    4. iobroker restore 0 funktioniert nicht
      Thomas Braun Most Active @funkytown last edited by
      @funkytown
      Du kannst in meiner Signatur schauen, wie man nodejs (und damit auch npm) richtig installiert.
      funkytown 1 Reply Last reply Reply Quote 0
      • funkytown
        funkytown @Homoran last edited by
        da ein Restore nicht ging, vermutete ich dass man über diese Fehlerbeschreibung eher an die eigentliche Ursache kommt.
        Kann/soll ich den Titel ändern?
        • funkytown
          funkytown @Thomas Braun last edited by
          Da scheint ja einiges kaputt zu sein!
          markus@rpi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
          [sudo] Passwort für markus:
          ├── iobroker.tr-064-community@2.0.3 invalid: "https://github.com/iobroker-community-adapters/ioBroker.tr-064-community/tarball/5aff47d0395896a02c70a2a97910c5a0e7006cef" from the root project
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
          npm ERR! invalid: iobroker.openweathermap@0.3.0 /opt/iobroker/node_modules/iobroker.openweathermap
          npm ERR! invalid: iobroker.tr-064-community@2.0.3 /opt/iobroker/node_modules/iobroker.tr-064-community
          npm ERR! extraneous: negotiator@0.6.3 /opt/iobroker/node_modules/negotiator
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-16T21_57_52_169Z-debug-0.log
          iobroker.inst@2.0.3 /opt/iobroker
          ├── colors@1.4.0
          ├── event-target-shim@5.0.1 extraneous
          ├── fs-extra@7.0.1
          ├── iobroker.admin@6.2.20
          ├── iobroker.alexa2@3.19.7
          ├── iobroker.backitup@2.4.10
          ├── iobroker.cloud@4.2.2
          ├── iobroker.cul@2.0.2
          ├── iobroker.discovery@3.0.5
          ├── iobroker.dwd@2.8.3
          ├── iobroker.email@1.1.3
          ├── iobroker.history@2.2.0
          ├── iobroker.hm-rega@3.0.40
          ├── iobroker.hm-rpc@1.15.12
          ├── iobroker.icons-mfd-svg@1.1.0
          ├── iobroker.info@1.9.19
          ├── iobroker.iot@1.11.8
          ├── iobroker.javascript@6.0.0
          ├── iobroker.js-controller@4.0.23
          ├── iobroker.linux-control@1.1.5
          ├── iobroker.mqtt@4.0.7
          ├── iobroker.node-red@3.3.1
          ├── iobroker.openweathermap@0.3.0 invalid: "0.2.5" from the root project
          ├── iobroker.ping@1.5.3
          ├── iobroker.pollenflug@1.0.6
          ├── iobroker.pushover@3.0.2
          ├── iobroker.radar2@2.0.3
          ├── iobroker.rpi2@1.3.2
          ├── iobroker.scenes@2.3.9
          ├── iobroker.simple-api@2.7.0
          ├── iobroker.socketio@4.2.0
          ├── iobroker.synology@2.1.9
          ├── iobroker.tankerkoenig@2.1.1
          ├── iobroker.telegram@1.13.0
          ├── iobroker.text2command@2.2.2
          ├── iobroker.tr-064@4.2.16
          ├── iobroker.trashschedule@2.0.3
          ├── iobroker.vis-material-advanced@1.7.2
          ├── iobroker.vis@1.4.15
          ├── iobroker.web@4.3.0
          ├── iobroker.withings@0.0.9
          ├── iobroker.yahka@0.13.1
          ├── iobroker@2.0.3
          ├── negotiator@0.6.3 extraneous
          ├── semver@5.7.1
          └── yargs@7.1.2
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-16T21_59_58_839Z-debug-0.log
            @funkytown sagte in iobroker restore 0 funktioniert nicht:
            Kannst du deinstallieren, gibt es nicht mehr.
            Nochmal drüber installieren, wenn nodejs sauber ist.
            • funkytown
              @thomas-braun sagte in iobroker restore 0 funktioniert nicht:
              Irgendwie ist da der Wurm drin
              markus@rpi:/opt/iobroker $ iobroker del tr-064-community
              Delete adapter "tr-064-community"
              host.rpi Counted 1 instances of tr-064-community
              host.rpi Counted 2 meta of tr-064-community
              host.rpi Counted 1 adapter for tr-064-community
              host.rpi Counted 5 devices of tr-064-community
              host.rpi Counted 9 channels of tr-064-community
              host.rpi Counted 133 states of tr-064-community
              host.rpi Counted 15 states of system.adapter.tr-064-community
              host.rpi Counted 133 states (io.tr-064-community.*) from states
              host.rpi Counted 16 states (system.adapter.tr-064-community.*) from states
              host.rpi file tr-064-community.admin deleted
              host.rpi object tr-064-community deleted
              host.rpi object tr-064-community.admin deleted
              host.rpi Deleting 166 object(s).
              host.rpi Deleting 149 state(s).
