    4. Alpha Testing: OCPP Wallbox Adapter
    • Meister Mopper
      Meister Mopper @foxriver76 last edited by Meister Mopper
      @foxriver76
      Eben wollte ich das Laden transActive false beenden. Es funktionierte jedoch nicht wegen eines timeout.
      Nachdem ich availability auf false und wieder true gesetzt hatte, schaltete das System nach erneutem transActive false von Charging auf Finishing.
      Hier das log:
      ocpp.0	2022-09-19 18:01:35.690	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Timeout for message 1472e968-074e-452a-8e15-6220076eeb36
      ocpp.0	2022-09-19 18:02:07.174	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
      ocpp.0	2022-09-19 18:02:07.221	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6028,12128},0,0,350,2022-09-19T16:02:06Z,1,3,{0,0,0,0,0,0,0,0,0},280,14,3,112,0,350,160,0
      ocpp.0	2022-09-19 18:02:21.206	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
      ocpp.0	2022-09-19 18:02:21.397	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6033,12128},0,0,350,2022-09-19T16:02:20Z,1,3,{0,0,0,0,0,0,0,0,0},280,14,3,112,0,350,160,0
      ocpp.0	2022-09-19 18:02:39.406	info	Received stop transaction from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
      ocpp.0	2022-09-19 18:02:40.122	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Finishing
      ocpp.0	2022-09-19 18:02:43.947	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11926,6155,61600},0,0,350,2022-09-19T16:02:39Z,0,3,{0,0,0,0,0,0,0,0,0},280,13,3,112,0,350,900,0
      • foxriver76
        foxriver76 Developer @Meister Mopper last edited by
        @meister-mopper kannst du den Change mal rückgängig machen, hier https://github.com/foxriver76/ioBroker.ocpp/blob/48303d5b08f18682ed681038d614133990a50c1e/src/main.ts#L520 ein W statt einem A rein schreibe, den chargeLimit state unter Objekte mit einer sinnvollen Wattbegrenzung beschreiben und dann nochmal starten. Evtl. benötigt die WB die Begrenzung in Watt, ich finde leider keine Spezifikation. Falls es das ist, kann ich es einbauen.
        Meister Mopper G 2 Replies Last reply Reply Quote 0
        • Meister Mopper
          @foxriver76 sagte in Alpha Testing: OCPP Wallbox Adapter:
          Was meinst Du damit "den Change mal rückgängig machen"?
          • foxriver76
            @meister-mopper die Zeilen die wird bei dir abgeändert haben, wieder in den Urzustand versetzen 😉
            • Meister Mopper
              @foxriver76
              Nein, leider hat die Rücknahme des Change und der Austausch 'W' gegen 'A' nicht funktioniert. Ich erhalte wieder:
              ocpp.0	2022-09-20 16:39:30.406	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
              • foxriver76
                @meister-mopper kannst du davon mal debug log zeigen?
                • Meister Mopper
                  @foxriver76
                  ocpp.0	2022-09-20 16:30:27.465	info	Received stop transaction from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                  ocpp.0	2022-09-20 16:30:28.133	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Finishing
                  ocpp.0	2022-09-20 16:30:32.213	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11936,6151,61594},0,0,320,2022-09-20T14:30:27Z,0,3,{0,0,0,0,0,0,0,0,0},260,9,4,112,0,300,900,0
                  ocpp.0	2022-09-20 16:30:53.680	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                  ocpp.0	2022-09-20 16:31:20.824	error	Cannot execute command "chargeLimit" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                  ocpp.0	2022-09-20 16:31:52.059	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                  • foxriver76
                    @meister-mopper steht dir Instanz auf loglevel debug? gg
                    Da scheint was zu fehlen
                    • Meister Mopper
                      @foxriver76
                      Das ist das debug log. Hier mal alles, was ausgeworfen wurde:
                      ocpp.0	2022-09-20 15:27:01.250	info	New valid connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" (http/ocpp1.6)
                      ocpp.0	2022-09-20 15:36:08.075	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                      ocpp.0	2022-09-20 15:36:08.125	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11940,9973,61568},0,0,290,2022-09-20T13:36:07Z,0,3,{0,0,0,0,0,0,0,0,0},200,1,0,112,0,210,900,0
                      ocpp.0	2022-09-20 15:43:12.140	info	Loglevel changed from "info" to "debug"
                      ocpp.0	2022-09-20 15:43:54.143	debug	Sending RemoteStartTransaction for http://192_168_178_80:9220/EVB-XXXXXXXXX: {"connectorId":1,"idTag":"XXXXXXXXX"}
                      ocpp.0	2022-09-20 15:43:54.307	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:43:54.308	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:43:54.942	debug	{"idTag":"XXXXXXXXX","commandOcpp":"Authorize"}
                      ocpp.0	2022-09-20 15:43:54.943	info	Received Authorization Request from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:43:56.889	debug	{"connectorId":1,"status":"Preparing","errorCode":"NoError","timestamp":"2022-09-20T13:43:56Z","commandOcpp":"StatusNotification"}
                      ocpp.0	2022-09-20 15:43:56.891	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                      ocpp.0	2022-09-20 15:43:56.967	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Off,0,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,290,2022-09-20T13:43:56Z,0,3,{0,0,0,0,0,0,0,0,0},200,0,0,125,0,210,900,0","commandOcpp":"DataTransfer"}
                      ocpp.0	2022-09-20 15:43:56.968	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Off,0,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,290,2022-09-20T13:43:56Z,0,3,{0,0,0,0,0,0,0,0,0},200,0,0,125,0,210,900,0
                      ocpp.0	2022-09-20 15:43:58.796	debug	{"connectorId":1,"status":"SuspendedEVSE","errorCode":"NoError","info":"B;290","timestamp":"2022-09-20T13:43:58Z","commandOcpp":"StatusNotification"}
                      ocpp.0	2022-09-20 15:43:58.798	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEVSE
                      ocpp.0	2022-09-20 15:43:59.504	debug	{"connectorId":1,"status":"SuspendedEV","errorCode":"NoError","info":"B;290","timestamp":"2022-09-20T13:43:59Z","commandOcpp":"StatusNotification"}
                      ocpp.0	2022-09-20 15:43:59.504	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEV
                      ocpp.0	2022-09-20 15:44:01.250	debug	{"connectorId":1,"idTag":"XXXXXXXXX","timestamp":"2022-09-20T13:43:57Z","meterStart":0,"commandOcpp":"StartTransaction"}
