_ID	"Wert = ""SunS"" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte"		uint32be	2	1	0		value		true	false	false
              40003	C_SunSpec_DID	Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“		uint16be	1	1	0		value		true	false	false
              40004	C_SunSpec_Länge	65 = Länge eines Blocks in 16-bit Registern		uint16be	1	1	0		value		true	false	false
              40005	C_Hersteller	"Bei SunSpec eingetragener Wert = ""SolarEdge"""		string	16	1	0		value		true	false	false
              40021	C_Modell	Spezifischer SolarEdge Wert		string	16	1	0		value		true	false	false
              40045	C_Version	Spezifischer SolarEdge Wert		string	8	1	0		value		true	false	false
              40053	C_Seriennummer	Eindeutiger SolarEdge Wert		string	16	1	0		value		true	false	false
              40069	C_Geräteadresse	Modbus-ID der entsprechenden Einheit		uint16be	1	1	0		value		true	false	false
              40070	C_SunSpec_DID	101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig		uint16be	1	1	0		value		true	false	false
              40071	C_SunSpec_Länge	50 = Länge des Modellblocks	Register	uint16be	1	1	0		value		true	false	false
              40072	I_AC_Strom	AC-Gesamtstromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])	value		true	false	false	false
              40073	I_AC_StromA	AC-Phase A (L1) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])	value		true	false	false	false
              40074	I_AC_StromB	AC-Phase B (L2) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])	value		true	false	false	false
              40075	I_AC_StromC	AC-Phase C (L3) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])	value		true	false	false	false
              40076	I_AC_Strom_SF	AC-Strom Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40077	I_AC_SpannungAB	AC-Spannung Phase AB (L1-L2) Wert	V	uint16be	1	1	0	x * Math.pow(10, sf['40083'])	value		true	false	false	false
              40078	I_AC_SpannungBC	AC-Spannung Phase BC (L2-L3) Wert	V	uint16be	1	1	0	x * Math.pow(10, sf['40083'])	value		true	false	false	false
              40079	I_AC_SpannungCA	AC-Spannung Phase CA (L3-L1) Wert	V	uint16be	1	1	0	x * Math.pow(10, sf['40083'])	value		true	false	false	false
              40080	I_AC_SpannungAN	AC-Spannung Phase A-N (L1-N) Wert	V	uint16be	1	1	0	x * Math.pow(10, sf['40083'])	value		true	false	false	false
              40081	I_AC_SpannungBN	AC-Spannung Phase B-N (L2-N) Wert	V	uint16be	1	1	0	x * Math.pow(10, sf['40083'])	value		true	false	false	false
              40082	I_AC_SpannungCN	AC-Spannung Phase C-N (L3-N) Wert	V	uint16be	1	1	0	x * Math.pow(10, sf['40083'])	value		true	false	false	false
              40083	I_AC_Spannung_SF	AC-Spannung Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40084	I_AC_Leistung	AC-Leistungswert	W	uint16be	1	1	0	x * Math.pow(10, sf['40085'])	value		true	false	false
              40085	I_AC_Leistung_SF	AC-Leistung Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40086	I_AC_Frequenz	Frequenzwert	Hz	uint16be	1	1	0	x * Math.pow(10, sf['40087'])	value		true	false	false	false
              40087	I_AC_Frequenz_SF	Frequenz Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40088	I_AC_VA	Scheinleistung	VA	uint16be	1	1	0	x * Math.pow(10, sf['40089'])	value		true	false	false
              40089	I_AC_VA_SF	Scheinleistung Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40090	I_AC_VAR	Blindleistung	VAR	uint16be	1	1	0	x * Math.pow(10, sf['40091'])	value		true	false	false
              40091	I_AC_VAR_SF	Blindleistung Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40092	I_AC_PF	Leistungsfaktor	%	uint16be	1	1	0	x * Math.pow(10, sf['40093'])	value		true	false	false
              40093	I_AC_PF_SF	Leistungsfaktor Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40094	I_AC_Energie_WH	AC Gesamt-Energieproduktion	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40096'])	value		true	false	false
              40096	I_AC_Energie_WH_SF	AC Gesamtenergie Skalierungsfaktor		uint16be	1	1	0		value		true	false	false	true
              40097	I_DC_Strom	DC-Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40098'])	value		true	false	false
