    4. iobroker restore 0 funktioniert nicht
      Thomas Braun Most Active @funkytown last edited by
      @funkytown
      iobroker status
      iobroker update
      iobroker list instances
      funkytown 1 Reply Last reply Reply Quote 0
      • funkytown
        funkytown @Thomas Braun last edited by
        markus@rpi:~ $ iobroker status
        Objects type: jsonl
        States  type: jsonl
        markus@rpi:~ $ iobroker update
        Used repository: stable
        Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
        Adapter    "alexa2"       : 3.19.9   , installed 3.19.7 [Updatable]
        Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
        Adapter    "cloud"        : 4.2.2    , installed 4.2.2
        Adapter    "cul"          : 2.0.2    , installed 2.0.2
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
        Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
        Adapter    "linux-control": 1.1.3    , installed 1.1.5
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
        Adapter    "openweathermap": 0.3.0   , installed 0.3.0
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
        Adapter    "radar2"       : 2.0.3    , installed 2.0.3
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "synology"     : 2.1.9    , installed 2.1.9
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "withings"     : 0.0.9    , installed 0.0.9
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        markus@rpi:~ $ iobroker list instances
          system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
          system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
        + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
        + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
          system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
        + system.adapter.email.0                  : email                 : rpi                                      -  enabled
        + system.adapter.history.0                : history               : rpi                                      -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
        + system.adapter.info.0                   : info                  : rpi                                      -  enabled
        + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
        + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
        + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
          system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
        + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
        + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
          system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
          system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : rpi                                      - disabled
        + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
          system.adapter.vis.0                    : vis                   : rpi                                      - disabled
          system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.withings.0               : withings              : rpi                                      - disabled
          system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
        + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
        + instance is alive
          Thomas Braun Most Active @funkytown last edited by Thomas Braun
          @funkytown
          iobroker upgrade
          iobroker del admin.1
          iobroker start admin.0
          Warum 2 Instanzen vom Admin?
          funkytown 2 Replies Last reply Reply Quote 0
          • funkytown
            Da stimmt schon was nicht!
            markus@rpi:~ $ iobroker upgrade
            This upgrade of "alexa2" will introduce the following changes:
            -> 3.19.9:
            Receive the correct player status again when musik is stopped
            -> 3.19.8:
            Add safeguard for too high intervals
            Would you like to upgrade alexa2 from @3.19.7 to @3.19.9 now? [(y)es, (n)o]: y
            Update alexa2 from @3.19.7 to @3.19.9
            NPM version: 8.15.0
            Installing iobroker.alexa2@3.19.9... (System call)
            host.rpi Cannot install iobroker.alexa2@3.19.9: 217
              @funkytown
              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
              • funkytown
                This upgrade of "openweathermap" will introduce the following changes:
                -> 0.3.0:
                Added new widget for vis2.0
                Would you like to upgrade openweathermap from @0.2.5 to @0.3.0 now? [(y)es, (n)o]: n
                No upgrade of "openweathermap" desired.
                This upgrade of "admin" will introduce the following changes:
                -> 6.2.22:
                Corrected admin4 adapter settings
                -> 6.2.21:
                Corrected small JSON config issue
                Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
                Update admin from @6.2.20 to @6.2.22
                host.rpi Adapter "system.adapter.admin.0" is stopped.
                NPM version: 8.15.0
                Installing iobroker.admin@6.2.22... (System call)
                host.rpi Cannot install iobroker.admin@6.2.22: 217
                  @funkytown sagte in iobroker restore 0 funktioniert nicht:
                  iobroker upgrade admin --debug
                  • funkytown
                    markus@rpi:~ $ iobroker upgrade admin --debug
                    -> 6.2.22:
                    -> 6.2.21:
                    NPM version: 8.15.0
                    npm ERR! code ENOTEMPTY
                    npm ERR! syscall rename
                    npm ERR! path /opt/iobroker/node_modules/addressparser
                    npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
                    npm ERR! errno -39
                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
                    npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_14_23_357Z-debug-0.log
                      @funkytown
                      Nochmal
                      • funkytown
                        Zwischendurch einmal ein DANKE an dich!
                        • funkytown
                          -> 6.2.22:
                          -> 6.2.21:
                          NPM version: 8.15.0
                          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                          npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                          npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                          npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                          npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
                          npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
                          npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_27_53_207Z-debug-0.log
                          markus@rpi:~ $
                          mikeal created this issue in request/request
                          open Request’s Past, Present and Future #3142
                          Qix- created this issue in visionmedia/debug
                          closed ReDos Vulnerability Regression Visibility Notice #797
                            @funkytown
                            Führst du das nicht aus?
                            Das sollte das eigentlich alles bereinigen.
                            • funkytown
                              Das habe ich jedes mal ausgeführt. Muss das evtl als sudo ausgeführt werden?
                                Wenn du die Rechte nicht zerschossen hast nicht.
                                iobroker stop
                                iobroker fix
                                • funkytown
                                  funkytown @Thomas Braun last edited by funkytown
                                  eben wird das erste mal was ausgegeben! Muss wohl tatsächlich unter sudo ausgeführt werden!
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/zconf.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/tiff.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/expat.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/demux.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/decode.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux_types.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/types.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/encode.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/pnglibconf.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/ffi.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/lcms2.h' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/libvips-cpp.so.42' ist nicht möglich: Keine Berechtigung
                                  rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/glib-2.0/include/glibconfig.h' ist nicht möglich: Keine Berechtigung
                                    Da dürftest du mal als root / mit sudo hantiert haben.
                                    iobroker fix ausgeführt?
                                    • funkytown
                                      kann ich jetzt mit Sicherheit nicht mehr sagen. Aber ja, das könnte schon bei den vielen Versuchen den Fehler zu beheben in der Vergangenheit passiert sein.
                                        @funkytown
                                        Dann die Version für Erwachsene:
                                        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                                        • funkytown
                                          kann immer noch nicht zugreifen!
                                          markus@rpi:~ $ iobroker fix
                                          library: loaded
                                          Library version=2022-06-15
                                              Welcome to the ioBroker installation fixer!
                                              Script version: 2022-06-03
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/3)
                                          [sudo] Passwort für markus:
                                          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                          OK:3 https://dl.yarnpkg.com/debian stable InRelease
                                          OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          Paketlisten werden gelesen… Fertig
                                          Installed gcc-c++
                                              Checking ioBroker user and directory permissions (2/3)
                                          Created /etc/sudoers.d/iobroker
                                          Fixing directory permissions...
                                              Checking autostart (3/3)
                                          Enabling autostart...
                                          Autostart enabled!
                                              Your installation was fixed successfully
                                              Run iobroker start to start ioBroker again!
                                          markus@rpi:~ $ iobroker start
                                          markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                          Adapter "admin"          is up to date.
                                          markus@rpi:~ $
                                            @funkytown
                                            iobroker update
                                            Glasfaser funkytown 2 Replies Last reply Reply Quote 0
                                            2930
