    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
      heli-wolf @DJMarc75 last edited by
      @djmarc75 said in Grafana Installation - Fehler grafana-rpi:armhf:
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      iobroker@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      iobroker@iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      4.0.23
      iobroker
      iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
      /home/iobroker
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://packages.grafana.com/oss/deb stable InRelease
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:7 https://repos.influxdata.com/debian bullseye InRelease
      Reading package lists... Done
      Building dependency tree... Done
      14 packages can be upgraded. Run 'apt list --upgradable' to see them.
      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      nodejs:
        Installed: 16.17.0-deb-1nodesource1
        Candidate: 16.17.0-deb-1nodesource1
        Version table:
       *** 16.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      • DJMarc75
        DJMarc75 @heli-wolf last edited by
        @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
        und immernoch nicht
        sudo apt upgrade
        ausgeführt
          @djmarc75
          Doch hatte ich schon ausgeführt.
          iobroker@iobroker:~ $ sudo apt upgrade
          Calculating upgrade... Done
          The following packages will be upgraded:
            base-files curl dpkg dpkg-dev libcurl3-gnutls libcurl4 libdpkg-perl
            libpam-systemd libsystemd0 publicsuffix raspi-config systemd systemd-sysv
            systemd-timesyncd
          14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 12.5 MB of archives.
          After this operation, 5,120 B disk space will be freed.
          Do you want to continue? [Y/n] y
          Get:1 http://deb.debian.org/debian bullseye/main arm64 base-files arm64 11.1+deb11u5 [70.1 kB]
          Get:2 http://deb.debian.org/debian bullseye/main arm64 dpkg arm64 1.20.12 [2,521 kB]
          Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-config all 20220907 [31.7 kB]
          Get:4 http://deb.debian.org/debian bullseye/main arm64 systemd-sysv arm64 247.3-7+deb11u1 [113 kB]
          Get:5 http://deb.debian.org/debian bullseye/main arm64 libpam-systemd arm64 247.3-7+deb11u1 [274 kB]
          Get:6 http://deb.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 247.3-7+deb11u1 [130 kB]
          Get:7 http://deb.debian.org/debian bullseye/main arm64 systemd arm64 247.3-7+deb11u1 [4,153 kB]
          Get:8 http://deb.debian.org/debian bullseye/main arm64 libsystemd0 arm64 247.3-7+deb11u1 [354 kB]
          Get:9 http://deb.debian.org/debian bullseye/main arm64 curl arm64 7.74.0-1.3+deb11u3 [264 kB]
          Get:10 http://deb.debian.org/debian bullseye/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u3 [324 kB]
          Get:11 http://deb.debian.org/debian bullseye/main arm64 dpkg-dev all 1.20.12 [2,312 kB]
          Get:12 http://deb.debian.org/debian bullseye/main arm64 libdpkg-perl all 1.20.12 [1,551 kB]
          Get:13 http://deb.debian.org/debian bullseye/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u3 [321 kB]
          Get:14 http://deb.debian.org/debian bullseye/main arm64 publicsuffix all 20220811.1734-0+deb11u1 [127 kB]
          Fetched 12.5 MB in 5s (2,691 kB/s)
          Reading changelogs... Done
          (Reading database ... 54954 files and directories currently installed.)
          Preparing to unpack .../base-files_11.1+deb11u5_arm64.deb ...
          Unpacking base-files (11.1+deb11u5) over (11.1+deb11u4) ...
          Setting up base-files (11.1+deb11u5) ...
          Installing new version of config file /etc/debian_version ...
          Preparing to unpack .../dpkg_1.20.12_arm64.deb ...
          Unpacking dpkg (1.20.12) over (1.20.11) ...
          Setting up dpkg (1.20.12) ...
          Preparing to unpack .../systemd-sysv_247.3-7+deb11u1_arm64.deb ...
          Unpacking systemd-sysv (247.3-7+deb11u1) over (247.3-7) ...
          Preparing to unpack .../libpam-systemd_247.3-7+deb11u1_arm64.deb ...
