    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
      Homoran Global Moderator Administrators @heli-wolf last edited by
      @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
      bringt aber wieder einen Fehler.
      versuch es mal wie alle apt Befehle mit sudo davor
        heli-wolf @Homoran last edited by
        Vielen Dank, jetzt hat er zumindest die Installation fortgeführt.
        iobroker@iobroker:~ $ sudo apt install grafana
        Reading package lists... Done
        Building dependency tree... Done
        The following NEW packages will be installed:
          grafana
        0 upgraded, 1 newly installed, 0 to remove and 14 not upgraded.
        Need to get 76.8 MB of archives.
        After this operation, 271 MB of additional disk space will be used.
        Get:1 https://packages.grafana.com/oss/deb stable/main arm64 grafana arm64 9.1.4 [76.8 MB]
        Fetched 76.8 MB in 29s (2,660 kB/s)
        Selecting previously unselected package grafana.
        (Reading database ... 54954 files and directories currently installed.)
        Preparing to unpack .../grafana_9.1.4_arm64.deb ...
        Unpacking grafana (9.1.4) ...
        dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (--unpack):
         trying to overwrite '/usr/lib/systemd/system/grafana-server.service', which is also in package grafana-rpi:armhf 9.1.4
        dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
        Errors were encountered while processing:
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        iobroker@iobroker:~ $ sudo /bin/systemctl enable grafana-server
        [sudo] password for iobroker:
        Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
        Executing: /lib/systemd/systemd-sysv-install enable grafana-server
        Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /lib/systemd/system/grafana-server.service.
        iobroker@iobroker:~ $ sudo /bin/systemctl start grafana-server
        Aber in den folgenden Zeilen besteht ein weiteres Problem:
          @heli-wolf ich hab das mal nach OffTopic verschoben.
          Grafana ist kein Bestandteil von ioBroker.
          ich denke du hast einen Pi?
          was willst du dann mit einem 64Bit PC paket?
            @homoran said in Grafana Installation - Fehler grafana-rpi:armhf:
            Bearbeiten
            das habe ich nicht ausgewählt.
            Wie kann ich das ändern?
            Homoran DJMarc75 2 Replies Last reply Reply Quote 0
              @heli-wolf sorry, mein Fehler!
              arm ist nicht amd 😞
              alles gut
              ab hier jann ich nicht mehr helfen, nutze Grafana nicht
              • DJMarc75
                DJMarc75 @heli-wolf last edited by
                @heli-wolf
                Wie bist Du denn da prinzipiell am Start ?
                sudo ln -s /usr/bin/node /usr/bin/nodejs
                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  heli-wolf @DJMarc75 last edited by
                  @djmarc75 said in Grafana Installation - Fehler grafana-rpi:armhf:
                  iobroker@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                  iobroker@iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  aarch64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.0
                  v16.17.0
                  8.15.0
                  4.0.23
                  iobroker
                  iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
                  /home/iobroker
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Hit:7 https://repos.influxdata.com/debian bullseye InRelease
                  14 packages can be upgraded. Run 'apt list --upgradable' to see them.
                  W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                  W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                  W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                  W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                  W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                  W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                  W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                  W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                  W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                  W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                  nodejs:
                    Installed: 16.17.0-deb-1nodesource1
                    Candidate: 16.17.0-deb-1nodesource1
                    Version table:
                   *** 16.17.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                          100 /var/lib/dpkg/status
                       12.22.12~dfsg-1~deb11u1 500
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.5~dfsg-2~11u1 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  • DJMarc75
                    und immernoch nicht
                    sudo apt upgrade
                    ausgeführt
                      @djmarc75
                      Doch hatte ich schon ausgeführt.
                      iobroker@iobroker:~ $ sudo apt upgrade
                      Calculating upgrade... Done
                      The following packages will be upgraded:
                        base-files curl dpkg dpkg-dev libcurl3-gnutls libcurl4 libdpkg-perl
                        libpam-systemd libsystemd0 publicsuffix raspi-config systemd systemd-sysv
                        systemd-timesyncd
                      14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 12.5 MB of archives.
                      After this operation, 5,120 B disk space will be freed.
                      Do you want to continue? [Y/n] y
                      Get:1 http://deb.debian.org/debian bullseye/main arm64 base-files arm64 11.1+deb11u5 [70.1 kB]
                      Get:2 http://deb.debian.org/debian bullseye/main arm64 dpkg arm64 1.20.12 [2,521 kB]
                      Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-config all 20220907 [31.7 kB]
                      Get:4 http://deb.debian.org/debian bullseye/main arm64 systemd-sysv arm64 247.3-7+deb11u1 [113 kB]
                      Get:5 http://deb.debian.org/debian bullseye/main arm64 libpam-systemd arm64 247.3-7+deb11u1 [274 kB]
                      Get:6 http://deb.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 247.3-7+deb11u1 [130 kB]
                      Get:7 http://deb.debian.org/debian bullseye/main arm64 systemd arm64 247.3-7+deb11u1 [4,153 kB]
                      Get:8 http://deb.debian.org/debian bullseye/main arm64 libsystemd0 arm64 247.3-7+deb11u1 [354 kB]
                      Get:9 http://deb.debian.org/debian bullseye/main arm64 curl arm64 7.74.0-1.3+deb11u3 [264 kB]
                      Get:10 http://deb.debian.org/debian bullseye/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u3 [324 kB]
                      Get:11 http://deb.debian.org/debian bullseye/main arm64 dpkg-dev all 1.20.12 [2,312 kB]
                      Get:12 http://deb.debian.org/debian bullseye/main arm64 libdpkg-perl all 1.20.12 [1,551 kB]
                      Get:13 http://deb.debian.org/debian bullseye/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u3 [321 kB]
                      Get:14 http://deb.debian.org/debian bullseye/main arm64 publicsuffix all 20220811.1734-0+deb11u1 [127 kB]
                      Fetched 12.5 MB in 5s (2,691 kB/s)
                      Reading changelogs... Done
                      Preparing to unpack .../base-files_11.1+deb11u5_arm64.deb ...
