    3. Off Topic
    4. Grafana
    5. Grafana Installation - Fehler grafana-rpi:armhf
      Thomas Braun Most Active @heli-wolf last edited by
      @heli-wolf
      Boote die Kiste mal durch.
      sudo reboot
      Und dann nochmal
      systemctl status grafana-server.service
        heli-wolf @Thomas Braun last edited by
        @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
        iobroker@iobroker:~ $ systemctl status grafana-server.service
        ● grafana-server.service - Grafana instance
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
             Active: active (running) since Mon 2022-09-12 21:26:33 CEST; 24s ago
               Docs: http://docs.grafana.org
           Main PID: 650 (grafana-server)
              Tasks: 15 (limit: 8986)
                CPU: 2.987s
             CGroup: /system.slice/grafana-server.service
                     └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini ->
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-1>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=20>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=202>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmana>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T2>
        lines 1-20/20 (END)
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
                CPU: 2.987s
                     └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gat>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=20>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="r>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starti>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finish>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for st>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server List>
        lines 1-20/20 (END)
                CPU: 2.987s
                     └─650 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/va>
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=live.push_http t=2022-09-12T21:26:45.201864419+02:00 level=info msg="Live Push Gateway initialization"
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ticker t=2022-09-12T21:26:45.245089302+02:00 level=info msg=starting first_tick=2022-09-12T21:26:50+02:00
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=infra.usagestats.collector t=2022-09-12T21:26:45.551953479+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=server t=2022-09-12T21:26:45.55277811+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=650
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600007286+02:00 level=info msg="starting to provision alerting"
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=provisioning.alerting t=2022-09-12T21:26:45.600505784+02:00 level=info msg="finished to provision alerting"
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert t=2022-09-12T21:26:45.601030486+02:00 level=info msg="warming cache for startup"
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=grafanaStorageLogger t=2022-09-12T21:26:45.620020442+02:00 level=info msg="storage starting"
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=ngalert.multiorg.alertmanager t=2022-09-12T21:26:45.638255863+02:00 level=info msg="starting MultiOrg Alertmanager"
        Sep 12 21:26:45 iobroker grafana-server[650]: logger=http.server t=2022-09-12T21:26:45.643460555+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
        lines 1-20/20 (END)
          @heli-wolf
          Läuft.
          sudo apt update
          um zu schauen ob apt/dpkg jetzt auch sauber ist.
            sudo apt update
            iobroker@iobroker:~ $ sudo apt update
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://packages.grafana.com/oss/deb stable InRelease
            Hit:6 https://repos.influxdata.com/debian bullseye InRelease
            Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
            Reading package lists... Done
            Building dependency tree... Done
            All packages are up to date.
              @heli-wolf
              Gut.
              Und
              apt policy grafana*
              spuckt jetzt auch die Versionen aus den Repos aus und nicht mehr die .deb-Dateien?
                apt policy grafana*
                iobroker@iobroker:~ $ apt policy grafana*
                N: Unable to locate package grafana_9.1.4_armhf.deb
                N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                  @heli-wolf
                  Nochmal. Wo hast du die drei genannten Dateien her und wo hast du die abgelegt und wie hast du die installiert?
                    Das war ein Onlinekurs von Stefan auf Verdrahtet.com
                    Die Installation war:
                    wget https://dl.grafana.com/oss/release/grafana-rpi_7.5.0_armhf.deb
                    sudo dpkg -i grafana-rpi_7.5.0_armhf.deb
                    sudo /bin/systemctl enable grafana-server
                    sudo /bin/systemctl start grafana-server
                    und die anderen Beiden habe ich von diversen Internetrecherchen ebenfalls versucht.
                      @heli-wolf
                      Mit Verlaub...
                      Ganz große Grütze wird da verzapft.
                      Dann leg dir die Datein nochmal genau dorthin wo sie zuerst waren.
                      Du hast die zwischenzeitlich gelöscht, vermute ich?
                        sollte ich die drei befehle nochmals ausführen?
                        sudo dpkg -i grafana-rpi_9.1.4_armhf.deb
                        den dritten weiß ich nicht mehr wo der her ist
                          Thomas Braun Most Active @heli-wolf last edited by Thomas Braun
                          @heli-wolf
                          NEIN!
                          -i bedeutet Installieren, das willst du ja gerade nicht.
