    4. iobroker plötzlich nicht mehr erreichbar
      Thomas Braun Most Active @spicer last edited by
      @spicer sagte in iobroker plötzlich nicht mehr erreichbar:
      /opt/iobroker/iobroker-data/objects.jsonl
      Da stimmt was mit den Rechten nicht.
      getfacl /opt/iobroker/iobroker-data/objects.jsonl
      • spicer
        pi@iobroker:/ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
        getfacl: Entferne führende '/' von absoluten Pfadnamen
        # file: opt/iobroker/iobroker-data/objects.jsonl
        # owner: iobroker
        # group: iobroker
        user::rw-
        group::r-x
        group:iobroker:rwx
        mask::rwx
        other::r--
        pi@iobroker:/ $ iobroker stop
        pi@iobroker:/ $ iobroker start
        Aber wieso sollten da plötzlich die Rechte falsch sein?
        Hab ja nichts daran gemacht.
          @spicer
          Auf meinem System stehen die so:
          echad@chet:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
          getfacl: Removing leading '/' from absolute path names
          # owner: iobroker
          # group: iobroker
          user::rw-
          group::r-x                      #effective:r--
          group:iobroker:rwx              #effective:rw-
          mask::rw-
          other::r--
          Schubs den Fixer mal drüber:
          iob stop
          curl -fsL https://iobroker.net/fix.sh | bash -
          • spicer
            Hat leider nichts gebracht 😞
              @spicer
              Soll konkret was bedeuten? Ausgaben in der Konsole?
              spicer 1 Reply Last reply Reply Quote 0
              • spicer
                spicer @Thomas Braun last edited by
                pi@iobroker:/ $ iob stop
                pi@iobroker:/ $ curl -fsL https://iobroker.net/fix.sh | bash -
                library: loaded
                Library version=2022-06-15
                    Welcome to the ioBroker installation fixer!
                    Script version: 2022-06-03
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/3)
                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                Installed gcc-c++
                    Checking ioBroker user and directory permissions (2/3)
                Created /etc/sudoers.d/iobroker
                Fixing directory permissions...
                    Checking autostart (3/3)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                  @spicer
                  cd ~
                  iob status
                  • spicer
                    pi@iobroker:/ $ cd ~
                    pi@iobroker:~ $ iob status
                    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                      @spicer
                      dmesg -T | grep -i ext4
                      df -h
                      • spicer
                        Habe mal die objects.jsonl umbenannt und iob neu gestartet.
                         Cannot read system.config: null (OK when migrating or restoring)
                        Objects type: jsonl
                        States  type: jsonl
                        • spicer
                          pi@iobroker:~ $ dmesg -T | grep -i ext4
                          [Mo Sep 19 16:09:43 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=0b3a03bb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                          [Mo Sep 19 16:09:46 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                          [Mo Sep 19 16:09:46 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                          [Mo Sep 19 16:09:49 2022] EXT4-fs (mmcblk0p2): recovery complete
                          [Mo Sep 19 16:09:50 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                          [Mo Sep 19 16:09:50 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Mo Sep 19 16:09:53 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                          pi@iobroker:~ $ df -h
                          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                          /dev/root        29G    3.8G   24G   14% /
                          devtmpfs        430M       0  430M    0% /dev
                          tmpfs           462M       0  462M    0% /dev/shm
                          tmpfs           462M     12M  450M    3% /run
                          tmpfs           5.0M    4.0K  5.0M    1% /run/lock
                          tmpfs           462M       0  462M    0% /sys/fs/cgroup
                          /dev/sda1        30G    986M   29G    4% /media/usb
                          /dev/mmcblk0p1  253M     49M  204M   20% /boot
                          tmpfs            93M       0   93M    0% /run/user/1000
                            Da hats aber mal Einschläge auf dem Dateisystem gegeben.
                            • spicer
                              spicer @Thomas Braun last edited by spicer
                              SD hinüber?
                              War vor 2 Jahren auch schon mal der Fall.
                                @spicer
                                Zumindest angeschossen. Zu dem Zeitpunkt unsauber (aka. 'Ich rupf dem Ding den Strom raus, dann startet der ja auch neu) rebootet?
                                • spicer
                                  Hab gerade einen "sudo reboot" gemacht.
                                  Läuft immer noch nicht.
                                  • spicer
                                    spicer @spicer last edited by
                                    fsck bringt was?
                                      @spicer
                                      fsck hat die Kiste ja beim reboot automatisch ausgeführt. Die Ergebnisse sind aber mit Vorsicht zu genießen, insbesondere auf SD-Karten, die zwei Jahre geknechtet wurden.
                                      Vielleicht kannst du das Mini-HowTo auf jsonl adaptieren:
                                      https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1663610052343
                                      • spicer
                                        Seit dem Reboot ist etwas anders:
                                        pi@iobroker:~ $ iobroker status
                                        No connection to databases possible ...
                                          @spicer
                                          Wie gesagt: Schau mal ob du mit dem Mini-HowTo parat kommst. Funktionierende *.jsonl an die richtige Stelle kopieren.
                                            Homoran Global Moderator Administrators @spicer last edited by Homoran
                                            wundert dich das wenn du die Datebank löschst?
                                            1610