                      ocpp.0	2022-09-20 15:44:01.251	info	Received Start transaction from "http://192.168.178.80:9220/XXXXXXXXX"
                      ocpp.0	2022-09-20 15:44:04.015	debug	{"connectorId":1,"status":"Charging","errorCode":"NoError","info":"C;290","timestamp":"2022-09-20T13:44:03Z","commandOcpp":"StatusNotification"}
                      ocpp.0	2022-09-20 15:44:04.016	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
                      ocpp.0	2022-09-20 15:44:06.405	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7984,0},{0,0},{B,11936,9132,61568},0,0,290,2022-09-20T13:43:58Z,1,3,{0,0,0,0,0,0,0,0,0},200,0,0,125,0,210,0,0","commandOcpp":"DataTransfer"}
                      ocpp.0	2022-09-20 15:44:06.406	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7984,0},{0,0},{B,11936,9132,61568},0,0,290,2022-09-20T13:43:58Z,1,3,{0,0,0,0,0,0,0,0,0},200,0,0,125,0,210,0,0
                      ocpp.0	2022-09-20 15:44:11.254	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11952,8652,12112},0,0,290,2022-09-20T13:43:59Z,1,3,{0,0,0,0,0,0,0,0,0},200,0,0,125,0,210,60,0","commandOcpp":"DataTransfer"}
                      ocpp.0	2022-09-20 15:44:11.255	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11952,8652,12112},0,0,290,2022-09-20T13:43:59Z,1,3,{0,0,0,0,0,0,0,0,0},200,0,0,125,0,210,60,0
                      ocpp.0	2022-09-20 15:44:16.392	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Charging,NoError,No error.,1,Blue,1,{20,7984,10},{0,0},{C,11944,5868,12128},0,0,290,2022-09-20T13:44:03Z,1,3,{0,0,0,0,0,0,0,0,0},200,0,0,112,0,210,60,0","commandOcpp":"DataTransfer"}
                      ocpp.0	2022-09-20 15:44:16.393	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,10},{0,0},{C,11944,5868,12128},0,0,290,2022-09-20T13:44:03Z,1,3,{0,0,0,0,0,0,0,0,0},200,0,0,112,0,210,60,0
                      ocpp.0	2022-09-20 15:44:49.230	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:44:49.231	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:45:44.299	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:45:44.300	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:46:39.228	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:46:39.228	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:47:34.302	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:47:34.303	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:48:29.228	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:48:29.228	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:49:24.237	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:49:24.238	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:50:19.226	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:50:19.226	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:51:14.231	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:51:14.232	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:52:09.243	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:52:09.245	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:53:04.226	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:53:04.227	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:53:59.225	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:53:59.226	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:54:54.223	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:54:54.224	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:55:49.223	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:55:49.224	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:56:44.227	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:56:44.229	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:57:39.212	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:57:39.213	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:58:34.212	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:58:34.213	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:59:05.570	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2022-09-20T13:59:05Z","sampledValue":[{"value":"0","measurand":"Energy.Active.Import.Register","unit":"Wh"}]}],"commandOcpp":"MeterValues"}
                      ocpp.0	2022-09-20 15:59:05.571	info	Received MeterValues from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 15:59:10.234	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11942,6042,12096},0,0,290,2022-09-20T13:59:05Z,1,3,{0,0,0,0,0,0,0,0,0},220,15,5,111,0,250,160,0","commandOcpp":"DataTransfer"}
                      ocpp.0	2022-09-20 15:59:10.234	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11942,6042,12096},0,0,290,2022-09-20T13:59:05Z,1,3,{0,0,0,0,0,0,0,0,0},220,15,5,111,0,250,160,0
                      ocpp.0	2022-09-20 15:59:29.221	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 15:59:29.222	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:00:24.218	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:00:24.219	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:01:19.219	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:01:19.220	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:02:14.219	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:02:14.220	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:03:09.218	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:03:09.218	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:04:04.218	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:04:04.219	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:04:59.208	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:04:59.209	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:05:54.207	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:05:54.208	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:06:49.215	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:06:49.216	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:07:44.252	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:07:44.253	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:08:39.207	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:08:39.208	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:09:34.215	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:09:34.216	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:10:29.217	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:10:29.218	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:11:24.203	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:11:24.204	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:12:19.374	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:12:19.375	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:13:14.211	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:13:14.212	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:14:07.894	debug	{"connectorId":1,"transactionId":1,"meterValue":[{"timestamp":"2022-09-20T14:14:07Z","sampledValue":[{"value":"0","measurand":"Energy.Active.Import.Register","unit":"Wh"}]}],"commandOcpp":"MeterValues"}
