    4. iobroker plötzlich nicht mehr erreichbar
    • spicer
      spicer last edited by
      pi@iobroker:/ $ ls -l /opt/iobroker/iobroker-data/objects.jsonl
      -rw-rwxr--+ 1 iobroker iobroker 528381525 Sep 18 22:35 /opt/iobroker/iobroker-data/objects.jsonl
        Thomas Braun Most Active @spicer last edited by
        @spicer sagte in iobroker plötzlich nicht mehr erreichbar:
        Da stimmt was mit den Rechten nicht.
        getfacl /opt/iobroker/iobroker-data/objects.jsonl
        • spicer
          pi@iobroker:/ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
          getfacl: Entferne führende '/' von absoluten Pfadnamen
          # file: opt/iobroker/iobroker-data/objects.jsonl
          # owner: iobroker
          # group: iobroker
          user::rw-
          group::r-x
          group:iobroker:rwx
          mask::rwx
          other::r--
          pi@iobroker:/ $ iobroker stop
          pi@iobroker:/ $ iobroker start
          Aber wieso sollten da plötzlich die Rechte falsch sein?
          Hab ja nichts daran gemacht.
            @spicer
            Auf meinem System stehen die so:
            echad@chet:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
            getfacl: Removing leading '/' from absolute path names
            # owner: iobroker
            # group: iobroker
            user::rw-
            group::r-x                      #effective:r--
            group:iobroker:rwx              #effective:rw-
            mask::rw-
            other::r--
            Schubs den Fixer mal drüber:
            iob stop
            curl -fsL https://iobroker.net/fix.sh | bash -
            • spicer
              Hat leider nichts gebracht 😞
                @spicer
                Soll konkret was bedeuten? Ausgaben in der Konsole?
                spicer 1 Reply Last reply Reply Quote 0
                • spicer
                  spicer @Thomas Braun last edited by
                  pi@iobroker:/ $ iob stop
                  pi@iobroker:/ $ curl -fsL https://iobroker.net/fix.sh | bash -
                  library: loaded
                  Library version=2022-06-15
                      Welcome to the ioBroker installation fixer!
                      Script version: 2022-06-03
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/3)
                  OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:2 http://archive.raspberrypi.org/debian buster InRelease
                  OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                  Installed gcc-c++
                      Checking ioBroker user and directory permissions (2/3)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Checking autostart (3/3)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                    @spicer
                    cd ~
                    iob status
                    • spicer
                      pi@iobroker:/ $ cd ~
                      pi@iobroker:~ $ iob status
                      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                        @spicer
                        dmesg -T | grep -i ext4
                        df -h
                        • spicer
                          Habe mal die objects.jsonl umbenannt und iob neu gestartet.
                           Cannot read system.config: null (OK when migrating or restoring)
                          Objects type: jsonl
                          States  type: jsonl
                          • spicer
                            pi@iobroker:~ $ dmesg -T | grep -i ext4
                            [Mo Sep 19 16:09:43 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=0b3a03bb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                            [Mo Sep 19 16:09:46 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                            [Mo Sep 19 16:09:46 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                            [Mo Sep 19 16:09:49 2022] EXT4-fs (mmcblk0p2): recovery complete
                            [Mo Sep 19 16:09:50 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                            [Mo Sep 19 16:09:50 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Mo Sep 19 16:09:53 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                            pi@iobroker:~ $ df -h
                            Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                            /dev/root        29G    3.8G   24G   14% /
                            devtmpfs        430M       0  430M    0% /dev
                            tmpfs           462M       0  462M    0% /dev/shm
                            tmpfs           462M     12M  450M    3% /run
                            tmpfs           5.0M    4.0K  5.0M    1% /run/lock
                            tmpfs           462M       0  462M    0% /sys/fs/cgroup
                            /dev/sda1        30G    986M   29G    4% /media/usb
                            /dev/mmcblk0p1  253M     49M  204M   20% /boot
                            tmpfs            93M       0   93M    0% /run/user/1000
                              Da hats aber mal Einschläge auf dem Dateisystem gegeben.
                              • spicer
                                spicer @Thomas Braun last edited by spicer
                                SD hinüber?
                                War vor 2 Jahren auch schon mal der Fall.
                                  @spicer
                                  Zumindest angeschossen. Zu dem Zeitpunkt unsauber (aka. 'Ich rupf dem Ding den Strom raus, dann startet der ja auch neu) rebootet?
                                  • spicer
                                    Hab gerade einen "sudo reboot" gemacht.
                                    Läuft immer noch nicht.
                                    • spicer
                                      spicer @spicer last edited by
                                      fsck bringt was?
                                        @spicer
                                        fsck hat die Kiste ja beim reboot automatisch ausgeführt. Die Ergebnisse sind aber mit Vorsicht zu genießen, insbesondere auf SD-Karten, die zwei Jahre geknechtet wurden.
                                        Vielleicht kannst du das Mini-HowTo auf jsonl adaptieren:
                                        https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1663610052343
                                        • spicer
                                          Seit dem Reboot ist etwas anders:
                                          pi@iobroker:~ $ iobroker status
                                          No connection to databases possible ...
                                            @spicer
                                            Wie gesagt: Schau mal ob du mit dem Mini-HowTo parat kommst. Funktionierende *.jsonl an die richtige Stelle kopieren.
                                            1610
