    4. iobroker restore 0 funktioniert nicht
    • funkytown
      funkytown @Thomas Braun last edited by
      markus@rpi:~ $ iobroker upgrade admin --debug
      This upgrade of "admin" will introduce the following changes:
      -> 6.2.22:
      Corrected admin4 adapter settings
      -> 6.2.21:
      Corrected small JSON config issue
      Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
      Update admin from @6.2.20 to @6.2.22
      NPM version: 8.15.0
      Installing iobroker.admin@6.2.22... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/addressparser
      npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
      npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_14_23_357Z-debug-0.log
      host.rpi Cannot install iobroker.admin@6.2.22: 217
        Thomas Braun Most Active @funkytown last edited by
        @funkytown
        Nochmal
        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
        funkytown 2 Replies Last reply Reply Quote 0
        • funkytown
          Zwischendurch einmal ein DANKE an dich!
          • funkytown
            -> 6.2.22:
            -> 6.2.21:
            NPM version: 8.15.0
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
            npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
            npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
            npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
            npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
            npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_27_53_207Z-debug-0.log
            markus@rpi:~ $
            mikeal created this issue in request/request
            open Request’s Past, Present and Future #3142
            Qix- created this issue in visionmedia/debug
            closed ReDos Vulnerability Regression Visibility Notice #797
              @funkytown
              Führst du das nicht aus?
              Das sollte das eigentlich alles bereinigen.
              • funkytown
                Das habe ich jedes mal ausgeführt. Muss das evtl als sudo ausgeführt werden?
                  @funkytown sagte in iobroker restore 0 funktioniert nicht:
                  Wenn du die Rechte nicht zerschossen hast nicht.
                  iobroker stop
                  iobroker fix
                  • funkytown
                    funkytown @Thomas Braun last edited by funkytown
                    eben wird das erste mal was ausgegeben! Muss wohl tatsächlich unter sudo ausgeführt werden!
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/zconf.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/tiff.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/expat.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/demux.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/decode.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux_types.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/types.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/encode.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/pnglibconf.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/ffi.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/lcms2.h' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/libvips-cpp.so.42' ist nicht möglich: Keine Berechtigung
                    rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/glib-2.0/include/glibconfig.h' ist nicht möglich: Keine Berechtigung
                      Thomas Braun Most Active @funkytown last edited by Thomas Braun
                      Da dürftest du mal als root / mit sudo hantiert haben.
                      iobroker fix ausgeführt?
                      funkytown 1 Reply Last reply Reply Quote 0
                      • funkytown
                        kann ich jetzt mit Sicherheit nicht mehr sagen. Aber ja, das könnte schon bei den vielen Versuchen den Fehler zu beheben in der Vergangenheit passiert sein.
                          @funkytown
                          Dann die Version für Erwachsene:
                          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                          • funkytown
                            kann immer noch nicht zugreifen!
                            markus@rpi:~ $ iobroker fix
                            library: loaded
                            Library version=2022-06-15
                                Welcome to the ioBroker installation fixer!
                                Script version: 2022-06-03
                                You might need to enter your password a couple of times.
                                Installing prerequisites (1/3)
                            [sudo] Passwort für markus:
                            OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                            OK:3 https://dl.yarnpkg.com/debian stable InRelease
                            OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                            Paketlisten werden gelesen… Fertig
                            Installed gcc-c++
                                Checking ioBroker user and directory permissions (2/3)
                            Created /etc/sudoers.d/iobroker
                            Fixing directory permissions...
                                Checking autostart (3/3)
                            Enabling autostart...
                            Autostart enabled!
                                Your installation was fixed successfully
                                Run iobroker start to start ioBroker again!
                            markus@rpi:~ $ iobroker start
                            markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                            Adapter "admin"          is up to date.
                            markus@rpi:~ $
                              @funkytown
                              iobroker update
                              iobroker list instances
                              Glasfaser funkytown 2 Replies Last reply Reply Quote 0
                              • Glasfaser
                                Glasfaser @Thomas Braun last edited by
                                habe hier nur kurz reingeschaut ... sehe immer stop .. start.
                                Wurde mal ein Reboot durchgeführt.
                                • funkytown
                                  markus@rpi:~ $ iobroker update
                                  #Used repository: stable
                                  Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                  Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                                  Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                                  Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                                  Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                  Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                  Adapter    "email"        : 1.1.3    , installed 1.1.3
                                  Adapter    "history"      : 2.2.0    , installed 2.2.0
                                  Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                  Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                                  Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                                  Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                                  Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                  Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                  Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                                  Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
                                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                  Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                                  Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                  Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                  Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                  Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                  Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                  Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                  Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                  Adapter    "withings"     : 0.0.9    , installed 0.0.9
                                  Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                  markus@rpi:~ $ iobroker list instances
                                  + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                                  + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                                  + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                                  + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                    system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                                  + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                                  + system.adapter.history.0                : history               : rpi                                      -  enabled
                                  + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                  + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                  + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                                  + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                                  + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                                  + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                                  + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                    system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                                  + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                                  + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                    system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                    system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                                  + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                    system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                                  + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.withings.0               : withings              : rpi                                      - disabled
                                    system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                                  + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                                  + instance is alive
                                  markus@rpi:~ $
                                    @funkytown
                                    Läuft.
                                    Zieh die updates der anderen Adapter noch nach.
                                    funkytown 2 Replies Last reply Reply Quote 1
                                    • funkytown
                                      Der ioBroker ist wieder über Port 8081 erreichbar 🙂
                                      Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
                                      Vielen Dank Thomas Braun!
                                      • funkytown
                                        Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
                                          Thomas Braun Most Active last edited by
                                          Wann?
                                          • funkytown
                                            nach einem reboot des System. War auf 8081 nicht erreichbar, und nach einem Start des admin.0 über die command line funktionierte wieder alles.
                                            2930
