    4. Test Adapter HAM 5.2.0 (GitHub)
      apollon77 @iPhilBln last edited by
      @iphilbln Ohne logging von der Library das man sieht was die tut komm ich da nicht weiter. Also am besten bitte loglevel auf "silly" und diesen erweiterten Log modus des Plugins aktivieren ... btw mal die gleichen änderungen machen die wir auf githbu schonmal durchexerziert haben.
      • iPhilBln
        @apollon77
        hab die index.js jetzt so angepasst, dass die value von den Setter und Gettern ausgegeben werden.
        getPowerState(callback) {
           let isFanOn = false;
           if (this.fanDevice && this.fanDevice.isFanConnected()) {
             isFanOn = this.fanDevice.isPowerOn();
           this.logInfo(`DEBUG: Callback -> get PowerState ${isFanOn}`);
           callback(null, isFanOn ? Characteristic.Active.ACTIVE : Characteristic.Active.INACTIVE);
         setPowerState(state, callback) {
           this.logInfo(`DEBUG: Try to set PowerState ${state}`);
             let isPowerOn = state === Characteristic.Active.ACTIVE;
             // only fire the setPowerOn method when we want to turn off the fan or the fan is off
             // the rotaion speed slider fires this method many times even when the fan is already on so i need to limit that
             if (isPowerOn === false || this.fanDevice.isPowerOn() === false) {
               this.fanDevice.setPowerOn(isPowerOn);
             this.logInfo(`DEBUG: Callback -> set PowerState {state: ${state} , isPowerOn: ${isPowerOn}}`);
             callback();
           } else {
             callback(this.createError(`cannot set power state`));
         getFanState(callback) {
           let fanState = Characteristic.CurrentFanState.INACTIVE;
             fanState = this.fanDevice.isPowerOn() ? Characteristic.CurrentFanState.BLOWING_AIR : Characteristic.CurrentFanState.IDLE
           callback(null, fanState);
         getRotationSpeed(callback) {
           let fanRotationSpeed = 0;
             fanRotationSpeed = this.fanDevice.getRotationSpeed();
             fanRotationSpeed = this.adjustToPercentageRange(fanRotationSpeed);
           this.logInfo(`DEBUG: Callback -> get Rotationspeed ${fanRotationSpeed}`);
           callback(null, fanRotationSpeed);
         setRotationSpeed(value, callback) {
           this.logInfo(`DEBUG: Try to set Rotationspeed ${value}`);
             // use debounce to limit the number of calls when the user slides the rotation slider
             if (this.rotationSpeedTimeout) clearTimeout(this.rotationSpeedTimeout);
             this.rotationSpeedTimeout = setTimeout(() => this.fanDevice.setRotationSpeed(value), 500);
             this.logInfo(`DEBUG: Callback -> set Rotationspeed ${value}`);
             callback();
           } else {
             callback(this.createError(`cannot set rotation speed`));
        Was mich wundert, dass die Getter nur ein mal aufgerufen werden, obwohl die Daten richtig abgeholt werden, wenn ich in der App den Ventilator steuer. Die Setter werden aber nie aufgerufen.
        ham.log
          @iphilbln Ein silly log bitte
          • iPhilBln
            @apollon77 gut, ich ging davon aus, dass wenn der log-level auf silly steht, auch über den Adapter debug Modus silly ankommt. Jetzt ist alles im Log enthalten.
            ham.log.zip
              @iphilbln Na dann muss ich mal lokal bei mir versuchen irgendwie der Lib vorzugaukeln das das so ein gerät ist ....
              • iPhilBln
                iPhilBln last edited by iPhilBln
                @apollon77 ich kann deine private Nachricht leider nicht öffnen. Erhalte nur folgende Fehlermeldung:
                Mein ganze Chatfunktion scheint nicht zu funktionieren:
                  @iphilbln interessant. Log dich mal aus und neu ein. Aber ist einfach: konnte es nachstellen. Muss dann nochmal was Umbauen
                  • iPhilBln
                    @apollon77 alles schon probiert. Hab auch alle Tabs geschlossen und neu geöffnet. Keine Chance...
