    4. [Frage] Xiaomi Vacuum cleaner
      skorpil last edited by
      Hast Du in der mihome App einen Namen für Deinen Sauger vergeben? Such den mal mit der Suchfunktion Deines Editors in der squite Datei
        markus- 0 last edited by
        Dann such dir doch erst mal nen SQLite Editor oder Viewer.
          Karim last edited by
          Ich möchte gerade einen 2. Roboter einrichten. Der erste läuft wunderbar über ioBroker, wenn ich aber einen weiteren Adapter hinzufüge, bekomme ich Fehler.
          Habt ihr eine Idee wo der Fehler liegen könnte?
          host.raspberrypi	2017-06-30 12:35:21.521	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
          host.raspberrypi	2017-06-30 12:35:21.521	error	instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK)
          host.raspberrypi	2017-06-30 12:35:20.137	info	instance system.adapter.mihome-vacuum.1 started with pid 1660
          host.raspberrypi	2017-06-30 12:34:50.118	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
          host.raspberrypi	2017-06-30 12:34:50.117	error	instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK)
          host.raspberrypi	2017-06-30 12:34:48.726	info	instance system.adapter.mihome-vacuum.1 started with pid 1646
          host.raspberrypi	2017-06-30 12:34:18.707	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
          host.raspberrypi	2017-06-30 12:34:18.706	error	instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK)
          host.raspberrypi	2017-06-30 12:34:17.326	info	instance system.adapter.mihome-vacuum.1 started with pid 1635
          host.raspberrypi	2017-06-30 12:33:47.307	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
          host.raspberrypi	2017-06-30 12:33:47.306	error	instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK)
          host.raspberrypi	2017-06-30 12:33:45.929	info	instance system.adapter.mihome-vacuum.1 started with pid 1621
          host.raspberrypi	2017-06-30 12:33:15.910	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
          host.raspberrypi	2017-06-30 12:33:15.910	error	instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK)
          host.raspberrypi	2017-06-30 12:33:14.468	info	instance system.adapter.mihome-vacuum.1 started with pid 1608
          host.raspberrypi	2017-06-30 12:32:44.447	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
          host.raspberrypi	2017-06-30 12:32:44.447	error	instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK)
          host.raspberrypi	2017-06-30 12:32:43.076	info	instance system.adapter.mihome-vacuum.1 started with pid 1592
          host.raspberrypi	2017-06-30 12:32:13.058	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
          host.raspberrypi	2017-06-30 12:32:13.058	error	instance system.adapter.mihome-vacuum.1 terminated with code 0 (OK)
          host.raspberrypi	2017-06-30 12:32:11.646	info	instance system.adapter.mihome-vacuum.1 started with pid 1580
          Das kommt immer und immer wieder. Wie gesagt, mit dem anderen Adapter und Mi Roboter klappt alles wunderbar.
          Lieben Gruß, Karim.
          • Meistertr
            @Karim:
            Lieben Gruß, Karim. `
            Hast du den eigenen Port geändert? Wenn du zwei im Einsatz hast, muss es über zwei unterschiedliche ports laufe
            Gesendet von meinem Handy
              Ah okay, danke! Nein das habe ich natürlich nicht gemacht 😉
              Wie finde ich denn den 2. Port heraus, oder kann ich da irgendwas eintragen?
              Lieben Gruß, Karim.
              Edit: Danke, habe es einfach mal versucht und nun klappt es 🙂 Habe einfach den eigenen Port geändert, Danke 🙂
                Freaky_1993 last edited by
                @skorpil:
                Hast Du in der mihome App einen Namen für Deinen Sauger vergeben? Such den mal mit der Suchfunktion Deines Editors in der squite Datei `
                Ja das hab ich gemacht, ich habe den Sauger RobiSaugi genannt und in der suche oder in einem SQLite Viewer finde ich ebenfalls nichts -.- Ich versteh garnicht das ich der einzige bin der das Problem hat, habe es sogar alles auf Mac und Windows probiert
                  RobiSaugi MUSS in der squite Datei zu finden sein. Mach bitte mal einen Screenshot von der geöffneten Mihome App. Da muss der Name stehen. Und genau den findest Du in der Squite Datei. Ganz sicher.
                    Und das Backup des iPhones hast Du NACH der Installation des Saugers und der Integration in DEIN wifi erstellt?
                      Und, Freaky_1993, läuft?
                      • Meistertr
                        so ich glaube ich bin mit der neuen version Fertig, wäre super wenn ich mindestens von zwei Leuten Rückmeldung bekommen könnte, da doch einiges geändert wurde, Also bei mir läuft er nun seit ca einer Woche Fehlerfrei auf windows, raspberry2 mit jessie und odroid mit ubuntu alles mit unterschiedlichen node versionen, also sollte eigentlich nix mehr schief gehen.
