    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
      Thomas Braun Most Active last edited by
      Bin gerade am Handy. Schau später mit großem Monitor mal rein. Aber da sind falsche list-Dateien und falsche Pakete installiert, wenn ich das richtig sehe.
        heli-wolf @Thomas Braun last edited by
        Vielen Dank !!!
          Thomas Braun Most Active @heli-wolf last edited by Thomas Braun
          @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
          alte Version der grafana_9.1.4_arm64.deb
          Wo kommt die denn her? Hast du die etwa am Paketmanager vorbei in das System geschraubt?
          Die mehrfach vorhandenen Einträge/Zeilen in der
          /etc/apt/sources.list.d/grafana.list
          löschen.
          Da sollte nur
          deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main
          drin stehen.
          Dann
          sudo apt purge grafana-rpi
          sudo apt update
          apt policy grafana*
            @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
            apt policy grafana*
            iobroker@iobroker:~ $ sudo apt purge grafana-rpi
            Reading package lists... Done
            Building dependency tree... Done
            The following packages were automatically installed and are no longer required:
              libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
              libpng16-16:armhf libuuid1:armhf zlib1g:armhf
            Use 'sudo apt autoremove' to remove them.
            The following packages will be REMOVED:
              grafana-rpi:armhf*
            0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
            After this operation, 258 MB disk space will be freed.
            Do you want to continue? [Y/n] y
            (Reading database ... 54954 files and directories currently installed.)
            Removing grafana-rpi:armhf (9.1.4) ...
            (Reading database ... 47955 files and directories currently installed.)
            Purging configuration files for grafana-rpi:armhf (9.1.4) ...
            dpkg: warning: while removing grafana-rpi:armhf, directory '/etc/grafana' not empty so not removed
            dpkg: warning: while removing grafana-rpi:armhf, directory '/usr/lib/systemd/system' not empty so not removed
            iobroker@iobroker:~ $ sudo apt update
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://packages.grafana.com/oss/deb stable InRelease
            Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
            Hit:7 https://repos.influxdata.com/debian bullseye InRelease
            All packages are up to date.
            W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
            W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
            W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
            W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
            W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
            W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
            W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
            W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
            W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
            W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
            iobroker@iobroker:~ $ apt policy grafana*
            N: Unable to locate package grafana_9.1.4_armhf.deb
            N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
            N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
            sollten die Fehler jetzt behoben sein?
            kann ich die Installation mit
            sudo apt install grafana
            jetzt wieder starten?
            H Thomas Braun 2 Replies Last reply Reply Quote 0
              heli-wolf @heli-wolf last edited by
              @heli-wolf
              löschen.
              Wie lösche ich diese Dateien.
              Über Filezilla habe ich keine Berechtigung Dateien zu löschen.
                Nein, da hast du ganz schon rumgeaast...
                Da ist einiges schief.
                löschen.
                Da sollte nur
                drin stehen.
                  Nicht die Datei löschen, die doppelten Zeilen darin.
                  Geht mit einem Editor, nano z. B.
                  sudo nano /etc/apt/sources.list.d/grafana.list
                    Die Grafana.list habe ich mit einem Editor angesehen und sieht folgend aus:
                    deb https://packages.grafana.com/oss/deb stable main
                    2 davon habe ich gelöscht.
                      @heli-wolf
                      sudo apt update
                        sudo apt update
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                          @heli-wolf
                          apt policy grafana*
                            apt policy grafana*
                              @heli-wolf
                              Die drei hast du mal versucht manuell zu installieren? Per dpgk oder wie?
                                kann sein, ich habe vieles versucht.
                                  @heli-wolf
                                  apt install grafana-rpi --dry-run
                                    iobroker@iobroker:~ $ apt install grafana-rpi --dry-run
                                    NOTE: This is only a simulation!
                                          apt needs root privileges for real execution.
                                          Keep also in mind that locking is deactivated,
                                          so don't depend on the relevance to the real current situation!
                                    The following NEW packages will be installed:
                                      grafana-rpi:armhf
                                    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                    Inst grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                                    Conf grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                                      @heli-wolf
                                      .k
                                      apt install grafana --dry-run
                                        iobroker@iobroker:~ $ apt install grafana --dry-run
                                        Use 'apt autoremove' to remove them.
                                          grafana
                                        Inst grafana (9.1.4 grafana stable:stable [arm64])
                                        Conf grafana (9.1.4 grafana stable:stable [arm64])
                                          sudo apt autoremove
                                            sudo apt autoremove
                                            iobroker@iobroker:~ $ sudo apt install grafana
                                              grafana
                                            Need to get 0 B/76.8 MB of archives.
                                            After this operation, 271 MB of additional disk space will be used.
                                            (Reading database ... 47950 files and directories currently installed.)
                                            Preparing to unpack .../grafana_9.1.4_arm64.deb ...
                                            Unpacking grafana (9.1.4) ...
                                            Setting up grafana (9.1.4) ...
                                            ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                                             sudo /bin/systemctl daemon-reload
                                             sudo /bin/systemctl enable grafana-server
                                            ### You can start grafana-server by executing
                                             sudo /bin/systemctl start grafana-server
                                            iobroker@iobroker:~ $ sudo apt autoremove
                                            0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
                                            After this operation, 2,598 kB disk space will be freed.
                                            Removing libfontconfig1:armhf (2.13.1-4.2) ...
                                            Removing libfreetype6:armhf (2.10.4+dfsg-1+deb11u1) ...
                                            Removing libbrotli1:armhf (1.0.9-2+b2) ...
                                            Removing libexpat1:armhf (2.2.10-2+deb11u3) ...
                                            Removing libpng16-16:armhf (1.6.37-3) ...
                                            Removing libuuid1:armhf (2.36.1-8+deb11u1) ...
                                            Removing zlib1g:armhf (1:1.2.11.dfsg-2+deb11u2) ...
                                            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
                                            6235
