    4. Material Design Widgets: Wetter View
      AKuehnemann73 last edited by
      So habe das Widget jetzt auch mal in anderen Views und Projekten probiert.
      Leider ändert sich nichts. Auch hier wird die View die ich eingetragen habe nicht geöffnet.
      Der Dialog bleibt leer / ohne Inhalt.
      • Glasfaser
        Glasfaser @AKuehnemann73 last edited by
        @akuehnemann73 sagte in Material Design Widgets: Wetter View:
        Nimm dieses neue Dialog Widget und passe nur deine View an .
        [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"360","vibrateOnMobilDevices":"50","buttonStyle":"raised","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.secondary","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.default.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text","imageColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.button_icon","iconPosition":"left","closingClickOutside":"true","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.background","headerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_background","footerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.footer_background","dividerColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.divider","overlayColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.overlay","showTitle":"true","titleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.title","titleFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.title","titleColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_text","buttonPosition":"flex-end","buttonSize":"medium","buttonFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.button","buttonFontColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_text","pressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_press","fullscreenCloseIconColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_icon","fullscreenCloseIconPressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_fullscreen_press","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"02","z_index":"900","dialogMaxWidth":"1500","viewHeight":"600","viewDistanceToBorder":"100"},"style":{"left":"97px","top":"411px","width":"151px","height":"71px","z-index":"100"},"widgetSet":"materialdesign"}]
          AKuehnemann73 @Glasfaser last edited by
          @glasfaser
          danke dafür. Hat aber den gleichen Effekt.
          Der Dialog bleibt leer. Habe jetzt echt schon alles ausprobiert und
          keinen Plan woran das liegen könnte. Die anderen Dialog Widgets
          funktionieren alle so wie sie sollen nur das hier nicht.
          Marc_el_K 1 Reply Last reply Reply Quote 0
          • Ottili
            Ottili last edited by Ottili
            Hi!
            seitdem ich Probleme mit dem Update des Admin Adpaters auf 3.5.1 hatte und dann ein Backup installiert habe sind alle Material-Design Charts verschwunden.
            Ich kann auch keine mehr importieren.
            Gerade habe noch mal versucht den Vis View von Sigi234 (Speed-Test und Drucker) zu importieren.
            Soweit alles prima, jedoch die Charts wurden nicht mit importiert??
            Das ist das Original von Sigi:
            und so sieht es bei mir aus, nach View Import:
            Die Charts existieren nicht.
            Hat jemand eine Lösung dafür?
            Viele Grüße
            Otti
            Ottili 1 Reply Last reply Reply Quote 0
            • Ottili
              Ottili @Ottili last edited by
              @ottili
              Hi hat sich erledigt.
              Anscheinend wurde der Material-Design Widgets Adapter beim Backup nicht richtig übernommen.
              Habe gerade den Adapter gelöscht und reinstalliert.... und schwubs... alle Charts sind wieder da.
              Ciao Otti
                myssv last edited by myssv
                Moin zusammen,
                vielen Dank für die tolle Arbeit!
                Ich habe das bei mir importiert und es hat fast alles auf Anhieb funktioniert. Ein paar Anpassungen war nötig aber im großen und ganzen funktioniert alles super.
                ABER 🙂
                Ich bekomme den Regenradar nicht zu sehen. Nur das hier (wobei "nur" nicht negativ gemeint ist!)
                Was muss ich da noch anpassen?
                • Glasfaser
                  Glasfaser @myssv last edited by
                  @myssv sagte in Material Design Widgets: Wetter View:
                  https://forum.iobroker.net/post/502920
                  M 3 Replies Last reply Reply Quote 0
                    myssv @Glasfaser last edited by
                    @glasfaser Super, vielen Dank! Habe ich nicht gefunden oder übersehen ...
                      @glasfaser irgendwie doch zu früh gefreut ...
                      Ich habe den View "Wetter_Regenradar" gefunden und angepasst. Da wird es auch angezeigt.
                      Wenn ich dann aber auf den View "Wetter" gehe, wird der Regenradar unten nicht angezeigt.
                      Wir bekomme ich den unten aktiv?
                        @glasfaser habe jetzt weitere View definiert und nun klappt es!
