    • Andreas_Z
      Andreas_Z @Armilar last edited by Andreas_Z
      @armilar
      javascript.0	2022-09-23 11:26:32.057	error	at processImmediate (node:internal/timers:468:21)
      javascript.0	2022-09-23 11:26:32.057	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1504:17)
      javascript.0	2022-09-23 11:26:32.057	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2017:17
      javascript.0	2022-09-23 11:26:32.057	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1990:37)
      javascript.0	2022-09-23 11:26:32.057	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1679:24)
      javascript.0	2022-09-23 11:26:32.057	error	at Object.createScript (node:vm:265:10)
      javascript.0
      	2022-09-23 11:26:32.057	error	at new Script (node:vm:100:7)
      javascript.0	2022-09-23 11:26:32.057	error	SyntaxError: await is only valid in async functions and the top level bodies of modules
      javascript.0	2022-09-23 11:26:32.057	error	^^^^^
      javascript.0	2022-09-23 11:26:32.057	error	await Datenpunkte_anlegen();
      javascript.0	2022-09-23 11:26:32.057	error	script.js.common.NSPanel_1 compile failed: at script.js.common.NSPanel_1:154
      javascript.0	2022-09-23 11:26:32.054	info	script.js.common.NSPanel_1: TypeScript compilation successful
      javascript.0	2022-09-23 11:26:29.430	info	script.js.common.NSPanel_1: compiling TypeScript source...
      javascript.0	2022-09-23 11:26:29.396	debug	File /home/Javascript/common/NSPanel_1.ts change
      Nachtrag: Ich habe angefangen meine anderen Scripte einmal zu deaktivieren, auf halber Strecke fing das nspanel.ts Script dann plötzlich an zu laufen, kann aber noch nicht sagen welches Script es war. Zumindest sind nun die Datenpunkte schon einmal angelegt
      11:42:20.850 info javascript.0 (1013313) script.js.common.NSPanel_1: compiling TypeScript source...
      11:42:21.046 info javascript.0 (1013313) script.js.common.NSPanel_1: source code did not change, using cached compilation result...
      11:42:21.065 info javascript.0 (1013313) script.js.common.NSPanel_1: registered 12 subscriptions, 6 schedules, 0 messages, 0 logs and 0 file subscriptions
      11:42:21.372 warn javascript.0 (1013313) at script.js.common.NSPanel_1:1185:46
      11:42:21.372 warn javascript.0 (1013313) at step (script.js.common.NSPanel_1:33:23)
      11:42:21.372 warn javascript.0 (1013313) at Object.next (script.js.common.NSPanel_1:14:53)
      11:42:21.372 warn javascript.0 (1013313) at fulfilled (script.js.common.NSPanel_1:5:58)
      • Armilar
        Armilar Most Active Forum Testing @Andreas_Z last edited by Armilar
        @andreas_z sagte in SONOFF NSPanel mit Lovelace UI:
        @armilar
        javascript.0
        Bekomme immer noch nicht auf den Schirm, wo dieser Funktionsaufruf await Datenpunkte_anlegen() herkommt 🕵️‍♂️ . Also ein Funktionsaufruf, der in einer Funktion aufgerufen wird, die nicht async ist... Und vor allem, die kein Teil dieses Scriptes ist? 🙄
        Welche Version vom JS-Controller und welche NodeJS Version benutzt du?
        Nachtrag - gute Idee - Die Lokalisierung des Skriptes nacheinander. Ist bestimmt diese komische Funktion drin
        Andreas_Z 1 Reply Last reply Reply Quote 0
        • Andreas_Z
          @armilar
          javascript.0 v6.0.3
          Node.js v16.17.0
          • Armilar
            @armilar
            javascript.0 v6.0.3
            Node.js v16.17.0
            Siehe Erweiterung (Nachtrag) und wenn du diesen ominösen Funktionsaufruf gefunden hast, dann entweder "async" vor die function oder "await" rausnehmen
            Beschreibe "auf halber Strecke fing das nspanel.ts Script dann plötzlich an zu laufen". Funktioniert das Panel nun oder nicht?
