    4. Test Adapter TP-Link Tapo
      tombox @schuellerf last edited by
      @schuellerf Wenn der Stecker in der app ist dann müsste auch ein Ordner angelegt werden.
      • mrbungle64
        mrbungle64 Developer @tombox last edited by
        @tombox
        Mir fällt noch auf, dass bei einem (geplanten) Neustart der Adapter Instanz eine Reihe von Errors und Warnings in's Log geschrieben werden.
        Ist das nur bei mir so?
        tapo.0	2022-09-11 08:41:01.235	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.tapo#79dc670bac773e69d6dd6926501e990a54fca102) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.17.0, js-controller: 4.0.23
        host.raspberrypi-3	2022-09-11 08:40:56.401	info	instance system.adapter.tapo.0 started with pid 24616
        host.raspberrypi-3	2022-09-11 08:40:54.647	info	instance system.adapter.tapo.0 terminated with code null ()
        host.raspberrypi-3	2022-09-11 08:40:54.646	warn	instance system.adapter.tapo.0 terminated due to SIGTERM
        host.raspberrypi-3	2022-09-11 08:40:53.913	info	stopInstance system.adapter.tapo.0 killing pid 24609
        host.raspberrypi-3	2022-09-11 08:40:52.910	info	stopInstance system.adapter.tapo.0 send kill signal
        host.raspberrypi-3	2022-09-11 08:40:52.612	info	stopInstance system.adapter.tapo.0 (force=false, process=true)
        host.raspberrypi-3	2022-09-11 08:40:52.163	info	instance system.adapter.tapo.0 started with pid 24609
        host.raspberrypi-3	2022-09-11 08:40:49.957	info	instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        tapo.0	2022-09-11 08:40:49.342	error	Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.17": Connection is closed.
        tapo.0	2022-09-11 08:40:49.341	error	Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.23": Connection is closed.
        tapo.0	2022-09-11 08:40:49.339	error	Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.16": Connection is closed.
        tapo.0	2022-09-11 08:40:49.336	error	Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.16: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
        tapo.0	2022-09-11 08:40:49.335	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.334	warn	Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.15: DB closed
        tapo.0	2022-09-11 08:40:49.333	error	Error: Could not check object existence of tapo.0.8022xxxx4523.past7d03.22: Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.22": Connection is closed.
        tapo.0	2022-09-11 08:40:49.333	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.332	warn	Could not perform strict object check of state tapo.0.8022xxxx4523.past7d03.21: DB closed
        tapo.0	2022-09-11 08:40:49.331	error	Error: Could not check object existence of tapo.0.8022xxxx1CF04.past7d03.15: Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.15": Connection is closed.
        tapo.0	2022-09-11 08:40:49.330	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.329	warn	Could not perform strict object check of state tapo.0.8022xxxx1CF04.past7d03.14: DB closed
        tapo.0	2022-09-11 08:40:49.327	error	Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
        tapo.0	2022-09-11 08:40:49.325	error	Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.22": Connection is closed.
        tapo.0	2022-09-11 08:40:49.324	error	Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.15": Connection is closed.
        tapo.0	2022-09-11 08:40:49.319	error	Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.15: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": DB closed
        tapo.0	2022-09-11 08:40:49.319	error	Error: Could not check object existence of tapo.0.8022xxxx4523.past7d03.21: Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.21": DB closed
        tapo.0	2022-09-11 08:40:49.318	error	Error: Could not check object existence of tapo.0.8022xxxx1CF04.past7d03.14: Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.14": DB closed
        tapo.0	2022-09-11 08:40:49.316	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.316	warn	Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.14: DB closed
        tapo.0	2022-09-11 08:40:49.315	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.314	warn	Could not perform strict object check of state tapo.0.8022xxxx4523.past7d03.20: DB closed
        tapo.0	2022-09-11 08:40:49.312	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.311	warn	Could not perform strict object check of state tapo.0.8022xxxx1CF04.past7d03.13: DB closed
        tapo.0	2022-09-11 08:40:49.308	error	Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": DB closed
        tapo.0	2022-09-11 08:40:49.308	error	Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.21": DB closed
        tapo.0	2022-09-11 08:40:49.306	error	Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.14": DB closed
        tapo.0	2022-09-11 08:40:49.300	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.298	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.295	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.255	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.253	warn	get state error: Connection is closed.
        tapo.0	2022-09-11 08:40:49.228	warn	get state error: DB closed
        host.raspberrypi-3
        2022-09-11 08:40:48.630	info	stopInstance system.adapter.tapo.0 send kill signal
        tapo.0	2022-09-11 08:40:48.617	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        tapo.0	2022-09-11 08:40:48.611	info	terminating
        tapo.0	2022-09-11 08:40:48.606	info	Got terminate signal TERMINATE_YOURSELF
          tombox @mrbungle64 last edited by
          @mrbungle64 Ich habe mal was in der GitHub version geändert schau mal ob es dann besser wird
          mrbungle64 1 Reply Last reply Reply Quote 0
          • mrbungle64
            @tombox
            Es ist leider noch das Gleiche. Sieht im Log eigentlich identisch aus zu vorher.