              Error deleting adapter tr-064-community from disk: host.rpi: Cannot uninstall iobroker.tr-064-community: 217
              You might have to delete it yourself!
              markus@rpi:/opt/iobroker $ iobroker del openweathermap
              Delete adapter "openweathermap"
              host.rpi object openweathermap deleted
              host.rpi object openweathermap.admin deleted
              Error deleting adapter openweathermap from disk: host.rpi: Cannot uninstall iobroker.openweathermap: 217
                Thomas Braun Most Active last edited by Thomas Braun
                @funkytown
                Ist node und npm sauber? Das vor allem anderen prüfen.
                Was sagt:
                sudo ln -s /usr/bin/node /usr/bin/nodejs
                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                Und auch
                dmesg -T | grep -i ext4
                • funkytown
                  markus@rpi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                  ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                  markus@rpi:/opt/iobroker $ dmesg -T | grep -i ext4
                  [Fr Sep 16 19:47:41 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:28:5E:37 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
                  [Fr Sep 16 19:47:50 2022] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fr Sep 16 19:47:50 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:17.
                  [Fr Sep 16 19:47:59 2022] EXT4-fs (sdb1): re-mounted. Opts: (null). Quota mode: none.
                  markus@rpi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.0
                  v16.17.0
                  8.15.0
                  4.0.23
                  markus
                  markus adm cdrom sudo audio video plugdev games users input netdev gpio iobroker
                  /opt/iobroker
                  OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                  OK:4 https://dl.yarnpkg.com/debian stable InRelease
                  Paketlisten werden gelesen… Fertig
                  Abhängigkeitsbaum wird aufgebaut… Fertig
                  Statusinformationen werden eingelesen… Fertig
                  Aktualisierung für 24 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                  nodejs:
                    Installiert:           16.17.0-deb-1nodesource1
                    Installationskandidat: 16.17.0-deb-1nodesource1
                    Versionstabelle:
                   *** 16.17.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                          100 /var/lib/dpkg/status
                       12.22.12~dfsg-1~deb11u1 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                    @funkytown
                    sudo apt update
                    sudo apt full-upgrade
                    iobroker stop
                    sudo reboot
                    funkytown 2 Replies Last reply Reply Quote 0
                    • funkytown
                      funkytown @Thomas Braun last edited by funkytown
                      markus@rpi:~ $ sudo apt update
                      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:3 https://dl.yarnpkg.com/debian stable InRelease
                      OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Aktualisierung für 13 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      markus@rpi:~ $ sudo apt full-upgrade
                      Paketaktualisierung (Upgrade) wird berechnet… Fertig
                      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                        alsa-base gstreamer0.10-alsa gstreamer0.10-plugins-base libbluetooth3 libcdio18 libgstreamer-plugins-base0.10-0
                        libgstreamer0.10-0 libnfs12 libxfconf-0-2 lxplug-volume pimixer point-rpi
                      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                      Die folgenden Pakete werden ENTFERNT:
                        bluealsa fuse libgc1c2 libpolkit-backend-1-0 raspberrypi-artwork
                      Die folgenden NEUEN Pakete werden installiert:
                        agnostics cups-pk-helper fio flashrom fuse3 gir1.2-notify-0.7 gir1.2-packagekitglib-1.0 gir1.2-polkit-1.0 gir1.2-secret-1
                        gui-pkinst ibverbs-providers libaio1 libboost-iostreams1.74.0 libboost-thread1.74.0 libcupsimage2 libftdi1-2 libfuse3-3 libgc1
                        libgfapi0 libgfrpc0 libgfxdr0 libglusterfs0 libibverbs1 libnma-common libnma0 libnuma1 librados2 librbd1 librdmacm1
                        lxplug-magnifier lxplug-menu lxplug-netman lxplug-updater lxplug-volumepulse pi-printer-support pixflat-icons
                        printer-driver-escpr pulseaudio-module-bluetooth python3-cups python3-cupshelpers python3-smbc python3-toml rp-bookshelf
                        rpi-eeprom system-config-printer system-config-printer-common system-config-printer-udev
                      Die folgenden Pakete werden aktualisiert (Upgrade):
                        guile-2.2-libs gvfs gvfs-backends gvfs-common gvfs-daemons gvfs-fuse gvfs-libs libpolkit-agent-1-0 libpolkit-gobject-1-0
                        policykit-1 raspberrypi-sys-mods raspberrypi-ui-mods raspi-config
                      13 aktualisiert, 47 neu installiert, 5 zu entfernen und 0 nicht aktualisiert.
                      Es müssen 31,3 MB an Archiven heruntergeladen werden.
                      Nach dieser Operation werden 78,8 MB Plattenplatz zusätzlich benutzt.
                      Möchten Sie fortfahren? [J/n] J
                      Holen:1 http://archive.raspberrypi.org/debian bullseye/main armhf policykit-1 armhf 0.105-31+rpt1+deb11u1 [91,5 kB]
                      Es wurde alles ohne Fehler installiert
                      Jetzt komme ich nach dem reboot mit meinem SSH Client nicht mehr auf den PI.
