    5. Hs 100 Probleme
    Hs 100 Probleme
      arteck Developer Most Active @Spidermike last edited by
      @spidermike das ist admin.. nicht der adapter..mach ein extra Thread dafür auf bitte
        Spidermike @arteck last edited by
        ich muss mich wal wieder melden und zwar habe ich arge Probleme mit dem HS 100 Adapter und ich hoffe ihr könnt mir helfen.
        Der Adapter stürzt immer wieder ab und schreibt folgendes in die Protokolldatei
        host.raspberrypi4-iobroker
        	2022-09-20 15:31:19.212	warn	Do not restart adapter system.adapter.hs100.0 because restart loop detected
        	2022-09-20 15:31:19.212	info	Restart adapter system.adapter.hs100.0 because enabled
        	2022-09-20 15:31:19.212	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        	2022-09-20 15:31:19.212	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
        	2022-09-20 15:31:19.212	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
        	2022-09-20 15:31:19.211	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
        	2022-09-20 15:31:19.211	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
        	2022-09-20 15:31:19.211	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
        	2022-09-20 15:31:19.211	error	Caught by controller[2]: at processTimers (node:internal/timers:502:7)
        	2022-09-20 15:31:19.211	error	Caught by controller[2]: at listOnTimeout (node:internal/timers:559:17)
        	2022-09-20 15:31:19.210	error	Caught by controller[2]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
        	2022-09-20 15:31:19.210	error	Caught by controller[1]: at processTimers (node:internal/timers:502:7)
        	2022-09-20 15:31:19.210	error	Caught by controller[1]: at listOnTimeout (node:internal/timers:559:17)
        	2022-09-20 15:31:19.210	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
        	2022-09-20 15:31:19.210	error	Caught by controller[1]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
        	2022-09-20 15:31:19.210	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
        	2022-09-20 15:31:19.210	error	Caught by controller[0]: at processTimers (node:internal/timers:502:7)
        	2022-09-20 15:31:19.209	error	Caught by controller[0]: at listOnTimeout (node:internal/timers:559:17)
        	2022-09-20 15:31:19.209	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
        	2022-09-20 15:31:19.209	error	Caught by controller[0]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
        	2022-09-20 15:31:19.209	error	Caught by controller[0]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
        hs100.0
        	2022-09-20 15:31:18.631	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.0
        	2022-09-20 15:31:18.629	info	terminating
        hs100.0
        	2022-09-20 15:31:18.628	info	cleaned everything up...
        hs100.0
        	2022-09-20 15:31:18.623	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
        hs100.0
        	2022-09-20 15:31:18.622	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
        hs100.0
        	2022-09-20 15:31:18.621	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_monthstat":{"year":2022}}}
        hs100.0
        	2022-09-20 15:31:18.621	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        hs100.0
        	2022-09-20 15:31:17.888	warn	getDevice Socket connection Timeout ip: 192.168.178.94 please reconnect the Device
        hs100.0
        	2022-09-20 15:31:12.895	warn	getDevice Socket connection Timeout ip: 192.168.178.94 please reconnect the Device
        was läuft jetzt wieder schief?
          Thomas Braun Most Active @Spidermike last edited by Thomas Braun
          @spidermike sagte in Hs 100 Probleme:
          Netzwerktrouble.
          Und der Pfad /opt/iobroker/node_modules/tplink-smarthome-api/ kommt mir auch komisch vor. Üblicherweise liegen Deps mindestens eine Ebene tiefer im tree.
          S arteck 2 Replies Last reply Reply Quote 0
            Spidermike @Thomas Braun last edited by Spidermike
            danke für deine schnelle Antwort, was muss ich jetzt machen?
            Denn das nervt, denn mein Script für meine Heizstäbe funktioniert dann nicht mehr wenn der Adapter nicht läuft
            Und was hat das mit dem Timeout auf sich?
              @spidermike
              Beim Netzwerktrouble kann man nur sehr eingeschränkt helfen.
              Musst du vor Ort klären. Insbesondere bei WLAN kann das aufwendig sein.
              Zum iobroker:
              sudo ln -s /usr/bin/node /usr/bin/nodejs
              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              iobroker update
              cd /opt/iobroker
              npm ls
              anschauen.
                Das Gerät hat auf einen 'Anruf' nicht innerhalb von 10 Sekunden reagiert.
                  @thomas-braun sagte in Hs 100 Probleme:
                  Kann das sein das die Wlanverbindung zu der steckdose zu schlecht ist?
                  Steckdose ist im Keller
                  Thomas Braun S 2 Replies Last reply Reply Quote 0
                    Natürlich. Ich sag ja: Netzwerktrouble.
