    3. Off Topic
    4. InfluxDB
    5. InfluxDB 2.0 Measurement löschen
      SpacerX @Damrak2022 last edited by
      @damrak2022
      Genau! Probiere mal sudo davor. Scheint ein Rechte Problem zu sein.
      was sagt sudo influx -h ?
      Ansonsten so wie @ftd schrieb. Die Userconfig ist nur dazu da um nicht jedes mal den token mit eingeben zu müssen.
      • Damrak2022
        Damrak2022 @SpacerX last edited by
        @spacerx Zuerst habe ich es mal Testwiese mit angepassten Daten eingegeben wie @ftd erklärt hatte:
        Dann bekomme ich das:
        pi@homebridge:~ $ sudo influx delete --token fayAjyR5wxqnnusJHjEJXXXXXXXXXXXXX-6Gv9QxiFgOpdRQw6nahGIN474W75Sr0im9TFt8MKa9aw== --org Andy --DBANDY1 --start 2022-06-20T10:00:00:000Z --stop 2022-06-20T10:10:00.000 --predicate '_measurement="dieReihewowasgeloeschtwerdensoll"'
        Incorrect Usage: flag provided but not defined: -DBANDY1
        NAME:
            delete - Delete points from InfluxDB
        USAGE:
            delete [command options] [arguments...]
        DESCRIPTION:
           Delete points from InfluxDB, by specify start, end time and a sql like predicate string
        COMMON OPTIONS:
           --host value                     HTTP address of InfluxDB [$INFLUX_HOST]
           --skip-verify                    Skip TLS certificate chain and host name verification [$INFLUX_SKIP_VERIFY]
           --configs-path value             Path to the influx CLI configurations [$INFLUX_CONFIGS_PATH]
           --active-config value, -c value  Config name to use for command [$INFLUX_ACTIVE_CONFIG]
           --http-debug
           --token value, -t value          Token to authenticate request [$INFLUX_TOKEN]
        OPTIONS:
           --org-id value               The ID of the organization that owns the bucket [$INFLUX_ORG_ID]
           --org value, -o value        The name of the organization that owns the bucket [$INFLUX_ORG]
           --bucket-id value            The ID of the bucket to delete from [$INFLUX_BUCKET_ID]
           --bucket value, -b value     The name of the bucket to delete from [$INFLUX_BUCKET_NAME]
           --start value                The start time in RFC3339Nano format (ex: '2009-01-02T23:00:00Z')
           --stop value                 The stop time in RFC3339Nano format (ex: '2009-01-02T23:00:00Z')
           --predicate value, -p value  sql like predicate string (ex: 'tag1="v1" and (tag2=123)')
        Error: flag provided but not defined: -DBANDY1
        pi@homebridge:~ $
        Mein Bucket heißt definitiv "DBANDY1".
        Bei der Eingabe von sudo influx -h bekomme ich das:
        pi@homebridge:~ $ sudo influx -h
        NAME:
           influx - Influx Client
        USAGE:
           influx [command]
        COMMANDS:
           version              Print the influx CLI version
           write                Write points to InfluxDB
           bucket               Bucket management commands
           completion           Generates completion scripts
           query                Execute a Flux query
           config               Config management commands
           org, organization    Organization management commands
           delete               Delete points from InfluxDB
           user                 User management commands
           task                 Task management commands
           telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
           dashboards           List Dashboard(s).
           export               Export existing resources as a template
           secret               Secret management commands
           v1                   InfluxDB v1 management commands
           auth, authorization  Authorization management commands
           apply                Apply a template to manage resources
           stacks               List stack(s) and associated templates. Subcommands manage stacks.
