    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
      Thomas Braun Most Active @heli-wolf last edited by
      @heli-wolf
      sudo apt update
        heli-wolf @Thomas Braun last edited by
        @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
        sudo apt update
        iobroker@iobroker:~ $ sudo apt update
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
        Hit:7 https://repos.influxdata.com/debian bullseye InRelease
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
          @heli-wolf
          apt policy grafana*
            apt policy grafana*
            iobroker@iobroker:~ $ apt policy grafana*
            N: Unable to locate package grafana_9.1.4_armhf.deb
            N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
            N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
              Thomas Braun Most Active @heli-wolf last edited by Thomas Braun
              @heli-wolf
              Die drei hast du mal versucht manuell zu installieren? Per dpgk oder wie?
                kann sein, ich habe vieles versucht.
                  @heli-wolf
                  apt install grafana-rpi --dry-run
                    iobroker@iobroker:~ $ apt install grafana-rpi --dry-run
                    NOTE: This is only a simulation!
                          apt needs root privileges for real execution.
                          Keep also in mind that locking is deactivated,
                          so don't depend on the relevance to the real current situation!
                    The following NEW packages will be installed:
                      grafana-rpi:armhf
                    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                    Inst grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                    Conf grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                      @heli-wolf
                      .k
                      apt install grafana --dry-run
                        iobroker@iobroker:~ $ apt install grafana --dry-run
                        The following packages were automatically installed and are no longer required:
                          libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
                          libpng16-16:armhf libuuid1:armhf zlib1g:armhf
                        Use 'apt autoremove' to remove them.
                          grafana
                        Inst grafana (9.1.4 grafana stable:stable [arm64])
                        Conf grafana (9.1.4 grafana stable:stable [arm64])
                          @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
                          sudo apt install grafana
                          sudo apt autoremove
                            sudo apt autoremove
                            iobroker@iobroker:~ $ sudo apt install grafana
                            Use 'sudo apt autoremove' to remove them.
                              grafana
                            Need to get 0 B/76.8 MB of archives.
                            After this operation, 271 MB of additional disk space will be used.
                            (Reading database ... 47950 files and directories currently installed.)
                            Preparing to unpack .../grafana_9.1.4_arm64.deb ...
                            Unpacking grafana (9.1.4) ...
                            Setting up grafana (9.1.4) ...
                            ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                             sudo /bin/systemctl daemon-reload
                             sudo /bin/systemctl enable grafana-server
                            ### You can start grafana-server by executing
                             sudo /bin/systemctl start grafana-server
                            iobroker@iobroker:~ $ sudo apt autoremove
                            The following packages will be REMOVED:
                            0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
                            After this operation, 2,598 kB disk space will be freed.
                            Do you want to continue? [Y/n] y
                            (Reading database ... 54954 files and directories currently installed.)
                            Removing libfontconfig1:armhf (2.13.1-4.2) ...
                            Removing libfreetype6:armhf (2.10.4+dfsg-1+deb11u1) ...
                            Removing libbrotli1:armhf (1.0.9-2+b2) ...
                            Removing libexpat1:armhf (2.2.10-2+deb11u3) ...
                            Removing libpng16-16:armhf (1.6.37-3) ...
                            Removing libuuid1:armhf (2.36.1-8+deb11u1) ...
                            Removing zlib1g:armhf (1:1.2.11.dfsg-2+deb11u2) ...
                            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
                              systemctl status grafana-server.service
                              sudo systemctl daemon-reload
                              sudo systemctl enable grafana-server
                                nach dem ersten Befehl
                                kam folgendes:
                                Warning: The unit file, source configuration file or drop-ins of grafana-server>
                                ● grafana-server.service - Grafana instance
                                     Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
                                     Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 27m>
                                       Docs: http://docs.grafana.org
                                    Process: 15830 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
                                   Main PID: 15830 (code=killed, signal=SYS)
                                        CPU: 68ms
                                Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart >
                                Sep 12 19:52:17 iobroker systemd[1]: Stopped Grafana instance.
                                Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repe>
                                Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result>
                                Sep 12 19:52:17 iobroker systemd[1]: Failed to start Grafana instance.
                                H Thomas Braun 2 Replies Last reply Reply Quote 0
                                  heli-wolf @heli-wolf last edited by
                                  @heli-wolf
                                  rest lief ohne Probleme:
                                  iobroker@iobroker:~ $ sudo systemctl daemon-reload
                                  [sudo] password for iobroker:
                                  iobroker@iobroker:~ $ sudo systemctl enable grafana-server
                                  Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                                  Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                                    @heli-wolf
                                    Mach das Mäusekinofenster von puTTY mal breiter. Da fehlt die rechte Hälfte.
                                    Dann
                                      iobroker@iobroker:~ $ systemctl status grafana-server.service
                                           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                                           Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 31min ago
                                              CPU: 68ms
                                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
                                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repeated too quickly.
                                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result 'signal'.
                                        @heli-wolf
                                        Boote die Kiste mal durch.
                                        sudo reboot
                                        Und dann nochmal
                                               Active: active (running) since Mon 2022-09-12 21:26:33 CEST; 24s ago
                                             Main PID: 650 (grafana-server)
                                                Tasks: 15 (limit: 8986)
                                                  CPU: 2.987s
                                               CGroup: /system.slice/grafana-server.service
                                                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini ->
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-1>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=20>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=202>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmana>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T2>
                                          lines 1-20/20 (END)
                                                  CPU: 2.987s
                                                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gat>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=20>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="r>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starti>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finish>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for st>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server List>
                                          lines 1-20/20 (END)
                                                  CPU: 2.987s
                                                       └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/va>
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gateway initialization"
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=2022-09-12T21:26:50+02:00
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=650
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starting to provision alerting"
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finished to provision alerting"
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for startup"
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage starting"
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg="starting MultiOrg Alertmanager"
                                          Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
                                          lines 1-20/20 (END)
                                            @heli-wolf
                                            Läuft.
                                            sudo apt update
                                            um zu schauen ob apt/dpkg jetzt auch sauber ist.
                                            6235
