    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
      Thomas Braun Most Active @heli-wolf last edited by Thomas Braun
      @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
      alte Version der grafana_9.1.4_arm64.deb
      Wo kommt die denn her? Hast du die etwa am Paketmanager vorbei in das System geschraubt?
      Die mehrfach vorhandenen Einträge/Zeilen in der
      /etc/apt/sources.list.d/grafana.list
      löschen.
      Da sollte nur
      deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main
      drin stehen.
      Dann
      sudo apt purge grafana-rpi
      sudo apt update
      apt policy grafana*
        heli-wolf @Thomas Braun last edited by
        @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
        apt policy grafana*
        iobroker@iobroker:~ $ sudo apt purge grafana-rpi
        Reading package lists... Done
        Building dependency tree... Done
        The following packages were automatically installed and are no longer required:
          libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
          libpng16-16:armhf libuuid1:armhf zlib1g:armhf
        Use 'sudo apt autoremove' to remove them.
        The following packages will be REMOVED:
          grafana-rpi:armhf*
        0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
        After this operation, 258 MB disk space will be freed.
        Do you want to continue? [Y/n] y
        (Reading database ... 54954 files and directories currently installed.)
        Removing grafana-rpi:armhf (9.1.4) ...
        (Reading database ... 47955 files and directories currently installed.)
        Purging configuration files for grafana-rpi:armhf (9.1.4) ...
        dpkg: warning: while removing grafana-rpi:armhf, directory '/etc/grafana' not empty so not removed
        dpkg: warning: while removing grafana-rpi:armhf, directory '/usr/lib/systemd/system' not empty so not removed
        iobroker@iobroker:~ $ sudo apt update
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://packages.grafana.com/oss/deb stable InRelease
        Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
        Hit:7 https://repos.influxdata.com/debian bullseye InRelease
        All packages are up to date.
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
        W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
        iobroker@iobroker:~ $ apt policy grafana*
        N: Unable to locate package grafana_9.1.4_armhf.deb
        N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
        N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
        sollten die Fehler jetzt behoben sein?
        kann ich die Installation mit
        sudo apt install grafana
        jetzt wieder starten?
        H Thomas Braun 2 Replies Last reply Reply Quote 0
          heli-wolf @heli-wolf last edited by
          @heli-wolf
          löschen.
          Wie lösche ich diese Dateien.
          Über Filezilla habe ich keine Berechtigung Dateien zu löschen.
            Nein, da hast du ganz schon rumgeaast...
            Da ist einiges schief.
            löschen.
            Da sollte nur
            drin stehen.
              Nicht die Datei löschen, die doppelten Zeilen darin.
              Geht mit einem Editor, nano z. B.
              sudo nano /etc/apt/sources.list.d/grafana.list
                Die Grafana.list habe ich mit einem Editor angesehen und sieht folgend aus:
                deb https://packages.grafana.com/oss/deb stable main
                2 davon habe ich gelöscht.
                  @heli-wolf
                  sudo apt update
                    sudo apt update
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                      @heli-wolf
                      apt policy grafana*
                        apt policy grafana*
                          @heli-wolf
                          Die drei hast du mal versucht manuell zu installieren? Per dpgk oder wie?
                            kann sein, ich habe vieles versucht.
                              @heli-wolf
                              apt install grafana-rpi --dry-run
                                iobroker@iobroker:~ $ apt install grafana-rpi --dry-run
                                NOTE: This is only a simulation!
                                      apt needs root privileges for real execution.
                                      Keep also in mind that locking is deactivated,
                                      so don't depend on the relevance to the real current situation!
                                The following NEW packages will be installed:
                                  grafana-rpi:armhf
                                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                Inst grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                                Conf grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                                  @heli-wolf
                                  .k
                                  apt install grafana --dry-run
                                    iobroker@iobroker:~ $ apt install grafana --dry-run
                                    Use 'apt autoremove' to remove them.
                                      grafana
                                    Inst grafana (9.1.4 grafana stable:stable [arm64])
                                    Conf grafana (9.1.4 grafana stable:stable [arm64])
                                      sudo apt autoremove
                                        sudo apt autoremove
                                        iobroker@iobroker:~ $ sudo apt install grafana
                                          grafana
                                        Need to get 0 B/76.8 MB of archives.
                                        After this operation, 271 MB of additional disk space will be used.
                                        (Reading database ... 47950 files and directories currently installed.)
                                        Preparing to unpack .../grafana_9.1.4_arm64.deb ...
                                        Unpacking grafana (9.1.4) ...
                                        Setting up grafana (9.1.4) ...
                                        ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                                         sudo /bin/systemctl daemon-reload
                                         sudo /bin/systemctl enable grafana-server
                                        ### You can start grafana-server by executing
                                         sudo /bin/systemctl start grafana-server
                                        iobroker@iobroker:~ $ sudo apt autoremove
                                        0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
                                        After this operation, 2,598 kB disk space will be freed.
                                        Removing libfontconfig1:armhf (2.13.1-4.2) ...
                                        Removing libfreetype6:armhf (2.10.4+dfsg-1+deb11u1) ...
                                        Removing libbrotli1:armhf (1.0.9-2+b2) ...
                                        Removing libexpat1:armhf (2.2.10-2+deb11u3) ...
                                        Removing libpng16-16:armhf (1.6.37-3) ...
                                        Removing libuuid1:armhf (2.36.1-8+deb11u1) ...
                                        Removing zlib1g:armhf (1:1.2.11.dfsg-2+deb11u2) ...
                                        Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
                                          systemctl status grafana-server.service
                                          sudo systemctl daemon-reload
                                          sudo systemctl enable grafana-server
                                            nach dem ersten Befehl
                                            kam folgendes:
                                            Warning: The unit file, source configuration file or drop-ins of grafana-server>
                                            ● grafana-server.service - Grafana instance
                                                 Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
                                                 Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 27m>
                                                   Docs: http://docs.grafana.org
                                                Process: 15830 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
                                               Main PID: 15830 (code=killed, signal=SYS)
                                                    CPU: 68ms
                                            Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart >
                                            Sep 12 19:52:17 iobroker systemd[1]: Stopped Grafana instance.
                                            Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repe>
                                            Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result>
                                            Sep 12 19:52:17 iobroker systemd[1]: Failed to start Grafana instance.
                                            6235