                      Unpacking base-files (11.1+deb11u5) over (11.1+deb11u4) ...
                      Setting up base-files (11.1+deb11u5) ...
                      Installing new version of config file /etc/debian_version ...
                      Preparing to unpack .../dpkg_1.20.12_arm64.deb ...
                      Unpacking dpkg (1.20.12) over (1.20.11) ...
                      Setting up dpkg (1.20.12) ...
                      Preparing to unpack .../systemd-sysv_247.3-7+deb11u1_arm64.deb ...
                      Unpacking systemd-sysv (247.3-7+deb11u1) over (247.3-7) ...
                      Preparing to unpack .../libpam-systemd_247.3-7+deb11u1_arm64.deb ...
                      Unpacking libpam-systemd:arm64 (247.3-7+deb11u1) over (247.3-7) ...
                      Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u1_arm64.deb ...
                      Unpacking systemd-timesyncd (247.3-7+deb11u1) over (247.3-7) ...
                      Preparing to unpack .../systemd_247.3-7+deb11u1_arm64.deb ...
                      Unpacking systemd (247.3-7+deb11u1) over (247.3-7) ...
                      Preparing to unpack .../libsystemd0_247.3-7+deb11u1_arm64.deb ...
                      Unpacking libsystemd0:arm64 (247.3-7+deb11u1) over (247.3-7) ...
                      Setting up libsystemd0:arm64 (247.3-7+deb11u1) ...
                      Preparing to unpack .../0-curl_7.74.0-1.3+deb11u3_arm64.deb ...
                      Unpacking curl (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                      Preparing to unpack .../1-libcurl4_7.74.0-1.3+deb11u3_arm64.deb ...
                      Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                      Preparing to unpack .../2-dpkg-dev_1.20.12_all.deb ...
                      Unpacking dpkg-dev (1.20.12) over (1.20.11) ...
                      Preparing to unpack .../3-libdpkg-perl_1.20.12_all.deb ...
                      Unpacking libdpkg-perl (1.20.12) over (1.20.11) ...
                      Preparing to unpack .../4-libcurl3-gnutls_7.74.0-1.3+deb11u3_arm64.deb ...
                      Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                      Preparing to unpack .../5-publicsuffix_20220811.1734-0+deb11u1_all.deb ...
                      Unpacking publicsuffix (20220811.1734-0+deb11u1) over (20211207.1025-0+deb11u1) ...
                      Preparing to unpack .../6-raspi-config_20220907_all.deb ...
                      Unpacking raspi-config (20220907) over (20220901) ...
                      Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) ...
                      Setting up systemd (247.3-7+deb11u1) ...
                      Setting up systemd-timesyncd (247.3-7+deb11u1) ...
                      Setting up libdpkg-perl (1.20.12) ...
                      Setting up libcurl4:arm64 (7.74.0-1.3+deb11u3) ...
                      Setting up curl (7.74.0-1.3+deb11u3) ...
                      Setting up raspi-config (20220907) ...
                      Setting up publicsuffix (20220811.1734-0+deb11u1) ...
                      Setting up systemd-sysv (247.3-7+deb11u1) ...
                      Setting up dpkg-dev (1.20.12) ...
                      Setting up libpam-systemd:arm64 (247.3-7+deb11u1) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      Processing triggers for dbus (1.12.20-2) ...
                      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
                      • DJMarc75
                        @heli-wolf nochmal:
                          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                          aarch64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.17.0
                          v16.17.0
                          8.15.0
                          4.0.23
                          iobroker
                          /home/iobroker
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                          Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                          All packages are up to date.
                          nodejs:
                            Version table:
                          • DJMarc75
                            @heli-wolf
                            puh, da weiss ich auch nicht weiter.
                            Vielleicht kann da mal @thomas-braun drauf schauen wenn er Zeit und Muße hat.
                              @djmarc75
                              wie kann ich eine Datei umbenennen bzw. Löschen.
                              mit dem Befehl
                              rm grafana_9.1.4_arm64.deb
                              lässt er es nicht zu.
                              ebenfalls funktioniert das Umbenennen mit MV auch nicht.
                              • DJMarc75
                                Was hast Du da vor ??
                                  @djmarc75
                                  ich habe jetzt die Grafanainstallation entfernt und neu installiert und dabei die richtigen Dateien installiert.
                                  aber leider hat er die alte Version der grafana_9.1.4_arm64.deb noch im Archiv und das stößt bei der Installation auf Probleme.
                                    grafana
                                  0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                  Need to get 0 B/76.8 MB of archives.
                                  dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (  --unpack):
                                  Jetzt wollte ich die besagte Datei löschen um so die Installation ohne Konflikt vornehmen zu können.
                                    ohne Konflikt
                                    da ist kein Konflikt
                                    da hast du wohl etwas am Paketmanager vorbei kaputt gespielt
                                    Broken pipe
                                      wie kann man den Rohrbruch beseitigen?
                                        keine Ahnung.
                                        Aber vielleicht kann @thomas-braun da helfen, wenn er Zeit hat
                                          Thomas Braun Most Active last edited by
                                          Bin gerade am Handy. Schau später mit großem Monitor mal rein. Aber da sind falsche list-Dateien und falsche Pakete installiert, wenn ich das richtig sehe.
                                            heli-wolf @Thomas Braun last edited by
                                            Vielen Dank !!!
                                            1.0k
                                            6219