          Unpacking libpam-systemd:arm64 (247.3-7+deb11u1) over (247.3-7) ...
          Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u1_arm64.deb ...
          Unpacking systemd-timesyncd (247.3-7+deb11u1) over (247.3-7) ...
          Preparing to unpack .../systemd_247.3-7+deb11u1_arm64.deb ...
          Unpacking systemd (247.3-7+deb11u1) over (247.3-7) ...
          Preparing to unpack .../libsystemd0_247.3-7+deb11u1_arm64.deb ...
          Unpacking libsystemd0:arm64 (247.3-7+deb11u1) over (247.3-7) ...
          Setting up libsystemd0:arm64 (247.3-7+deb11u1) ...
          Preparing to unpack .../0-curl_7.74.0-1.3+deb11u3_arm64.deb ...
          Unpacking curl (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
          Preparing to unpack .../1-libcurl4_7.74.0-1.3+deb11u3_arm64.deb ...
          Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
          Preparing to unpack .../2-dpkg-dev_1.20.12_all.deb ...
          Unpacking dpkg-dev (1.20.12) over (1.20.11) ...
          Preparing to unpack .../3-libdpkg-perl_1.20.12_all.deb ...
          Unpacking libdpkg-perl (1.20.12) over (1.20.11) ...
          Preparing to unpack .../4-libcurl3-gnutls_7.74.0-1.3+deb11u3_arm64.deb ...
          Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
          Preparing to unpack .../5-publicsuffix_20220811.1734-0+deb11u1_all.deb ...
          Unpacking publicsuffix (20220811.1734-0+deb11u1) over (20211207.1025-0+deb11u1) ...
          Preparing to unpack .../6-raspi-config_20220907_all.deb ...
          Unpacking raspi-config (20220907) over (20220901) ...
          Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) ...
          Setting up systemd (247.3-7+deb11u1) ...
          Setting up systemd-timesyncd (247.3-7+deb11u1) ...
          Setting up libdpkg-perl (1.20.12) ...
          Setting up libcurl4:arm64 (7.74.0-1.3+deb11u3) ...
          Setting up curl (7.74.0-1.3+deb11u3) ...
          Setting up raspi-config (20220907) ...
          Setting up publicsuffix (20220811.1734-0+deb11u1) ...
          Setting up systemd-sysv (247.3-7+deb11u1) ...
          Setting up dpkg-dev (1.20.12) ...
          Setting up libpam-systemd:arm64 (247.3-7+deb11u1) ...
          Processing triggers for man-db (2.9.4-2) ...
          Processing triggers for dbus (1.12.20-2) ...
          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
          • DJMarc75
            @heli-wolf nochmal:
              ln: failed to create symbolic link '/usr/bin/nodejs': File exists
              aarch64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.17.0
              v16.17.0
              8.15.0
              4.0.23
              iobroker
              /home/iobroker
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:6 https://packages.grafana.com/oss/deb stable InRelease
              All packages are up to date.
              nodejs:
                Version table:
              • DJMarc75
                @heli-wolf
                puh, da weiss ich auch nicht weiter.
                Vielleicht kann da mal @thomas-braun drauf schauen wenn er Zeit und Muße hat.
                  @djmarc75
                  wie kann ich eine Datei umbenennen bzw. Löschen.
                  mit dem Befehl
                  rm grafana_9.1.4_arm64.deb
                  lässt er es nicht zu.
                  ebenfalls funktioniert das Umbenennen mit MV auch nicht.
                  • DJMarc75
                    Was hast Du da vor ??
                      @djmarc75
                      ich habe jetzt die Grafanainstallation entfernt und neu installiert und dabei die richtigen Dateien installiert.
                      aber leider hat er die alte Version der grafana_9.1.4_arm64.deb noch im Archiv und das stößt bei der Installation auf Probleme.
                      iobroker@iobroker:~ $ sudo apt install grafana
                      The following NEW packages will be installed:
                        grafana
                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 0 B/76.8 MB of archives.