                      Spidermike @Spidermike last edited by Spidermike
                      @spidermike
                      uname -m && type -P nodejs node npm && nodejs -v &&        node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /d        ev/null && sudo apt update && apt policy nodejs
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.0
                      v16.17.0
                      8.15.0
                      4.0.23
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
                      /home/pi
                      OK:1 http://phoscon.de/apt/deconz bullseye InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:4 https://repos.influxdata.com/debian bullseye InRelease
                      OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Paketlisten werden gelesen… Fertig
                      Abhängigkeitsbaum wird aufgebaut… Fertig
                      Statusinformationen werden eingelesen… Fertig
                      Alle Pakete sind aktuell.
                      nodejs:
                        Installiert:           16.17.0-deb-1nodesource1
                        Installationskandidat: 16.17.0-deb-1nodesource1
                        Versionstabelle:
                       *** 16.17.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                              100 /var/lib/dpkg/status
                           12.22.12~dfsg-1~deb11u1 500
                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                      pi@raspberrypi4-iobroker:~ $ pi@raspberrypi4-iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v &&        node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /d        ev/null && sudo apt update && apt policy nodejs
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.0
                      v16.17.0
                      8.15.0
                      4.0.23
                      pi
                      /home/pi
                        @spidermike
                        iobroker update
                        cd /opt/iobroker
                        npm ls
                        noch nachreichen.
                          @spidermike
                          iobroker update
                          cd /opt/iobroker
                          npm ls
                          noch nachreichen.
                          pi@raspberrypi4-iobroker:~ $ iobroker update
                          Used repository: stable
                          Adapter    "admin"        : 6.2.22   , installed 6.2.22
                          Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                          Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                          Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                          Adapter    "devices"      : 1.0.12   , installed 1.0.12
                          Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                          Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
                          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                          Adapter    "growatt"      : 1.1.19   , installed 1.1.19
                          Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
                          Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                          Adapter    "iot"          : 1.11.9   , installed 1.11.9
                          Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
                          Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                          Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                          Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                          Adapter    "vis"          : 1.4.15   , installed 1.4.15
                          Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
                          Adapter    "wled"         : 0.6.7    , installed 0.6.7
                          Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                          pi@raspberrypi4-iobroker:~ $ cd /opt/iobroker
                          pi@raspberrypi4-iobroker:/opt/iobroker $ cd /opt/iobroker
                          pi@raspberrypi4-iobroker:/opt/iobroker $ npm ls
                          iobroker.inst@3.0.0 /opt/iobroker
                          ├── iobroker.admin@6.2.22
                          ├── iobroker.alexa2@3.19.9
                          ├── iobroker.backitup@2.4.10
                          ├── iobroker.cloud@4.2.2
                          ├── iobroker.deconz@1.3.21
                          ├── iobroker.devices@1.0.12
                          ├── iobroker.discovergy@0.5.8
                          ├── iobroker.discovery@3.0.5
                          ├── iobroker.fb-checkpresence@1.1.19
                          ├── iobroker.fullybrowser@2.1.2
                          ├── iobroker.growatt@1.1.19
                          ├── iobroker.homeconnect@1.0.1
                          ├── iobroker.hs100@2.1.2
                          ├── iobroker.iot@1.11.9
                          ├── iobroker.iqontrol@2.0.0
                          ├── iobroker.javascript@6.0.3
                          ├── iobroker.js-controller@4.0.23
                          ├── iobroker.mqtt@4.0.7
                          ├── iobroker.plenticore@2.2.0
                          ├── iobroker.rpi2@1.3.2
                          ├── iobroker.shelly@6.0.0
                          ├── iobroker.simple-api@2.7.0
                          ├── iobroker.socketio@4.2.0
                          ├── iobroker.telegram@1.14.1
                          ├── iobroker.vis@1.4.15
                          ├── iobroker.web@4.3.0
                          ├── iobroker.whatsapp-cmb@0.2.2
                          ├── iobroker.wled@0.6.7
                          └── iobroker.zigbee@1.7.5
                            @spidermike
                            Das ist alles total i. O.
                            Bleibt dein WLAN.
                              habe mal in mein Mesh geschaut, die Steckdose verbindet sich mit einen Repeater der viel zu weit weg ist, kann ich nicht IP adressen direkt an einen Repeater binden ?
                                @spidermike
                                Keine Ahnung. Was ist denn da für Hardware involviert?
                                  @spidermike
                                  Bleibt dein WLAN.
                                  Ich habe heute erst alles auf Node.js 16 umgestellt
                                    @spidermike
                                    Ich habe eine Fritzbox 7590 als Master und mehrere Repeater in 2 Stockwerken im Haus
                                    Muss noch leider alles über Wlan und über Steckdosen laufen lassen da ich kein Netzwerkkabel verbaut hab
                                      Thomas Braun Most Active last edited by
                                      @spidermike
                                      Für gewöhnlich organisiert sich so ein Mesh autark. Zumindest in der Theorie.
                                      Ich hab selber keins laufen hier, kann also da nicht wirklich weiterhelfen.
                                        ich warte seid 2 Jahren auf LWL im Haus und wollte dann mir Netzwerkkabel verlegen, aber angeblich sollte das dieses Jahr passieren aber die kommen nicht vorwärts.
                                          arteck Developer Most Active @Thomas Braun last edited by arteck
                                          das ist richtig so...
                                          @spidermike die Dose antwortet nicht innerhalb der Parameter.. kannst ewtl. mal in der Adapter Einstellugen die Antwortzeit verlängern
                                            @arteck sagte in Hs 100 Probleme:
                                            @spidermike die Dose antwortet nicht innerhalb der Parameter.. kannst ewtl. mal in der Adapter Winstellugen die Antwortzeit verlängern
                                            wie mache ich das?
                                            2561