              40098	I_DC_Strom_SF	DC-Strom Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40099	I_DC_Spannung	DC-Spannungswert	V	uint16be	1	1	0	x * Math.pow(10, sf['40100'])	value		true	false	false	false
              40100	I_DC_Spannung_SF	DC-Spannung Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40101	I_DC_Leistung	DC-Leistungswert	W	uint16be	1	1	0	x * Math.pow(10, sf['40102'])	value		true	false	false
              40102	I_DC_Leistung_SF	DC-Leistung Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40104	I_Temp_Kühler	Kühlkörpertemperatur	°C	uint16be	1	1	0	x * Math.pow(10, sf['40107'])	value		true	false	false	false
              40107	I_Temp_SF	Kühlkörpertemperatur Skalierungsfaktor		int16be	1	1	0		value		true	false	false	true
              40108	I_Status	Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup)		uint16be	1	1	0		value		true	false	false	false
              40109	I_Status_Anbieter	Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup		uint16be	1	1	0		value		true	false	false	false
              40122	meter_C_SunSpec_DID	Value = 0x0001. Uniquely identifies this as a SunSpec Common Model Block		uint16be	1	1	0		value		true	false
              40123	meter_C_SunSpec_Length	65 = Length of block in 16-bit registers		uint16be	1	1	0		value		true	false
              40124	meter_C_Manufacturer	Meter manufacturer		string	32	1	0		value		true	false
              40140	meter_C_Model	Meter model		string	32	1	0		value		true	false
              40156	meter_C_Option	Export + Import, Production, consumption,		string	16	1	0		value		true	false
              40164	meter_C_Version	Meter version		string	16	1	0		value		true	false
              40172	meter_C_SerialNumber	Meter SN		string	32	1	0		value		true	false
              40188	meter_C_DeviceAddress	Inverter Modbus ID		uint16be	1	1	0		value		true	false
              40189	meter_C_SunSpec_DID	Well-known value. Uniquely identifies this as a SunSpecMODBUS Map: Single Phase (AN or AB) Meter (201) Split Single Phase (ABN) Meter (202) Wye-Connect Three Phase (ABCN) Meter (203) Delta-Connect Three Phase (ABC) Meter(204)		uint16be	1	1	0		value		true	false
              40190	meter_C_SunSpec_Length	Length of meter model block		uint16be	1	1	0		value		true	false
              40191	meter_M_AC_Current	AC Current (sum of active phases)	A	int16be	1	1	0	x * Math.pow(10, sf['40195'])	value		true	false	false	false
              40192	meter_M_AC_Current_A	Phase A AC Current	A	int16be	1	1	0	x * Math.pow(10, sf['40195'])	value		true	false	false	false
              40193	meter_M_AC_Current_B	Phase B AC Current	A	int16be	1	1	0	x * Math.pow(10, sf['40195'])	value		true	false	false	false
              40194	meter_M_AC_Current_C	Phase C AC Current	A	int16be	1	1	0	x * Math.pow(10, sf['40195'])	value		true	false	false	false
              40195	meter_M_AC_Current_SF	AC Current Scale Factor		int16be	1	1	0		value		true	false		true
              40196	meter_M_AC_Voltage_L N	Line to Neutral AC Voltage (average of active phases)	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40197	meter_M_AC_Voltage_A N	Phase A to Neutral AC Voltage	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40198	meter_M_AC_Voltage_B N	Phase B to Neutral AC Voltage	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40199	meter_M_AC_Voltage_C N	Phase C to Neutral AC Voltage	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40200	meter_M_AC_Voltage_L L	Line to Line AC Voltage (average of active phases)	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40201	meter_M_AC_Voltage_A B	Phase A to Phase B AC Voltage	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40202	meter_M_AC_Voltage_B C	Phase B to Phase C AC Voltage	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40203	meter_M_AC_Voltage_C A	Phase C to Phase A AC Voltage	V	int16be	1	1	0	x * Math.pow(10, sf['40204'])	value		true	false	false	false
              40204	meter_M_AC_Voltage_SF	AC Voltage Scale Factor		int16be	1	1	0		value		true	false		true
              40205	meter_M_AC_Freq	AC Frequency	Hz	int16be	1	1	0	x * Math.pow(10, sf['40206'])	value		true	false	false	false
