    4. Iobroker Admin Webseite nicht erreichbar
      matthesjimte @Thomas Braun last edited by matthesjimte
      @thomas-braun sagte in Iobroker Admin Webseite nicht erreichbar:
      iobroker update -i
      Sorry, hatte ich vergessen
      Bitte schön
      iobroker@iobroker-pi:/opt/iobroker $ iobroker update -i
      Used repository: Stable (default)
      hash changed or no sources cached => force download of new sources
      Cannot get any information of "_repoInfo". Ignored.
      update done
      Adapter    "admin"         : 6.2.20   , installed 6.2.17 [Updateable]
      Adapter    "backitup"      : 2.4.10   , installed 2.1.17 [Updateable]
      Adapter    "discovery"     : 3.0.5    , installed 2.6.1 [Updateable]
      Adapter    "fritzdect"     : 2.2.3    , installed 2.1.15 [Updateable]
      Adapter    "habpanel"      : 0.5.0    , installed 0.4.3 [Updateable]
      Adapter    "i2c"           : 1.2.1    , installed 1.2.0 [Updateable]
      Adapter    "info"          : 1.9.19   , installed 1.7.10 [Updateable]
      Adapter    "javascript"    : 6.0.0    , installed 5.1.3 [Updateable]
      Controller "js-controller" : 4.0.23   , installed 3.2.16 [Updateable]
      Adapter    "kecontact"     : 1.4.1    , installed 1.3.3 [Updateable]
      Adapter    "modbus"        : 5.0.4    , installed 3.2.6 [Updateable]
      Adapter    "node-red"      : 3.3.1    , installed 2.4.0 [Updateable]
      Adapter    "parser"        : 1.1.8    , installed 1.0.7 [Updateable]
      Adapter    "sbfspot"       : 4.0.8    , installed 4.0.5 [Updateable]
      Adapter    "simple-api"    : 2.7.0    , installed 2.5.3 [Updateable]
      Adapter    "socketio"      : 4.2.0    , installed 3.1.4 [Updateable]
      Adapter    "terminal"      : 0.2.6    , installed 0.2.6
      Adapter    "web"           : 4.3.0    , installed 3.4.7 [Updateable]
      iobroker@iobroker-pi:/opt/iobroker $ iobroker list instances
        system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              -  enabled
      + system.adapter.i2c.0                    : i2c                   : iobroker-pi                              -  enabled
      + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
      + system.adapter.kecontact.0              : kecontact             : iobroker-pi                              -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker-pi                              -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker-pi                              -  enabled
      + system.adapter.modbus.2                 : modbus                : iobroker-pi                              -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker-pi                              -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.parser.0                 : parser                : iobroker-pi                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 192.168.1.150, run as: admin
      + system.adapter.terminal.0               : terminal              : iobroker-pi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + instance is alive
      • BananaJoe
        BananaJoe Most Active @matthesjimte last edited by BananaJoe
        @matthesjimte Admin läuft bei dir auf Port 8081 und nur über https.
        Ich hoffe es ist auch ein Zertifikat hinterlegt ...
        Edit1: und es fehlt das + vor der admin-Instanz, die läuft also nicht
        iobroker start admin.0
        Edit2: mit
        iobroker add admin --enabled --port 9091
        könntest du eine weitere Instanz admin.1 ohne https/SSL auf Port 9091 hinzufügen (oder andere Zahl einsetzen) und darüber schauen was mit der Instanz auf Port 8081 los ist (admin.0) - hatte das vorher mit https:// funktioniert oder es gerade diese Änderung schuld am Problem?
          matthesjimte @BananaJoe last edited by matthesjimte
          @bananajoe
          das Plus habe ich total übersehen
          Habe versucht admin zu starten, dass "+" kommt aber nicht
          Wenn ich versuche einen neuen Port zu definieren
          iobroker@iobroker-pi:/opt/iobroker $ sudo iobroker add admin --enabled --port 9091
          host.iobroker-pi create instance admin
          /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:979
                                                  Object.keys(adapterConf.instanceObjects[i].common.name).forEach(lang => adapterConf.instanceObjects[i].common.name[lang] = adapterConf.instanceObjects[i].common.name.replace('%INSTANCE%', instance));
          TypeError: adapterConf.instanceObjects[i].common.name.replace is not a function
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:979:207
              at Array.forEach (<anonymous>)
              at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:979:97)
              at processImmediate (internal/timers.js:463:21)
          Habe auch versucht es mit admin.1
          iobroker@iobroker-pi:/opt/iobroker $ sudo iobroker add admin.1 --enabled --port 9091
          DJMarc75 Thomas Braun 3 Replies Last reply Reply Quote 0
          • DJMarc75
            DJMarc75 @matthesjimte last edited by
            @matthesjimte nicht mit SUDO vor iobroker Kommandos !