                        https://github.com/MeisterTR/ioBroker.m … m/tree/new
                          MeisterTR, würde gerne, kann aber wg. Urlaub bis Dienstag nicht. Mittwoch teste ich dann gerne.
                          Sag mir bitte noch, wie ich diese Version installieren muss. Danke!
                            ceerix last edited by
                            @Meistertr:
                            so ich glaube ich bin mit der neuen version Fertig, wäre super wenn ich mindestens von zwei Leuten Rückmeldung bekommen könnte, da doch einiges geändert wurde, Also bei mir läuft er nun seit ca einer Woche Fehlerfrei auf windows, raspberry2 mit jessie und odroid mit ubuntu alles mit unterschiedlichen node versionen, also sollte eigentlich nix mehr schief gehen. `
                            Hallo Meistertr,
                            vielen Dank für deinen Einsatz. Leider kann ich dir noch kein Feedback geben weil mein Xiaomi erst nächste Woche (hoffentlich) kommt.
                            Ich finde aber deinen View schon mal klasse für den Roboter. Wärst du bereit diesen zu exportieren und der Allgemeinheit zur Verfügung zu stellen?
                            Beste Grüße
                            Alex
                              looxer01 last edited by
                              Hi Meister,
                              die Installation von GIT hat nicht geklappt:
                              ! $ ./iobroker url "https://github.com/MeisterTR/ioBroker.m … m/tree/new" --debug
                              ! install https://github.com/MeisterTR/ioBroker.m ... all/master
                              ! npm install https://github.com/MeisterTR/ioBroker.m ... all/master --production --prefix "/opt/iobroker" (System call)
                              ! npm
                              ! ERR! fetch failed https://github.com/MeisterTR/ioBroker.m ... all/master
                              ! npm
                              ! WARN retry will retry, error on last attempt: Error: fetch failed with status code 404
                              Ich habe es dann manuell durchgeführt. Hat soweit dann geklappt.
                              Die Fortschreibung der Historie habe ich nicht als Objekt (JSON). Ich nehme an, dass du das selber machst oder sollte ich ein objekt mit einer json Tabelle haben ?
                              Noch eine Bitte; Koenntest du deine View posten ? Wuerde bestimmt einigen und mir Arbeit ersparen 😉
                              vG Looxer
                              • Meistertr
                                @looxer01:
                                Hi Meister,
                                ! npm
                                ! npm
                                vG Looxer `
                                Du musst die ZIP von git downloaden entpacken und in das Verzeichnis node-Module/mihome-vacuum rein kopieren dann noch einmal im Terminal iobroker upload mihome-vacuum dann sollte es gehen. Der ist noch nicht mein npm
                                  jap, das hatte ich gemacht. Das meinte ich mit "manuell"
                                  ich habe mir die states code io.package.jason angesehen. Die wurden nicht angelegt.
                                  Schaue ich mir nochmal an.
                                  vG Looxer
                                  • Meistertr
                                    @looxer01:
                                    vG Looxer `
                                    die muss auf jedefall die neue version haben, dann sollte in den instanzen 0.5.5 stehen bei installierter version. Dann solltest du wie auf dem bild zu sehen die objekte mit json, und html table sehen
                                      ja, danke dir.
                                      Ich habe es mir jetzt leicht gemacht und die instanz geloescht und neu angelegt.
                                      die Objekte sind jetzt da.
                                        Ich habe das gemacht, während der robby arbeitete.
                                        Die States werden fortgeschrieben. Sieht alles gut aus.
                                        Abfrageintervall habe ich auf 1000 ms gestellt.
                                        Hierzu ein kleines Feedback. Das Intervall hatte keinen Vorgabewert. Waere gut, wenn es einen Defaultwert dazu gaebe.
                                        vG Looxer
                                          …dann ist mir gerade aufgefallen, dass die cleaning history nicht vollstaendig ist.
                                          Vergleich App und Adapter:
                                          App Adapter
                                          29.06. nein
                                          26.06. nein
                                          24.06. ok
                                          22.06. ok
                                          19.06. ok
                                          17.06. ok
                                          15.06. nein
                                          vG Looxer
                                          • Meistertr
                                            Die historie sollte sich nach dem saugen neu aufbauen und dann sollte alles drin sein. Default ist 10000 da viele Anfragen mit Wartezeit gesendet werden. Bei unter 10 sec nimmt er automatisch 10 sec an.
                                            2196
                                            938090