              40206	meter_M_AC_Freq_SF	AC Frequency Scale Factor		int16be	1	1	0		value		true	false		true
              40207	meter_M_AC_Power	Total Real Power (sum of active phases)	W	int16be	1	1	0	x * Math.pow(10, sf['40211'])	value		true	false	false
              40208	meter_M_AC_Power_A	Phase A AC Real Power	W	int16be	1	1	0	x * Math.pow(10, sf['40211'])	value		true	false	false
              40209	meter_M_AC_Power_B	Phase B AC Real Power	W	int16be	1	1	0	x * Math.pow(10, sf['40211'])	value		true	false	false
              40210	meter_M_AC_Power_C	Phase C AC Real Power	W	int16be	1	1	0	x * Math.pow(10, sf['40211'])	value		true	false	false
              40211	meter_M_AC_Power_SF	AC Real Power Scale Factor		int16be	1	1	0		value		true	false	false	true
              40212	meter_M_AC_VA	Total AC Apparent Power (sum of active phases)	VA	int16be	1	1	0	x * Math.pow(10, sf['40216'])	value		true	false	false	false
              40213	meter_M_AC_VA_A	Phase A AC Apparent Power	VA	int16be	1	1	0	x * Math.pow(10, sf['40216'])	value		true	false	false	false
              40214	meter_M_AC_VA_B	Phase B AC Apparent Power	VA	int16be	1	1	0	x * Math.pow(10, sf['40216'])	value		true	false	false	false
              40215	meter_M_AC_VA_C	Phase C AC Apparent Power	VA	int16be	1	1	0	x * Math.pow(10, sf['40216'])	value		true	false	false	false
              40216	meter_M_AC_VA_SF	AC Apparent Power Scale Factor		int16be	1	1	0		value		true	false	false	true
              40227	meter_M_Exported	Total Exported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40229	meter_M_Exported_A	Phase A Exported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40231	meter_M_Exported_B	Phase B Exported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40233	meter_M_Exported_C	Phase C Exported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40235	meter_M_Imported	Total Imported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40237	meter_M_Imported_A	Phase A Imported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40239	meter_M_Imported_B	Phase B Imported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40241	meter_M_Imported_C	Phase C Imported Real Energy	Wh	uint32be	2	1	0	x * Math.pow(10, sf['40243'])	value		true	false	false
              40243	meter_M_Energy_W_SF	Real Energy Scale Factor		int16be	1	1	0		value		true	false	false	true
              40294	meter_M_Events	See M_EVENT_ flags. 0 = nts.		uint32be	2	1	0		value		true	false	false
              Achtung
              Die Werte mit RW am Ende sind beschreibbar und sollten mit äußerster Vorsicht behandelt werden.
              / Chris
              C D 2 Replies Last reply Reply Quote 0
                @chris87 Gibts es ne Möglichkeit deine Liste direkt in die Holding Register zu importieren?
                Was auch noch ist, mir werden in den javascripten die Einheiten nicht angezeigt, obwohl sie als Units eingetragen sind.
                C 2 Replies Last reply Reply Quote 0
                  @christiank #
                  einfach oben (TSV bearbeiten), alles was drinnen ist löschen und meinen kompletten Spoiler einfügen.
                    @christiank
                    bezüglich der Units.
                    Wie hast du die Datenpunkte erzeugt?
                    Wenn du ihn Manuell erzeugt hast, schreib einfach in die Objektdaten "unit": "W",
                    / Chris
                      ChristianK @Chris87 last edited by ChristianK
                      @chris87 Liste habe ich importiert, Danke dafür.
                      Allerdings werden jetzt meine JS anders angezeigt. Z.B. TempWechselrichter ist jetzt um 2 Kommastellen verschoben. Anstatt 50Grad stehen jetzt 0,5. Register 40101 wird mir jetzt auch als 50 Grad angeziegt, sprich ich brauch den Faktor gar nicht mehr...
                      Datenpunkte hab ich im Skript per JS erstellt. Dort ist aber unit hinterlegt, wird nur nicht übertragen.
                      Irgend etwas passt bei mir noch nicht. 40084_I_AC_Leistung sollte mir die aktuelle Sonnenenergie anzeigen.
                      SolarEdgeMonitoring zeigt mir 3,4kW an, was in Bezug auf das Wetter passt. Modbus zeigt mir 5,2KW an.
