    4. iobroker restore 0 funktioniert nicht
    • funkytown
      funkytown @Thomas Braun last edited by
      Zwischendurch einmal ein DANKE an dich!
      • funkytown
        markus@rpi:~ $ iobroker upgrade admin --debug
        This upgrade of "admin" will introduce the following changes:
        -> 6.2.22:
        Corrected admin4 adapter settings
        -> 6.2.21:
        Corrected small JSON config issue
        Would you like to upgrade admin from @6.2.20 to @6.2.22 now? [(y)es, (n)o]: y
        Update admin from @6.2.20 to @6.2.22
        NPM version: 8.15.0
        Installing iobroker.admin@6.2.22... (System call)
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src
        npm ERR! dest /opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese/src' -> '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi/node_modules/encoding-japanese/src'
        npm ERR!     /home/iobroker/.npm/_logs/2022-09-22T20_27_53_207Z-debug-0.log
        host.rpi Cannot install iobroker.admin@6.2.22: 217
        markus@rpi:~ $
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
          Thomas Braun Most Active @funkytown last edited by
          @funkytown
          Führst du das nicht aus?
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          Das sollte das eigentlich alles bereinigen.
          funkytown 2 Replies Last reply Reply Quote 0
          • funkytown
            Das habe ich jedes mal ausgeführt. Muss das evtl als sudo ausgeführt werden?
              @funkytown sagte in iobroker restore 0 funktioniert nicht:
              Wenn du die Rechte nicht zerschossen hast nicht.
              iobroker stop
              iobroker fix
              • funkytown
                funkytown @Thomas Braun last edited by funkytown
                eben wird das erste mal was ausgegeben! Muss wohl tatsächlich unter sudo ausgeführt werden!
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/zconf.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/tiff.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/expat.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/demux.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/decode.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/mux_types.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/types.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/webp/encode.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/pnglibconf.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/ffi.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/include/lcms2.h' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/libvips-cpp.so.42' ist nicht möglich: Keine Berechtigung
                rm: das Entfernen von '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/8.12.2/linux-armv7/lib/glib-2.0/include/glibconfig.h' ist nicht möglich: Keine Berechtigung
                  Thomas Braun Most Active @funkytown last edited by Thomas Braun
                  Da dürftest du mal als root / mit sudo hantiert haben.
                  iobroker fix ausgeführt?
                  funkytown 1 Reply Last reply Reply Quote 0
                  • funkytown
                    kann ich jetzt mit Sicherheit nicht mehr sagen. Aber ja, das könnte schon bei den vielen Versuchen den Fehler zu beheben in der Vergangenheit passiert sein.
                      @funkytown
                      Dann die Version für Erwachsene:
                      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                      • funkytown
                        kann immer noch nicht zugreifen!
                        markus@rpi:~ $ iobroker fix
                        library: loaded
                        Library version=2022-06-15
                            Welcome to the ioBroker installation fixer!
                            Script version: 2022-06-03
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/3)
                        [sudo] Passwort für markus:
                        OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:3 https://dl.yarnpkg.com/debian stable InRelease
                        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Paketlisten werden gelesen… Fertig
                        Installed gcc-c++
                            Checking ioBroker user and directory permissions (2/3)
                        Created /etc/sudoers.d/iobroker
                        Fixing directory permissions...
                            Checking autostart (3/3)
                        Enabling autostart...
                        Autostart enabled!
                            Your installation was fixed successfully
                            Run iobroker start to start ioBroker again!
                        markus@rpi:~ $ iobroker start
                        markus@rpi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                        Adapter "admin"          is up to date.
                        markus@rpi:~ $
                          @funkytown
                          iobroker update
                          iobroker list instances
                          Glasfaser funkytown 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            Glasfaser @Thomas Braun last edited by
                            habe hier nur kurz reingeschaut ... sehe immer stop .. start.
                            Wurde mal ein Reboot durchgeführt.
                            • funkytown
                              markus@rpi:~ $ iobroker update
                              #Used repository: stable
                              Adapter    "admin"        : 6.2.22   , installed 6.2.22
                              Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                              Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
                              Adapter    "cloud"        : 4.2.2    , installed 4.2.2
                              Adapter    "cul"          : 2.0.2    , installed 2.0.2
                              Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                              Adapter    "email"        : 1.1.3    , installed 1.1.3
                              Adapter    "history"      : 2.2.0    , installed 2.2.0
                              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                              Adapter    "info"         : 1.9.19   , installed 1.9.19
                              Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
                              Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
                              Adapter    "linux-control": 1.1.3    , installed 1.1.5
                              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                              Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                              Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
                              Adapter    "ping"         : 1.5.3    , installed 1.5.3
                              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                              Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
                              Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                              Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                              Adapter    "synology"     : 2.1.9    , installed 2.1.9
                              Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                              Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                              Adapter    "text2command" : 2.2.2    , installed 2.2.2
                              Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                              Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                              Adapter    "vis"          : 1.4.15   , installed 1.4.15
                              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                              Adapter    "withings"     : 0.0.9    , installed 0.0.9
                              Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                              markus@rpi:~ $ iobroker list instances
                              + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
                              + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
                              + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
                              + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
                                system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
                              + system.adapter.email.0                  : email                 : rpi                                      -  enabled
                              + system.adapter.history.0                : history               : rpi                                      -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
                              + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
                              + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
                              + system.adapter.info.0                   : info                  : rpi                                      -  enabled
                              + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
                              + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
                              + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
                                system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
                              + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
                              + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
                              + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
                                system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
                                system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
                                system.adapter.text2command.0           : text2command          : rpi                                      - disabled
                              + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
                                system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
                                system.adapter.vis.0                    : vis                   : rpi                                      - disabled
                              + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                system.adapter.withings.0               : withings              : rpi                                      - disabled
                                system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
                              + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
                              + instance is alive
                              markus@rpi:~ $
                                @funkytown
                                Läuft.
                                Zieh die updates der anderen Adapter noch nach.
                                funkytown 2 Replies Last reply Reply Quote 1
                                • funkytown
                                  Der ioBroker ist wieder über Port 8081 erreichbar 🙂
                                  Ich habe jetzt viel gelernt und hoffe, dass ich beim nächsten Mal selbst ein Problem dieser Tragweite lösen kann.
                                  Vielen Dank Thomas Braun!
                                  • funkytown
                                    Ein Phänomen ist noch vorhanden. Ich muss admin.0 immer starten. Warum passiert das nicht automatisch?
                                      Thomas Braun Most Active last edited by
                                      Wann?
                                      • funkytown
                                        nach einem reboot des System. War auf 8081 nicht erreichbar, und nach einem Start des admin.0 über die command line funktionierte wieder alles.
                                        • funkytown
                                          ausserdem ist der alte admin 6.2.20 wieder installiert obwohl doch der 6.2.22 bereits installiert wurde!
                                            @funkytown Eigentlich sollten Adapter, die auf 'enabled' stehen beim Start des js-controllers auch wieder gestartet werden.
                                            sagt?
                                            2930
