    3. Entwicklung
    4. [Projekt] Admin-neo - die neue Oberfläche
    • V
      vore last edited by
      Hallo!
      Hier mal die Ausgaben bei der Installation. Sagt Euch das etwas?
      $ ./iobroker url "/home/volker/Downloads/ioBroker.admin-neo-master.zip" --debug
      install /home/volker/Downloads/ioBroker.admin-neo-master.zip
      npm install /home/volker/Downloads/ioBroker.admin-neo-master.zip --production --prefix "/opt/iobroker" (System call)
      npm
       ERR! addLocal Could not install /home/volker/Downloads/ioBroker.admin-neo-master.zip
      npm
       ERR! Linux 4.9.12-sunxinpm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "/home/volker/Downloads/ioBroker.admin-neo-master.zip" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v7.2.1
      npm ERR! npm  v3.10.10
      npm ERR! path /home/volker/Downloads/ioBroker.admin-neo-master.zipnpm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/volker/Downloads/ioBroker.admin-neo-master.zip'npm ERR! enoent ENOENT: no such file or directory, open '/home/volker/Downloads/ioBroker.admin-neo-master.zip'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
      ERROR: host.cubietruck Cannot install /home/volker/Downloads/ioBroker.admin-neo-master.zip: 254
      ERROR: process exited with code 25
        apollon77 last edited by
        Das ".zip" der Installations-URL am Ende ist falsch
        • V
          vore last edited by
          Klappt leider ohne .zip ebenfalls nicht 😞
          $ ./iobroker url "/home/volker/Downloads/ioBroker.admin-neo-master" --debug
          npm install /home/volker/Downloads/ioBroker.admin-neo-master --production --prefix "/opt/iobroker" (System call)
          npm
          npm
           ERR!
           Linux 4.9.12-sunxinpm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "/home/volker/Downloads/ioBroker.admin-neo-master" "--production" "--prefix" "/opt/iobroker"
          npm ERR! node v7.2.1npm ERR! npm  v3.10.10
          npm ERR! errno -2npm
           ERR! syscall open
          npm ERR!
           enoent ENOENT: no such file or directory, open '/home/volker/Downloads/ioBroker.admin-neo-master'npm ERR! enoent ENOENT: no such file or directory, open '/home/volker/Downloads/ioBroker.admin-neo-master'
          npm ERR! enoent
           and is related to npm not being able to find a file.npm
          ERR! enoent
          npm
          ERR!
          ERROR: host.cubietruck Cannot install /home/volker/Downloads/ioBroker.admin-neo-master: 254
            Wenn ich das richtig sehe hast du in github das zip heruntergeladen und willst admin-neo jetzt daraus installieren.
            Du musst im Octocat icon den Pfad zu der Github Seite eingeben.
            Rainer
            • V
              vore last edited by
              Hallo Rainer!
              Ja, genau. Von Gihub geladen und jetzt über "URL" installieren vom PC. Geht das nicht?
              Muss ich die Verwahrungsorte anpassen und dann von GitHub installieren? Konnte da aber leider nichts finden.
              Vore
              • ldittmar
                ldittmar Developer last edited by
                Hi Vore,
                gebe mal in das Feld URL das hier ein:
                https://github.com/ldittmar81/ioBroker.admin-neo
                Grüße,
                ldittmar
                • htrecksler
                  htrecksler Forum Testing last edited by
                  @Homoran:
                  Wenn ich das richtig sehe hast du in github das zip heruntergeladen und willst admin-neo jetzt daraus installieren. `
                  Bei mir hat das auch mit dem herunterladen und installieren geklappt.
                  • V
                    vore last edited by
                    Hallo! Das wars.. jetzt wurde der Adapter geladen. Danke!
                    Sehr schick das Ganze!
                    Vore
                    • cvidal
                      Hi zusammen,
                      Ich habe gerade auch mal installiert. Gefällt mir erstmal so ganz gut optisch mal eine sehr schöne alternative.
                      Ich Persönlich finde aber das wenn man Adapter sucht man viel scrollen muss weil nur drei nebeneinander sind und ich da etwas die Übersicht verliere, dazu muss ich aber auch sagen das ich meinst mit dem Laptop arbeite ist dann mit Touchpad etwas umständlich, ich möchte Admin Neo keinesfalls schlecht machen wollte mich aber einfach mal dazu äußern ich hoffe das nimmt man mir nicht übel.
                      Ich finde Neo ist sehr gut gelungen danke dafür.
                      Gruß Christian
                        Eine Listen-Ansicht gibts bei Neo aber auch. Schau mal bei den Icons oben
                        • ldittmar
                          Und falls ihr euch fragt warum der lahme Entwickler noch nicht fertig ist. Er kommt z.Z. einfach zu nichts… 😢
                          Grüße,
                          ldittmar
                            simpixo last edited by
                            Ich finde es definitiv super das Ihr Entwickler überhaupt in eurer FREIZEIT so viel für die Community macht! DANKE!!!!
                              @ldittmar:
                              Grüße,
                              ldittmar `
                              dann nimm dir doch Urlaub verdammt…scheiss Arbeit man kommt zu nichts....sag ich dir... :lol: :lol: :lol: :lol:
                              sehr schick das ganze...
