    4. iobroker restore 0 funktioniert nicht
      Thomas Braun Most Active @funkytown last edited by
      @funkytown sagte in iobroker restore 0 funktioniert nicht:
      iobroker upgrade admin --debug
      funkytown 1 Reply Last reply Reply Quote 0
      • funkytown
        funkytown @Thomas Braun last edited by
        markus@rpi:~ $ iobroker upgrade admin --debug
        This upgrade of "admin" will introduce the following changes:
        -> 6.2.22:
        Corrected admin4 adapter settings
        -> 6.2.21:
        Corrected small JSON config issue
        Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
        Update admin from @6.2.20 to @6.2.22
        NPM version: 8.15.0
        Installing iobroker.admin@6.2.22... (System call)
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/addressparser
        npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
        npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_14_23_357Z-debug-0.log
        host.rpi Cannot install iobroker.admin@6.2.22: 217
          @funkytown
          Nochmal
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          funkytown 2 Replies Last reply Reply Quote 0
          • funkytown
            Zwischendurch einmal ein DANKE an dich!
            • funkytown
              -> 6.2.22:
              -> 6.2.21:
              NPM version: 8.15.0
              npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
              npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
              npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
              npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
              npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
              npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
              npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
              npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
              npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
              npm ERR! errno -39
              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
              npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_27_53_207Z-debug-0.log
              markus@rpi:~ $
              mikeal created this issue in request/request
              open Request’s Past, Present and Future #3142
              Qix- created this issue in visionmedia/debug
              closed ReDos Vulnerability Regression Visibility Notice #797
                @funkytown
                Führst du das nicht aus?
                Das sollte das eigentlich alles bereinigen.
                • funkytown
                  Das habe ich jedes mal ausgeführt. Muss das evtl als sudo ausgeführt werden?
                    Wenn du die Rechte nicht zerschossen hast nicht.
                    iobroker stop
                    iobroker fix
                    • funkytown
                      funkytown @Thomas Braun last edited by funkytown
                      eben wird das erste mal was ausgegeben! Muss wohl tatsächlich unter sudo ausgeführt werden!
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/zconf.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/tiff.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/expat.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/demux.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/decode.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux_types.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/types.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/encode.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/pnglibconf.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/ffi.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/lcms2.h' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/libvips-cpp.so.42' ist nicht möglich: Keine Berechtigung
                      rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/glib-2.0/include/glibconfig.h' ist nicht möglich: Keine Berechtigung
                        Thomas Braun Most Active @funkytown last edited by Thomas Braun
                        Da dürftest du mal als root / mit sudo hantiert haben.
                        iobroker fix ausgeführt?
                        • funkytown
                          kann ich jetzt mit Sicherheit nicht mehr sagen. Aber ja, das könnte schon bei den vielen Versuchen den Fehler zu beheben in der Vergangenheit passiert sein.
                            @funkytown
                            Dann die Version für Erwachsene:
                            for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                            • funkytown
                              kann immer noch nicht zugreifen!
                              markus@rpi:~ $ iobroker fix
                              library: loaded
                              Library version=2022-06-15
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2022-06-03
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/3)
                              [sudo] Passwort für markus:
                              OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              OK:3 https://dl.yarnpkg.com/debian stable InRelease
                              OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                              Paketlisten werden gelesen… Fertig
                              Installed gcc-c++
                                  Checking ioBroker user and directory permissions (2/3)
                              Created /etc/sudoers.d/iobroker
                              Fixing directory permissions...
                                  Checking autostart (3/3)
                              Enabling autostart...
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              markus@rpi:~ $ iobroker start
                              markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                              Adapter "admin"          is up to date.
                              markus@rpi:~ $
                                @funkytown
                                iobroker update
                                iobroker list instances
                                Glasfaser funkytown 2 Replies Last reply Reply Quote 0
                                • Glasfaser
                                  Glasfaser @Thomas Braun last edited by
                                  habe hier nur kurz reingeschaut ... sehe immer stop .. start.
                                  Wurde mal ein Reboot durchgeführt.
                                  • funkytown
                                    markus@rpi:~ $ iobroker update
                                    #Used repository: stable
                                    Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                                    Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                                    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                                    Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                    Adapter    "email"        : 1.1.3    , installed 1.1.3
                                    Adapter    "history"      : 2.2.0    , installed 2.2.0
                                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                                    Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                                    Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                    Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                                    Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
                                    Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                    Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                                    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                    Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                    Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                    Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                    Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                    Adapter    "withings"     : 0.0.9    , installed 0.0.9
                                    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                    markus@rpi:~ $ iobroker list instances
                                    + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                                    + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                                    + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                                    + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                      system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                                    + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                                    + system.adapter.history.0                : history               : rpi                                      -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                    + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                                    + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                                    + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                                    + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                                    + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                                    + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                      system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                                    + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                                    + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                      system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                      system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                      system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                                    + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                      system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                      system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                                    + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      system.adapter.withings.0               : withings              : rpi                                      - disabled
                                      system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                                    + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                                    + instance is alive
                                    markus@rpi:~ $
                                      @funkytown
                                      Läuft.
                                      Zieh die updates der anderen Adapter noch nach.
                                      funkytown 2 Replies Last reply Reply Quote 1
                                      • funkytown
                                        Der ioBroker ist wieder über Port 8081 erreichbar 🙂
                                        Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
                                        Vielen Dank Thomas Braun!
                                        • funkytown
                                          Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
                                            Thomas Braun Most Active last edited by
                                            Wann?
                                            2930