                        leo8405 @Scheuler last edited by
                        @scheuler Hallo Bernd, hast du passende Register zum Heizstab gefunden? Ich habe bis heute nichts passendes gefunden.
                        Michael
                        G C 2 Replies Last reply Reply Quote 0
                          @christiank sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
                          Hallo @ChristianK, das habe ich oben geschrieben, ich habe die Umrechnungen bereits im Modbus-Adapter gemacht.
                          Wie sieht dein JS aus, das Problem muss ja da liegen.
                          Die Eigentliche Solarleistung muss errechnet werden, 40084 zeigt dir nur die Wechselrichter-Leistung an. Du musst 40084 + 102837 rechnen, dann hast die reine PV Leistung.
                            technikaffin @Glasfaser last edited by
                            @glasfaser
                            Herzlichen Dank, diese Liste funktioniert bei mir jetzt endlich. 👯
                            Allerdings nur bis Zeile "40108 I_Status_Anbieter" inklusive, danach nicht mehr.
                            Hab einen SE9K, die restlichen Felder werden wohl nicht unterstützt und liefern beim Versuch einen Fehler.
                            Der Wert von
                            40093 I_AC_Energie_WH AC Gesamt-Energieproduktion Wh
                            stimmt auch mit dem überein was mein Sonnen Akku gemessen hat seit Beginn, passt also perfekt.
                            Ich hatte am Anfang Probleme überhaupt irgendwas auszulesen, hatte beide Offsets probiert wie im Tutorial beschrieben. So wie ich das sehe muss man aber immer von ganz vorne alle Register auslesen, sonst geht garnix.
                            Glasfaser 1 Reply Last reply Reply Quote 1
                            • Glasfaser
                              Glasfaser @technikaffin last edited by
                              @technikaffin sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
                              Danach wird der SolarEdge Zähler abgefragt und mein LG Akku .
                              Hier mal aktuell das Modbus-Register von mir.:
                              40000	C_SunSpec_ID	"Wert = ""SunS"" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte"		uint32be	2	1	0		value		true	false	false	false
                              40002	C_SunSpec_DID	Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“		uint16be	1	1	0		value		true	false	false	false
                              40003	C_SunSpec_Länge	65 = Länge eines Blocks in 16-bit Registern		uint16be	1	1	0		value		true	false	false	false
                              40004	C_Hersteller	"Bei SunSpec eingetragener Wert = ""SolarEdge"""		string	16	1	0		value		true	false	false	false
                              40020	C_Modell	Spezifischer SolarEdge Wert		string	16	1	0		value		true	false	false	false
                              40044	C_Version	Spezifischer SolarEdge Wert		string	8	1	0		value		true	false	false	false
                              40052	C_Seriennummer	Eindeutiger SolarEdge Wert		string	16	1	0		value		true	false	false	false
                              40068	C_Geräteadresse	Modbus-ID der entsprechenden Einheit		uint16be	1	1	0		value		true	false	false	false
                              40069	C_SunSpec_DID	101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig		uint16be	1	1	0		value		true	false	false	false
                              40070	C_SunSpec_Länge	50 = Länge des Modellblocks	Register	uint16be	1	1	0		value		true	false	false	false
                              40071	I_AC_Strom	AC-Gesamtstromwert	A	uint16be	1	1	0		value		true	false	false	false
                              40072	I_AC_StromA	AC-Phase A (L1) Stromwert	A	uint16be	1	1	0		value		true	false	false	false
                              40073	I_AC_StromB	AC-Phase B (L2) Stromwert	A	uint16be	1	1	0		value		true	false	false	false
                              40074	I_AC_StromC	AC-Phase C (L3) Stromwert	A	uint16be	1	1	0		value		true	false	false	false
                              40075	I_AC_Strom_SF	AC-Strom Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40076	I_AC_SpannungAB	AC-Spannung Phase AB (L1-L2) Wert	V	uint16be	1	1	0		value		true	false	false	false
                              40077	I_AC_SpannungBC	AC-Spannung Phase BC (L2-L3) Wert	V	uint16be	1	1	0		value		true	false	false	false