                      ocpp.0	2022-09-20 16:14:07.895	info	Received MeterValues from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:14:09.211	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:14:09.212	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:14:12.224	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6041,12096},0,0,310,2022-09-20T14:14:07Z,1,3,{0,0,0,0,0,0,0,0,0},240,15,5,112,0,280,160,0","commandOcpp":"DataTransfer"}
                      ocpp.0	2022-09-20 16:14:12.225	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6041,12096},0,0,310,2022-09-20T14:14:07Z,1,3,{0,0,0,0,0,0,0,0,0},240,15,5,112,0,280,160,0
                      ocpp.0	2022-09-20 16:15:04.200	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:15:04.200	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:15:59.210	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:15:59.210	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:16:54.208	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:16:54.209	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:17:49.212	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:17:49.213	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:18:44.207	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:18:44.208	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:19:39.207	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:19:39.208	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:20:34.206	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:20:34.206	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:21:29.196	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:21:29.197	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:22:24.196	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:22:24.197	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:23:19.204	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:23:19.205	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:24:14.220	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:24:14.221	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:25:09.203	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:25:09.204	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:26:04.202	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:26:04.203	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:26:59.203	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:26:59.204	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:27:54.331	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:27:54.332	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:28:49.191	debug	{"commandOcpp":"Heartbeat"}
                      ocpp.0	2022-09-20 16:28:49.192	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:29:09.364	info	Got terminate signal TERMINATE_YOURSELF
                      ocpp.0	2022-09-20 16:29:09.381	info	terminating
                      ocpp.0	2022-09-20 16:29:09.383	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      ocpp.0	2022-09-20 16:29:15.031	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.17.0, js-controller: 4.0.23
                      ocpp.0	2022-09-20 16:29:15.073	info	Starting OCPP Server
                      ocpp.0	2022-09-20 16:29:15.112	info	Server listening on port 9220
                      ocpp.0	2022-09-20 16:29:49.241	info	New valid connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" (http/ocpp1.6)
                      ocpp.0	2022-09-20 16:29:49.296	info	New device connected: "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:29:49.298	info	Requesting BootNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:29:50.336	info	Requesting StatusNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:29:54.295	info	Received boot notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:29:54.550	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
                      ocpp.0	2022-09-20 16:29:59.218	info	Received MeterValues from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:30:04.335	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6028,12112},0,0,320,2022-09-20T14:29:10Z,1,3,{0,0,0,0,0,0,0,0,0},250,15,5,112,0,300,160,0
                      ocpp.0	2022-09-20 16:30:09.215	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6028,12112},0,0,320,2022-09-20T14:29:54Z,1,3,{0,0,0,0,0,0,0,0,0},250,15,5,112,0,300,160,0
                      ocpp.0	2022-09-20 16:30:20.343	warn	Could not request states of "http://192.168.178.80:9220/EVB-XXXXXXXXX": Timeout for message 062d14a2-1029-4f6b-b35b-5f30427e56cb
                      ocpp.0	2022-09-20 16:36:40.723	info	Got terminate signal TERMINATE_YOURSELF
                      ocpp.0	2022-09-20 16:36:40.732	info	terminating
                      ocpp.0	2022-09-20 16:36:40.734	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      ocpp.0	2022-09-20 16:36:51.314	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.17.0, js-controller: 4.0.23
                      ocpp.0	2022-09-20 16:36:51.361	info	Starting OCPP Server
                      ocpp.0	2022-09-20 16:36:51.403	info	Server listening on port 9220
                      ocpp.0	2022-09-20 16:37:20.269	info	New valid connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" (http/ocpp1.6)
                      ocpp.0	2022-09-20 16:37:20.320	info	New device connected: "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:37:20.322	info	Requesting BootNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:37:21.359	info	Requesting StatusNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:37:25.213	info	Received boot notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:37:25.541	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                      ocpp.0	2022-09-20 16:37:30.243	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,330,2022-09-20T14:37:25Z,0,3,{0,0,0,0,0,0,0,0,0},250,1,4,113,0,290,900,0
                      ocpp.0	2022-09-20 16:37:51.367	warn	Could not request states of "http://192.168.178.80:9220/EVB-XXXXXXXXX": Timeout for message a016bbd2-6f88-4ed1-a0a5-e0e8098f2919
                      ocpp.0	2022-09-20 16:38:09.419	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                      ocpp.0	2022-09-20 16:38:35.293	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Unavailable