              Thomas Braun Most Active @matthesjimte last edited by
              @matthesjimte sagte in Iobroker Admin Webseite nicht erreichbar:
              sudo iobroker
              Ich weine still...
              M 1 Reply Last reply Reply Quote 2
                @matthesjimte
                iobroker stop
                iobroer fix
                iobroker update
                iobroker upgrade
                iobroker start
                  Du darfst auch laut weinen.
                  Ich bin jetzt nicht der Experte und werde es aufnehmen
                  Danke für den Hinweis
                    Thomas Braun Most Active @matthesjimte last edited by Thomas Braun
                    @matthesjimte
                    fix es lieber.
                    Und ich verstehe auch nicht wo der Blödsinn immer herkommt.
                    Hier im Thread hat bislang niemand sudo iobroker vorgegeben. Warum meinst du also es müsste ein sudo vorweg gesetzt werden?
                      matthesjimte @DJMarc75 last edited by
                      @djmarc75
                        bin dran
                          @matthesjimte #
                          Der js-controller muss auch aktuell gehalten werden.
                          Also zusätzlich noch:
                          iobroker stop
                          iobroker update
                          iobroker upgrade self
                          iobroker start
                          Ich vermute jetzt mal, nodejs hat's auch nötig:
                          sudo ln -s /usr/bin/node /usr/bin/nodejs
                          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            Erstmal danke für den Support
                            Habe jetzt bis zum Js-controller die Update alles gemacht, aber da ich aktuell auf meine Heizungssteuerung angewiesen bin (kein Öl mehr zum Heizen), muss ich das jetzt erstmal hier stoppen.
                            Muss dann mal heute Nacht schauen, ich kann mich erinnern das bestimmte Scripte damals nicht gelaufen sind und ich deshalb das System nie weiter hochgezogen habe.
                            Werden dann ein Image ziehen und dann weiter machen, in der Hoffnung dass das System danach wieder läuft.
                            Aber ich denke ich werde wahrscheinlich nicht drum rum kommen es auf einen neuen System nochmals aufzubauen
                            Nochmals Danke
                              Schtallone @matthesjimte last edited by
                              Hallo, ich nehme den Ball hier noch einmal auf,
                              ich kann auch nicht mehr auf meinen iobroker per Browser zugreifen.
                              hier das log
                              -----              Welcome to your ioBroker Docker container!              -----
                              -----                    Startupscript is now running!                     -----
                              -----                          Please be patient!                          -----
                              -----                          System Information                          -----
                              -----                    arch:                x86_64                       -----
                              -----                    hostname:            iobroker                     -----
                              -----                          Version Information                         -----
                              -----                    image:               v8.1.0                       -----
                              -----                    build:               2023-09-14T23:45:28+00:00    -----
                              -----                    node:                v18.17.1                     -----
                              -----                    npm:                 9.6.7                        -----
                              -----                        Environment Variables                         -----
                              -----                    SETGID:              1000                         -----
                              -----                    SETUID:              1000                         -----
                              -----                   Step 1 of 5: Preparing container                   -----
                              This is not the first run of this container. Skipping first run preparation.
                              -----             Step 2 of 5: Detecting ioBroker installation             -----
                              Existing installation of ioBroker detected in "/opt/iobroker".
                              -----             Step 3 of 5: Checking ioBroker installation              -----
                              (Re)setting permissions (This might take a while! Please be patient!)... Done.
                              Fixing "sudo-bug" by replacing sudo with gosu... Done.
                              Checking Database connection... Done.
                              Hostname in ioBroker matches the hostname of this container.
                              No action required.
                              -----                Step 4 of 5: Applying special settings                -----
                              Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                              For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
                              -----                    Step 5 of 5: ioBroker startup                     -----
                              Starting ioBroker...
                              ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                              ================================== > LOG REDIRECT system.adapter.jarvis.0 => true [starting]
                              host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.node-red.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.pushover.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.ical.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.meross.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.modbus.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.mqtt.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.mqtt.1" for host "iobroker"
                              host.iobroker check instance "system.adapter.netatmo.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.sonos.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.cloud.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.device-watcher.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.energiefluss.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.feiertage.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.jarvis.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.pvforecast.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.schoolfree.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.shuttercontrol.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.snmp.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.sourceanalytix.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.terminal.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.vw-connect.0" for host "iobroker"
                              host.iobroker check instance "system.adapter.web.0" for host "iobroker"
                              Ich habe alle Schritte in diesem Thread bzgl. der Updates der Ardapter, controller usw. erfolgreich durchgeführt.