                              40078	I_AC_SpannungCA	AC-Spannung Phase CA (L3-L1) Wert	V	uint16be	1	1	0		value		true	false	false	false
                              40079	I_AC_SpannungAN	AC-Spannung Phase A-N (L1-N) Wert	V	uint16be	1	1	0		value		true	false	false	false
                              40080	I_AC_SpannungBN	AC-Spannung Phase B-N (L2-N) Wert	V	uint16be	1	1	0		value		true	false	false	false
                              40081	I_AC_SpannungCN	AC-Spannung Phase C-N (L3-N) Wert	V	uint16be	1	1	0		value		true	false	false	false
                              40082	I_AC_Spannung_SF	AC-Spannung Skalierungsfaktor	V	int16be	1	1	0		value		true	false	false	false
                              40083	I_AC_Leistung	AC-Leistungswert	W	uint16be	1	1	0		value		true	false	false	false
                              40084	I_AC_Leistung_SF	AC-Leistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40085	I_AC_Frequenz	Frequenzwert	Hz	uint16be	1	1	0		value		true	false	false	false
                              40086	I_AC_Frequenz_SF	Frequenz Skalierungsfaktor		int16be	1	1	0		value		true	false	false	false
                              40087	I_AC_VA	Scheinleistung	VA	uint16be	1	1	0		value		true	false	false	false
                              40088	I_AC_VA_SF	Scheinleistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40089	I_AC_VAR	Blindleistung	VAR	uint16be	1	1	0		value		true	false	false	false
                              40090	I_AC_VAR_SF	Blindleistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40091	I_AC_PF	Leistungsfaktor	%	uint16be	1	1	0		value		true	false	false	false
                              40092	I_AC_PF_SF	Leistungsfaktor Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40093	I_AC_Energie_WH	AC Gesamt-Energieproduktion	Wh	uint32be	2	1	0		value		true	false	false	false
                              40095	I_AC_Energie_WH_SF	AC Gesamtenergie Skalierungsfaktor	SF	uint16be	1	1	0		value		true	false	false	false
                              40096	I_DC_Strom	DC-Stromwert	A	uint16be	1	1	0		value		true	false	false	false
                              40097	I_DC_Strom_SF	DC-Strom Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40098	I_DC_Spannung	DC-Spannungswert	V	uint16be	1	1	0		value		true	false	false	false
                              40099	I_DC_Spannung_SF	DC-Spannung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40100	I_DC_Leistung	DC-Leistungswert	W	uint16be	1	1	0		value		true	false	false	false
                              40101	I_DC_Leistung_SF	DC-Leistung Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40103	I_Temp_Kühler	Kühlkörpertemperatur	°C	uint16be	1	1	0		value		true	false	false	false
                              40106	I_Temp_SF	Kühlkörpertemperatur Skalierungsfaktor	SF	int16be	1	1	0		value		true	false	false	false
                              40107	I_Status	Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup)		uint16be	1	1	0		value		true	false	false	false
                              40108	I_Status_Anbieter	Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup		uint16be	1	1	0		value		true	false	false	false
                              40123	C_Manufacturer	Meter manufacturer		string	32	1	0		value		true	false	false	false
                              40127	Global Events	Global Events		uint16be	1	1	0		value		false	false	false	false
                              40139	C_Model	Meter model		string	32	1	0		value		true	false	false	false
                              40155	C_Option	Export + Import, Production, consumption		string	16	1	0		value		true	false	false	false
                              40190	M_AC_Current	AC Current (sum of active phases)	A	uint16be	1	1	0		value		true	false	false	false
                              40194	M_AC_Current_S F	AC Current Scale Factor	SF	int16be	1	1	0		value		true	false	false	false
                              40206	M_AC_Power	Total Real Power (sum of active phases)	W	int16be	1	1	0		value		true	false	false	false
                              40210	M_AC_Power_SF	AC Real Power Scale Factor	SF	int16be	1	1	0		value		true	false	false	false
                              40226	M_Exported	Total Exported Real Energy	Wh	uint32be	2	1	0		value		true	false	false	false
                              40234	M_Imported	Total Imported Real Energy	Wh	uint32be	2	1	0		value		true	false	false	false
                              40242	M_Energy_W_SF	Real Energy Scale Factor	SF	int16be	1	1	0		value		true	false	false	false
