Tuya Steckdose offline - Alexa erreichbar
Was bringt das?
Die Frage, die sich stellt, ist doch, ob die sich von deinem iobroker System aus anpingen lässt.
/opt/iobroker$ ping 192.168.177.175 PING 192.168.177.175 (192.168.177.175) 56(84) bytes of data. 64 bytes from 192.168.177.175: icmp_seq=1 ttl=255 time=91.0 ms 64 bytes from 192.168.177.175: icmp_seq=2 ttl=255 time=149 ms 64 bytes from 192.168.177.175: icmp_seq=3 ttl=255 time=34.4 ms 64 bytes from 192.168.177.175: icmp_seq=4 ttl=255 time=56.3 ms 64 bytes from 192.168.177.175: icmp_seq=5 ttl=255 time=85.7 ms 64 bytes from 192.168.177.175: icmp_seq=6 ttl=255 time=108 ms 64 bytes from 192.168.177.175: icmp_seq=7 ttl=255 time=20.9 ms 64 bytes from 192.168.177.175: icmp_seq=8 ttl=255 time=7.05 ms 64 bytes from 192.168.177.175: icmp_seq=9 ttl=255 time=27.6 ms 64 bytes from 192.168.177.175: icmp_seq=10 ttl=255 time=10.1 ms 64 bytes from 192.168.177.175: icmp_seq=11 ttl=255 time=7.41 ms 64 bytes from 192.168.177.175: icmp_seq=12 ttl=255 time=9.57 ms 64 bytes from 192.168.177.175: icmp_seq=13 ttl=255 time=5.77 ms 64 bytes from 192.168.177.175: icmp_seq=14 ttl=255 time=5.80 ms 64 bytes from 192.168.177.175: icmp_seq=15 ttl=255 time=5.56 ms 64 bytes from 192.168.177.175: icmp_seq=16 ttl=255 time=9.18 ms 64 bytes from 192.168.177.175: icmp_seq=17 ttl=255 time=5.96 ms 64 bytes from 192.168.177.175: icmp_seq=18 ttl=255 time=12.3 ms 64 bytes from 192.168.177.175: icmp_seq=19 ttl=255 time=5.50 ms 64 bytes from 192.168.177.175: icmp_seq=20 ttl=255 time=7.31 ms 64 bytes from 192.168.177.175: icmp_seq=21 ttl=255 time=7.46 ms 64 bytes from 192.168.177.175: icmp_seq=22 ttl=255 time=7.15 ms 64 bytes from 192.168.177.175: icmp_seq=23 ttl=255 time=23.4 ms 64 bytes from 192.168.177.175: icmp_seq=24 ttl=255 time=9.34 ms 64 bytes from 192.168.177.175: icmp_seq=25 ttl=255 time=8.35 ms 64 bytes from 192.168.177.175: icmp_seq=26 ttl=255 time=7.87 ms -
Okay, dann belegt vermutlich etwas den Port 6668.
@ofbeqnpolkkl6mby5e13
Bei diesen 2 IPs?? Weil andere Tuya Geräte funktionieren ja einwandfrei. -
Dann stellt sich die Frage, ob das, was da unter der IP-Adresse antwortet, tatsächlich die Steckdose ist.
Hast du die Steckdose einfach mal rausgezogen und wieder reingesteckt?
Ich verstehe was du meinst.
Kann ich in der App oder über Alexa irgendwie die IP rausfinden? -
Zunächst guckst du in die App. In den Informationen zu der Steckdose findest du die MAC-Adresse.
Diese vergleichst du mit der MAC-Adresse, die in der Fritzbox zu der IP-Adresse angezeigt wird. -
MAC Adressen sind in der App und FritzBox unter der IP-Adresse identisch.
Hattest du die Steckdosen mal vom Strom getrennt?
Nein. Nur vor ca. 2 Wochen iobroker Updates (nodejs und etliche Adapter) gemacht.
Dann mach das mal.
stehen immer noch auf "Online - false".
Das stehen die bei mir auch hin und wieder. Schalten lassen sie sich trotzdem.
Schalten lassen sie sich leider nicht.
Haben die denn überhaupt schon jemals funktioniert?
Ja, einwandfrei sogar. Und jetzt seit ein paar Tagen nicht mehr.
Dann habe ich keine Idee mehr, außer dass die ein Firmwareupdate erhalten haben, das den Localport abschaltet oder ähnliches.
Hersteller, Modell, Firmwareversion?
Ich habe jetzt auf Abhieb zu dem Gerär nichts gefunden.
Du kannst entweder den Entwickler des Tuya-Adapters ansprechen, ob er noch einen Tipp hat, oder nutzt den HAM-Adapter mit Tuya-Web-Plugin und steuerst die Geräte darüber.
Du könntest zusätzlich noch die Objektstruktur hier posten,
