    4. iobroker restore 0 funktioniert nicht
    • funkytown
      funkytown @Thomas Braun last edited by
      markus@rpi:~ $ iobroker upgrade
      This upgrade of "openweathermap" will introduce the following changes:
      -> 0.3.0:
      Added new widget for vis2.0
      Would you like to upgrade openweathermap from @0.2.5 to @0.3.0 now? [(y)es, (n)o]: n
      No upgrade of "openweathermap" desired.
      This upgrade of "admin" will introduce the following changes:
      -> 6.2.22:
      Corrected admin4 adapter settings
      -> 6.2.21:
      Corrected small JSON config issue
      Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
      Update admin from @6.2.20 to @6.2.22
      host.rpi Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.15.0
      Installing iobroker.admin@6.2.22... (System call)
      host.rpi Cannot install iobroker.admin@6.2.22: 217
        Thomas Braun Most Active @funkytown last edited by
        @funkytown sagte in iobroker restore 0 funktioniert nicht:
        iobroker upgrade admin --debug
        funkytown 1 Reply Last reply Reply Quote 0
        • funkytown
          markus@rpi:~ $ iobroker upgrade admin --debug
          -> 6.2.22:
          -> 6.2.21:
          NPM version: 8.15.0
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/addressparser
          npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_14_23_357Z-debug-0.log
            @funkytown
            Nochmal
            for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
            funkytown 2 Replies Last reply Reply Quote 0
            • funkytown
              Zwischendurch einmal ein DANKE an dich!
              • funkytown
                -> 6.2.22:
                -> 6.2.21:
                NPM version: 8.15.0
                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
                npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
                npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_27_53_207Z-debug-0.log
                markus@rpi:~ $
                mikeal created this issue in request/request
                open Request’s Past, Present and Future #3142
                Qix- created this issue in visionmedia/debug
                closed ReDos Vulnerability Regression Visibility Notice #797
                  @funkytown
                  Führst du das nicht aus?
                  Das sollte das eigentlich alles bereinigen.
                  • funkytown
                    Das habe ich jedes mal ausgeführt. Muss das evtl als sudo ausgeführt werden?
                      Wenn du die Rechte nicht zerschossen hast nicht.
                      iobroker stop
                      iobroker fix
                      • funkytown
                        funkytown @Thomas Braun last edited by funkytown
                        eben wird das erste mal was ausgegeben! Muss wohl tatsächlich unter sudo ausgeführt werden!
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/zconf.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/tiff.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/expat.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/demux.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/decode.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux_types.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/types.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/encode.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/pnglibconf.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/ffi.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/lcms2.h' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/libvips-cpp.so.42' ist nicht möglich: Keine Berechtigung
                        rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/glib-2.0/include/glibconfig.h' ist nicht möglich: Keine Berechtigung
                          Thomas Braun Most Active @funkytown last edited by Thomas Braun
                          Da dürftest du mal als root / mit sudo hantiert haben.
                          iobroker fix ausgeführt?
                          • funkytown
                            kann ich jetzt mit Sicherheit nicht mehr sagen. Aber ja, das könnte schon bei den vielen Versuchen den Fehler zu beheben in der Vergangenheit passiert sein.
                              @funkytown
                              Dann die Version für Erwachsene:
                              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                              • funkytown
                                kann immer noch nicht zugreifen!
                                markus@rpi:~ $ iobroker fix
                                library: loaded
                                Library version=2022-06-15
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2022-06-03
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/3)
                                [sudo] Passwort für markus:
                                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                OK:3 https://dl.yarnpkg.com/debian stable InRelease
                                OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Paketlisten werden gelesen… Fertig
                                Installed gcc-c++
                                    Checking ioBroker user and directory permissions (2/3)
                                Created /etc/sudoers.d/iobroker
                                Fixing directory permissions...
                                    Checking autostart (3/3)
                                Enabling autostart...
                                Autostart enabled!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                markus@rpi:~ $ iobroker start
                                markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                Adapter "admin"          is up to date.
                                markus@rpi:~ $
                                  @funkytown
                                  iobroker update
                                  iobroker list instances
                                  Glasfaser funkytown 2 Replies Last reply Reply Quote 0
                                  • Glasfaser
                                    Glasfaser @Thomas Braun last edited by
                                    habe hier nur kurz reingeschaut ... sehe immer stop .. start.
                                    Wurde mal ein Reboot durchgeführt.
                                    • funkytown
                                      markus@rpi:~ $ iobroker update
                                      #Used repository: stable
                                      Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                      Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                                      Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                                      Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                                      Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                      Adapter    "email"        : 1.1.3    , installed 1.1.3
                                      Adapter    "history"      : 2.2.0    , installed 2.2.0
                                      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                                      Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                                      Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                                      Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                      Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                                      Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
                                      Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                      Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                                      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                      Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                      Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                      Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                      Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                      Adapter    "withings"     : 0.0.9    , installed 0.0.9
                                      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                      markus@rpi:~ $ iobroker list instances
                                      + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                                      + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                                      + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                                      + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                        system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                                      + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                                      + system.adapter.history.0                : history               : rpi                                      -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                                      + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                                      + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                                      + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                                      + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                        system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                                      + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                                      + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                        system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                        system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                                      + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                        system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                        system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                                      + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.withings.0               : withings              : rpi                                      - disabled
                                        system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                                      + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                                      + instance is alive
                                      markus@rpi:~ $
                                        @funkytown
                                        Läuft.
                                        Zieh die updates der anderen Adapter noch nach.
                                        funkytown 2 Replies Last reply Reply Quote 1
                                        • funkytown
                                          Der ioBroker ist wieder über Port 8081 erreichbar 🙂
                                          Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
                                          Vielen Dank Thomas Braun!
                                          • funkytown
                                            Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
                                            2930