                    Aber ok, dann weiß ich Bescheid. Sonst melde dich lieber über GitHub. Hätte sonst noch die Idee dir eine VPN Zugang zu einem Testnetzwerk bereitzustellen und einen Testaccount bei Xiaomi, damit du da mehr testen könntest
                      @iphilbln ne ich hab in der lib files so gefaked das es soweit geht wie ich es brauche.
                        apollon77 last edited by
                        So also dann neuer Versuch @iPhilBln und alle ... Bitte 5.2.2 testen
                        Fabio iPhilBln 2 Replies Last reply Reply Quote 1
                        • Fabio
                          Fabio @apollon77 last edited by Fabio
                          @apollon77 geht leider nicht.
                          2022-09-14 11:24:36.456 warn Do not restart adapter system.adapter.ham.0 because restart loop detected
                          host.nuc
                          2022-09-14 11:24:36.456	error	instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          host.nuc
                          2022-09-14 11:24:36.456	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71)
                          host.nuc
                          host.nuc
                          host.nuc
                          host.nuc
                          host.nuc
                          host.nuc
                          host.nuc
                          host.nuc
                          2022-09-14 11:24:36.456	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:82)
                          host.nuc
                          2022-09-14 11:24:36.456	error	Caught by controller[2]: at Array.shift (<anonymous>)
                          host.nuc
                          2022-09-14 11:24:36.456	error	Caught by controller[2]: [14.9.2022, 11:24:35] [ connectivity kit] RangeError: Maximum call stack size exceeded
                          host.nuc
                          2022-09-14 11:24:36.456	error	Caught by controller[1]: [14.9.2022, 11:24:35] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                          host.nuc
                          2022-09-14 11:24:36.456	error	Caught by controller[0]: [14.9.2022, 11:24:35] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                            apollon77 @Fabio last edited by
                            @fa-bio Ok,d as scheint irgendwie aber seeehr Pluginspezifisch zu sein. Hab Dir ne PN geschickt.
                            Fabio 1 Reply Last reply Reply Quote 0
                            • iPhilBln
                              iPhilBln @apollon77 last edited by
                              @apollon77 leider keine Änderung. Was mich nach wie vor wundert ist, dass die Debug Nachrichten nur 2 mal im Log bei der Initialisierung erscheinen, obwohl die Daten richtig abgeholt werden, wenn ich den Ventilator über die App steuere.
                              log : ham.log.zip
                              • Fabio
                                @apollon77
                                host.nuc
                                2022-09-14 12:14:57.525	info	Restart adapter system.adapter.ham.0 because enabled
                                host.nuc
                                2022-09-14 12:14:57.525	error	instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                host.nuc
                                2022-09-14 12:14:57.525	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71)
                                host.nuc
                                host.nuc
                                host.nuc
                                host.nuc
                                host.nuc
                                host.nuc
                                host.nuc
                                host.nuc
                                2022-09-14 12:14:57.525	error	Caught by controller[2]: at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:82)
                                host.nuc
                                2022-09-14 12:14:57.525	error	Caught by controller[2]: at Array.shift (<anonymous>)
                                host.nuc
                                2022-09-14 12:14:57.525	error	Caught by controller[2]: [14.9.2022, 12:14:56] [ connectivity kit] RangeError: Maximum call stack size exceeded
                                host.nuc
                                2022-09-14 12:14:57.525	error	Caught by controller[1]: [14.9.2022, 12:14:56] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                                host.nuc
                                2022-09-14 12:14:57.525	error	Caught by controller[0]: [14.9.2022, 12:14:56] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                                ham.0
                                2022-09-14 12:14:57.175	debug	updateState Markise.Window-Covering.Name: set postponed value = Markise
                                ham.0
                                2022-09-14 12:14:57.129	debug	updateState Flurmarkise.Window-Covering.Name: set postponed value = Flurmarkise
                                ham.0
                                2022-09-14 12:14:57.129	info	updateState Markise.Window-Covering.Name: value = Markise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:57.086	debug	updateState Markise.Window-Covering.Target-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.086	debug	updateState Elternmarkise.Window-Covering.Name: set postponed value = Elternmarkise
                                ham.0
