    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
    • DJMarc75
      DJMarc75 @heli-wolf last edited by
      @heli-wolf nochmal:
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        heli-wolf @DJMarc75 last edited by
        @djmarc75 said in Grafana Installation - Fehler grafana-rpi:armhf:
        iobroker@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
        iobroker@iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        4.0.23
        iobroker
        iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
        /home/iobroker
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
        Hit:7 https://repos.influxdata.com/debian bullseye InRelease
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        nodejs:
          Installed: 16.17.0-deb-1nodesource1
          Candidate: 16.17.0-deb-1nodesource1
          Version table:
         *** 16.17.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u1 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        • DJMarc75
          @heli-wolf
          puh, da weiss ich auch nicht weiter.
          Vielleicht kann da mal @thomas-braun drauf schauen wenn er Zeit und Muße hat.
            @djmarc75
            wie kann ich eine Datei umbenennen bzw. Löschen.
            mit dem Befehl
            rm grafana_9.1.4_arm64.deb
            lässt er es nicht zu.
            ebenfalls funktioniert das Umbenennen mit MV auch nicht.
            • DJMarc75
              @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
              Was hast Du da vor ??
                @djmarc75
                ich habe jetzt die Grafanainstallation entfernt und neu installiert und dabei die richtigen Dateien installiert.
                aber leider hat er die alte Version der grafana_9.1.4_arm64.deb noch im Archiv und das stößt bei der Installation auf Probleme.
                iobroker@iobroker:~ $ sudo apt install grafana
                The following NEW packages will be installed:
                  grafana
                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                Need to get 0 B/76.8 MB of archives.
                After this operation, 271 MB of additional disk space will be used.
                (Reading database ... 54954 files and directories currently installed.)
                Preparing to unpack .../grafana_9.1.4_arm64.deb ...
                Unpacking grafana (9.1.4) ...
                dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (  --unpack):
                 trying to overwrite '/usr/lib/systemd/system/grafana-server.service', which is                                       also in package grafana-rpi:armhf 9.1.4
                dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                Errors were encountered while processing:
                E: Sub-process /usr/bin/dpkg returned an error code (1)
                Jetzt wollte ich die besagte Datei löschen um so die Installation ohne Konflikt vornehmen zu können.
                  Homoran Global Moderator Administrators @heli-wolf last edited by
                  ohne Konflikt
                  da ist kein Konflikt
                  da hast du wohl etwas am Paketmanager vorbei kaputt gespielt
                  Broken pipe
                    heli-wolf @Homoran last edited by
                    wie kann man den Rohrbruch beseitigen?
                      keine Ahnung.
                      Aber vielleicht kann @thomas-braun da helfen, wenn er Zeit hat
                        Thomas Braun Most Active last edited by
                        Bin gerade am Handy. Schau später mit großem Monitor mal rein. Aber da sind falsche list-Dateien und falsche Pakete installiert, wenn ich das richtig sehe.
                          heli-wolf @Thomas Braun last edited by
                          Vielen Dank !!!
                            Thomas Braun Most Active @heli-wolf last edited by Thomas Braun
                            Wo kommt die denn her? Hast du die etwa am Paketmanager vorbei in das System geschraubt?
                            Die mehrfach vorhandenen Einträge/Zeilen in der
                            löschen.
                            Da sollte nur
                            deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main
                            drin stehen.
                            Dann
                            sudo apt purge grafana-rpi
                            sudo apt update
                            apt policy grafana*
                              @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
                              apt policy grafana*
                              iobroker@iobroker:~ $ sudo apt purge grafana-rpi
                              The following packages were automatically installed and are no longer required:
                                libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
                                libpng16-16:armhf libuuid1:armhf zlib1g:armhf
                              Use 'sudo apt autoremove' to remove them.
                              The following packages will be REMOVED:
                                grafana-rpi:armhf*
                              0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                              After this operation, 258 MB disk space will be freed.
                              Do you want to continue? [Y/n] y
                              Removing grafana-rpi:armhf (9.1.4) ...
                              (Reading database ... 47955 files and directories currently installed.)
                              Purging configuration files for grafana-rpi:armhf (9.1.4) ...
                              dpkg: warning: while removing grafana-rpi:armhf, directory '/etc/grafana' not empty so not removed
                              dpkg: warning: while removing grafana-rpi:armhf, directory '/usr/lib/systemd/system' not empty so not removed
                              iobroker@iobroker:~ $ sudo apt update
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                              Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                              iobroker@iobroker:~ $ apt policy grafana*
                              N: Unable to locate package grafana_9.1.4_armhf.deb
                              N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                              N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                              sollten die Fehler jetzt behoben sein?
                              kann ich die Installation mit
                              jetzt wieder starten?
                              H Thomas Braun 2 Replies Last reply Reply Quote 0
                                heli-wolf @heli-wolf last edited by
                                @heli-wolf
                                löschen.
                                Wie lösche ich diese Dateien.
                                Über Filezilla habe ich keine Berechtigung Dateien zu löschen.
                                  Nein, da hast du ganz schon rumgeaast...
                                  Da ist einiges schief.
                                  löschen.
                                  Da sollte nur
                                  drin stehen.
                                    Nicht die Datei löschen, die doppelten Zeilen darin.
                                    Geht mit einem Editor, nano z. B.
                                    sudo nano /etc/apt/sources.list.d/grafana.list
                                      Die Grafana.list habe ich mit einem Editor angesehen und sieht folgend aus:
                                      deb https://packages.grafana.com/oss/deb stable main
                                      2 davon habe ich gelöscht.
                                        @heli-wolf
                                        sudo apt update
                                          sudo apt update
                                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                            @heli-wolf
                                            apt policy grafana*
                                            1.0k
                                            6228
