    4. iobroker restore 0 funktioniert nicht
      Thomas Braun Most Active @funkytown last edited by
      @funkytown sagte in iobroker restore 0 funktioniert nicht:
      iobroker.tr-064-community
      Kannst du deinstallieren, gibt es nicht mehr.
      iobroker.openweathermap
      Nochmal drüber installieren, wenn nodejs sauber ist.
      • funkytown
        @thomas-braun sagte in iobroker restore 0 funktioniert nicht:
        Irgendwie ist da der Wurm drin
        markus@rpi:/opt/iobroker $ iobroker del tr-064-community
        Delete adapter "tr-064-community"
        host.rpi Counted 1 instances of tr-064-community
        host.rpi Counted 2 meta of tr-064-community
        host.rpi Counted 1 adapter for tr-064-community
        host.rpi Counted 5 devices of tr-064-community
        host.rpi Counted 9 channels of tr-064-community
        host.rpi Counted 133 states of tr-064-community
        host.rpi Counted 15 states of system.adapter.tr-064-community
        host.rpi Counted 133 states (io.tr-064-community.*) from states
        host.rpi Counted 16 states (system.adapter.tr-064-community.*) from states
        host.rpi file tr-064-community.admin deleted
        host.rpi object tr-064-community deleted
        host.rpi object tr-064-community.admin deleted
        host.rpi Deleting 166 object(s).
        host.rpi Deleting 149 state(s).
        Error deleting adapter tr-064-community from disk: host.rpi: Cannot uninstall iobroker.tr-064-community: 217
        You might have to delete it yourself!
        markus@rpi:/opt/iobroker $ iobroker del openweathermap
        Delete adapter "openweathermap"
        host.rpi object openweathermap deleted
        host.rpi object openweathermap.admin deleted
        Error deleting adapter openweathermap from disk: host.rpi: Cannot uninstall iobroker.openweathermap: 217
          Thomas Braun Most Active last edited by Thomas Braun
          @funkytown
          Ist node und npm sauber? Das vor allem anderen prüfen.
          Was sagt:
          sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          Und auch
          dmesg -T | grep -i ext4
          funkytown 1 Reply Last reply Reply Quote 0
          • funkytown
            funkytown @Thomas Braun last edited by
            markus@rpi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            markus@rpi:/opt/iobroker $ dmesg -T | grep -i ext4
            [Fr Sep 16 19:47:41 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:28:5E:37 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
            [Fr Sep 16 19:47:50 2022] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
            [Fr Sep 16 19:47:50 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:17.
            [Fr Sep 16 19:47:59 2022] EXT4-fs (sdb1): re-mounted. Opts: (null). Quota mode: none.
            markus@rpi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.17.0
            v16.17.0
            8.15.0
            4.0.23
            markus
            markus adm cdrom sudo audio video plugdev games users input netdev gpio iobroker
            /opt/iobroker
            OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
            OK:4 https://dl.yarnpkg.com/debian stable InRelease
            Paketlisten werden gelesen… Fertig
            Abhängigkeitsbaum wird aufgebaut… Fertig
            Statusinformationen werden eingelesen… Fertig
            Aktualisierung für 24 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
            nodejs:
              Installiert:           16.17.0-deb-1nodesource1
              Installationskandidat: 16.17.0-deb-1nodesource1
              Versionstabelle:
             *** 16.17.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u1 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
              @funkytown
              sudo apt update
              sudo apt full-upgrade
              iobroker stop
              sudo reboot
              funkytown 2 Replies Last reply Reply Quote 0
              • funkytown
                funkytown @Thomas Braun last edited by funkytown