                      ocpp.0	2022-09-20 16:38:35.468	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Unavailable,NoError,No error.,0,Red,0,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,330,2022-09-20T14:38:35Z,0,3,{0,0,0,0,0,0,0,0,0},250,1,4,113,0,290,900,0
                      ocpp.0	2022-09-20 16:38:46.892	error	Cannot execute command "chargeLimit" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                      ocpp.0	2022-09-20 16:38:55.894	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                      ocpp.0	2022-09-20 16:38:56.086	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,330,2022-09-20T14:38:55Z,0,3,{0,0,0,0,0,0,0,0,0},250,1,4,113,0,290,900,0
                      ocpp.0	2022-09-20 16:42:33.342	info	Got terminate signal TERMINATE_YOURSELF
                      ocpp.0	2022-09-20 16:42:33.360	info	terminating
                      ocpp.0	2022-09-20 16:42:33.363	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      ocpp.0	2022-09-20 16:42:39.050	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.17.0, js-controller: 4.0.23
                      ocpp.0	2022-09-20 16:42:39.092	info	Starting OCPP Server
                      ocpp.0	2022-09-20 16:42:39.131	info	Server listening on port 9220
                      ocpp.0	2022-09-20 16:43:13.240	info	New valid connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" (http/ocpp1.6)
                      ocpp.0	2022-09-20 16:43:13.295	info	New device connected: "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:43:13.298	info	Requesting BootNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:43:14.339	info	Requesting StatusNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:43:18.199	info	Received boot notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:43:18.420	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                      ocpp.0	2022-09-20 16:43:23.214	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,330,2022-09-20T14:43:18Z,0,3,{0,0,0,0,0,0,0,0,0},250,1,4,113,0,280,900,0
                      ocpp.0	2022-09-20 16:43:38.782	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Unavailable
                      ocpp.0	2022-09-20 16:43:38.833	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Unavailable,NoError,No error.,0,Red,0,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,330,2022-09-20T14:43:38Z,0,3,{0,0,0,0,0,0,0,0,0},250,1,4,113,0,280,900,0
                      ocpp.0	2022-09-20 16:43:44.347	warn	Could not request states of "http://192.168.178.80:9220/EVB-XXXXXXXXX": Timeout for message f3819643-d0ce-46ff-8554-02bb546ab406
                      ocpp.0	2022-09-20 16:43:55.528	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                      ocpp.0	2022-09-20 16:43:55.576	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11935,9132,61568},0,0,330,2022-09-20T14:43:55Z,0,3,{0,0,0,0,0,0,0,0,0},250,1,4,113,0,280,900,0
                      ocpp.0	2022-09-20 16:44:04.590	info	Received Authorization Request from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                      ocpp.0	2022-09-20 16:44:06.952	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                      ocpp.0	2022-09-20 16:44:06.994	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Off,1,{20,7984,100},{0,0},{B,11934,9132,61568},0,0,330,2022-09-20T14:44:06Z,0,3,{0,0,0,0,0,0,0,0,0},250,0,0,125,0,280,900,0
                      • foxriver76
                        @meister-mopper So einen Start benötige ich auf debug wie
                        Die Zeile nur wenn es fehlschlägt, sprich Adapter auf Loglevel Debug stellen und dann eine Transaktion starten. Was ja nicht gehen sollte.
                        • Meister Mopper
                          @foxriver76
                          Ich habe die Instanz so eingestellt:
                          Es kommt aber nicht mehr als:
                          Woran liegt das?
                          • foxriver76
                            foxriver76 Developer @Meister Mopper last edited by foxriver76
                            @meister-mopper hm komisch, da sollte auf jeden fall ein debug log kommen.
                            Kannst du mal bitte auf 0.7.0 updaten, es sollte ein State erstellt werden chargeLimitType da solltest du zwischen A und W wählen können. Bitte mal prüfen, dass bei Änderung sich die Einheit vom chargeLimit State ändert.
                            Falls das tut mal z. B. auf W stellen und 8000 in den chargeLimit State schreiben und dann nochmal transactionActive triggern. Und bitte alles auf debug nach Möglichkeit.
                            • Meister Mopper
                              @foxriver76
                              Update auf 0.7.0:
                              $ iobroker url https://github.com/foxriver76/ioBroker.ocpp.git --host rpizigbee --debug
                              install foxriver76/ioBroker.ocpp#a7c06c513c0e8c6272a10deddd07152bc6efbed7
                              NPM version: 8.15.0
                              Installing foxriver76/ioBroker.ocpp#a7c06c513c0e8c6272a10deddd07152bc6efbed7... (System call)
                              npm WARN skipping integrity check for git dependency ssh://git@github.com/foxriver76/ioBroker.ocpp.git
                              npm WARN deprecated joi-date-extensions@1.2.0: This module has moved and is now available at @hapi/joi-date. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                              npm WARN deprecated hoek@5.0.4: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                              npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                              npm WARN deprecated joi@13.7.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                              added 8 packages, and changed 51 packages in 2m88 packages are looking for funding run `npm fund` for details
                              upload [1] ocpp.admin /opt/iobroker/node_modules/iobroker.ocpp/admin/jsonConfig.json jsonConfig.json application/json
                              upload [0] ocpp.admin /opt/iobroker/node_modules/iobroker.ocpp/admin/ocpp.png ocpp.png image/png
                              Update "system.adapter.ocpp.0"
                              Process exited with code 0
                              Ich kann auf Watt umstellen, die Einheit ändert sich auch. Allerdings beginnt der Ladevorgang nach transactionActive nicht und ich musste mit dem rfid chip direkt an der Wallbox das Laden starten.