                                2022-09-14 12:14:57.085	info	updateState Flurmarkise.Window-Covering.Name: value = Flurmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:57.084	debug	updateState Büromarkise.Window-Covering.Name: set postponed value = Büromarkise
                                ham.0
                                2022-09-14 12:14:57.083	debug	updateState Flurmarkise.Window-Covering.Target-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.083	info	updateState Markise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
                                ham.0
                                2022-09-14 12:14:57.081	info	updateState Elternmarkise.Window-Covering.Name: value = Elternmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:57.080	debug	updateState Connectivity-kit-ledBox.Lightbulb.Brightness: set postponed value = 14
                                ham.0
                                2022-09-14 12:14:57.080	info	updateState Büromarkise.Window-Covering.Name: value = Büromarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:57.079	debug	updateState Markisenbeleuchtung.Switch.Name: set postponed value = Markisenbeleuchtung
                                ham.0
                                2022-09-14 12:14:57.078	debug	updateState Markise.Window-Covering.Position-State: set postponed value = 2
                                ham.0
                                2022-09-14 12:14:57.078	info	updateState Flurmarkise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
                                ham.0
                                2022-09-14 12:14:57.074	debug	updateState Elternmarkise.Window-Covering.Target-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.074	debug	updateState Büromarkise.Window-Covering.Target-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.074	info	updateState Connectivity-kit-ledBox.Lightbulb.Brightness: value = 14 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.brightness","name":"Brightness"}
                                ham.0
                                2022-09-14 12:14:57.073	info	updateState Markisenbeleuchtung.Switch.Name: value = Markisenbeleuchtung /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:57.072	debug	updateState Flurmarkise.Window-Covering.Position-State: set postponed value = 2
                                ham.0
                                2022-09-14 12:14:57.072	info	updateState Markise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
                                ham.0
                                2022-09-14 12:14:57.071	debug	updateState Connectivity-kit-ledBox.Lightbulb.Name: set postponed value = Connectivity kit-ledBox
                                ham.0
                                2022-09-14 12:14:57.070	info	updateState Elternmarkise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
                                ham.0
                                2022-09-14 12:14:57.070	info	updateState Büromarkise.Window-Covering.Target-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":true,"role":"level.blind","name":"Target Position"}
                                ham.0
                                2022-09-14 12:14:57.069	debug	updateState Markisenbeleuchtung.Switch.On: set postponed value = false
                                ham.0
                                2022-09-14 12:14:57.068	debug	updateState Markise.Window-Covering.Current-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.068	info	updateState Flurmarkise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
                                ham.0
                                2022-09-14 12:14:57.066	debug	updateState Elternmarkise.Window-Covering.Position-State: set postponed value = 2
                                ham.0
                                2022-09-14 12:14:57.066	debug	updateState Büromarkise.Window-Covering.Position-State: set postponed value = 2
                                ham.0
                                2022-09-14 12:14:57.065	info	updateState Connectivity-kit-ledBox.Lightbulb.Name: value = Connectivity kit-ledBox /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:57.065	info	updateState Markisenbeleuchtung.Switch.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                                ham.0
                                2022-09-14 12:14:57.064	info	updateState Markise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
                                ham.0
                                2022-09-14 12:14:57.063	debug	updateState Flurmarkise.Window-Covering.Current-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.062	info	updateState Elternmarkise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
                                ham.0
                                2022-09-14 12:14:57.061	info	updateState Büromarkise.Window-Covering.Position-State: value = 2 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value.working","name":"Position State","unit":""}
                                ham.0
                                2022-09-14 12:14:57.058	debug	updateState Connectivity-kit-ledBox.Lightbulb.On: set postponed value = false
                                ham.0
                                2022-09-14 12:14:57.057	debug	updateState Elternmarkise.Window-Covering.Current-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.057	info	updateChannel Markisenbeleuchtung.Switch: name =
                                ham.0
                                2022-09-14 12:14:57.057	debug	updateState Büromarkise.Window-Covering.Current-Position: set postponed value = 0