                markus@rpi:~ $ sudo apt update
                [sudo] Passwort für markus:
                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:3 https://dl.yarnpkg.com/debian stable InRelease
                OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                Aktualisierung für 13 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                markus@rpi:~ $ sudo apt full-upgrade
                Paketaktualisierung (Upgrade) wird berechnet… Fertig
                Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                  alsa-base gstreamer0.10-alsa gstreamer0.10-plugins-base libbluetooth3 libcdio18 libgstreamer-plugins-base0.10-0
                  libgstreamer0.10-0 libnfs12 libxfconf-0-2 lxplug-volume pimixer point-rpi
                Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                Die folgenden Pakete werden ENTFERNT:
                  bluealsa fuse libgc1c2 libpolkit-backend-1-0 raspberrypi-artwork
                Die folgenden NEUEN Pakete werden installiert:
                  agnostics cups-pk-helper fio flashrom fuse3 gir1.2-notify-0.7 gir1.2-packagekitglib-1.0 gir1.2-polkit-1.0 gir1.2-secret-1
                  gui-pkinst ibverbs-providers libaio1 libboost-iostreams1.74.0 libboost-thread1.74.0 libcupsimage2 libftdi1-2 libfuse3-3 libgc1
                  libgfapi0 libgfrpc0 libgfxdr0 libglusterfs0 libibverbs1 libnma-common libnma0 libnuma1 librados2 librbd1 librdmacm1
                  lxplug-magnifier lxplug-menu lxplug-netman lxplug-updater lxplug-volumepulse pi-printer-support pixflat-icons
                  printer-driver-escpr pulseaudio-module-bluetooth python3-cups python3-cupshelpers python3-smbc python3-toml rp-bookshelf
                  rpi-eeprom system-config-printer system-config-printer-common system-config-printer-udev
                Die folgenden Pakete werden aktualisiert (Upgrade):
                  guile-2.2-libs gvfs gvfs-backends gvfs-common gvfs-daemons gvfs-fuse gvfs-libs libpolkit-agent-1-0 libpolkit-gobject-1-0
                  policykit-1 raspberrypi-sys-mods raspberrypi-ui-mods raspi-config
                13 aktualisiert, 47 neu installiert, 5 zu entfernen und 0 nicht aktualisiert.
                Es müssen 31,3 MB an Archiven heruntergeladen werden.
                Nach dieser Operation werden 78,8 MB Plattenplatz zusätzlich benutzt.
                Möchten Sie fortfahren? [J/n] J
                Holen:1 http://archive.raspberrypi.org/debian bullseye/main armhf policykit-1 armhf 0.105-31+rpt1+deb11u1 [91,5 kB]
                Es wurde alles ohne Fehler installiert
                Jetzt komme ich nach dem reboot mit meinem SSH Client nicht mehr auf den PI.
                Ich melde mich wieder wenn der PI korrekt hochgefahren ist.
                  @funkytown
                  Und schalte den Desktop an der Kiste aus. Da ist ja der ganze GUI-Quatsch drauf.
                  • funkytown
                    Bin noch nicht dazu gekommen den PI flott zu machen.
                    Das gute daran ist, dass ich/wir jetzt erkennen, dass wir im Haus nicht vom ioBroker abhängig sind. Wir senden meistens (Status)Informationen in Wort und Bild hin und her. Das was wir über Sprachsteuerung im Haus darüber schalten, kann auch alles manuell geschaltet werden 🙂 Gute Erkenntnis!
                    • funkytown
                      mein RPi läuft wieder. Durch den reboot wurde eine falsche UUID in der cmdline.txt eingetragen.
                      Leider ist der ioBroker immer noch nicht da!
                        @funkytown
                        Leider kann man da ohne Meldungen immer noch nichts zu sagen.
                        Welche UUID war es denn? Die werden ja nicht gewürfelt...
                        • funkytown
                          also jetzt blicke ich da garnicht mehr durch. Ich bin jetzt an via ssh an dem betroffenen System angemeldet und die cmdline.txt und fstab schaut jetzt so aus. Wo ist mein Eintrag geblieben. Mir scheint als ob ich in einer anderen Baumstruktur also einem anderen /etc/boot bin.