                              Hier Energy_Active_Import_Register
                              So sieht es dann aus (das Haus benötigt ca. 500 W):
                              Hier noch das log:
                              ocpp.0	2022-09-21 15:26:58.566	info	New valid connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" (http/ocpp1.6)
                              ocpp.0	2022-09-21 15:41:35.643	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                              ocpp.0	2022-09-21 15:41:35.727	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11940,10012,61568},0,0,300,2022-09-21T13:41:35Z,0,3,{0,0,0,0,0,0,0,0,0},220,1,1,112,0,230,900,0
                              ocpp.0	2022-09-21 15:41:42.522	info	Received Authorization Request from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 15:41:44.670	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                              ocpp.0	2022-09-21 15:41:44.716	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Off,1,{20,7984,100},{0,0},{B,11936,9146,61568},0,0,300,2022-09-21T13:41:44Z,0,3,{0,0,0,0,0,0,0,0,0},220,0,0,125,0,230,900,0
                              ocpp.0	2022-09-21 15:41:46.974	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEVSE
                              ocpp.0	2022-09-21 15:41:47.178	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEV
                              ocpp.0	2022-09-21 15:41:49.463	info	Received Start transaction from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 15:41:50.480	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
                              ocpp.0	2022-09-21 15:41:54.388	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11937,8736,9416},0,0,300,2022-09-21T13:41:46Z,1,3,{0,0,0,0,0,0,0,0,0},220,0,0,125,0,230,60,0
                              ocpp.0	2022-09-21 15:41:59.374	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11938,8652,12128},0,0,300,2022-09-21T13:41:46Z,1,3,{0,0,0,0,0,0,0,0,0},220,0,0,125,0,230,60,0
                              ocpp.0	2022-09-21 15:42:04.372	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,5868,12131},0,0,300,2022-09-21T13:41:50Z,1,3,{0,0,0,0,0,0,0,0,0},220,2,0,114,0,230,160,0
                              ocpp.0	2022-09-21 15:56:51.319	info	Received MeterValues from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 15:56:56.363	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6044,12112},0,0,310,2022-09-21T13:56:50Z,1,3,{0,0,0,0,0,0,0,0,0},240,16,4,112,0,260,160,0
                              ocpp.0	2022-09-21 16:11:53.660	info	Received MeterValues from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:11:58.377	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6043,12112},0,0,330,2022-09-21T14:11:53Z,1,3,{0,0,0,0,0,0,0,0,0},260,15,4,112,0,290,160,0
                              ocpp.0	2022-09-21 16:12:43.852	info	Got terminate signal TERMINATE_YOURSELF
                              ocpp.0	2022-09-21 16:12:43.861	info	terminating
                              ocpp.0	2022-09-21 16:12:43.862	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              ocpp.0	2022-09-21 16:12:49.701	info	starting. Version 0.7.0 (non-npm: foxriver76/ioBroker.ocpp#a7c06c513c0e8c6272a10deddd07152bc6efbed7) in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.17.0, js-controller: 4.0.23
                              ocpp.0	2022-09-21 16:12:49.743	info	Starting OCPP Server
                              ocpp.0	2022-09-21 16:12:49.815	info	Server listening on port 9220
                              ocpp.0	2022-09-21 16:13:23.494	info	New valid connection from "http://192.168.178.80:9220/EVB-XXXXXXXXX" (http/ocpp1.6)
                              ocpp.0	2022-09-21 16:13:23.551	info	New device connected: "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:13:23.555	info	Requesting BootNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:13:24.595	info	Requesting StatusNotification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:13:28.345	info	Received boot notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:13:28.600	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
                              ocpp.0	2022-09-21 16:13:33.486	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11936,6041,12112},0,0,330,2022-09-21T14:13:28Z,1,3,{0,0,0,0,0,0,0,0,0},260,15,4,112,0,290,160,0
                              ocpp.0	2022-09-21 16:13:54.604	warn	Could not request states of "http://192.168.178.80:9220/EVB-XXXXXXXXX": Timeout for message 17557d23-e18f-4a14-89f4-3147f46615ff
                              ocpp.0	2022-09-21 16:14:32.775	info	Loglevel changed from "info" to "silly"
                              ocpp.0	2022-09-21 16:15:18.339	debug	{"commandOcpp":"Heartbeat"}
                              ocpp.0	2022-09-21 16:15:18.341	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:15:59.639	debug	Sending RemoteStopTransaction for http://192_168_178_80:9220/EVB-XXXXXXXXX
                              ocpp.0	2022-09-21 16:16:05.078	debug	{"transactionId":1,"idTag":"048EAB728E6781","timestamp":"2022-09-21T14:16:04Z","meterStop":0,"reason":"Remote","commandOcpp":"StopTransaction"}
                              ocpp.0	2022-09-21 16:16:05.079	info	Received stop transaction from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:16:05.695	debug	{"connectorId":1,"status":"Finishing","errorCode":"NoError","timestamp":"2022-09-21T14:16:05Z","commandOcpp":"StatusNotification"}
                              ocpp.0	2022-09-21 16:16:05.696	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Finishing
                              ocpp.0	2022-09-21 16:16:09.338	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11936,6156,61596},0,0,330,2022-09-21T14:16:05Z,0,3,{0,0,0,0,0,0,0,0,0},260,9,3,112,0,300,900,0","commandOcpp":"DataTransfer"}
                              ocpp.0	2022-09-21 16:16:09.339	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11936,6156,61596},0,0,330,2022-09-21T14:16:05Z,0,3,{0,0,0,0,0,0,0,0,0},260,9,3,112,0,300,900,0
