    4. File index.html not found: {} bei VIS Aufruf
      Thomas Braun Most Active @hg6806 last edited by
      @hg6806
      iobroker stop
      iobroker fix
      iobroker update
      • hg6806
        hg6806 Most Active @Thomas Braun last edited by
        Problem besteht weiterhin
          Thomas Braun Most Active @hg6806 last edited by Thomas Braun
          @hg6806
          iobroker update
          Ein- und Ausgaben zeigen. Meine Glaskugel ist kaputt.
          • hg6806
            @thomas-braun sagte in File index.html not found: {} bei VIS Aufruf:
            Meine auch, deswegen hie die Ausgaben:
            pi@raspberrypi:~ $ iobroker update
            Used repository: beta
            Adapter    "admin"        : 6.2.22   , installed 6.2.22
            Adapter    "alarm"        : 3.1.1    , installed 3.1.1
            Adapter    "backitup"     : 2.4.12   , installed 2.4.12
            Adapter    "ble"          : 0.13.0   , installed 0.13.0
            Adapter    "canbus"       : 1.3.1    , installed 1.3.1
            Adapter    "cloud"        : 4.2.2    , installed 4.2.2
            Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
            Adapter    "denon"        : 1.13.4   , installed 1.13.4
            Adapter    "devices"      : 1.0.12   , installed 1.0.12
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "email"        : 1.1.3    , installed 1.1.3
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "heos"         : 1.10.0   , installed 1.10.0
            Adapter    "history"      : 2.2.3    , installed 2.2.1  [Updatable]
            Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
            Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.15
            Adapter    "i2c"          : 1.2.1    , installed 1.2.1
            Adapter    "ical"         : 1.13.2   , installed 1.13.1 [Updatable]
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "info"         : 1.9.20   , installed 1.9.19 [Updatable]
            Adapter    "iot"          : 1.11.9   , installed 1.11.9
            Adapter    "javascript"   : 6.0.3    , installed 6.0.3
            Adapter    "modbus"       : 5.0.5    , installed 5.0.5
            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
            Adapter    "niu"          : 0.0.3    , installed 0.0.2  [Updatable]
            Adapter    "parser"       : 1.2.1    , installed 1.2.1
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "proxy"        : 1.3.1    , installed 1.3.1
            Adapter    "psa"          : 0.0.11   , installed 0.0.11
            Adapter    "samsung"      : 0.5.11   , installed 0.5.11
            Adapter    "simple-api"   : 2.7.1    , installed 2.7.1
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "smartthings"  : 0.0.3    , installed 0.0.3
            Adapter    "socketio"     : 6.1.10   , installed 6.1.10
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "statistics"   : 2.2.0    , installed 2.2.0
            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
            Adapter    "telegram"     : 1.14.1   , installed 1.14.1
            Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
            Adapter    "tuya"         : 3.6.15   , installed 3.6.15
            Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
            Adapter    "vis"          : 1.4.15   , installed 1.4.8  [Updatable]
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
            Adapter    "web"          : 5.2.5    , installed 5.2.5
            Adapter    "wireless-mbus": 0.8.2    , installed 0.8.2
            Adapter    "wlanthermo-nano": 0.2.1  , installed 0.2.1
            Adapter    "wled"         : 0.6.7    , installed 0.6.7
            Adapter    "worx"         : 1.6.6    , installed 1.6.6
            Adapter    "ws"           : 2.1.5    , installed 2.1.5
            Adapter    "zigbee"       : 1.7.6    , installed 1.7.6
            pi@raspberrypi:~ $
              @hg6806
              Bring den Kram erstmal vollständig auf Stand.
              • hg6806
                Ich hatte das falsche und ältere Backup genommen.
                Somit setze ich alles nochmal neu auf. Ist ja nicht soviel.
                Aaalso, nach der ioBroker Instl. erst VIS installieren DANN das Backup, gell?
                  @hg6806
                  Ja.
                  • hg6806
                    hg6806 Most Active @Thomas Braun last edited by hg6806
                    So, alles nochmal komplett neu aufgesetzt und schon wieder den Fehler dass ich kein VIS aufrufen kann .
                    Vor dem Einspielen des Backups hatte ich VIS + Webserver installiert und auf VIS sogar aufgerufen, was auch funktioniert hatte. Zumindest kam der Test-View.
                    pi@raspberrypi:~ $ iob stop
                    Adapter    "eventlist"    : 1.0.1    , installed 1.0.1
                    Adapter    "history"      : 2.2.3    , installed 2.2.3
                    Adapter    "ical"         : 1.13.2   , installed 1.13.2
                    Adapter    "info"         : 1.9.20   , installed 1.9.20
                    Adapter    "niu"          : 0.0.3    , installed 0.0.3
                    Adapter    "vis"          : 1.4.15   , installed 1.4.15
                    pi@raspberrypi:~ $
                    Fix hatte ich auch schon ausgeführt
                    • DJMarc75
                      DJMarc75 @hg6806 last edited by
                      @hg6806 sagte in File index.html not found: {} bei VIS Aufruf:
                      So ein Quatsch...
                      Du sollst vor dem Backup VIS in einer Vorgängerversion installieren und nicht da gleich mit VIS rumhampeln und iwas Visualisieren...
                      • hg6806
                        hg6806 Most Active @DJMarc75 last edited by
                        @djmarc75
                        Das mit der Vorgängerversion hatte ich so nicht auf dem Schirm.
                        Auf jeden Fall geht es jetzt. Ich hatte es im Browser nochmal neu aufgerufen.
                        Irgendwie immer spannend und zeitraubend das Neuaufsetzen.
                        683
