    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
      Thomas Braun Most Active @heli-wolf last edited by Thomas Braun
      @heli-wolf
      Mach das Mäusekinofenster von puTTY mal breiter. Da fehlt die rechte Hälfte.
      Dann
      systemctl status grafana-server.service
        heli-wolf @Thomas Braun last edited by
        @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
        iobroker@iobroker:~ $ systemctl status grafana-server.service
        ● grafana-server.service - Grafana instance
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
             Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 31min ago
               Docs: http://docs.grafana.org
           Main PID: 15830 (code=killed, signal=SYS)
                CPU: 68ms
        Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
        Sep 12 19:52:17 iobroker systemd[1]: Stopped Grafana instance.
        Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repeated too quickly.
        Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result 'signal'.
        Sep 12 19:52:17 iobroker systemd[1]: Failed to start Grafana instance.
          @heli-wolf
          Boote die Kiste mal durch.
          sudo reboot
          Und dann nochmal
                 Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
                 Active: active (running) since Mon 2022-09-12 21:26:33 CEST; 24s ago
               Main PID: 650 (grafana-server)
                  Tasks: 15 (limit: 8986)
                    CPU: 2.987s
                 CGroup: /system.slice/grafana-server.service
                         └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini ->
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-1>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=20>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=202>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmana>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T2>
            lines 1-20/20 (END)
                    CPU: 2.987s
                         └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gat>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=20>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="r>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starti>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finish>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for st>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server List>
            lines 1-20/20 (END)
                    CPU: 2.987s
                         └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/va>
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gateway initialization"
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=2022-09-12T21:26:50+02:00
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=650
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starting to provision alerting"
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finished to provision alerting"
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for startup"
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage starting"
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg="starting MultiOrg Alertmanager"
            Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
            lines 1-20/20 (END)
              @heli-wolf
              Läuft.
              sudo apt update
              um zu schauen ob apt/dpkg jetzt auch sauber ist.
                sudo apt update
                iobroker@iobroker:~ $ sudo apt update
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                Reading package lists... Done
                Building dependency tree... Done
                All packages are up to date.
                  @heli-wolf
                  Gut.
                  Und
                  apt policy grafana*
                  spuckt jetzt auch die Versionen aus den Repos aus und nicht mehr die .deb-Dateien?
                    apt policy grafana*
                    iobroker@iobroker:~ $ apt policy grafana*
                    N: Unable to locate package grafana_9.1.4_armhf.deb
                    N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                    N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                      @heli-wolf
                      Nochmal. Wo hast du die drei genannten Dateien her und wo hast du die abgelegt und wie hast du die installiert?
                        Das war ein Onlinekurs von Stefan auf Verdrahtet.com
                        Die Installation war:
                        wget https://dl.grafana.com/oss/release/grafana-rpi_7.5.0_armhf.deb
                        sudo dpkg -i grafana-rpi_7.5.0_armhf.deb
                        sudo /bin/systemctl enable grafana-server
                        sudo /bin/systemctl start grafana-server
                        und die anderen Beiden habe ich von diversen Internetrecherchen ebenfalls versucht.
                          @heli-wolf
                          Mit Verlaub...
                          Ganz große Grütze wird da verzapft.
                          Dann leg dir die Datein nochmal genau dorthin wo sie zuerst waren.
                          Du hast die zwischenzeitlich gelöscht, vermute ich?
                            sollte ich die drei befehle nochmals ausführen?
                            sudo dpkg -i grafana-rpi_9.1.4_armhf.deb
                            den dritten weiß ich nicht mehr wo der her ist
                              @heli-wolf
                              NEIN!
                              -i bedeutet Installieren, das willst du ja gerade nicht.
                              dpkg -l grafana
                              dpkg -l grafana-rpi
                                iobroker@iobroker:~ $ dpkg -l grafana
                                Desired=Unknown/Install/Remove/Purge/Hold
                                | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                                |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                                ||/ Name           Version      Architecture Description
                                ii  grafana        9.1.4        arm64        Grafana
                                iobroker@iobroker:~ $ dpkg -l grafana-rpi
                                dpkg-query: no packages found matching grafana-rpi
                                  @heli-wolf
                                  Irgendwo hängt der .deb-Mist noch drin. Ich weiß nur nicht wo, weil man eigentlich nie Pakete auf diese Art installiert, man nutzt immer apt oder apt-get oder sonst einen 'intelligenten' Paketmanager, aber nicht dpkg.
                                  Wenn du also nochmal irgendwo dpkg -i oder sowas lesen solltest: Mach die Seite gleich zu, ist zu 99% Quark.
                                  sudo apt-get clean
                                  versuchen.
                                    iobroker@iobroker:~ $ sudo apt-get clean
                                      @heli-wolf
                                      Kommt jetzt bei
                                      apt policy grafana*
                                      was anderes als die drei gestrandeten deb-files?
                                        apt policy grafana*
                                          @heli-wolf
                                          apt-cache showpkg grafana-rpi
                                             Description Language:
                                                             File: /var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages
                                                              MD5: ae5be29cb6f62180c4b5d1500e319aca
                                            6.1.3 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                            6.1.2 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                            6.1.1 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                            6.1.0 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                            Reverse Depends:
                                            Dependencies:
                                            9.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null))
                                            7.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.1.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.1.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.1.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.1.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.1.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.0.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.0.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.0.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.0.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.0.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.0.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            7.0.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.7.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.7.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.7.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.7.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.7.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.7.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.6.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.6.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.6.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.5.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.5.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.5.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.5.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.4.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.4.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.4.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.4.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.4.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.7 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.2.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.2.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.2.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.1.6 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.1.5 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.1.4 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.1.3 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.1.2 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.1.1 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            6.1.0 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                            Provides:
                                            9.1.0 -
                                            7.4.0 -
                                            7.3.3 -
                                            7.3.2 -
                                            7.3.1 -
                                            7.3.0 -
                                            7.2.2 -
                                            7.2.1 -
                                            7.2.0 -
                                            7.1.5 -
                                            7.1.4 -
                                            7.1.3 -
                                            7.1.2 -
                                            7.1.1 -
                                            7.1.0 -
                                            7.0.6 -
                                            7.0.5 -
                                            7.0.4 -
                                            7.0.3 -
                                            7.0.2 -
                                            7.0.1 -
                                            7.0.0 -
                                            6.7.6 -
                                            6.7.4 -
                                            6.7.3 -
                                            6.7.2 -
                                            6.7.1 -
                                            6.7.0 -
                                            6.6.2 -
                                            6.6.1 -
                                            6.6.0 -
                                            6.5.3 -
                                            6.5.2 -
                                            6.5.1 -
                                            6.5.0 -
                                            6.4.5 -
                                            6.4.4 -
                                            6.4.3 -
                                            6.4.2 -
                                            6.4.1 -
                                            6.4.0 -
                                            6.3.7 -
                                            6.3.6 -
                                            6.3.5 -
                                            6.3.4 -
                                            6.3.3 -
                                            6.3.2 -
                                            6.3.1 -
                                            6.3.0 -
                                            6.2.5 -
                                            6.2.4 -
                                            6.2.3 -
                                            6.2.2 -
                                            6.2.1 -
                                            6.2.0 -
                                            6.1.6 -
                                            6.1.5 -
                                            6.1.4 -
                                            6.1.3 -
                                            6.1.2 -
                                            6.1.1 -
                                            6.1.0 -
                                            Reverse Provides:
                                            Hier wird mir gar nicht die gesamte Liste angezeigt.
                                            6235