           template             Summarize the provided template
           bucket-schema        Bucket schema management commands
           ping                 Check the InfluxDB /health endpoint
           setup                Setup instance with initial user, org, bucket
           backup               Backup database
           restore              Restores a backup directory to InfluxDB
           remote               Remote connection management commands
           replication          Replication stream management commands
           server-config        Display server config
           help, h              Shows a list of commands or help for one command
        GLOBAL OPTIONS:
           --help, -h  show help
        pi@homebridge:~ $
        Mi leuchtetr das mit dem Zeitbereich durchaus ein, aber bei mir sind es eher falsche Daatenpunkte, welche ich nicht mehr benötige:
        Ich möchte ja nur diese einzelnen Datenpunkte löschen:
          @damrak2022
          Da fehlt --bucket vor DBANDY1
            SpacerX @Damrak2022 last edited by SpacerX
            @damrak2022
            sudo influx delete --token fayAjyR5wxqnnusJHjEJXXXXXXXXXXXXX-6Gv9QxiFgOpdRQw6nahGIN474W75Sr0im9TFt8MKa9aw== --org Andy --bucket DBANDY1 --start 1970-01-01T00:00:00Z --stop $(date +"%Y-%m-%dT%H:%M:%SZ") --predicate '_measurement="Drucker_currentday"'
            als Beispiel löscht gesamten geloggten Datenpunkt.
            Vorher das Loggen des Datenpunktes deaktivieren !
            Noch ein bischen Lesestoff zum Thema Influxdb delete
            Damrak2022 Glasfaser 2 Replies Last reply Reply Quote 1
            • Damrak2022
              @spacerx sagte in InfluxDB 2.0 Measurement löschen:
              Hallo ich habe das loggen des Datenpunkts deaktiviert.
              Wenn ich dann Deinen Befehl eingebe bekomme ich folgende Meldung:
              Error: failed to delete data: 401 Unauthorized: unauthorized access
              Wie erlaube ich den Zugriff?
              • Glasfaser
                Glasfaser @SpacerX last edited by Glasfaser
                @damrak2022
                als Beispiel
                Hast du den token angepaßt !
                • Damrak2022
                  Damrak2022 @Glasfaser last edited by Damrak2022
                  @glasfaser Ups - sorry
                  Perfekt es klappt vielen Dank an Euch
                    friemelkarl last edited by
                    Danke für den Tipp. Die Datenpunkte sind auch definitiv nicht mehr da, allerdings hat sich das irgendwie nicht positiv auf den Speicherplatz ausgewirkt. Konnte keine Veränderung feststellen.
                    Da sollte doch eigentlich Speicherplatz frei werden, oder?
                      Aquin last edited by
                      Guten Tag,
                      ich bin der Anleitung in diesem Beispiel gefolgt und habe den Befehl angepasst nur leider ohne Erfolg 😠
                      Lösche Datenpunkte vom 11.09.22 9:00 Uhr - 11.09.22 11:00 Uhr
                      sudo influx delete --token sKJliJreWx9_eYkJ3wiHQAmAvmHoMIIvJgzUUbADTC9LjFv5bgL6RQPt1TGAeHmmDnoQvff5G00LaYSA09T8YQ== --org my-org --bucket iobroker --start 2022-09-11T09:00:00.000Z --stop 2022-09-11T11:00:00.000Z --predicate '_measurement="Netzeinspeisung"'
                      Dieser Befehl wird auch angenommen, nur bekomme ich kein positives oder negatives Feedback und der Fehlerhafte Datenpunkt ist auch noch vorhanden.
                      Evtl. kann mir jemand weiterhelfen, vielen Dank.
                      S F 2 Replies Last reply Reply Quote 0
                        SpacerX @Aquin last edited by
                        @aquin hast du die Browserseite auch mal neu geladen.
                          ftd @Aquin last edited by
                          @aquin Falsche Start- und Stop-Zeit
                          Im Graph steht 10:00 Uhr= Browserzeit nehme ich an
                          Deine Query sagt: Z
                          Z wie Zulutime = UTC + 0 (https://www.timeanddate.com/worldclock/timezone/zulu)
                          Zur Zeit sind wir aber +2 Stunden UTC
                          Also muss deine Abfrage lauten: --start 2022-09-11T07:58:00.000Z --stop 2022-09-11T08:02:00.000Z
                          10:00 Uhr (Browserzeit) plus/mimus 2 Minuten von der UTC (Z) Zeit minus 2 Stunden
                            Danke, für die schnellen Antworten.
