    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
    • Z
      Zuki last edited by Zuki
      Gab es schon das Problem dass der ioBroker innerhalb des Dockers nicht starten zu scheint?
      Laut log scheint der ioBroker Startup im Schritt 5 hängen zu bleiben
      -----             Step 2 of 5: Detecting ioBroker installation             -----
      Existing installation of ioBroker detected in /opt/iobroker.
      -----             Step 3 of 5: Checking ioBroker installation              -----
      (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
      Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
      -----                Step 4 of 5: Applying special settings                -----
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      Z-Wave is activated by ENV.
      Running setup script...
      [setup_zwave.sh] Openzwave is already installed. Nothing to do here.
      Done.
      -----                    Step 5 of 5: ioBroker startup                     -----
      Starting ioBroker...
      host.iobroker_productive check instance "system.adapter.admin.0" for host "iobroker_productive"
      host.iobroker_productive check instance "system.adapter.discovery.0" for host "iobroker_productive"
      host.iobroker_productive check instance "system.adapter.backitup.0" for host "iobroker_productive"
      Da hängt der Docker nun schon seit gestern Abend. Das Admin Webinterface ist entsprechend natürlich nicht erreichbar.
      Danke euch schon mal.
        Thomas Braun Most Active @Zuki last edited by
        @zuki
        The host name contains illegal characters This may cause undefined behavior when using some network services. Please change the host name using only valid characters (A-Z, a-z, 0-9, -)
        Z 2 Replies Last reply Reply Quote 0
        • Z
          Zuki @Thomas Braun last edited by
          Super. Danke 🙂
          • Z
            Ich habe noch ein wenig mit dem Hostnamen probiert aber das scheint leider nicht das Kernproblem zu sein.
            Auch mit einem "legalen" Hostname bleibt das ioBroker Startup (Step 5) hängen.
            [setup_zwave.sh] Openzwave is NOT installed. Going to install it now... Done.
            Done.
            host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
            host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
            host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
            object system.meta.uuid created: dd8a9d53-2fb8-4053-bc5c-efe297ccf068
            Glasfaser hollywoot 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser @Zuki last edited by
              @zuki sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
              Was sagt
              iobroker logs --watch
              in der Konsole
              • Z
                Zuki @Glasfaser last edited by
                @glasfaser
                Der Admin scheint zu laufen... Ist aber leider nicht erreichbar.
                22-09-19 15:20:00.232  - info: host.iobroker 3 instances found
                2022-09-19 15:20:00.241  - info: host.iobroker starting 3 instances
                2022-09-19 15:20:00.275  - info: host.iobroker instance system.adapter.admin.0 started with pid 421
                2022-09-19 15:20:01.858  - info: admin.0 (421) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.17.0, js-controller: 4.0.23
                2022-09-19 15:20:01.895  - info: admin.0 (421) requesting all states
                2022-09-19 15:20:01.896  - info: admin.0 (421) requesting all objects
                2022-09-19 15:20:02.103  - info: admin.0 (421) received all objects
                2022-09-19 15:20:02.206  - info: admin.0 (421) Request actual repository...
                2022-09-19 15:20:02.220  - info: admin.0 (421) http server listening on port 8081
                2022-09-19 15:20:02.221  - info: admin.0 (421) Use link "http://localhost:8081" to configure.
                2022-09-19 15:20:02.327  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                2022-09-19 15:20:03.685  - info: admin.0 (421) Repository received successfully.
                2022-09-19 15:20:04.266  - info: host.iobroker instance system.adapter.discovery.0 started with pid 436
                2022-09-19 15:20:05.574  - info: discovery.0 (436) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.17.0, js-controller: 4.0.23
                2022-09-19 15:20:08.263  - info: host.iobroker instance system.adapter.backitup.0 started with pid 464
                2022-09-19 15:20:09.707  - info: backitup.0 (464) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.17.0, js-controller: 4.0.23
                2022-09-19 15:20:09.754  - info: backitup.0 (464) [iobroker] backup was activated at 02:40 every 1 day(s)
                Glasfaser 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @Zuki last edited by Glasfaser
                  mehr Instanzen hast du nicht !?
                  Was hast du vorher gehabt !?
                  wie nicht erreichbar , Fehler im Browser oder ...!?
                  iobroker list instances
                  • Glasfaser
                    @zuki
                    Hast du wieder das Problem mit SSL
                    https://forum.iobroker.net/post/580437
                    iobroker set admin.0 --secure false
                    • hollywoot
                      hollywoot @Zuki last edited by
                      @zuki
                      Wie sieht deine compose aus?
                      Und was sagt iobroker status?
                      • Z
                        @glasfaser sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
                        @zuki
                        Boah...
                        Danke. Das ist das Problem wenn der Spaß einfach läuft und man nach Ewigkeiten mal wieder rum spielt 😉
                        Gut das es Hilfe in Foren gibt und das Internet nichts vergisst.
                        Glasfaser 1 Reply Last reply Reply Quote 1
                        • Glasfaser
                          Danke.
                          Kein Thema ... 😉
                          dein
                          kam mir bekannt vor ... deshalb konnte ich mich an den Thread erinnern 🙂
                            Telefisch @Glasfaser last edited by
                            Hallo Forum,
                            ich habe meinen ioB seit geraumer Zeit auf einer Synology mittels Docker laufen.
                            Jetzt wollte ich eine MariaDB Datenbank hinzufügen, bekomme aber vom SQL Adapter immer nur unreachable.
                            Ich gehe doch recht in der Annahme, dass ich bei Host die IP der Syno eingeben sollte?