                              ocpp.0	2022-09-21 16:16:13.327	debug	{"commandOcpp":"Heartbeat"}
                              ocpp.0	2022-09-21 16:16:13.327	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:16:29.359	debug	Sending SetChargingProfile for http://192_168_178_80:9220/EVB-XXXXXXXXX
                              ocpp.0	2022-09-21 16:16:29.518	error	Cannot execute command "chargeLimit" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                              ocpp.0	2022-09-21 16:16:40.054	debug	Sending RemoteStartTransaction for http://192_168_178_80:9220/EVB-XXXXXXXXX: {"connectorId":1,"idTag":"048BEAB728E6781","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"W","chargingSchedulePeriod":[{"startPeriod":0,"limit":8000}]}}}
                              ocpp.0	2022-09-21 16:16:40.436	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                              ocpp.0	2022-09-21 16:17:01.444	debug	Sending RemoteStopTransaction for http://192_168_178_80:9220/EVB-XXXXXXXXX
                              ocpp.0	2022-09-21 16:17:05.951	debug	Sending ChangeAvailability for http://192_168_178_80:9220/EVB-XXXXXXXXX: Inoperative
                              ocpp.0	2022-09-21 16:17:06.349	debug	{"connectorId":1,"status":"Unavailable","errorCode":"NoError","timestamp":"2022-09-21T14:17:06Z","commandOcpp":"StatusNotification"}
                              ocpp.0	2022-09-21 16:17:06.350	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Unavailable
                              ocpp.0	2022-09-21 16:17:06.398	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Unavailable,NoError,No error.,0,Red,0,{20,7984,100},{0,0},{B,11934,9132,61568},0,0,330,2022-09-21T14:17:06Z,0,3,{0,0,0,0,0,0,0,0,0},260,1,1,112,0,300,900,0","commandOcpp":"DataTransfer"}
                              ocpp.0	2022-09-21 16:17:06.400	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Unavailable,NoError,No error.,0,Red,0,{20,7984,100},{0,0},{B,11934,9132,61568},0,0,330,2022-09-21T14:17:06Z,0,3,{0,0,0,0,0,0,0,0,0},260,1,1,112,0,300,900,0
                              ocpp.0	2022-09-21 16:17:08.314	debug	{"commandOcpp":"Heartbeat"}
                              ocpp.0	2022-09-21 16:17:08.315	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:17:12.444	debug	Sending ChangeAvailability for http://192_168_178_80:9220/EVB-XXXXXXXXX: Operative
                              ocpp.0	2022-09-21 16:17:12.772	debug	{"connectorId":1,"status":"Finishing","errorCode":"NoError","timestamp":"2022-09-21T14:17:12Z","commandOcpp":"StatusNotification"}
                              ocpp.0	2022-09-21 16:17:12.773	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Finishing
                              ocpp.0	2022-09-21 16:17:12.890	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11935,9132,61568},0,0,330,2022-09-21T14:17:12Z,0,3,{0,0,0,0,0,0,0,0,0},260,1,2,112,0,300,900,0","commandOcpp":"DataTransfer"}
                              ocpp.0	2022-09-21 16:17:12.891	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{B,11935,9132,61568},0,0,330,2022-09-21T14:17:12Z,0,3,{0,0,0,0,0,0,0,0,0},260,1,2,112,0,300,900,0
                              ocpp.0	2022-09-21 16:17:20.473	debug	Sending RemoteStartTransaction for http://192_168_178_80:9220/EVB-XXXXXXXXX: {"connectorId":1,"idTag":"048BEAB728E6781","chargingProfile":{"chargingProfileId":1,"stackLevel":0,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"W","chargingSchedulePeriod":[{"startPeriod":0,"limit":8000}]}}}
                              ocpp.0	2022-09-21 16:17:20.616	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/EVB-XXXXXXXXX": Sender's message does not comply with protocol specification.
                              ocpp.0	2022-09-21 16:18:03.322	debug	{"commandOcpp":"Heartbeat"}
                              ocpp.0	2022-09-21 16:18:03.322	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:18:33.622	debug	{"idTag":"048EAB728E6781","commandOcpp":"Authorize"}
                              ocpp.0	2022-09-21 16:18:33.623	info	Received Authorization Request from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:18:36.216	debug	{"connectorId":1,"status":"Preparing","errorCode":"NoError","timestamp":"2022-09-21T14:18:35Z","commandOcpp":"StatusNotification"}
                              ocpp.0	2022-09-21 16:18:36.217	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Preparing
                              ocpp.0	2022-09-21 16:18:36.273	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Preparing,NoError,No error.,0,Off,1,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,330,2022-09-21T14:18:35Z,0,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,300,900,0","commandOcpp":"DataTransfer"}
                              ocpp.0	2022-09-21 16:18:36.274	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Preparing,NoError,No error.,0,Off,1,{20,7984,100},{0,0},{B,11936,9132,61568},0,0,330,2022-09-21T14:18:35Z,0,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,300,900,0
                              ocpp.0	2022-09-21 16:18:37.696	debug	{"connectorId":1,"status":"SuspendedEVSE","errorCode":"NoError","info":"B;330","timestamp":"2022-09-21T14:18:37Z","commandOcpp":"StatusNotification"}
                              ocpp.0	2022-09-21 16:18:37.697	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEVSE
                              ocpp.0	2022-09-21 16:18:37.887	debug	{"connectorId":1,"status":"SuspendedEV","errorCode":"NoError","info":"B;330","timestamp":"2022-09-21T14:18:37Z","commandOcpp":"StatusNotification"}
                              ocpp.0	2022-09-21 16:18:37.888	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": SuspendedEV
                              ocpp.0	2022-09-21 16:18:40.327	debug	{"connectorId":1,"idTag":"048EAB728E6781","timestamp":"2022-09-21T14:18:36Z","meterStart":0,"commandOcpp":"StartTransaction"}