                      Ich melde mich wieder wenn der PI korrekt hochgefahren ist.
                        @funkytown
                        Und schalte den Desktop an der Kiste aus. Da ist ja der ganze GUI-Quatsch drauf.
                        • funkytown
                          Bin noch nicht dazu gekommen den PI flott zu machen.
                          Das gute daran ist, dass ich/wir jetzt erkennen, dass wir im Haus nicht vom ioBroker abhängig sind. Wir senden meistens (Status)Informationen in Wort und Bild hin und her. Das was wir über Sprachsteuerung im Haus darüber schalten, kann auch alles manuell geschaltet werden 🙂 Gute Erkenntnis!
                          • funkytown
                            mein RPi läuft wieder. Durch den reboot wurde eine falsche UUID in der cmdline.txt eingetragen.
                            Leider ist der ioBroker immer noch nicht da!
                              @funkytown
                              Leider kann man da ohne Meldungen immer noch nichts zu sagen.
                              Welche UUID war es denn? Die werden ja nicht gewürfelt...
                              • funkytown
                                also jetzt blicke ich da garnicht mehr durch. Ich bin jetzt an via ssh an dem betroffenen System angemeldet und die cmdline.txt und fstab schaut jetzt so aus. Wo ist mein Eintrag geblieben. Mir scheint als ob ich in einer anderen Baumstruktur also einem anderen /etc/boot bin.
                                markus@rpi:/boot $ cat cmdline.txt
                                dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
                                markus@rpi:/boot $ cat /etc/fstab
                                proc            /proc           proc    defaults          0       0
                                PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                                #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                                # a swapfile is not a swap partition, no line here
                                #   use  dphys-swapfile swap[on|off]  for that
                                /dev/sdb1       /               ext4    defaults,noatime  0       1
                                /dev/sdb2       swap            swap    defaults          0       0
                                Ich bin jetzt mal für 3 Std. weg.
                                  Thomas Braun Most Active @funkytown last edited by Thomas Braun
                                  root=/dev/sdb1
                                  Keine Ahnung was du da wie warum treibst, jedenfalls ist der Eintrag
                                  root=/dev/sdb1
                                  absolut atypisch. Vor allendingen sdb1
                                  Für gewöhnlich wird da die UUID aus
                                  blkid
                                  eingetragen.
                                  • funkytown
                                    Das System läuft ja wieder nach dem full-upgrade.
                                    markus@rpi:/opt/iobroker $ blkid
                                    /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                                    /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                                    /dev/sda1: LABEL="ESD-USB" UUID="5CD7-2DC8" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="292eb410-01"
                                    /dev/sdb1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                                    /dev/sdb2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.17.0
                                    v16.17.0
                                    8.15.0
                                    4.0.23
                                    markus
                                    markus adm cdrom sudo audio video plugdev games users input netdev lpadmin gpio iobroker
                                    /opt/iobroker
                                    Alle Pakete sind aktuell.
                                    nodejs:
                                     Versionstabelle:
                                      @funkytown
                                      Ich würde da halt die UUID in die cmdline.txt eintragen. Dann springt dir die boot-Partition auch nicht weg.
                                      Zum iobroker: Logs? Kommandozeile?
                                      • funkytown
                                        Hab den Eintrag in der cmdline.txt gemacht und rebootet.
                                        Welche Logs benötigst du jetzt?
                                        markus@rpi:~ $ blkid
                                        markus@rpi:~ $ cat /boot/cmdline.txt
                                        dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          @funkytown
                                          iobroker status
                                          iobroker update
                                          iobroker list instances
                                          • funkytown
                                            markus@rpi:~ $ iobroker status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            markus@rpi:~ $ iobroker update
                                            Used repository: stable
                                            Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                                            Adapter    "alexa2"       : 3.19.9   , installed 3.19.7 [Updatable]
                                            Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                                            Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                                            Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                            Adapter    "email"        : 1.1.3    , installed 1.1.3
                                            Adapter    "history"      : 2.2.0    , installed 2.2.0
                                            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                            Adapter    "info"         : 1.9.19   , installed 1.9.19
                                            Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                                            Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                                            Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                            Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                                            Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                                            Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                            Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                                            Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                            Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                            Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                            Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                            Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                            Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                            Adapter    "withings"     : 0.0.9    , installed 0.0.9
                                            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                            markus@rpi:~ $ iobroker list instances
                                              system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                              system.adapter.admin.1                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                              system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                                              system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                                            + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                                            + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                              system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                                            + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                                            + system.adapter.history.0                : history               : rpi                                      -  enabled
                                            + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                                            + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                            + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                            + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                            + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                                            + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                                            + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                                            + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                                            + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                                            + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                                            + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                              system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                                            + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                                            + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                                            + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                              system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                                            + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                              system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                              system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                                            + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                              system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                              system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                                              system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                              system.adapter.withings.0               : withings              : rpi                                      - disabled
                                              system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                                            + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                                            + instance is alive
                                            2825