                          dpkg -l grafana
                          dpkg -l grafana-rpi
                            iobroker@iobroker:~ $ dpkg -l grafana
                            Desired=Unknown/Install/Remove/Purge/Hold
                            | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                            |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                            ||/ Name           Version      Architecture Description
                            ii  grafana        9.1.4        arm64        Grafana
                            iobroker@iobroker:~ $ dpkg -l grafana-rpi
                            dpkg-query: no packages found matching grafana-rpi
                              @heli-wolf
                              Irgendwo hängt der .deb-Mist noch drin. Ich weiß nur nicht wo, weil man eigentlich nie Pakete auf diese Art installiert, man nutzt immer apt oder apt-get oder sonst einen 'intelligenten' Paketmanager, aber nicht dpkg.
                              Wenn du also nochmal irgendwo dpkg -i oder sowas lesen solltest: Mach die Seite gleich zu, ist zu 99% Quark.
                              sudo apt-get clean
                              versuchen.
                                iobroker@iobroker:~ $ sudo apt-get clean
                                  @heli-wolf
                                  Kommt jetzt bei
                                  apt policy grafana*
                                  was anderes als die drei gestrandeten deb-files?
                                    apt policy grafana*
                                      @heli-wolf
                                      apt-cache showpkg grafana-rpi
                                         Description Language:
                                                         File: /var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages
                                                          MD5: ae5be29cb6f62180c4b5d1500e319aca
                                        6.1.3 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                        6.1.2 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                        6.1.1 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                        6.1.0 (/var/lib/apt/lists/packages.grafana.com_oss_deb_dists_stable_main_binary-armhf_Packages)
                                        Reverse Depends:
                                        Dependencies:
                                        9.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null))
                                        7.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.1.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.1.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.1.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.1.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.1.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.1.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.0.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.0.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.0.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.0.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.0.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.0.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        7.0.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.7.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.7.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.7.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.7.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.7.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.7.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.6.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.6.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.6.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.5.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.5.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.5.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.5.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.4.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.4.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.4.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.4.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.4.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.4.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.7 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.6 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.3.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.2.5 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.2.4 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.2.3 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.2.2 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.2.1 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.2.0 - adduser:armhf (0 (null)) libfontconfig1:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.1.6 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.1.5 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.1.4 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.1.3 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.1.2 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.1.1 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        6.1.0 - adduser:armhf (0 (null)) libfontconfig:armhf (0 (null)) grafana (0 (null)) grafana:armhf (0 (null))
                                        Provides:
                                        9.1.0 -
                                        7.4.0 -
                                        7.3.3 -
                                        7.3.2 -
                                        7.3.1 -
                                        7.3.0 -
                                        7.2.2 -
                                        7.2.1 -
                                        7.2.0 -
                                        7.1.5 -
                                        7.1.4 -
                                        7.1.3 -
                                        7.1.2 -
                                        7.1.1 -
                                        7.1.0 -
                                        7.0.6 -
                                        7.0.5 -
                                        7.0.4 -
                                        7.0.3 -
                                        7.0.2 -
                                        7.0.1 -
                                        7.0.0 -
                                        6.7.6 -
                                        6.7.4 -
                                        6.7.3 -
                                        6.7.2 -
                                        6.7.1 -
                                        6.7.0 -
                                        6.6.2 -
                                        6.6.1 -
                                        6.6.0 -
                                        6.5.3 -
                                        6.5.2 -
                                        6.5.1 -
                                        6.5.0 -
                                        6.4.5 -
                                        6.4.4 -
                                        6.4.3 -
                                        6.4.2 -
                                        6.4.1 -
                                        6.4.0 -
                                        6.3.7 -
                                        6.3.6 -
                                        6.3.5 -
                                        6.3.4 -
                                        6.3.3 -
                                        6.3.2 -
                                        6.3.1 -
                                        6.3.0 -
                                        6.2.5 -
                                        6.2.4 -
                                        6.2.3 -
                                        6.2.2 -
                                        6.2.1 -
                                        6.2.0 -
                                        6.1.6 -
                                        6.1.5 -
                                        6.1.4 -
                                        6.1.3 -
                                        6.1.2 -
                                        6.1.1 -
                                        6.1.0 -
                                        Reverse Provides:
                                        Hier wird mir gar nicht die gesamte Liste angezeigt.
                                          @heli-wolf
                                          Frag den verdrahtet-Typen, wie man das sauber bekommt.
                                          Wobei... Besser nicht. Nachher kommt da noch mehr Murks bei herum.
                                            den habe ich mit meinem Problem schon kontaktiert. Seither höre und lese ich nichts mehr von ihm.
                                            6235