                              ocpp.0	2022-09-21 16:18:40.328	info	Received Start transaction from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              ocpp.0	2022-09-21 16:18:42.407	debug	{"connectorId":1,"status":"Charging","errorCode":"NoError","info":"C;330","timestamp":"2022-09-21T14:18:42Z","commandOcpp":"StatusNotification"}
                              ocpp.0	2022-09-21 16:18:42.408	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX": Charging
                              ocpp.0	2022-09-21 16:18:45.345	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7983,10},{0,0},{B,11936,8752,8393},0,0,330,2022-09-21T14:18:37Z,1,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,300,60,0","commandOcpp":"DataTransfer"}
                              ocpp.0	2022-09-21 16:18:45.346	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEVSE,NoError,No error.,0,Yellow,1,{20,7983,10},{0,0},{B,11936,8752,8393},0,0,330,2022-09-21T14:18:37Z,1,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,300,60,0
                              ocpp.0	2022-09-21 16:18:50.344	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11936,8639,12153},0,0,330,2022-09-21T14:18:37Z,1,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,300,60,0","commandOcpp":"DataTransfer"}
                              ocpp.0	2022-09-21 16:18:50.345	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,SuspendedEV,NoError,No error.,0,Yellow,1,{20,7984,10},{0,0},{B,11936,8639,12153},0,0,330,2022-09-21T14:18:37Z,1,3,{0,0,0,0,0,0,0,0,0},260,0,0,125,0,300,60,0
                              ocpp.0	2022-09-21 16:18:55.345	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Charging,NoError,No error.,1,Blue,1,{20,7984,10},{0,0},{C,11936,5852,12160},0,0,330,2022-09-21T14:18:42Z,1,3,{0,0,0,0,0,0,0,0,0},260,1,0,117,0,300,60,0","commandOcpp":"DataTransfer"}
                              ocpp.0	2022-09-21 16:18:55.346	info	Received DataTransfer from "http://192.168.178.80:9220/EVB-XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,10},{0,0},{C,11936,5852,12160},0,0,330,2022-09-21T14:18:42Z,1,3,{0,0,0,0,0,0,0,0,0},260,1,0,117,0,300,60,0
                              ocpp.0	2022-09-21 16:18:58.336	debug	{"commandOcpp":"Heartbeat"}
                              ocpp.0	2022-09-21 16:18:58.338	debug	Received heartbeat from "http://192.168.178.80:9220/EVB-XXXXXXXXX"
                              • foxriver76
                                @meister-mopper hm Schade, dann scheint die WB kein Anpassung der Ladeleistung zu unterstützen, schreib einfach mal in den State für chargeLimit ein String oder null rein, dann sollte er es gehen natürlich nach wie vor ohne Ladeleistungsanpassung.
                                • Meister Mopper
                                  @foxriver76
                                  Jup, funktioniert. Die Ladeleistung wollte ich aber ohnehin nicht geregelt haben. Bei meiner Konstellation sind 3.600 W genau richtig.
                                  • Meister Mopper
                                    @foxriver76
                                    Hier noch ein wenig Futter für Alpha.
                                    Gestern und heute reproduzierbar:
                                    Das Beenden eines Ladevorgangs ist wegen timeout nicht möglich. Erst nach einem Neustart des Adapters kann ich beenden.
                                    Hier das log:
                                    ocpp.0	2022-10-05 17:46:46.971	error	Cannot execute command "transactionActive" for "http://192_168_178_80:9220/XXXXXXXXX": Timeout for message b95c484c-4bdc-48cf-9553-98a1958e427b
                                    ocpp.0	2022-10-05 17:47:18.755	info	Got terminate signal TERMINATE_YOURSELF
                                    ocpp.0	2022-10-05 17:47:18.936	info	terminating
                                    ocpp.0	2022-10-05 17:47:18.938	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    ocpp.0	2022-10-05 17:47:24.009	debug	Redis Objects: Use Redis connection: 192.168.178.10:9001
                                    ocpp.0	2022-10-05 17:47:24.071	debug	Objects client ready ... initialize now
                                    ocpp.0	2022-10-05 17:47:24.073	debug	Objects create System PubSub Client
                                    ocpp.0	2022-10-05 17:47:24.075	debug	Objects create User PubSub Client
                                    ocpp.0	2022-10-05 17:47:24.175	debug	Objects client initialize lua scripts
                                    ocpp.0	2022-10-05 17:47:24.184	debug	Objects connected to redis: 192.168.178.10:9001
                                    ocpp.0	2022-10-05 17:47:24.236	debug	Redis States: Use Redis connection: 192.168.178.10:6379
                                    ocpp.0	2022-10-05 17:47:24.246	debug	States create System PubSub Client
                                    ocpp.0	2022-10-05 17:47:24.248	debug	States create User PubSub Client
                                    ocpp.0	2022-10-05 17:47:24.260	debug	States connected to redis: 192.168.178.10:6379
                                    ocpp.0	2022-10-05 17:47:24.434	info	starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.17.1, js-controller: 4.0.23
                                    ocpp.0	2022-10-05 17:47:24.476	info	Starting OCPP Server
                                    ocpp.0	2022-10-05 17:47:24.514	info	Server listening on port 9220
                                    ocpp.0	2022-10-05 17:47:58.342	debug	Connection from "http://192.168.178.80:9220/XXXXXXXXX" with credentials "undefined", protocol: "http", OCPP: ocpp1.6
                                    ocpp.0	2022-10-05 17:47:58.344	info	New valid connection from "http://192.168.178.80:9220/XXXXXXXXX" (http/ocpp1.6)
                                    ocpp.0	2022-10-05 17:47:58.395	info	New device connected: "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-10-05 17:47:58.397	info	Requesting BootNotification from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-10-05 17:47:58.479	debug	{"commandOcpp":"Heartbeat"}
