    4. admin hat falsche Version
    • Rette70
      Rette70 @Rette70 last edited by Homoran
      @rette70 ERROR: Process exited with code 25
      weniger
      mehr
      $ iobroker upgrade admin@6.2.22 --debug
      Update admin from @5.3.8 to @6.2.22
      NPM version: 8.15.0
      Installing iobroker.admin@6.2.22... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-09-18T18_43_21_565Z-debug-0.log
      host.IoBroker-Slave Cannot install iobroker.admin@6.2.22: 217
        Thomas Braun Most Active @Rette70 last edited by
        @rette70
        Nicht aus der GUI, nimm ein Terminal dafür.
        Rette70 1 Reply Last reply Reply Quote 0
          @rette70
          Vermutlich aber was aus der Ecke:
          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
          • Rette70
            Rette70 @Thomas Braun last edited by
            @thomas-braun kannst du mir kurz bitte den Befehl schreiben?
              Thomas Braun Most Active @Rette70 last edited by Thomas Braun
              @rette70
              Steht doch drin?
              iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slave
              Bei Multihost muss der Host angegeben werden.
              • Rette70
                Rette70 @Thomas Braun last edited by Homoran
                @thomas-braun ja danke. Dachte ist ein anderer Befehl.
                hab jetzt über die Konsole installiert. Das gleiche
                This upgrade of "admin" will at least introduce the following changes:
                -> 6.2.22:
                Corrected admin4 adapter settings
                -> 6.2.21:
                Corrected small JSON config issue
                -> 6.2.20:
                Corrected GUI issues
                -> 6.2.19:
                Corrected some issues
                -> 6.2.18:
                Corrected GUI bugs on custom settings
                -> 6.2.17:
                Corrected GUI bug on intro tab
                -> 6.2.16:
                Corrected many GUI issues
                Added `stable` flag for repositories
                Added reset button for repositories
                Improved `writeFile` function for socket communication
                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                Would you like to upgrade admin from @5.3.8 to @6.2.22 now? [(y)es, (n)o]: y
                NPM version: 8.15.0
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T18_55_48_988Z-debug-0.log
                pi@IoBroker-Slave:~ $
                * ****list item****
                  @rette70 sagte in admin hat falsche Version:
                  Das gleiche
                  Nein, ist nicht das gleiche.
                  Die Lösung hatte ich oben schon verlinkt.
                  • Rette70
                    pi@IoBroker-Slave:~ $ iobroker upgrade admin@6.2.22 --debug --host IoBroker-Slav                                                               e
                    -> 6.2.22:
                    -> 6.2.21:
                    -> 6.2.20:
                    -> 6.2.19:
                    -> 6.2.18:
                    -> 6.2.17:
                    -> 6.2.16:
                    NPM version: 8.15.0
                    npm ERR! errno -39
                    npm ERR!     /home/iobroker/.npm/_logs/2022-09-18T19_01_57_380Z-debug-0.log
                      @rette70
                      Bitte CodeTags verwenden. Danke
                      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                      Auf beiden Kisten.
                      • Rette70
                        @thomas-braun Du bist mein Held!! Ich habe gestern den ganzen Tag daran gesessen und dein Post auch auf beiden durch geführt. Aber jetzt die manuelle Installation funktioniert. Eventl. weil ich nie den Host angegeben habe. Dachte wenn ich mit Putty auf dem drauf bin , weiß er das es dort hin soll.
                        Was sind Code TAGs?
                        Ah ok.
                        code_text
                        Habs gefunden. Vielen Dank
                        admin falsche version smartgarden
                        1516