                                ham.0
                                2022-09-14 12:14:57.055	info	updateChannel Markise.Window-Covering: name =
                                ham.0
                                2022-09-14 12:14:57.055	info	updateState Flurmarkise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
                                ham.0
                                2022-09-14 12:14:57.053	info	updateState Connectivity-kit-ledBox.Lightbulb.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                                ham.0
                                2022-09-14 12:14:57.052	info	updateState Elternmarkise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
                                ham.0
                                2022-09-14 12:14:57.051	info	updateState Büromarkise.Window-Covering.Current-Position: value = 0 /common= {"type":"number","unit":"%","min":0,"max":100,"read":true,"write":false,"role":"value.blind","name":"Current Position"}
                                ham.0
                                2022-09-14 12:14:57.051	info	updateChannel Flurmarkise.Window-Covering: name =
                                ham.0
                                2022-09-14 12:14:57.050	debug	updateState Markisenbeleuchtung.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
                                ham.0
                                2022-09-14 12:14:57.049	debug	updateState Markise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
                                ham.0
                                2022-09-14 12:14:57.048	info	updateChannel Connectivity-kit-ledBox.Lightbulb: name =
                                ham.0
                                2022-09-14 12:14:57.047	info	updateChannel Elternmarkise.Window-Covering: name =
                                ham.0
                                2022-09-14 12:14:57.046	info	updateChannel Büromarkise.Window-Covering: name =
                                ham.0
                                2022-09-14 12:14:57.045	info	updateState Markisenbeleuchtung.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
                                ham.0
                                2022-09-14 12:14:57.045	debug	updateState Flurmarkise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
                                ham.0
                                2022-09-14 12:14:57.043	info	updateState Markise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
                                ham.0
                                2022-09-14 12:14:57.043	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
                                ham.0
                                2022-09-14 12:14:57.042	debug	updateState Elternmarkise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
                                ham.0
                                2022-09-14 12:14:57.042	debug	updateState Büromarkise.Accessory-Information.Firmware-Revision: set postponed value = 2.2.40
                                ham.0
                                2022-09-14 12:14:57.041	debug	updateState Markisenbeleuchtung.Accessory-Information.Serial-Number: set postponed value = ogp:9341619
                                ham.0
                                2022-09-14 12:14:56.998	info	updateState Flurmarkise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
                                ham.0
                                2022-09-14 12:14:56.998	debug	updateState Markise.Accessory-Information.Serial-Number: set postponed value = ogp:922101
                                ham.0
                                2022-09-14 12:14:56.997	info	updateState Connectivity-kit-ledBox.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
                                ham.0
                                2022-09-14 12:14:56.996	info	updateState Büromarkise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
                                ham.0
                                2022-09-14 12:14:56.995	info	updateState Markisenbeleuchtung.Accessory-Information.Serial-Number: value = ogp:9341619 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
                                ham.0
                                2022-09-14 12:14:56.996	info	updateState Elternmarkise.Accessory-Information.Firmware-Revision: value = 2.2.40 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
                                ham.0
                                2022-09-14 12:14:56.994	debug	updateState Flurmarkise.Accessory-Information.Serial-Number: set postponed value = ogp:6106340
                                ham.0
                                2022-09-14 12:14:56.993	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Serial-Number: set postponed value = ogp:15728639
                                ham.0
                                2022-09-14 12:14:56.993	debug	updateState Elternmarkise.Accessory-Information.Serial-Number: set postponed value = ogp:13160805
                                ham.0
                                2022-09-14 12:14:56.992	debug	updateState Büromarkise.Accessory-Information.Serial-Number: set postponed value = ogp:12414329
                                ham.0
                                2022-09-14 12:14:56.992	info	updateState Markise.Accessory-Information.Serial-Number: value = ogp:922101 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
                                ham.0