                                    ocpp.0	2022-10-05 17:47:58.480	debug	Received heartbeat from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-10-05 17:47:59.433	info	Requesting StatusNotification from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-10-05 17:48:03.308	debug	{"chargePointVendor":"EV-BOX","chargePointModel":"G4E-WIFI","chargePointSerialNumber":"21312507","firmwareVersion":"P0422B0422v0.211223_U6.0.0-050","commandOcpp":"BootNotification"}
                                    ocpp.0	2022-10-05 17:48:03.309	info	Received boot notification from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-10-05 17:48:03.782	debug	{"connectorId":1,"status":"Charging","errorCode":"NoError","info":"C;370","timestamp":"2022-10-05T15:48:03Z","commandOcpp":"StatusNotification"}
                                    ocpp.0	2022-10-05 17:48:03.783	info	Received Status Notification from "http://192.168.178.80:9220/XXXXXXXXX": Charging
                                    ocpp.0	2022-10-05 17:48:08.325	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11920,6044,12159},0,0,370,2022-10-05T15:48:03Z,1,3,{0,0,0,0,0,0,0,0,0},300,14,5,113,0,360,160,0","commandOcpp":"DataTransfer"}
                                    ocpp.0	2022-10-05 17:48:08.326	info	Received DataTransfer from "http://192.168.178.80:9220/XXXXXXXXX" with id "evbStatusNotification": 1,Charging,NoError,No error.,1,Blue,1,{20,7984,26},{0,0},{C,11920,6044,12159},0,0,370,2022-10-05T15:48:03Z,1,3,{0,0,0,0,0,0,0,0,0},300,14,5,113,0,360,160,0
                                    ocpp.0	2022-10-05 17:48:29.439	warn	Could not request states of "http://192.168.178.80:9220/XXXXXXXXX": Timeout for message 3dbb5093-d330-4511-86e4-6e16480013ec
                                    ocpp.0	2022-10-05 17:48:30.797	debug	Sending RemoteStopTransaction for http://192_168_178_80:9220/XXXXXXXXX
                                    ocpp.0	2022-10-05 17:48:36.144	debug	{"transactionId":1,"idTag":"048EAB728E6781","timestamp":"2022-10-05T15:48:35Z","meterStop":0,"reason":"Remote","commandOcpp":"StopTransaction"}
                                    ocpp.0	2022-10-05 17:48:36.145	info	Received stop transaction from "http://192.168.178.80:9220/XXXXXXXXX"
                                    ocpp.0	2022-10-05 17:48:36.956	debug	{"connectorId":1,"status":"Finishing","errorCode":"NoError","timestamp":"2022-10-05T15:48:36Z","commandOcpp":"StatusNotification"}
                                    ocpp.0	2022-10-05 17:48:36.957	info	Received Status Notification from "http://192.168.178.80:9220/XXXXXXXXX": Finishing
                                    ocpp.0	2022-10-05 17:48:40.315	debug	{"vendorId":"EV-BOX","messageId":"evbStatusNotification","data":"1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11920,6156,61616},0,0,370,2022-10-05T15:48:36Z,0,3,{0,0,0,0,0,0,0,0,0},310,13,4,113,0,360,900,0","commandOcpp":"DataTransfer"}
                                    ocpp.0	2022-10-05 17:48:40.316	info	Received DataTransfer from "http://192.168.178.80:9220/XXXXXXXXX" with id "evbStatusNotification": 1,Finishing,NoError,No error.,0,Green,0,{20,7984,100},{0,0},{C,11920,6156,61616},0,0,370,2022-10-05T15:48:36Z,0,3,{0,0,0,0,0,0,0,0,0},310,13,4,113,0,360,900,0
                                    • foxriver76
                                      @meister-mopper Die 0.8.0 fixed das eventuell. Die Struktur hat sich allerdings geändert um Charger mit mehreren Connectoren zu unterstützen.
                                      • Meister Mopper
                                        @foxriver76
                                        Konnte heute mal wieder testen:
                                        Version 0.8.0
                                        Ein Ladestart war erst möglich, nachdem ich den Adapter gestoppt, den kompletten Objektbaum gelöscht und den Adapter neu gestartet hatte.
                                        Bei Ladestopp tat sich nichts ( because no active transaction found), also habe ich versucht, available auf false zu stellen. Auch nichts. Letztlich habe ich den Stecker gezogen.
                                        ocpp.0	2022-10-28 16:19:20.562	debug	Sending RemoteStopTransaction for http://192_168_178_80:9220/XXXXXXXXX.1
                                        ocpp.0	2022-10-28 16:19:20.563	warn	Cannot stop transaction on http://192_168_178_80:9220/EVB-XXXXXXXXX.1, because no active transaction found
                                        ocpp.0	2022-10-28 16:19:30.904	debug	Sending ChangeAvailability for http://192_168_178_80:9220/EVB-XXXXXXXXX.1: Inoperative
                                        ocpp.0	2022-10-28 16:19:31.257	debug	{"connectorId":1,"status":"Charging","errorCode":"NoError","info":"C;400","timestamp":"2022-10-28T14:19:30Z","commandOcpp":"StatusNotification"}
                                        ocpp.0	2022-10-28 16:19:31.259	info	Received Status Notification from "http://192.168.178.80:9220/EVB-XXXXXXXXX.1": Charging
                                        Soeni 1 Reply Last reply Reply Quote 0
                                        • Soeni
                                          Soeni @Meister Mopper last edited by
                                          hallo, ich würde gerne den GO-E Charger testen und habe den adapter eingerichtet. Im Go E habe ich die Adresse mit Port eingetragen. Der Go E meldet keine Verbindung. Gibt es eine Debugmöglichkeit? Bin ich der erste, der den Go E testet?
                                          • Meister Mopper
                                            Meister Mopper @Soeni last edited by
                                            @soeni
                                            Wie hast Du denn die Adresse mit Port eingetragen? Ich musste die IP bei meiner EVbox mit ws:// eintragen.
                                            31.7k
                                            79.8k
                                            adapter ocpp wallbox
                                            48
                                            440
                                            78013