                            • Browser neu geladen, Datenpunkt noch vorhanden
                            • Befehl angepasst, Datenpunkt noch vorhanden
                              sudo influx delete --token sKJliJreWx9_eYkJ3wiHQAmAvmHoMIIKJUzUUbADTC9LjFv5bgL6RQPt1TGAeHmmDnoQvff5G00LaYSA09T8YQ== --org my-org --bucket iobroker --start 2022-09-11T07:58:00.000Z --stop 2022-09-11T08:02:00.000Z --predicate '_measurement="Netzeinspeisung"'
                            Vielleicht noch weitere Ideen 🙂
                              @aquin
                              Überprüfe bitte noch mal deinen Token und
                              probiere mal:
                              sudo influx delete --token sKJliJreWx9_eYkJ3wiHQAmAvmHoMIIKJUzUUbADTC9LjFv5bgL6RQPt1TGAeHmmDnoQvff5G00LaYSA09T8YQ== --org 'my-org' --bucket iobroker --start 2022-09-11T07:58:00.00Z --stop 2022-09-11T08:02:00.00Z --predicate '_measurement="Netzeinspeisung"'
                                Aquin @SpacerX last edited by Aquin
                                @spacerx
                                Habe den Token nochmal überprüft und den Befehl übernommen, leider ohne Erfolg. 😠
                                Das komische ist, ich bekomme keine Feedback, eine neu Zeile wird geöffnet.
                                m@ubuntuserver:~$ sudo influx delete --token sKJliJreWx9_eYkJ3wiHQAmAvmHoMIIKJUzUUbADTC9LjFv5bgL6RQPt1TGAeHmmDnoQvff5G00LaYSA09T8YQ== --org 'my-org' --bucket iobroker --start 2022-09-11T07:58:00.00Z --stop 2022-09-11T08:02:00.00Z --predicate '_measurement="Netzeinspeisung"'
                                m@ubuntuserver:~$
                                  SpacerX @Aquin last edited by SpacerX
                                  @aquin
                                  keine Ahnung mehr. Bitte setzt die Befehle in code-Tags das liest sich einfach besser.
                                  Vieleicht mal anders herum einen Query für diese bestimmte Zeit und schauen ob überhaupt in dem Zeitpunkt Daten da sind.
                                  sudo influx query 'from(bucket: "iobroker") |> range(start: 2022-09-11T07:58:00.00Z, stop: 2022-09-11T08:02:00.00Z ) |> filter(fn: (r) => r["_measurement"] == "Netzeinspeisung")' --token sKJliJreWx9_eYkJ3wiHQAmAvmHoMIIKJUzUUbADTC9LjFv5bgL6RQPt1TGAeHmmDnoQvff5G00LaYSA09T8YQ== --org my-org
                                  sollte dir den Bereich zeigen den du löschen möchtest.
                                  Bei mir kommt auch keine Meldung das der Datenpunkt gelöscht wurde.
                                    @spacerx danke für deine Hilfe. Leider kommen keine Daten, wieso auch immer, habe ja Daten in der Grafik.
                                    Kann es evtl. mit dem Alias zusammenhängen "Netzeinspeisung"?
                                      @aquin wundert mich?
                                      Benutzt du überhaupt flux in Influxdb?
                                        @spacerx
                                        Naja, ich bin neu in dieser Materie aber es sollte es sein 😊
                                          @aquin
                                          Erweitere mal die start und stop Zeit vom query um einen weiteren Bereich zu bekommen. Wo keine Points sind werden auch keine Angezeigt.
                                            @aquin said in InfluxDB 2.0 Measurement löschen:
                                            @spacerx
                                            Klick mal auf "View Raw Data" und zeig mal hier ein Bild mit Star/Stop/Time und dem Fehlerhaften Datenpunkt.
                                            97
                                            26026