                      After this operation, 271 MB of additional disk space will be used.
                      Preparing to unpack .../grafana_9.1.4_arm64.deb ...
                      Unpacking grafana (9.1.4) ...
                      dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (  --unpack):
                       trying to overwrite '/usr/lib/systemd/system/grafana-server.service', which is                                       also in package grafana-rpi:armhf 9.1.4
                      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                      Errors were encountered while processing:
                      E: Sub-process /usr/bin/dpkg returned an error code (1)
                      Jetzt wollte ich die besagte Datei löschen um so die Installation ohne Konflikt vornehmen zu können.
                        Homoran Global Moderator Administrators @heli-wolf last edited by
                        ohne Konflikt
                        da ist kein Konflikt
                        da hast du wohl etwas am Paketmanager vorbei kaputt gespielt
                        Broken pipe
                          heli-wolf @Homoran last edited by
                          wie kann man den Rohrbruch beseitigen?
                            keine Ahnung.
                            Aber vielleicht kann @thomas-braun da helfen, wenn er Zeit hat
                              Thomas Braun Most Active last edited by
                              Bin gerade am Handy. Schau später mit großem Monitor mal rein. Aber da sind falsche list-Dateien und falsche Pakete installiert, wenn ich das richtig sehe.
                                heli-wolf @Thomas Braun last edited by
                                Vielen Dank !!!
                                  Thomas Braun Most Active @heli-wolf last edited by Thomas Braun
                                  Wo kommt die denn her? Hast du die etwa am Paketmanager vorbei in das System geschraubt?
                                  Die mehrfach vorhandenen Einträge/Zeilen in der
                                  löschen.
                                  Da sollte nur
                                  deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main
                                  drin stehen.
                                  Dann
                                  sudo apt purge grafana-rpi
                                  sudo apt update
                                  apt policy grafana*
                                    @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
                                    apt policy grafana*
                                    iobroker@iobroker:~ $ sudo apt purge grafana-rpi
                                    The following packages were automatically installed and are no longer required:
                                      libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
                                      libpng16-16:armhf libuuid1:armhf zlib1g:armhf
                                    Use 'sudo apt autoremove' to remove them.
                                    The following packages will be REMOVED:
                                      grafana-rpi:armhf*
                                    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                    After this operation, 258 MB disk space will be freed.
                                    Removing grafana-rpi:armhf (9.1.4) ...
                                    (Reading database ... 47955 files and directories currently installed.)
                                    Purging configuration files for grafana-rpi:armhf (9.1.4) ...
                                    dpkg: warning: while removing grafana-rpi:armhf, directory '/etc/grafana' not empty so not removed
                                    dpkg: warning: while removing grafana-rpi:armhf, directory '/usr/lib/systemd/system' not empty so not removed
                                    iobroker@iobroker:~ $ sudo apt update
                                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    iobroker@iobroker:~ $ apt policy grafana*
                                    N: Unable to locate package grafana_9.1.4_armhf.deb
                                    N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                                    N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                                    sollten die Fehler jetzt behoben sein?
                                    kann ich die Installation mit
                                    jetzt wieder starten?
                                    H Thomas Braun 2 Replies Last reply Reply Quote 0
                                      heli-wolf @heli-wolf last edited by
                                      @heli-wolf
                                      löschen.
                                      Wie lösche ich diese Dateien.
                                      Über Filezilla habe ich keine Berechtigung Dateien zu löschen.
                                        Nein, da hast du ganz schon rumgeaast...
                                        Da ist einiges schief.
                                        löschen.
                                        Da sollte nur
                                        drin stehen.
                                          Nicht die Datei löschen, die doppelten Zeilen darin.
                                          Geht mit einem Editor, nano z. B.
                                          sudo nano /etc/apt/sources.list.d/grafana.list
                                            Die Grafana.list habe ich mit einem Editor angesehen und sieht folgend aus:
                                            deb https://packages.grafana.com/oss/deb stable main
                                            2 davon habe ich gelöscht.
                                            6219