                              57664	Battery 1 Device ID	Batterie Geräte ID		uint16be	1	1	0		value		true	false	false	false
                              57666	Battery 1 Rated Energy	Batterie Nennkapazität	Wh	floatsw	2	1	0		value		true	false	false	false
                              57668	Battery 1 Max Charge Continues Power	Batterie maximale Ladeleistung	W	floatsw	2	1	0		value		true	false	false	false
                              57670	Battery 1 Max Discharge Continues Power	Batterie maximale Entladeleistung	W	floatsw	2	1	0		value		true	false	false	false
                              57672	Battery 1 Max Charge Peak  Power	Batterie maximale Ladespitzenleistung	W	floatsw	2	1	0		value		true	false	false	false
                              57674	Battery 1 Max Discharge Peak  Power	Batterie maximale Entladespitzenleistung	W	floatsw	2	1	0		value		true	false	false	false
                              57708	Battery 1 Average Temperature	Batterie Durchschnittstemperatur	°C	floatsw	2	1	0		value		true	false	false	false
                              57710	Battery 1 Max Temperature	Batterie maximale Temperatur	°C	floatsw	2	1	0		value		true	false	false	false
                              57712	Battery 1 Instantaneous Voltage	Batterie momentane Spannung	V	floatsw	2	1	0		value		true	false	false	false
                              57714	Battery 1 Instantaneous Current	Batterie momentane Stromstärke	A	floatsw	2	1	0		value		true	false	false	false
                              57716	Battery 1 Instantaneous Power	Batterie momentane Leistung	W	floatsw	2	1	0		value		true	false	false	false
                              57718	Battery 1 Lifetime Export Energy Counter	Batterie Gesamtenergie entladen	Wh	uint64le	4	1	0		value		true	false	false	false
                              57722	Battery 1 Lifetime Import Energy Counter	Batterie Gesamtenergie geladen	Wh	uint64le	4	1	0		value		true	false	false	false
                              57726	Battery 1 Max Energy	Batteriekapazität aktualisiert nach Alterung	Wh	floatsw	2	1	0		value		true	false	false	false
                              57728	Battery 1 Available Energy	Batterie verfügbare Energie	Wh	floatsw	2	1	0		value		true	false	false	false
                              57730	Battery 1 State of Health (SOH)	Batterie Verhältnis von Nennkapazität zu Batteriekapazität nach Alterung	%	floatsw	2	1	0		value		true	false	false	false
                              57732	Battery 1 State of Energy (SOE)	Batterie Ladezustand (verfügbare Energie zu mögliche Kapazität)	%	floatsw	2	1	0		value		true	false	false	false
                              57734	Battery 1 Status	Batterie Zustand (0 = Aus, 1 = Standby, 2 = Initialisierung, 3 = Laden, 4 = Entladen, 5 = Fehler, 6 = Leerlauf)		uint32sw	2	1	0		level		true	false	false	false
                              57736	Battery 1 Status Internal	Batterie Hersteller spezifische Kodierung		uint32sw	2	1	0		level		false	false	false	false
                              57738	Battery 1 Events Log	Batterie Ereignisprotokoll		string	2	1	0		level		false	false	false	false
                                Foradh 0 last edited by Foradh 0
                                ich hätte da nochmal eine Frage zu den Modbus Registern für das Lademanagement.
                                Mit den 6xxxx Adressen kann ich sämtliche Werte auslesen, nur das Register 63243 "Timeout" macht mir nach wie vor Probleme. Hier wird der Wert "235929600" ausgelesen, den man nicht ändern kann - Wert springt nach Eingabe immer wieder auf "235929600" zurück. Das Timeout funktioniert auch nicht, somit bleibt der Wechselrichter im "Remote Control" mit den zuletzt vorhandenen Einstellungen.
                                Hier meine Adressen die ich auslese:
                                Verbaut ist der Wechselrichter SE10K-RWS48BNN4 mit einer LG RESU 10.
                                Aktuellste Firmware am Wechselrichter ist installiert.
                                Hat evtl. jemand das gleiche Problem und auch eine Lösung?
                                • Z
                                  ZoXx @sol21 last edited by
                                  Hallo in die Runde 🙂
                                  Vielen vielen Dank für die ausführliche Erklärung!
                                  Sind die ersten drei Beiträge noch aktuell?
                                  Dann würde ich mich gerne die nächsten Abende einmal dransetzen und es versuchen nachzubauen.
                                  Euch einen schönen Sonntag!