              @mrbungle64 Welchen Update interval hast du eingestellt
              • mrbungle64
                @tombox sagte in Test Adapter TP-Link Tapo:
                10 Sekunden
                • W0lfNeuz
                  W0lfNeuz last edited by
                  Bei mir läuft er leider gar nicht . Hab ich was falsch eingestellt? Schalten ist nicht möglich und Verbrauchswerte werden mir auch keine dargestellt 🙂
                  tapo.0
                  2022-09-11 13:31:16.046	error	Get Device Info failed for 80227D6168D49C1070309E29E7AC115920016034 - TypeError: Cannot read properties of undefined (reading 'request')
                  tapo.0
                  2022-09-11 13:31:16.044	error	357 Error Code: 9999, Session Timeout 192.168.178.174
                  tapo.0
                  2022-09-11 13:31:15.922	error	146 Error Code: 9999, Session Timeout 192.168.178.174
                  tapo.0
                  2022-09-11 13:31:15.630	error	Error Code: 9999, Session Timeout
                    tombox @W0lfNeuz last edited by
                    @w0lfneuz Komisch die Geräte sind aber in der App online? und unter 192.168.178.174 erreichbar?
                    W0lfNeuz 1 Reply Last reply Reply Quote 0
                    • W0lfNeuz
                      W0lfNeuz @tombox last edited by W0lfNeuz
                      @tombox Ja, in der App kann den Plug schalten und auch den Verbrauch sehen.
                      Unter der IP kommt Meldung
                      200 OK
                        @w0lfneuz Ist denn der iobroker im gleichen Netz wie die Steckdose
                        • W0lfNeuz
                          @tombox im selben Mesh Netzwerk
                          • Lucas Stiefel
                            Lucas Stiefel last edited by
                            Heyho, kann ich mit deinen Adapter meine Kamera C320WS (ganz normale Tapo TP Link Kamera mit Bewegungserkennung), die bewegungserkennung an und ausschalten, oder auch diese Quick Funktionen nutzen wie "ich bin zuhause" "zuhause verlassen", wäre super wichtig um eine Alarmanlage zu realisieren und nicht immer 5 Apps zu öffnen sondern das mit Blocky über ein Datenpunkt regeln zu können.
                            Danke dir vielmals
                              tombox @Lucas Stiefel last edited by
                              @lucas-stiefel wird denn irgendwas erkannt wenn du den Adapter installierst und die Login Daten eingibst.
                              • Codierknecht
                                Codierknecht Developer Most Active @tombox last edited by
                                @tombox
                                So, jetzt komme ich auch endlich mal dazu, den Adapter zu testen.
                                Zuerst einmal vielen Dank für Deine Mühe.
                                Das erste Problem habe ich (wie fast immer) bereits bei der Installation aus GitHub.
                                Mein ioBroker läuft als Docker-Container auf dem NAS (HP ProLiant mit DSM 6.1.7).
                                Eine Installation von Adaptern aus GitHub funktioniert fast nie. Beim letzten Versuch einen Adapter darüber zu installieren, habe ich gefühlte 100 Versuche benötigt. Irgendwann hat's dann auf wundersame Weise mal funktioniert - ohne dass ich etwas geändert hätte.