                                2022-09-14 12:14:56.991	debug	updateState Markisenbeleuchtung.Accessory-Information.Name: set postponed value = Markisenbeleuchtung
                                ham.0
                                2022-09-14 12:14:56.990	info	updateState Flurmarkise.Accessory-Information.Serial-Number: value = ogp:6106340 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
                                ham.0
                                2022-09-14 12:14:56.989	info	updateState Connectivity-kit-ledBox.Accessory-Information.Serial-Number: value = ogp:15728639 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
                                ham.0
                                2022-09-14 12:14:56.988	info	updateState Elternmarkise.Accessory-Information.Serial-Number: value = ogp:13160805 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
                                ham.0
                                2022-09-14 12:14:56.988	info	updateState Büromarkise.Accessory-Information.Serial-Number: value = ogp:12414329 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
                                ham.0
                                2022-09-14 12:14:56.988	debug	updateState Markise.Accessory-Information.Name: set postponed value = Markise
                                ham.0
                                2022-09-14 12:14:56.987	info	updateState Markisenbeleuchtung.Accessory-Information.Name: value = Markisenbeleuchtung /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:56.986	debug	updateState Flurmarkise.Accessory-Information.Name: set postponed value = Flurmarkise
                                ham.0
                                2022-09-14 12:14:56.985	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Name: set postponed value = Connectivity kit-ledBox
                                ham.0
                                2022-09-14 12:14:56.985	debug	updateState Elternmarkise.Accessory-Information.Name: set postponed value = Elternmarkise
                                ham.0
                                2022-09-14 12:14:56.984	debug	updateState Büromarkise.Accessory-Information.Name: set postponed value = Büromarkise
                                ham.0
                                2022-09-14 12:14:56.984	info	updateState Markise.Accessory-Information.Name: value = Markise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:56.983	debug	updateState Markisenbeleuchtung.Accessory-Information.Model: set postponed value = Light
                                ham.0
                                2022-09-14 12:14:56.982	info	updateState Flurmarkise.Accessory-Information.Name: value = Flurmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:56.982	info	updateState Connectivity-kit-ledBox.Accessory-Information.Name: value = Connectivity kit-ledBox /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:56.981	info	updateState Elternmarkise.Accessory-Information.Name: value = Elternmarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:56.980	info	updateState Büromarkise.Accessory-Information.Name: value = Büromarkise /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                ham.0
                                2022-09-14 12:14:56.978	debug	updateState Markise.Accessory-Information.Model: set postponed value = Awning
                                ham.0
                                2022-09-14 12:14:56.978	debug	updateState Flurmarkise.Accessory-Information.Model: set postponed value = Awning
                                ham.0
                                2022-09-14 12:14:56.978	info	updateState Markisenbeleuchtung.Accessory-Information.Model: value = Light /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
                                ham.0
                                2022-09-14 12:14:56.978	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Model: set postponed value = Light
                                ham.0
                                2022-09-14 12:14:56.977	debug	updateState Elternmarkise.Accessory-Information.Model: set postponed value = Awning
                                ham.0
                                2022-09-14 12:14:56.977	debug	updateState Büromarkise.Accessory-Information.Model: set postponed value = Awning
                                ham.0
                                2022-09-14 12:14:56.974	info	updateState Markise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
                                ham.0
                                2022-09-14 12:14:56.974	info	updateState Flurmarkise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
                                ham.0
                                2022-09-14 12:14:56.972	info	updateState Connectivity-kit-ledBox.Accessory-Information.Model: value = Light /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
                                ham.0
                                2022-09-14 12:14:56.972	info	updateState Elternmarkise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
                                ham.0
                                2022-09-14 12:14:56.972	info	updateState Büromarkise.Accessory-Information.Model: value = Awning /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
                                ham.0
                                2022-09-14 12:14:56.970	debug	updateState Markisenbeleuchtung.Accessory-Information.Manufacturer: set postponed value = Somfy
                                ham.0