                                  • Z
                                    ZoXx last edited by ZoXx
                                    Guten Morgen zusammen,
                                    ich habe das alles mal nachgebaut, vielen vielen Dank!
                                    • Allerdings habe ich bei der Anzeige:
                                      das Problem, dass folgende Fehlermeldung oben links angezueigt wird.
                                    InfluxDB Error: unsupported mean iterator type: *query.stringInterruptIterator
                                    hat den Fehler ebenfalls noch wer gehabt?
                                    -> Dieser Fehler hat sich erledigt.
                                    • Aktualisiert sich euer Wert für die "Einspeisung heute" auch nicht?
                                    • Beim modbus.0.holdingRegisters.40107_I_Status erhalte ich die Rückmeldung "1024" anstatt 1,2,3,4 etc.?
                                    • Z
                                      ZoXx @Chris87 last edited by
                                      @chris87 said in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
                                      Hi @hennerich ,
                                      kein Thema. Ich sag sogar Danke für die späte Antwort.
                                      Somit hatte ich die Möglichkeit mich mal detailiert mit Grafana auseinander zu setzten, mit (wie ich finde) gutem Resultat:
                                      Hey,
                                      kannst du mir verraten, welche Datenpunkte dafür verwendet wurden?
                                      Vor allem würde mich interessieren, was du beim select für einen Selector genommen hast.
                                      Viele Grüße
                                        Sammydk last edited by Sammydk
                                        Hallo bin neu hier und bekomme irgendwann auch mal meine Solaredge PV Anlage, wenn sie denn mal geliefert wird.
                                        Lieferzeit aktuell im 11 Monat wg. Glas Glas Module
                                        Ich bin selber mit RaspberryMatic, IOBRoker Inluxdb 1 und InfluxDB 2 und Grafana unterwegs.
                                        Um hier schon mal was vorzubereiten, habe ich dieses super Tutorial von Hennerich gefunden und versuche es soweit wie es ohne die HW schon mal möglich ist, nachzubauen.
                                        DIe zur Verfügung gestellten Scripte und Beispiele sind echt klasse und hilfreich, hoffe es läuft auch bei mir bald
                                        Nur bei dem Modbus Import habe ich mir erst mal die Ohren gebrochen.
                                        Ich benutze den Modbusadapter V5.0.5 unter IOBRoker Node.js: v14.20.1 und NPM: 6.14.17 bei dem sich die Syntax des Importes scheinbar verändert hat gegenüber dem Export von vor zwei Jahren von Hennerich.
                                        Ich habe mit mal erlaubt den Export von Hennerich anzupassen, so das man ihn in die Version V5.0.5 importieren kann. Alles aber ohne Gewähr, da ich noch nicht testen konnte.
                                        Verändert wurde :
                                        Wegfall der ersten Spaltenbeschreibung.
                                        Sieht dann so aus: "_address name description unit type len factor offset formula role room poll wp cw isScale"
                                        Wegfall von allen ";" wurden durch TAB's ersetzt und die "1" am Anfang jeder Zeile.
                                        Erweitert habe ich jede Zeile und "false false" für cw und isScale sonst meckert er den Import an wegen zwei fehlende Werte. Ob "false" oder "true" hier richtig ist , weiß ich nicht, da die beiden Werte im Original nicht existieren.
                                        Vielleicht hat ja mal jemand einen Export aus einer laufenden Modbus Installation.
                                        So dann hier das Ergebnis.
