    4. iobroker restore 0 funktioniert nicht
      Thomas Braun Most Active last edited by Thomas Braun
      @funkytown
      Ist node und npm sauber? Das vor allem anderen prüfen.
      Was sagt:
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      Und auch
      dmesg -T | grep -i ext4
      funkytown 1 Reply Last reply Reply Quote 0
      • funkytown
        funkytown @Thomas Braun last edited by
        markus@rpi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        markus@rpi:/opt/iobroker $ dmesg -T | grep -i ext4
        [Fr Sep 16 19:47:41 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:28:5E:37 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
        [Fr Sep 16 19:47:50 2022] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Fr Sep 16 19:47:50 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:17.
        [Fr Sep 16 19:47:59 2022] EXT4-fs (sdb1): re-mounted. Opts: (null). Quota mode: none.
        markus@rpi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        4.0.23
        markus
        markus adm cdrom sudo audio video plugdev games users input netdev gpio iobroker
        /opt/iobroker
        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        OK:4 https://dl.yarnpkg.com/debian stable InRelease
        Paketlisten werden gelesen… Fertig
        Abhängigkeitsbaum wird aufgebaut… Fertig
        Statusinformationen werden eingelesen… Fertig
        Aktualisierung für 24 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
        nodejs:
          Installiert:           16.17.0-deb-1nodesource1
          Installationskandidat: 16.17.0-deb-1nodesource1
          Versionstabelle:
         *** 16.17.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u1 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          Thomas Braun Most Active @funkytown last edited by
          @funkytown
          sudo apt update
          sudo apt full-upgrade
          iobroker stop
          sudo reboot
          funkytown 2 Replies Last reply Reply Quote 0
          • funkytown
            funkytown @Thomas Braun last edited by funkytown
            @thomas-braun sagte in iobroker restore 0 funktioniert nicht:
            markus@rpi:~ $ sudo apt update
            [sudo] Passwort für markus:
            OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:3 https://dl.yarnpkg.com/debian stable InRelease
            OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
            Aktualisierung für 13 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
            markus@rpi:~ $ sudo apt full-upgrade
            Paketaktualisierung (Upgrade) wird berechnet… Fertig
            Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
              alsa-base gstreamer0.10-alsa gstreamer0.10-plugins-base libbluetooth3 libcdio18 libgstreamer-plugins-base0.10-0
              libgstreamer0.10-0 libnfs12 libxfconf-0-2 lxplug-volume pimixer point-rpi
            Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
            Die folgenden Pakete werden ENTFERNT:
              bluealsa fuse libgc1c2 libpolkit-backend-1-0 raspberrypi-artwork
            Die folgenden NEUEN Pakete werden installiert:
              agnostics cups-pk-helper fio flashrom fuse3 gir1.2-notify-0.7 gir1.2-packagekitglib-1.0 gir1.2-polkit-1.0 gir1.2-secret-1
              gui-pkinst ibverbs-providers libaio1 libboost-iostreams1.74.0 libboost-thread1.74.0 libcupsimage2 libftdi1-2 libfuse3-3 libgc1
              libgfapi0 libgfrpc0 libgfxdr0 libglusterfs0 libibverbs1 libnma-common libnma0 libnuma1 librados2 librbd1 librdmacm1
              lxplug-magnifier lxplug-menu lxplug-netman lxplug-updater lxplug-volumepulse pi-printer-support pixflat-icons
              printer-driver-escpr pulseaudio-module-bluetooth python3-cups python3-cupshelpers python3-smbc python3-toml rp-bookshelf
              rpi-eeprom system-config-printer system-config-printer-common system-config-printer-udev
            Die folgenden Pakete werden aktualisiert (Upgrade):
              guile-2.2-libs gvfs gvfs-backends gvfs-common gvfs-daemons gvfs-fuse gvfs-libs libpolkit-agent-1-0 libpolkit-gobject-1-0
              policykit-1 raspberrypi-sys-mods raspberrypi-ui-mods raspi-config
            13 aktualisiert, 47 neu installiert, 5 zu entfernen und 0 nicht aktualisiert.
            Es müssen 31,3 MB an Archiven heruntergeladen werden.
            Nach dieser Operation werden 78,8 MB Plattenplatz zusätzlich benutzt.
            Möchten Sie fortfahren? [J/n] J
            Holen:1 http://archive.raspberrypi.org/debian bullseye/main armhf policykit-1 armhf 0.105-31+rpt1+deb11u1 [91,5 kB]
            Es wurde alles ohne Fehler installiert
            Jetzt komme ich nach dem reboot mit meinem SSH Client nicht mehr auf den PI.
            Ich melde mich wieder wenn der PI korrekt hochgefahren ist.
              @funkytown
              Und schalte den Desktop an der Kiste aus. Da ist ja der ganze GUI-Quatsch drauf.
              • funkytown
                Bin noch nicht dazu gekommen den PI flott zu machen.
                Das gute daran ist, dass ich/wir jetzt erkennen, dass wir im Haus nicht vom ioBroker abhängig sind. Wir senden meistens (Status)Informationen in Wort und Bild hin und her. Das was wir über Sprachsteuerung im Haus darüber schalten, kann auch alles manuell geschaltet werden 🙂 Gute Erkenntnis!
                • funkytown
                  mein RPi läuft wieder. Durch den reboot wurde eine falsche UUID in der cmdline.txt eingetragen.
                  Leider ist der ioBroker immer noch nicht da!
                    @funkytown
                    Leider kann man da ohne Meldungen immer noch nichts zu sagen.
                    Welche UUID war es denn? Die werden ja nicht gewürfelt...