                                2022-09-14 12:14:56.969	debug	updateState Markise.Accessory-Information.Manufacturer: set postponed value = Somfy
                                ham.0
                                2022-09-14 12:14:56.969	debug	updateState Flurmarkise.Accessory-Information.Manufacturer: set postponed value = Somfy
                                ham.0
                                2022-09-14 12:14:56.968	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Manufacturer: set postponed value = Somfy
                                ham.0
                                2022-09-14 12:14:56.968	debug	updateState Elternmarkise.Accessory-Information.Manufacturer: set postponed value = Somfy
                                ham.0
                                2022-09-14 12:14:56.968	debug	updateState Büromarkise.Accessory-Information.Manufacturer: set postponed value = Somfy
                                ham.0
                                2022-09-14 12:14:56.966	info	updateState Markisenbeleuchtung.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
                                ham.0
                                2022-09-14 12:14:56.966	info	updateState Markise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
                                ham.0
                                2022-09-14 12:14:56.965	info	updateState Flurmarkise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
                                ham.0
                                2022-09-14 12:14:56.965	info	updateState Connectivity-kit-ledBox.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
                                ham.0
                                2022-09-14 12:14:56.964	info	updateState Elternmarkise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
                                ham.0
                                2022-09-14 12:14:56.963	info	updateState Büromarkise.Accessory-Information.Manufacturer: value = Somfy /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
                                ham.0
                                2022-09-14 12:14:56.963	debug	updateState Markisenbeleuchtung.Accessory-Information.Identify: set value = false
                                ham.0
                                2022-09-14 12:14:56.962	debug	updateState Markise.Accessory-Information.Identify: set value = false
                                ham.0
                                2022-09-14 12:14:56.962	debug	updateState Flurmarkise.Accessory-Information.Identify: set value = false
                                ham.0
                                2022-09-14 12:14:56.961	debug	updateState Connectivity-kit-ledBox.Accessory-Information.Identify: set value = false
                                ham.0
                                2022-09-14 12:14:56.961	debug	updateState Elternmarkise.Accessory-Information.Identify: set value = false
                                ham.0
                                2022-09-14 12:14:56.959	debug	updateState Büromarkise.Accessory-Information.Identify: set value = false
                                ham.0
                                2022-09-14 12:14:56.958	info	updateState Markisenbeleuchtung.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                                ham.0
                                2022-09-14 12:14:56.958	info	updateState Markise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                                ham.0
                                2022-09-14 12:14:56.958	info	updateState Flurmarkise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                                ham.0
                                2022-09-14 12:14:56.957	info	updateState Connectivity-kit-ledBox.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                                ham.0
                                2022-09-14 12:14:56.957	info	updateState Elternmarkise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                                ham.0
                                2022-09-14 12:14:56.956	info	updateState Büromarkise.Accessory-Information.Identify: value = false /common= {"type":"boolean","read":false,"write":true,"role":"button","name":"Identify","unit":""}
                                ham.0
                                2022-09-14 12:14:56.953	info	updateChannel Markisenbeleuchtung.Accessory-Information: name =
                                ham.0
                                2022-09-14 12:14:56.952	info	updateChannel Markise.Accessory-Information: name =
                                ham.0
                                2022-09-14 12:14:56.952	info	updateChannel Flurmarkise.Accessory-Information: name =
                                ham.0
                                2022-09-14 12:14:56.951	info	updateChannel Connectivity-kit-ledBox.Accessory-Information: name =
                                ham.0
                                2022-09-14 12:14:56.951	info	updateChannel Elternmarkise.Accessory-Information: name =
                                ham.0
                                2022-09-14 12:14:56.950	info	updateChannel Büromarkise.Accessory-Information: name =
                                ham.0
                                2022-09-14 12:14:56.947	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                ham.0
                                2022-09-14 12:14:56.947	info	terminating
                                ham.0
                                2022-09-14 12:14:56.943	info	cleaned everything up...
