    4. iobroker plötzlich nicht mehr erreichbar
    • spicer
      spicer last edited by
      Hat leider nichts gebracht 😞
        Thomas Braun Most Active @spicer last edited by
        @spicer
        Soll konkret was bedeuten? Ausgaben in der Konsole?
        spicer 1 Reply Last reply Reply Quote 0
        • spicer
          spicer @Thomas Braun last edited by
          pi@iobroker:/ $ iob stop
          pi@iobroker:/ $ curl -fsL https://iobroker.net/fix.sh | bash -
          library: loaded
          Library version=2022-06-15
              Welcome to the ioBroker installation fixer!
              Script version: 2022-06-03
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          OK:2 http://archive.raspberrypi.org/debian buster InRelease
          OK:3 https://deb.nodesource.com/node_16.x buster InRelease
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@iobroker:/ $ iobroker start
            @spicer
            cd ~
            iob status
            • spicer
              pi@iobroker:/ $ cd ~
              pi@iobroker:~ $ iob status
              Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                @spicer
                dmesg -T | grep -i ext4
                df -h
                • spicer
                  Habe mal die objects.jsonl umbenannt und iob neu gestartet.
                   Cannot read system.config: null (OK when migrating or restoring)
                  Objects type: jsonl
                  States  type: jsonl
                  • spicer
                    pi@iobroker:~ $ dmesg -T | grep -i ext4
                    [Mo Sep 19 16:09:43 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=0b3a03bb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                    [Mo Sep 19 16:09:46 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                    [Mo Sep 19 16:09:46 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                    [Mo Sep 19 16:09:49 2022] EXT4-fs (mmcblk0p2): recovery complete
                    [Mo Sep 19 16:09:50 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                    [Mo Sep 19 16:09:50 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Mo Sep 19 16:09:53 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                    pi@iobroker:~ $ df -h
                    Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                    /dev/root        29G    3.8G   24G   14% /
                    devtmpfs        430M       0  430M    0% /dev
                    tmpfs           462M       0  462M    0% /dev/shm
                    tmpfs           462M     12M  450M    3% /run
                    tmpfs           5.0M    4.0K  5.0M    1% /run/lock
                    tmpfs           462M       0  462M    0% /sys/fs/cgroup
                    /dev/sda1        30G    986M   29G    4% /media/usb
                    /dev/mmcblk0p1  253M     49M  204M   20% /boot
                    tmpfs            93M       0   93M    0% /run/user/1000
                      @spicer sagte in iobroker plötzlich nicht mehr erreichbar:
                      Da hats aber mal Einschläge auf dem Dateisystem gegeben.
                      • spicer
                        spicer @Thomas Braun last edited by spicer
                        SD hinüber?
                        War vor 2 Jahren auch schon mal der Fall.
                          @spicer
                          Zumindest angeschossen. Zu dem Zeitpunkt unsauber (aka. 'Ich rupf dem Ding den Strom raus, dann startet der ja auch neu) rebootet?
                          • spicer
                            Hab gerade einen "sudo reboot" gemacht.
                            Läuft immer noch nicht.
                            • spicer
                              spicer @spicer last edited by
                              fsck bringt was?
                                @spicer
                                fsck hat die Kiste ja beim reboot automatisch ausgeführt. Die Ergebnisse sind aber mit Vorsicht zu genießen, insbesondere auf SD-Karten, die zwei Jahre geknechtet wurden.
                                Vielleicht kannst du das Mini-HowTo auf jsonl adaptieren:
                                https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1663610052343
                                • spicer
                                  Seit dem Reboot ist etwas anders:
                                  pi@iobroker:~ $ iobroker status
                                  No connection to databases possible ...
                                    @spicer
                                    Wie gesagt: Schau mal ob du mit dem Mini-HowTo parat kommst. Funktionierende *.jsonl an die richtige Stelle kopieren.
                                      Homoran Global Moderator Administrators @spicer last edited by Homoran
                                      wundert dich das wenn du die Datebank löschst?
                                      • spicer
                                        spicer @Homoran last edited by
                                        Hatte die Datei nur renamed. Jetzt ist sie wieder wie vorher da stehen.
                                        • spicer
                                          Nach der Mini-HowTo Prozedur erscheint nun:
                                          Objects type: jsonl
                                          States  type: jsonl
                                          • spicer
                                            Und läuft!
                                            Vielen Dank Euch allen!
                                            1610