                            Der ioB läuft mit MACVLAN unter einer anderen IP, localhost ist damit dann ja raus…?
                            Also Port hab ich verschiedene Ports probiert, witzigerweise war standard 3307 eingestellt, in alle tutorials heißt es immer 3306?
                            Mit dem PHPmyadmin kann ich aus der Syno direkt auf die DB zugreifen.
                            Einen eigenen user habe ich auch bereits probiert, genauso wie natürlich root.
                            Also Eingaben wir folgt:
                            DBTyp : MySQL
                            Host: IP der Syno
                            Port 3306, 3307 etc…
                            Datenbankname wie unter myAdmin angelegt
                            User und Passwort wie angelegt, alternativ root probiert
                            Naja der Rest ist ja eh selbsterklärend.
                            Fehler ist immer
                            Error: connect EHOSTUNREACH IP-Adresse:Portnummer
                            hollywoot andre 2 Replies Last reply Reply Quote 0
                            • hollywoot
                              hollywoot @Telefisch last edited by hollywoot
                              @telefisch
                              Ich meine mich erinnern zu können, dass du aus dem macvlan den eigentlichen Host nicht erreichen kannst.
                              Geh mal im iobroker auf die cli und versuche deine Syno zu pingen.
                              Entweder nutzt du dann den Hackentrick (guck mal hier: https://www.synology-forum.de/threads/macvlan-zugriff-auf-den-host.103178/) , damit du den Host erreichen kannst oder aber du packst den iobroker und die mariadb in ein gemeinsames Docker-Network.
                                Telefisch @hollywoot last edited by
                                @hollywoot
                                Danke für den Hinweis, ich kapiere es aber nicht.
                                ich muss also (sinnvollerweise über Portainer) eine bridge anlegen.
                                Host Adresse ist 192.168.178.2, Docker-ioBroker ist 192.168.178.4.
                                Was muss ich in dei drei Felder eintragen?
                                Hab gefühlt alle sinnvollen Kombinationen durch aber ich finde irgendwie keine Lösung.
                                hollywoot 1 Reply Last reply Reply Quote 0
                                • hollywoot
                                  @telefisch
                                  Ich habe mir in auf der Syno ein Shell-Script gebaut und führe dies mit der Syno-Aufgabenplanung beim Boot aus.
                                  Hier mal das Script:
                                  #!/bin/sh
                                  ip link add mynet-shim link eth0 type macvlan mode bridge
                                  ip addr add <IP-für-die-Bridge>/32 dev mynet-shim
                                  ip link set mynet-shim up
                                  ip route add <Syno-IP>/32 dev mynet-shim
                                    Telefisch @hollywoot last edited by Telefisch
                                    @hollywoot
                                    Danke für das Script aber wie muss denn die IP für die Bridge lauten?
                                    Ist das dann eine bestimmte oder irgend eine aus dem IP-Kreis der Syno bzw. des Containers?
                                    Ich checks einfach nicht.
                                    Bei dem ganzen probieren hab ich mir natürlich direkt mal meine komplette ioB Installation gelöscht.
                                    Das Restore dauert etwas…
                                    • hollywoot
                                      @telefisch
                                      Wäre ja grundsätzlich nicht verkehrt wenn man wenigstens ein klitzekleines Bisschen versteht was man da tut 🙂
                                      Wieso machst du es mit einem macvlan? Hau das Ding doch einfach stinknormal über die Host-IP rein...
                                      Naja, sei es drum.
                                      Nimm eine freie IP aus deinem Netzwerk. Die Syno ist dann ja quasi ebenfalls, zu Ihrer eigentlichen IP, über diese Bridge-IP zu erreichen. Das hat jetzt grundsätzlich erstmal wenig mit dem macvlan zu tun.
                                      Deine bridge kriegt dann bspw die 192.168.178.200.
                                      Nimm am besten eine IP, die nicht über den DHCP (deiner Fritzbox?!) vergeben werden könnte.
                                      Oder schränk den DHCP Kreis der Fritze ein. ZB erst ab 50-199.
                                      So hättest du alle IP bis zur 50 zur manuellen Vergabe offen.
                                      Zum Thema Restore:
                                      Jopp, kann dauern. Wobei dauern auch relativ ist.
                                      Mit meiner sehr großen ioBroker Installation auf der Arbeit brauche ich für einen fullrestore etwa 30min.
                                      • andre
                                        andre Developer @Telefisch last edited by
                                        @telefisch Ich gehe mal davon aus, deine MariaDB läuft auf der Synology und nicht als Docker Container.
                                        Dein ioBroker wenn ich richtig verstanden habe, mit eigener IP im MACVLAN.
                                        Problem: Du kannst aus dem Container heraus die DiskStation nicht erreichen.
                                        Lösung: Dem ioBroker Container einfach das (oder ein eigenes) Bridge Netzwerk hinzufügen. Dann ist die DiskStation über das Gateway in diesem Netzwerk erreichbar:
                                        Das ist m. E. der einfachste Weg. Natürlich kann (und sollte) man ein eigenes Bridge Netzwerk anlegen. Außerdem gibt es auch die Möglichkeit das Routing zu verbiegen...
                                        MfG,
                                        André
                                          Telefisch @andre last edited by Telefisch
                                          @andre
                                          ok, das Problem von grade eben wäre gelöst, hatte nen Tippfehler im Netzwerk.
                                          Mit der Bridge probiere ich sobald iob wieder läuft.
                                          Danke Euch erstmal für Euren Support.
                                            @hollywoot Du hast Recht, ich bin strunzdoof...
                                            Network Interface falsch geschrieben 🤦‍♂️
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1537077