                                        "BASE = 0"
                                        und hier auch noch mal für BASE 1
                                        40001	C_SunSpec_ID	"Wert = ""SunS"" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte"		uint32be	2	1	0	value		true	false  false  false
                                        40021	C_Modell	Spezifischer SolarEdge Wert		string	16	1	0	value		true	false  false  false
                                        40045	C_Version	Spezifischer SolarEdge Wert		string	8	1	0	value		true	false  false  false
                                        40053	C_Seriennummer	Eindeutiger SolarEdge Wert		string	16	1	0	value		true	false  false  false
                                        40070	C_SunSpec_DID	101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig		uint16be	1	1	0	value		true	false  false  false
                                        40072	I_AC_Strom	AC-Gesamtstromwert	A	uint16be	1	1	0	value		true	false  false  false
                                        40073	I_AC_StromA	AC-Phase A (L1) Stromwert	A	uint16be	1	1	0	value		true	false  false  false
                                        40074	I_AC_StromB	AC-Phase B (L2) Stromwert	A	uint16be	1	1	0	value		true	false  false  false
                                        40075	I_AC_StromC	AC-Phase C (L3) Stromwert	A	uint16be	1	1	0	value		true	false  false  false
                                        40076	I_AC_Strom_SF	AC-Strom Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40084	I_AC_Leistung	AC-Leistungswert	W	uint16be	1	1	0	value		true	false  false  false
                                        40085	I_AC_Leistung_SF	AC-Leistung Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40088	I_AC_VA	Scheinleistung	VA	uint16be	1	1	0	value		true	false  false  false
                                        40089	I_AC_VA_SF	Scheinleistung Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40090	I_AC_VAR	Blindleistung	VAR	uint16be	1	1	0	value		true	false  false  false
                                        40091	I_AC_VAR_SF	Blindleistung Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40092	I_AC_PF	Leistungsfaktor	%	uint16be	1	1	0	value		true	false  false  false
                                        40093	I_AC_PF_SF	Leistungsfaktor Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40094	I_AC_Energie_WH	AC Gesamt-Energieproduktion	Wh	uint32be	2	1	0	value		true	false  false  false
                                        40096	I_AC_Energie_WH_SF	AC Gesamtenergie Skalierungsfaktor	SF	uint16be	1	1	0	value		true	false  false  false
                                        40097	I_DC_Strom	DC-Stromwert	A	uint16be	1	1	0	value		true	false  false  false
                                        40098	I_DC_Strom_SF	DC-Strom Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40099	I_DC_Spannung	DC-Spannungswert	V	uint16be	1	1	0	value		true	false  false  false
                                        40100	I_DC_Spannung_SF	DC-Spannung Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40101	I_DC_Leistung	DC-Leistungswert	W	uint16be	1	1	0	value		true	false  false  false
                                        40102	I_DC_Leistung_SF	DC-Leistung Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40104	I_Temp_Kühler	Kühlkörpertemperatur	°C	uint16be	1	1	0	value		true	false  false  false
                                        40107	I_Temp_SF	Kühlkörpertemperatur Skalierungsfaktor	SF	int16be	1	1	0	value		true	false  false  false
                                        40124	C_Manufacturer	Meter manufacturer		string	32	1	0	value		true	false  false  false
                                        40140	C_Model	Meter model		string	32	1	0	value		true	false  false  false
                                        40156	C_Option	Export + Import, Production, consumption		string	16	1	0	value		true	false  false  false
                                        40191	M_AC_Current	AC Current (sum of active phases)	A	uint16be	1	1	0	value		true	false  false  false
                                        40195	M_AC_Current_S F	AC Current Scale Factor	SF	int16be	1	1	0	value		true	false  false  false
                                        40207	M_AC_Power	Total Real Power (sum of active phases)	W	int16be	1	1	0	value		true	false  false  false
                                        40211	M_AC_Power_SF	AC Real Power Scale Factor	SF	int16be	1	1	0	value		true	false  false  false
                                        40227	M_Exported	Total Exported Real Energy	Wh	uint32be	2	1	0	value		true	false  false  false
                                        40235	M_Imported	Total Imported Real Energy	Wh	uint32be	2	1	0	value		true	false  false  false
                                        40243	M_Energy_W_SF	Real Energy Scale Factor	SF	int16be	1	1	0	value		true	false  false  false
                                        Sollte das jemand versuchen, bitte immer erst mit dem System und mit dem von Hennerich erstellen Export am Anfang vergleichen.
                                        G Dietmar
                                        Josef Kristen 1 Reply Last reply Reply Quote 0
                                          hennerich last edited by
                                          @sammydk
                                          Hey, ich würde dir sehr gerne meine aktuellen Werte exportieren, muss aber zu meiner Schande gestehen, dass ich zu doof dafür bin.
                                          Früher gab es ja oben rechts das Plus/Minus Symbol. Die sind jetzt nicht mehr da.
                                          Wo geht das denn jetzt?
                                            Sammydk @hennerich last edited by
                                            @hennerich
                                            Auf die beiden Pfeile drücken.
                                            G Dietmar
                                            grafana modbus solaredge
                                            91
                                            606
                                            199458