                              • UncleSam
                                UncleSam Developer last edited by
                                Hi ldittmar
                                Bei meiner neusten Adapter-Entwicklung (noch nicht veröffentlicht) setze ich die Admin HTML-Seite mit https://www.jsviews.com/ um und habe dabei gemerkt, wieviel einfacher es gehen kann, wenn man eine (gute) View/View Model Trennung (MVVM oder MVC) hat. So kann ich mir das Laden und Zurückspeichern von Werten im Config Objekt sparen und es direkt mit der View (respektive dem Template) verbinden.
                                Ist in dieser Hinsicht bei Admin-neo (insbesondere für die jeweilige Adapter-Konfiguration) etwas geplant? Klar kann das jeder machen wie er will, aber je nachdem könnte Admin-neo die Adapter dabei unterstützen.
                                Ich habe wenig Erfahrung mit JavaScript, arbeite aber beruflich oft mit MVVM in der .NET/C#/WPF-Welt. Vielleicht hast du mit jQuery schon etwas ähnliches gemacht; ansonsten wären JsViews oder sogar Angular 2 wahrscheinlich interessante Frameworks. Was meinst du?
                                Grüsse
                                UncleSam
                                • ldittmar
                                  Hi UncleSam,
                                  die Frage die sich mir stellt, ist ob man nicht alles jetzt nochmal umwirft und auf React setzt. Ich kenne mich mit React noch nicht aus, aber was ich so gehört und gesehen habe soll es einfach super sein. Bin noch bis zum 10.08 weg und werde mich danach darum kümmern.
                                  Grüße,
                                  ldittmar
                                  P.S.: Der Administrations-Adapter ist riesig und ich könnte Hilfe gebrauchen. 😉
                                  • BBTown
                                    BBTown last edited by
                                    @ldittmar:
                                    Grüße,
                                    ldittmar `
                                    Wir haben hier doch den "Bedanken Button".
                                    Ich glaube wir benötigen zukünftig für solche Fälle etwas ähnliches wie ein "hierfür zeihe ich dir eine Danksagung wieder ab" Button.
                                    damit Du dich mehr anstrengst?? :shock: :lol: :lol: 8-)
                                    Vielen Dank euch allen allen für eure Arbeit und Engagement !!!
                                    • ldittmar
                                      @BBTown:
                                      @ldittmar:
                                      Grüße,
                                      ldittmar `
                                      Vielen Dank euch allen allen für eure Arbeit und Engagement !!! `
                                      Hey… ich strenge mich doch an! Ich strenge mich an in der kroatische Sonne nicht zu schmelzen. :lol: Danach gehts weiter...
                                      Grüße,
                                      Ldittmar
                                        @BBTown:
                                        Wir haben hier doch den "Bedanken Button". `
                                        den haben wir!
                                        (=thumbs up!)
                                        @ldittmar:
                                        Ich strenge mich an in der kroatische Sonne nicht zu schmelzen. :lol: Danach gehts weiter… `
                                        Shönen Urlaub.
                                        Rainer
                                        • carsten04
                                          carsten04 Developer last edited by
                                          @ldittmar:
                                          Hi UncleSam,
                                          Grüße,
                                          ldittmar
                                          P.S.: Der Administrations-Adapter ist riesig und ich könnte Hilfe gebrauchen. 😉 `
                                          Hallo ldittmar,
                                          wenn Du gerade sowieso lange Weile hast :-), dann schau Dir doch mal vue.js an. Ich fange gerade an mich damit zu beschäftigen und bin eigentlich immer mehr begeistert von diesem framework. Ich finde das wäre ein perfektes framework für Deine Ideen. Natürlich gibt es auch angular2 und react, aber Beide haben eine sehr hohe Einstiegsschwelle (Angular2 -> typescript, react -> jsx) . vue.js wächst quasi mit den Aufgaben und ist rein js basiert. Du kannst js V5 und V6 nutzen und es gibt ein riesiges Ökosystem mit Lösungen für wirklich fast alle Themen rund um spa-Entwicklung. Für mich der Hauptvorteil ist die Art Komponenten für das FE zu entwicklen und die klare Strukturierung die sich daraus ergibt. Du hast eine Trennung zwischen Template (html-Struktur), js für die Logik und style zum aufhübschen und kannst sogar fast alles, wenn Du denn möchtest, serverside rendern. Ein Blick wäre es mMn auf jeden Fall mal wert (https://vuejs.org).
                                          Carsten
                                          • Bluefox
                                            Bluefox last edited by
                                            @carsten04:
                                            @ldittmar:
                                            Hi UncleSam,
                                            Grüße,
                                            ldittmar
                                            Hallo ldittmar,
                                            Carsten `
                                            Angular, react, vue….
                                            hab panel - Angular, material - react.
                                            Vue hat genauso wie Angular ng-xxx v-xxx Elemente. Und man muss die lernen.
                                            React hat fast pure html für Templates und das erleichtert den Einstieg.
                                            54
                                            12560