            Wenn ich tippen müsste, dann würde ich sagen: "sehe mal in das andere Script "testansage" im global-Verzeichnis, ob das diese Funktion hat."
            • Andreas_Z
              @armilar
              Das Verursachende Script habe ich gefunden, eine Altlast aus den Anfängen mit Alexa, dieses habe ich nun deaktiviert und wird auch nicht mehr benötigt.
              Auf dem Panel selbst wird leider noch nichts angezeigt, aktuell wird an mqtt.1.SmartHome.NSPanel_1.cmnd.CustomSend immer timeout~15 gesendet
              Es war die Testansage 🙂
              • Armilar
                @armilar
                Das kostet dich mindestens einen Daumen nach oben 😉
                Die Nachricht ist perfekt. Jetzt haben wir wahrscheinlich noch ein Problem im mqtt.1.
                Edit:
                Was macht denn das Panel gerade? Waiting for content?
                Kommt im mqtt.1.SmartHome.NSPanel_1.tele.RESULT etwas an?
                Häufigste Ursachen:
                • mqtt.1. hat einen Port eingestellt, der bereits in mqtt.0. oder sonsoff.0. oder shelly.0. verwendet wird.
                • mqtt.1. ist falsch konfiguriert in der Instanz
                • berry-Driver ist nicht korrekt installiert. Dann alle Daten rauswerfen und autoexec.be neu anlegen + starten
                • tasmota hat die falschen mqtt Einstellungen (auch Portnummer sollte analog mqtt.1. sein)
                Hier findest du ebenfalls Hinweise und Configs für mqtt.X. :
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation (Punkt 4 und 6)
                • Andreas_Z
                  @armilar Daumen hoch auf jeden Fall 👍
                  Waiting for content.
                  Als MQTT verwende ich mosquitto, hier funktioniert die Anbindung:
                  1663929903: New connection from 192.168.178.140:62638 on port 1883.
                  1663929903: New client connected from 192.168.178.140:62638 as NSPanel_1 (p2, c1, k30, u'DVES_E7EFAC').
                  Der IOBroker ist nur als Client konfiguriert.
                  Im mqtt.1.SmartHome.NSPanel_1.tele.RESULT kommt an:
                  {"CustomRecv":"event,startup,42,eu"}
                  Im MQTT kommt auch etwas an:
                  • Armilar
                    @armilar
                    Berry Driver nochmal neu gemacht? Also autoexe.be und autoexec.bec weggeworfen?
                    https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be
                    danach Panel restarten
                    und falls dann immer noch nicht funktioniert nochmal:
                    FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.4.0.tft
                    Das Tasmota und das Script sprechen schon miteinander. Das Nextion aber noch nicht mit Tasmota...