                                Ach so: Hatte ich schon erwähnt, dass Linux für mich ein Buch mit sieben Siegeln ist? 😕
                                Hier das Log:
                                0 info it worked if it ends with ok
                                1 verbose cli [
                                1 verbose cli   '/usr/bin/node',
                                1 verbose cli   '/usr/bin/npm',
                                1 verbose cli   'install',
                                1 verbose cli   'TA2k/ioBroker.tapo#e99d534ec2420efacc344378ed55391cc8407ca9'
                                1 verbose cli ]
                                2 info using npm@6.14.15
                                3 info using node@v14.18.3
                                4 verbose config Skipping project config: /opt/iobroker/.npmrc. (matches userconfig)
                                5 verbose npm-session 73452b28fa3671ee
                                6 silly install loadCurrentTree
                                7 silly install readLocalPackageData
                                8 silly fetchPackageMetaData error for github:TA2k/ioBroker.tapo#e99d534ec2420efacc344378ed55391cc8407ca9 Error while executing:
                                8 silly fetchPackageMetaData /usr/bin/git ls-remote -h -t ssh://git@github.com/TA2k/ioBroker.tapo.git
                                8 silly fetchPackageMetaData error: cannot run ssh: No such file or directory
                                8 silly fetchPackageMetaData fatal: unable to fork
                                8 silly fetchPackageMetaData exited with error code: 128
                                9 timing stage:rollbackFailedOptional Completed in 2ms
                                10 timing stage:runTopLevelLifecycles Completed in 33447ms
                                11 verbose stack Error: exited with error code: 128
                                11 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/pacote/lib/util/finished.js:12:19)
                                11 verbose stack     at ChildProcess.emit (events.js:400:28)
                                11 verbose stack     at maybeClose (internal/child_process.js:1058:16)
                                11 verbose stack     at Socket.<anonymous> (internal/child_process.js:443:11)
                                11 verbose stack     at Socket.emit (events.js:400:28)
                                11 verbose stack     at Pipe.<anonymous> (net.js:686:12)
                                12 verbose cwd /opt/iobroker
                                13 verbose Linux 3.10.102
                                14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "TA2k/ioBroker.tapo#e99d534ec2420efacc344378ed55391cc8407ca9"
                                15 verbose node v14.18.3
                                16 verbose npm  v6.14.15
                                17 error Error while executing:
                                17 error /usr/bin/git ls-remote -h -t ssh://git@github.com/TA2k/ioBroker.tapo.git
                                17 error
                                17 error error: cannot run ssh: No such file or directory
                                17 error fatal: unable to fork
                                17 error
                                17 error exited with error code: 128
                                18 verbose exit [ 1, true ]
                                  tombox @Codierknecht last edited by
                                  @codierknecht Empfehlung ist hier npm 8 also node 16.
                                  Dazu müsstest du dein docker container updaten. der aktuelle buanet container enthält node 16
                                  Bei npm 6 muss man 15min warten bei GitHub installation aber der adapter ist jetzt auch im latest enthalten
                                  Codierknecht 2 Replies Last reply Reply Quote 0
                                  • Codierknecht
                                    @tombox
                                    Danke für den Hinweis!
                                    Ich hatte ein anderes Image verwendet. Mit dem Buanet-Image funktioniert's einwandfrei.
                                    Ich werde dann mal testen und berichten ...
                                      Fraenki23 last edited by Fraenki23
                                      Hallo
                                      Ich habe mehrer Tapo P100 Diese habe ich mit dem Adapter abgerufen und kann wie gewollt den Status loggen.
                                      Nun habe ich einen weiteren Tado p100 Acount und habe mit einem zusätzlichen Adapter den zweiten aktiviert. Leider habe ich festgestellt dass man nicht beide gleichzeitug nutzen kann wenn beide normal grün leuchten wird nur der Status von einem geändert.
                                      Sollte das funktionieren?
                                      Gruss Fränki
                                        tombox @Fraenki23 last edited by
                                        @fraenki23 Nie getestet eigentlich sollte es gehen aber einfacher wäre es mit einem account
                                        • Codierknecht
                                          @tombox
                                          Der Adapter flutet mein Log.
                                          Die Dose mit der genannten IP ist eingeschaltet und im Router nicht gesperrt. Schalten kann ich sowohl mit der App als auch mit dem Adapter.
                                          Von den aktuell 4 in der App eingerichteten Dosen ist eine (Lichterkette) aktuell gar nicht gesteckt. Die ist im Log völlig unauffällig.
                                          BTW: Von dem Konzept "Anmelden an der Cloud, um die Adressen zu ermitteln" bin ich noch nicht 100% überzeugt.
                                          Für meine Begriffe wäre ein manuelles Eintragen der IP dem Anwender durchaus zuzumuten. Natürlich nur, wenn das auch zur Steuerung ausreichen würde.
                                          Was passiert denn, wenn die Cloud mal nicht erreichbar ist? Sind die Dosen dann trotzdem schalt- und abfragbar?
                                          Kann man dann das Abfragen der Cloud - soweit es denn notwendig ist - per Button in den Instanzeinstellungen nur bei Bedarf ausführen?
                                            @codierknecht Abfrage zur cloud wird nur bei adapter start gemacht dann ist es unabhängig davon könnte man auch noch verbessern wenn die cloud nicht bei adapter start verfügbar ist
                                            Codierknecht 3 Replies Last reply Reply Quote 1
                                            753
                                            186477
