    4. iobroker restore 0 funktioniert nicht
      Thomas Braun Most Active @funkytown last edited by
      @funkytown Eigentlich sollten Adapter, die auf 'enabled' stehen beim Start des js-controllers auch wieder gestartet werden.
      iobroker list instances
      sagt?
      funkytown 1 Reply Last reply Reply Quote 0
      • funkytown
        funkytown @Thomas Braun last edited by
        markus@rpi:~ $ iobroker update
        Used repository: stable
        Adapter    "admin"        : 6.2.22   , installed 6.2.20 [Updatable]
        Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
        Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
        Adapter    "cloud"        : 4.2.2    , installed 4.2.2
        Adapter    "cul"          : 2.0.2    , installed 2.0.2
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.9   , installed 1.11.8 [Updatable]
        Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
        Adapter    "linux-control": 1.1.3    , installed 1.1.5
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
        Adapter    "openweathermap": 0.3.0   , installed 0.3.0
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pushover"     : 3.0.3    , installed 3.0.2  [Updatable]
        Adapter    "radar2"       : 2.0.3    , installed 2.0.3
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "synology"     : 2.1.9    , installed 2.1.9
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "withings"     : 0.0.9    , installed 0.0.9
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        markus@rpi:~ $
        markus@rpi:~ $ iobroker list instances
        + system.adapter.admin.0                  : admin                 : rpi                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : rpi                                      -  enabled
        + system.adapter.alexa2.1                 : alexa2                : rpi                                      -  enabled
        + system.adapter.backitup.0               : backitup              : rpi                                      -  enabled
        + system.adapter.discovery.0              : discovery             : rpi                                      -  enabled
          system.adapter.dwd.0                    : dwd                   : rpi                                      - disabled
        + system.adapter.email.0                  : email                 : rpi                                      -  enabled
        + system.adapter.history.0                : history               : rpi                                      -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : rpi                                      -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : rpi                                      -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : rpi                                      -  enabled, port: 0
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi                                      - disabled
        + system.adapter.info.0                   : info                  : rpi                                      -  enabled
        + system.adapter.iot.0                    : iot                   : rpi                                      -  enabled
        + system.adapter.javascript.0             : javascript            : rpi                                      -  enabled
        + system.adapter.linux-control.0          : linux-control         : rpi                                      -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : rpi                                      -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : rpi                                      -  enabled
          system.adapter.pollenflug.0             : pollenflug            : rpi                                      - disabled
        + system.adapter.pushover.0               : pushover              : rpi                                      -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : rpi                                      -  enabled
        + system.adapter.scenes.0                 : scenes                : rpi                                      -  enabled
          system.adapter.synology.0               : synology              : rpi                                      - disabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : rpi                                      -  enabled
          system.adapter.telegram.0               : telegram              : rpi                                      - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : rpi                                      - disabled
        + system.adapter.tr-064.0                 : tr-064                : rpi                                      -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi                                      - disabled
          system.adapter.vis.0                    : vis                   : rpi                                      - disabled
        + system.adapter.web.0                    : web                   : rpi                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.withings.0               : withings              : rpi                                      - disabled
          system.adapter.yahka.0                  : yahka                 : rpi                                      - disabled
        + system.adapter.yahka.1                  : yahka                 : rpi                                      -  enabled
        + instance is alive
        markus@rpi:~ $
          @funkytown
          Kann es sein, dass du da zwei Systeme parallel installiert hast und mal in das eine und mal in das andere bootest?
          funkytown 2 Replies Last reply Reply Quote 0
          • funkytown
            aber wie soll das denn passieren?
            ABER, das war ja auch mit der cmdline.txt merkwürdig!!! Ich weiß, dass ich den Eintrag mit der UUID geändert hatte, und plötzlich stand wieder was anderes drin.
            • funkytown
              Mir ist aber auch aufgefallen, dass das system nach einem reboot mal sehr schnell und dann wiederum sehr lange braucht bis ich drauf zugreifen kann. Ich denke du hast recht mit deiner Vermutung. Verstehen tue ich es aber nicht 🙂
                @funkytown
                Du hast doch da eine SD-Karte und noch irgendwas als Speichermedium dran. Nimm halt eins raus.
                • funkytown
                  Ich habe eine SSD-Platte und ein USB-Stick dran hängen. Da ich mir sicher bin damals das System umgestellt habe damit es von der SSD-Platte bootet, werde ich jetzt mal den USB-Stick heraus nehmen.
                    @funkytown sagte in iobroker restore 0 funktioniert nicht:
                    Zuerst umounten. Oder herunterfahren.
                    • funkytown
                      ich fahre das System herunter.
                        Thomas Braun Most Active @funkytown last edited by Thomas Braun
                        @funkytown
                        Da sind drei Speichermedien drin. Eine SD-Karte steckt auch noch drin.
                        Und die ist ebenso bootbar wie der USB_Stock auf /dev/sda1
                        • funkytown
                          soweit ich mich erinnern kann boote ich tatsächlich das System von der SD-Karte aber das Root-System liegt auf der SSD-Platte. Die root Partition ist auch nach wie vor auf der SSD-Platte. Ich habe auch nur einmal den iobroker installiert. Wo ist denn vermerkt, dass der admin.0 sofort starten soll?
                          Komisch, in der aktuellen fstab verweist /dev/sdb1 auf root obwohl es sdb1 eigentlich nicht gibt!
                          markus@rpi:/boot $ cat /boot/cmdline.txt
                          dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=3b18e43a-01 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                          markus@rpi:/boot $ blkid
                          /dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0C61-73F5" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="02211fe5-01"
                          /dev/mmcblk0p2: LABEL="rootfs" UUID="43f2d0bb-83be-464f-94d0-9a751f376c64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="02211fe5-02"
                          /dev/sda1: UUID="bbe67a8e-80a1-4c79-992c-a11ebfacecfe" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3b18e43a-01"
                          /dev/sda2: UUID="c25aeb0d-0033-4d60-a8a9-a914652a27c1" TYPE="swap" PARTUUID="3b18e43a-02"
                          markus@rpi:/opt/iobroker $ cat /etc/fstab
                          proc            /proc           proc    defaults          0       0
                          PARTUUID=02211fe5-01  /boot           vfat    defaults,flush    0       2
                          #PARTUUID=924c1207-02  /               ext4    defaults,noatime  0       1
                          # a swapfile is not a swap partition, no line here
                          #   use  dphys-swapfile swap[on|off]  for that
                          /dev/sdb1       /               ext4    defaults,noatime  0       1
                          /dev/sdb2       swap            swap    defaults          0       0
                          2464