                    • Andreas_Z
                      @armilar
                      14:31:31.836 CMD: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.4.0.tft
                      14:31:31.853 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextion":"Done"}
                      14:31:31.894 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v3.4.0.tft
                      14:31:33.187 FLH: Send (High Speed) flash start
                      14:31:33.621 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 0, "time_elapsed": 0}}
                      14:31:34.169 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v3.4.0.tft
                      14:31:35.294 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 90, "time_elapsed": 2}}
                      14:31:36.710 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 91, "time_elapsed": 3}}
                      14:31:39.662 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 92, "time_elapsed": 6}}
                      14:31:42.604 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 93, "time_elapsed": 9}}
                      14:31:45.691 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 94, "time_elapsed": 12}}
                      14:31:48.630 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 95, "time_elapsed": 15}}
                      14:31:51.587 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 96, "time_elapsed": 18}}
                      14:31:54.341 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 97, "time_elapsed": 21}}
                      14:31:57.284 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 98, "time_elapsed": 24}}
                      14:32:00.266 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": 99, "time_elapsed": 27}}
                      14:32:00.673 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:32:06.701 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,42,eu"}
                      14:32:06.709 NXP: Screen Initialized
                      14:32:06.831 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:32:06.930 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:32:06.993 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      Keine Ahnung was da schief läuft, die autoexec.be habe ich nun zum x-ten mal erneuert (alte Dateien zuvor gelöscht), dann nspanel-v3.4.0.tft erneut geflasht, das fängt dann aber nicht bei 1% an sondern wie oben zu sehen bei 90%
                      00:00:00.003 HDW: ESP32-D0WD-V3
                      00:00:00.088 UFS: FlashFS mounted with 292 kB free
                      00:00:00.182 CFG: Loaded from File, Anzahl 21
                      00:00:00.197 QPC: Count 1
                      00:00:00.423 BRY: Berry initialized, RAM used=3735 bytes
                      00:00:00.455 Projekt tasmota - Tasmota Version 12.1.1(tasmota)-2_0_4_1(2022.08.25 11:41:45)
                      00:00:00.173 NXP: Initializing Driver
                      00:00:00.181 BRY: Successfully loaded 'autoexec.be'
                      00:00:01.889 WIF: verbinden mit AP1 suppe2 Channel 6 BSSId 2C:3A:FD:A2:BE:A6 in Modus 11n als NSPanel-1-4012...
                      00:00:06.127 RSL: RESULT = {"CustomRecv":"event,startup,42,eu"}
                      00:00:06.765 WIF: verbunden
                      14:36:26.131 HTP: Web-Server aktiv bei NSPanel-1-4012 mit IP-Adresse 192.168.178.140
                      14:36:27.787 QPC: Reset
                      14:36:30.757 MQT: Verbindungsversuch...
                      14:36:30.796 MQT: verbunden
                      14:36:30.802 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
                      14:36:30.806 MQT: SmartHome/NSPanel_1/cmnd/POWER =
                      14:36:30.823 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"12.1.1(tasmota)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
                      14:36:30.842 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-4012","IPAddress":"192.168.178.140"}}
                      14:36:30.858 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":10}}
                      14:36:30.863 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                      14:36:30.867 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                      14:36:30.882 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
                      14:36:30.886 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
                      14:36:32.098 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,42,eu"}
                      14:36:32.214 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:32.258 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:32.560 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:34.949 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2022-09-23T14:36:34","Uptime":"0T00:00:15","UptimeSec":15,"Heap":133,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":70,"MqttCount":1,"Berry":{"HeapUsed":13,"Objects":213},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"suppe2","BSSId":"2C:3A:FD:A2:BE:A6","Channel":6,"Mode":"11n","RSSI":86,"Signal":-57,"LinkCount":1,"Downtime":"0T00:00:06"}}
                      14:36:34.996 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2022-09-23T14:36:34","ANALOG":{"Temperature1":3.6},"ESP32":{"Temperature":67.8},"TempUnit":"C"}
                      14:36:38.352 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,42,eu"}
                      14:36:38.473 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:38.524 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:38.581 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:44.359 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,42,eu"}
                      14:36:44.430 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:44.476 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:44.524 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      14:36:50.335 MQT: SmartHome/NSPanel_1/tele/RESULT = {"CustomRecv":"event,startup,42,eu"}
                      14:36:50.452 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      • Armilar
                        @armilar
                        Sieht für mich auch alles normal aus.
                        Was passiert, wenn du in die Tasmota-Console das Command eingibst?
                        CustomSend time~12:00
                        mqtt.1. empfängt zwar Daten, aber wie sieht es mit dem Senden aus?
                        Ich sag es ja ungern, aber evtl. mal den Weg ohne den Mosquitto wie beschrieben versuchen
                        Also nur weil in dem Datenpunkt CustomSend Daten drin stehen, heißt das noch nicht, dass dein Mosquitto die auch auf das Device bringt.