                              Hier noch die Instanzen:
                              root@iobroker:/opt/iobroker# iobroker list instances
                              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.10 (SSL), run as: admin
                                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
                                system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
                                system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                                system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
                                system.adapter.feiertage.0              : feiertage             : iobroker                                 - disabled
                                system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
                                system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
                                system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                                system.adapter.meross.0                 : meross                : iobroker                                 - disabled
                                system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
                                system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                                system.adapter.netatmo.0                : netatmo               : iobroker                                 - disabled
                                system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 192.168.1.10
                                system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                                system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
                                system.adapter.schoolfree.0             : schoolfree            : iobroker                                 - disabled
                                system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 192.168.1.10
                                system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
                                system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
                                system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
                                system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                                system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                                system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 192.168.1.10, run as: admin
                                system.adapter.vw-connect.0             : vw-connect            : iobroker                                 - disabled
                                system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              ICh hoffe Ihr könnt mir irgendwie weiter helfen. VIELEN DANK und Gruß
                              Marc Berg ? 2 Replies Last reply Reply Quote 0
                              • Marc Berg
                                Marc Berg Most Active @Schtallone last edited by
                                @schtallone sagte in Iobroker Admin Webseite nicht erreichbar:
                                Nachdem du WAS gemacht hast? Wie konkret willst du auf den Admin zugreifen?
                                  Schtallone @Marc Berg last edited by
                                  @marc-berg
                                  Ich hatte performance probleme und folgende Fehlermeldung:
                                  MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 101 onFirmwareUpdate listeners added to [EventEmitter]. Use emitter.setMaxListeners() to increase limit
                                  Daraufhin habe ich versucht, den iobroker aus einem Backup wiederherzustellen.
                                  ICh greife üblicherweise per IP:Port mit https zu
                                  • Marc Berg
                                    Wie betreibst du den Container? Im Host-Modus?
                                      @marc-berg
                                      ich habe eine feste ip vergeben, läuft per Docker. ODer was bedeutet die Frage?
                                      • Marc Berg
                                        Das ist eine Testfrage, ob sich der geneigte User mal mit den Docker-Grundlagen auseinandergesetzt hat ... 🙂
                                        Aber im Ernst: Container können im einem Bridge-Netzwerk betrieben werden, dann müssen alle Ports separat freigegeben/gemappt werden. Oder man betreibt den Container im sog. Host-Netzwerk, dann werden ALLE Ports automatisch an den Host weitergegeben. Dann muss man kein Port-Mapping vornehmen.
                                          A Former User @Schtallone last edited by A Former User
                                          Moin,
                                          der Thread, an den Du Dich gehangen hast, ist ein Jahr alt, warum macht man das? Warum keinen eigenen erstellen und vielleicht auf den alten beziehen/verlinken.
                                          Ist Dir aufgefallen, dass alles außer admin.0 und backitup.0 gestoppt ist?
                                          Du solltest es mal mit dem Dreigestirn versuchen
                                          # iob stop
                                          # iob fix
                                          # iob start
                                          Dann einmal schauen, ob die Adapter auch wieder gestartet werden, oder einfach mal den Docker Container neu starten 🙂
                                          @marc-berg
                                          Das ist jetzt eine Log-Meldung, die völlig aus dem Zusammenhang gerissen ist, aus welchem Log File, was stand da noch so.
                                          Das ist ein blinder Aktionismus, wenn man sich nicht sicher ist, lieber Fragen, das erspart Kopfschmerzen, auf allen Seiten 🙂
                                          VG
                                          Bernd
                                          Edit
                                          Ich bin schon etwas aus der ioBroker Dockernutzung raus, daher hab ich oben Blödsinn geschrieben, die Standardbefehle iob stop, iob start gibt es nicht im Docker, ob iob fix da funktioniert, kann ich auch nicht sagen. Der korrekte Weg für Stopp/Start ist im Docker
                                          pkill -u iobroker
                                          Und gestartet wird, durch Neustart des Containers.
                                            @marc-berg dann letzeres, habe keine ports weitergeleitet und andere container gehen auch aufzurufen wie nodered, grafana usw
                                            Marc Berg F Homoran 3 Replies Last reply Reply Quote 0
                                            115
                                            18491