                                ham.0
                                2022-09-14 12:14:56.935	error	Maximum call stack size exceeded
                                ham.0
                                2022-09-14 12:14:56.934	error	RangeError: Maximum call stack size exceeded at Array.shift (<anonymous>) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:82) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71) at Function.debug (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tahoma/src/Platform.ts:54:71)
                                ham.0
                                2022-09-14 12:14:56.926	error	unhandled promise rejection: Maximum call stack size exceeded
                                ham.0
                                2022-09-14 12:14:56.926	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                ham.0
                                2022-09-14 12:14:56.925	debug	setState Markise.Window-Covering.Name: set value = Markise
                                ham.0
                                2022-09-14 12:14:56.923	debug	Char change event: undefined --> Markise
                                ham.0
                                2022-09-14 12:14:56.923	debug	setState Flurmarkise.Window-Covering.Name: set value = Flurmarkise
                                ham.0
                                2022-09-14 12:14:56.922	debug	Char change event: undefined --> Flurmarkise
                                ham.0
                                2022-09-14 12:14:56.922	debug	setState Elternmarkise.Window-Covering.Name: set value = Elternmarkise
                                ham.0
                                2022-09-14 12:14:56.920	debug	Char change event: undefined --> Elternmarkise
                                ham.0
                                2022-09-14 12:14:56.920	debug	setState Büromarkise.Window-Covering.Name: set value = Büromarkise
                                ham.0
                                2022-09-14 12:14:56.918	debug	Char change event: undefined --> Büromarkise
                                ham.0
                                2022-09-14 12:14:56.918	debug	setState Markise.Window-Covering.Target-Position: set value = 0
                                ham.0
                                2022-09-14 12:14:56.916	debug	setState Flurmarkise.Window-Covering.Target-Position: set value = 0
                                ham.0
                                2022-09-14 12:14:56.915	debug	Char change event: undefined --> 0
                                ham.0
                                2022-09-14 12:14:56.916	debug	Char change event: undefined --> 0
                                ham.0
                                2022-09-14 12:14:56.915	debug	setState Connectivity-kit-ledBox.Lightbulb.Brightness: set value = 14
                                ham.0
                                2022-09-14 12:14:56.913	debug	Char change event: undefined --> 14
                                ham.0
                                2022-09-14 12:14:56.913	debug	setState Elternmarkise.Window-Covering.Target-Position: set value = 0
                                ham.0
                                2022-09-14 12:14:56.911	debug	Char change event: undefined --> 0
                                ham.0
                                2022-09-14 12:14:56.911	debug	setState Büromarkise.Window-Covering.Target-Position: set value = 0
                                ham.0
                                2022-09-14 12:14:56.909	debug	Char change event: undefined --> 0
                                ham.0
                                2022-09-14 12:14:56.909	debug	setState Markisenbeleuchtung.Switch.Name: set value = Markisenbeleuchtung
                                ham.0
                                2022-09-14 12:14:56.907	debug	Char change event: undefined --> Markisenbeleuchtung
                                ham.0
                                2022-09-14 12:14:56.907	debug	setState Markise.Window-Covering.Position-State: set value = 2
                                  apollon77 @iPhilBln last edited by apollon77
                                  @iphilbln Du hast aber schon gesehen was er so geloggt hat?
                                  zb:
                                  2022-09-14 11:32:18.033 - debug: ham.0 (106531) Characteristic warning for Standventilator.Standventilator.Swing-Mode: warn-message characteristic was supplied illegal value: number 30 exceeded maximum of 1 Error:
                                  Rotation Speed auf 30 sieht für mich so aus als ob es geklappt hat weil es vom device nochmal bestätigt wurde
                                  Ok nur Active ist komisch ...ich schaue nochmal
                                  EDIT: Ne nix komisch nur meine lokalen Fake-Änderungen weil ich so ein Gerät nicht habe waren weg ...
                                  Also bei mir geht das alles und es ändern sich auch werte.
                                  Bei Dir im Log ist nur auffällig das Du Active scheinbar immer aus schaltest (auf 0) .... die 1-Werte kommen immer nur wenn das gerät die setzt scheinbar ?!