                        Und für den Fall das du es testest, verwende bitte nicht schon wieder den Port 1883
                          joBr99 @Armilar last edited by
                          Wenn FlashNextion geht, sollte das Berry Skript passen, wenn über MQTT trotzdem nichts kommt, ist es in der regel etwas mit den tasmota mqtt settings
                          • Andreas_Z
                            Andreas_Z last edited by Andreas_Z
                            Grundsätzlich scheint etwas über MQTT anzukommen, das Schalten von POWER1 manuell über das Objekt SmartHome/NSPanel_1/cmnd/POWER funktioniert.
                            Wenn ich CustomSend time~12:00 in der Konsole absende, wird aber nichts auf dem Display angezeigt.
                            autexec.be:
                            # Sonoff NSPanel Tasmota Lovelace UI Berry Driver | code by joBr99
                            # based on;
                            # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21
                            # based on;
                            # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
                            # Example Flash
                            # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft
                            # FlashNextion http://nspanel.pky.eu/lui.tft
                            class Nextion : Driver
                                static header = bytes('55BB')
                                static flash_block_size = 4096
                                var flash_mode
                            	var flash_start_millis
                                var flash_size
                                var flash_written
                                var flash_buff
                                var flash_offset
                                var awaiting_offset
                                var tcp
                                var ser
                                var last_per
                            	var url
                                def split_55(b)
                                  var ret = []
                                  var s = size(b)
                                  var i = s-2   # start from last-1
                                  while i > 0
                                    if b[i] == 0x55 && b[i+1] == 0xBB
                                      ret.push(b[i..s-1]) # push last msg to list
                                      b = b[(0..i-1)]   # write the rest back to b
                                    end
                                    i -= 1
                                  end
                                  ret.push(b)
                                  return ret
                                end
                                def crc16(data, poly)
                                  if !poly  poly = 0xA001 end
                                  # CRC-16 MODBUS HASHING ALGORITHM
                                  var crc = 0xFFFF
                                  for i:0..size(data)-1
                                    crc = crc ^ data[i]
                                    for j:0..7
                                      if crc & 1
                                        crc = (crc >> 1) ^ poly
                                      else
                                        crc = crc >> 1
                                      end
                                    end
                                  end
                                  return crc
                                end
                            	# encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
                                def encode(payload)
                                  var b = bytes()
                                  b += self.header
                                  b.add(size(payload), 2)   # add size as 2 bytes, little endian
                                  b += bytes().fromstring(payload)
                                  var msg_crc = self.crc16(b)
                                  b.add(msg_crc, 2)       # crc 2 bytes, little endian
                                  return b
                                end
                                def encodenx(payload)
                                    var b = bytes().fromstring(payload)
                                    b += bytes('FFFFFF')
                                    return b
                                end
                                def sendnx(payload)
                                    import string
                                    var payload_bin = self.encodenx(payload)
                                    self.ser.write(payload_bin)
                                    log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3)
                                end
                                def send(payload)
                                    var payload_bin = self.encode(payload)
                                    if self.flash_mode==1
                                        log("NXP: skipped command becuase still flashing", 3)
                                    else
                                        log("NXP: payload sent = " + str(payload_bin), 3)
                                    end
                                end
                                def write_to_nextion(b)
                                    self.ser.write(b)
                                end
                                def screeninit()
                                    log("NXP: Screen Initialized")
                            		self.sendnx("recmod=1")
                                end
                                def write_block()
                                    import string
                                    log("FLH: Read block",3)
                                    while size(self.flash_buff)<self.flash_block_size && self.tcp.connected()
                                        if self.tcp.available()>0
                                            self.flash_buff += self.tcp.readbytes()
                                        else
                                            tasmota.delay(50)
                                            log("FLH: Wait for available...",3)
                                        end
                                    end
                                    log("FLH: Buff size "+str(size(self.flash_buff)),3)
                                    var to_write
                                    if size(self.flash_buff)>self.flash_block_size
                                        to_write = self.flash_buff[0..self.flash_block_size-1]
                                        self.flash_buff = self.flash_buff[self.flash_block_size..]