                          Wie kann ich die Tagesdetails weiter nach oben bekommen, so dass ich nicht scrollen muss um sie zu sehen:
                          • D3ltoroxp
                            D3ltoroxp last edited by
                            Hat sich hier noch mal was geändert ? Ich hatte fast alle Views ausgetauscht, nun sehe ich wieder fast gar nichts mehr auf der Wetter Seite.
                            • Glasfaser
                              Glasfaser @D3ltoroxp last edited by Glasfaser
                              @d3ltoroxp
                              Da hat sich nichts verändert .
                              Hast du auch die Zuweisungen dazu in den Datenpunkten geändert , da du ja einen anderen Viewnamen wohl dazu hast !?
                              Beispiel aus dem Original ( Wetter Hauptseite )
                              • D3ltoroxp
                                D3ltoroxp @Glasfaser last edited by
                                @glasfaser Ich hab da eigentlich nichts herum gedreht an der View. Ich schau mir das aber noch mal an die Tage, ob sich da vllt was verändert hat.
                                  Random 0 last edited by
                                  Hallo Leute,
                                  finde das Projekt klasse und möchte es gerne auch nutzen.
                                  Habe soweit alles nach Anleitung instaliert und eingestellt.
                                  Peinlicherweise weiß ich nicht wie es in der Anleitung im Abschnitt Instalation, Punkt 1 funktioniert. Skript herunterladen und unter Skripte anlegen.
                                  Lege ich ein neies Skript an? Links im Iobroker Menü (Skripte)? Wenn ja welches Skript? Kein Blockly, deke ich...
                                  Muss ich auf der Seite die sich auf Github öffnet, wenn ich auf Skript herunterladen klicke, den Inhalt kopieren und irgendwo einfügen? Da sind ja auch erklärungen neben den Befehlen, wähe blöd die mit zu kopieren.
                                  Sorry für die blöde Frage, hab auch versucht im Thread eine Antwort zu finden, aber zwei Jahre durchzuforsten dauert echt lange.
                                  Wäre klasse wenn jemand mir erklären könnte wie ich das skript runterladen und Anlegen kann..
                                    madman1602 @Random 0 last edited by
                                    @random-0 sagte in Material Design Widgets: Wetter View:
                                    Hallo Leute,
                                    Hi , ja genau , du kannst einfach ein neues Javascript erstellen und den RAW content des Github Scriptes Wetter.js dort einfügen.
                                    Dann speichern und mindestens einmal das Script starten , stoppen und wieder starten , dann werden die Datenpunkte automatisch erstellt.
                                    Ab da sollte alles funktionieren.
                                    Schönen Abend
                                      Random 0 @madman1602 last edited by
                                      @madman1602
                                      Vielen Dank, hat geklappt...
                                        Funktioniert soweit alles, wie es aussieht.
                                        Nur die Datenpunkte für Temeperatur usw passen wohl noch nicht. Hab auch meine eigenen seonsoren im Script angegeben. Die Mond und Sonnedaten müsste er sich doch auch von daswetter ziehen, oder? Die anderen Daten wie Temperaturen und Luftfeuchte für die nächsten Tage kommen doch auch von daswetter Adapter, oder nicht? Denn die scheinen zu funktionieren...
                                        R Glasfaser 2 Replies Last reply Reply Quote 0
                                          Random 0 @Random 0 last edited by
                                          @random-0
                                          Wie kann ich mir die komplette Übersicht (die Seite inc Popups der Vorschautage) in meine Vis integrieren? Durch das Imprtieren scheint es ein eigenen Projekt zu sein. Möchte es gerne in mein Projekt integrieren...
                                          Sieht echt klasse aus.
                                          Hatte mir mit den Daten aus dem daswetter Adapter selbst eine Übersicht gebastelt aber die kommt bei weitem nicht an das schicke ding von Scrounger ran. Hammer Arbeit.
                                          • Glasfaser
                                            Glasfaser @Random 0 last edited by
                                            https://forum.iobroker.net/post/468358
                                            daswetter javascript material design widgets pollenflug statusanzeige vis weatherunderground wetter
                                            78
                                            665
                                            161161