                                  Ich bin gerade am Ende meiner Idee was Dein Xiaomi Fan kram angeht. Lokal kann ich sehen das die Calls da in der Library ankommen wo Sie sollen ... Keine Idee warum das bei dir nicht tut
                                  iPhilBln 1 Reply Last reply Reply Quote 0
                                  • iPhilBln
                                    @apollon77
                                    --> War mein versehen, hab den falschen Datenpunkt geändert weil der direkt unter fanspeed ist. Hat also keine Aussagekraft.
                                    Hmm ja wie gesagt, wenn ich im ioBroker die Datenpunkte ändere kommt nichts an, würde ja sonst auch im Log stehen. Hatte jetzt in der Zwischenzeit auch mal den gesamten Adapter gelöscht und nen clean install durchgeführt aber Verhalten bleibt identisch. Daten werden abgeholt, können aber nicht gesetzt werden.
                                    Sofern du Lust und Zeit hast könntest du mir noch eine index.js (oder auch andere Dateien) zukommen lassen, wo weitere logging Punkte enthalten sind. Dann füge ich die gerne mit ein. Mehr kann ich denke ich nicht tun bis auf das Angebot mit nem VPN Zugang. Trotzdem schon mal riesen Dank für deine Bemühungen.
                                      @iphilbln sagte in Test Adapter HAM 5.2.0 (GitHub):
                                      Und du bist sicher das die index.js noch mit dem Logging drin und nicht überschrieben wurde? 🙂
                                      naja neben VPN wäre ich eher bei einer Anydesk session. Freitag ggf dafür zeit
                                        @fa-bio Ok, seems there was a buggy plugin version on npm ... we try if fixed version of plugin work again
                                        Fabio 1 Reply Last reply Reply Quote 1
                                        • Fabio
                                          @apollon77 ich danke dir ganz herzlich.
                                          So, dank dir läuft jetzt auch die 5.2.2 perfekt mit dem homebridge-tahoma@2.241 Plug in. 👍
                                          • iPhilBln
                                            iPhilBln @apollon77 last edited by iPhilBln
                                            @apollon77 ja bin mir da absolut sicher.
                                            Ich bearbeite die über VS Code mit nem ssh Zugang.
                                            Dein Wrapper Modul lädt die Module unter folgendem Pfad:
                                            /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-xiaomi-fan
                                            Die index.js sieht aktuell wie folgt aus:
                                             /*----------========== HOMEBRIDGE STATE SETTERS/GETTERS ==========----------*/
                                                this.logInfo(`DEBUG: getPowerState() -> Callback: ${isFanOn}`);
                                                this.logInfo(`DEBUG: setPowerState() -> value: ${state}`);
                                                  this.logInfo(`DEBUG: setPowerState() -> Callback: ${isPowerOn}`);
                                                  callback();
                                                } else {
                                                  this.logInfo(`DEBUG: setPowerState() -> Callback: cannot set power state`);
                                                this.logInfo(`DEBUG: getFanState() -> Callback: ${fanState}`);
                                                this.logInfo(`DEBUG: getRotationSpeed() -> Callback: ${fanRotationSpeed}`);
                                                this.logInfo(`DEBUG: setRotationSpeed() -> value: ${value}`);
                                                  this.logInfo(`DEBUG: setRotationSpeed() -> Callback: ${value}`);
                                                  callback();
                                                } else {
                                                  this.logInfo(`DEBUG: setRotationSpeed() -> Callback: cannot set rotation speed`);
                                            Hab es eben nochmal über das Terminal kontrolliert dass auch die richtige index.js editiert wird in VS Code.
                                            Ich logge mit folgendem Befehl:
                                            tail -f /opt/iobroker/log/iobroker.current.log | grep ham.0 > ham.log
                                            Danach kopiere ich es rüber auf meine Mac mit dem Befehl:
                                            scp ham.log philippmielke@10.0.10.4:/Users/philippmielke/Desktop/ham.log
                                            Im Log steht dann folgendes:
                                            states können gesetzt werden: ham.log.zip
                                            states können NICHT gesetzt werden: ham_kaputt.log.zip
                                            31.7k
                                            79.8k
                                            93
                                            7082