                          markus@rpi:/boot $ cat cmdline.txt
                          dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
                          markus@rpi:/boot $ cat /etc/fstab
                          proc            /proc           proc    defaults          0       0
                          PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                          #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                          # a swapfile is not a swap partition, no line here
                          #   use  dphys-swapfile swap[on|off]  for that
                          /dev/sdb1       /               ext4    defaults,noatime  0       1
                          /dev/sdb2       swap            swap    defaults          0       0
                          Ich bin jetzt mal für 3 Std. weg.
                            Thomas Braun Most Active @funkytown last edited by Thomas Braun
                            root=/dev/sdb1
                            Keine Ahnung was du da wie warum treibst, jedenfalls ist der Eintrag
                            root=/dev/sdb1
                            absolut atypisch. Vor allendingen sdb1
                            Für gewöhnlich wird da die UUID aus
                            blkid
                            eingetragen.
                            • funkytown
                              Das System läuft ja wieder nach dem full-upgrade.
                              markus@rpi:/opt/iobroker $ blkid
                              /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                              /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                              /dev/sda1: LABEL="ESD-USB" UUID="5CD7-2DC8" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="292eb410-01"
                              /dev/sdb1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                              /dev/sdb2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.17.0
                              v16.17.0
                              8.15.0
                              4.0.23
                              markus
                              markus adm cdrom sudo audio video plugdev games users input netdev lpadmin gpio iobroker
                              /opt/iobroker
                              Alle Pakete sind aktuell.
                              nodejs:
                               Versionstabelle:
                                @funkytown
                                Ich würde da halt die UUID in die cmdline.txt eintragen. Dann springt dir die boot-Partition auch nicht weg.
                                Zum iobroker: Logs? Kommandozeile?
                                • funkytown
                                  Hab den Eintrag in der cmdline.txt gemacht und rebootet.
                                  Welche Logs benötigst du jetzt?
                                  markus@rpi:~ $ blkid
                                  markus@rpi:~ $ cat /boot/cmdline.txt
                                  dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    @funkytown
                                    iobroker status
                                    iobroker update
                                    iobroker list instances
                                    • funkytown
                                      markus@rpi:~ $ iobroker status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      markus@rpi:~ $ iobroker update
                                      Used repository: stable
                                      Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                                      Adapter    "alexa2"       : 3.19.9   , installed 3.19.7 [Updatable]
                                      Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                                      Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                                      Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                      Adapter    "email"        : 1.1.3    , installed 1.1.3
                                      Adapter    "history"      : 2.2.0    , installed 2.2.0
                                      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                                      Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                                      Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                                      Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                      Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                                      Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                                      Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                      Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                                      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                      Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                      Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                      Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                      Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                      Adapter    "withings"     : 0.0.9    , installed 0.0.9
                                      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                      markus@rpi:~ $ iobroker list instances
                                        system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.admin.1                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                                        system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                                      + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                                      + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                        system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                                      + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                                      + system.adapter.history.0                : history               : rpi                                      -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                                      + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                                      + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                                      + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                                      + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                        system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                                      + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                                      + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                        system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                        system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                                      + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                        system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                        system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                                        system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.withings.0               : withings              : rpi                                      - disabled
                                        system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                                      + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                                      + instance is alive
                                        @funkytown
                                        iobroker upgrade
                                        iobroker del admin.1
                                        iobroker start admin.0
                                        Warum 2 Instanzen vom Admin?
                                        • funkytown
                                          Da stimmt schon was nicht!
                                          markus@rpi:~ $ iobroker upgrade
                                          This upgrade of "alexa2" will introduce the following changes:
                                          -> 3.19.9:
                                          Receive the correct player status again when musik is stopped
                                          -> 3.19.8:
                                          Add safeguard for too high intervals
                                          Would you like to upgrade alexa2 from @3.19.7 to @3.19.9 now? [(y)es, (n)o]: y
                                          Update alexa2 from @3.19.7 to @3.19.9
                                          NPM version: 8.15.0
                                          Installing iobroker.alexa2@3.19.9... (System call)
                                          host.rpi Cannot install iobroker.alexa2@3.19.9: 217
                                            @funkytown
                                            for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                            2820