                    • funkytown
                      also jetzt blicke ich da garnicht mehr durch. Ich bin jetzt an via ssh an dem betroffenen System angemeldet und die cmdline.txt und fstab schaut jetzt so aus. Wo ist mein Eintrag geblieben. Mir scheint als ob ich in einer anderen Baumstruktur also einem anderen /etc/boot bin.
                      markus@rpi:/boot $ cat cmdline.txt
                      dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/sdb1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait nosplash plymouth.ignore-serial-consoles
                      markus@rpi:/boot $ cat /etc/fstab
                      proc            /proc           proc    defaults          0       0
                      PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                      #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                      # a swapfile is not a swap partition, no line here
                      #   use  dphys-swapfile swap[on|off]  for that
                      /dev/sdb1       /               ext4    defaults,noatime  0       1
                      /dev/sdb2       swap            swap    defaults          0       0
                      Ich bin jetzt mal für 3 Std. weg.
                        Thomas Braun Most Active @funkytown last edited by Thomas Braun
                        @funkytown sagte in iobroker restore 0 funktioniert nicht:
                        root=/dev/sdb1
                        Keine Ahnung was du da wie warum treibst, jedenfalls ist der Eintrag
                        root=/dev/sdb1
                        absolut atypisch. Vor allendingen sdb1
                        Für gewöhnlich wird da die UUID aus
                        blkid
                        eingetragen.
                        • funkytown
                          Das System läuft ja wieder nach dem full-upgrade.
                          markus@rpi:/opt/iobroker $ blkid
                          /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                          /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                          /dev/sda1: LABEL="ESD-USB" UUID="5CD7-2DC8" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="292eb410-01"
                          /dev/sdb1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                          /dev/sdb2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.17.0
                          v16.17.0
                          8.15.0
                          4.0.23
                          markus
                          markus adm cdrom sudo audio video plugdev games users input netdev lpadmin gpio iobroker
                          /opt/iobroker
                          Alle Pakete sind aktuell.
                          nodejs:
                           Versionstabelle:
                            @funkytown
                            Ich würde da halt die UUID in die cmdline.txt eintragen. Dann springt dir die boot-Partition auch nicht weg.
                            Zum iobroker: Logs? Kommandozeile?
                            • funkytown
                              Hab den Eintrag in der cmdline.txt gemacht und rebootet.
                              Welche Logs benötigst du jetzt?
                              markus@rpi:~ $ blkid
                              markus@rpi:~ $ cat /boot/cmdline.txt
                              dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                @funkytown
                                iobroker status
                                iobroker update
                                iobroker list instances
                                • funkytown
                                  markus@rpi:~ $ iobroker status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  markus@rpi:~ $ iobroker update
                                  Used repository: stable
                                  Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
                                  Adapter    "alexa2"       : 3.19.9   , installed 3.19.7 [Updatable]
                                  Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                                  Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                                  Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                  Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                  Adapter    "email"        : 1.1.3    , installed 1.1.3
                                  Adapter    "history"      : 2.2.0    , installed 2.2.0
                                  Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                  Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                                  Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                                  Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                                  Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                  Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                  Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                                  Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                  Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                                  Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                  Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                  Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                  Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                  Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                  Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                  Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                  Adapter    "withings"     : 0.0.9    , installed 0.0.9
                                  Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                  markus@rpi:~ $ iobroker list instances
                                    system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.admin.1                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                                    system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                                  + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                                  + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                    system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                                  + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                                  + system.adapter.history.0                : history               : rpi                                      -  enabled
                                  + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                  + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                  + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                                  + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                                  + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                                  + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                                  + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                    system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                                  + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                                  + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                    system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                    system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                                  + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                    system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                                    system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.withings.0               : withings              : rpi                                      - disabled
                                    system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                                  + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                                  + instance is alive
                                    @funkytown
                                    iobroker upgrade
                                    iobroker del admin.1
                                    iobroker start admin.0
                                    Warum 2 Instanzen vom Admin?
                                    • funkytown
                                      Da stimmt schon was nicht!
                                      markus@rpi:~ $ iobroker upgrade
                                      This upgrade of "alexa2" will introduce the following changes:
                                      -> 3.19.9:
                                      Receive the correct player status again when musik is stopped
                                      -> 3.19.8:
                                      Add safeguard for too high intervals
                                      Would you like to upgrade alexa2 from @3.19.7 to @3.19.9 now? [(y)es, (n)o]: y
                                      Update alexa2 from @3.19.7 to @3.19.9
                                      NPM version: 8.15.0
                                      Installing iobroker.alexa2@3.19.9... (System call)
                                      host.rpi Cannot install iobroker.alexa2@3.19.9: 217
                                        @funkytown
                                        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                        • funkytown
                                          This upgrade of "openweathermap" will introduce the following changes:
                                          -> 0.3.0:
                                          Added new widget for vis2.0
                                          Would you like to upgrade openweathermap from @0.2.5 to @0.3.0 now? [(y)es, (n)o]: n
                                          No upgrade of "openweathermap" desired.
                                          This upgrade of "admin" will introduce the following changes:
                                          -> 6.2.22:
                                          Corrected admin4 adapter settings
                                          -> 6.2.21:
                                          Corrected small JSON config issue
                                          Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
                                          Update admin from @6.2.20 to @6.2.22
                                          host.rpi Adapter "system.adapter.admin.0" is stopped.
                                          NPM version: 8.15.0
                                          Installing iobroker.admin@6.2.22... (System call)
                                          host.rpi Cannot install iobroker.admin@6.2.22: 217
                                            iobroker upgrade admin --debug
                                            2823