                                    else
                                        self.flash_buff = bytes()
                                    end
                                    log("FLH: Writing "+str(size(to_write)),3)
                                    var per = (self.flash_written*100)/self.flash_size
                                    if (self.last_per!=per)
                                        self.last_per = per
                                        tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
                                    end
                                    if size(to_write)>0
                                        self.flash_written += size(to_write)
                                        self.ser.write(to_write)
                                    end
                                    log("FLH: Total "+str(self.flash_written),3)
                                    if (self.flash_written==self.flash_size)
                                        log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000)
                                        self.flash_mode = 0
                            			self.ser = nil
                            			tasmota.gc()
                            			self.ser = serial(17, 16, 115200, serial.SERIAL_8N1)
                                    end
                                end
                                def every_100ms()
                                    import string
                                    if self.ser.available() > 0
                                        var msg = self.ser.read()
                                        if size(msg) > 0
                                            log(string.format("NXP: Received Raw = %s",str(msg)), 3)
                                            if (self.flash_mode==1)
                                                var strv = msg[0..-4].asstring()
                                                if string.find(strv,"comok 2")>=0
                                                    log("FLH: Send (High Speed) flash start")
                            						self.flash_start_millis = tasmota.millis()
                                                    #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size))
                                                    self.sendnx(string.format("whmi-wris %d,921600,res0",self.flash_size))
                            						self.ser = serial(17, 16, 921600, serial.SERIAL_8N1)
                                                elif size(msg)==1 && msg[0]==0x08
                                                    log("FLH: Waiting offset...",3)
                                                    self.awaiting_offset = 1
                                                elif size(msg)==4 && self.awaiting_offset==1
                                                    self.awaiting_offset = 0
                                                    self.flash_offset = msg.get(0,4)
                                                    log("FLH: Flash offset marker "+str(self.flash_offset),3)
                            						if self.flash_offset != 0
                            							self.open_url_at(self.url, self.flash_offset)
                            							self.flash_written = self.flash_offset
                            						end
                                                    self.write_block()
                                                elif size(msg)==1 && msg[0]==0x05
                                                    self.write_block()
                                                else
                                                    log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2)
                                                end
                                            else
                                                var msg_list = self.split_55(msg)
                                                for i:0..size(msg_list)-1
                                                    msg = msg_list[i]
                                                    if size(msg) > 0
                                                        if msg == bytes('000000FFFFFF88FFFFFF')
                                                            self.screeninit()
                                                        elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB
                                                            var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring())
                                                            tasmota.publish_result(jm, "RESULT")
                                                        elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer
                                                            tasmota.cmd("buzzer 1,1")
                                                        else
                                                            var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                                                        end
                                                    end
                                                end
                                            end
                                        end
                                    end
                                end
                                def begin_nextion_flash()
                                    self.flash_written = 0
                                    self.flash_offset = 0
                                    self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN')
                                    self.sendnx('recmod=0')
                                    self.flash_mode = 1
                                    self.sendnx("connect")
                                end
                                def open_url_at(url, pos)
                            		self.url = url
                                    import string
                                    var host
                                    var port
                                    var s1 = string.split(url,7)[1]
                                    var i = string.find(s1,":")
                                    var sa
                                    if i<0
                                        port = 80
                                        i = string.find(s1,"/")
                                        sa = string.split(s1,i)
                                        host = sa[0]
                                    else
                                        host = sa[0]
                                        s1 = string.split(sa[1],1)[1]
                                        port = int(sa[0])
                                    end
                                    var get = sa[1]
                                    log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get))
                                    self.tcp = tcpclient()
                                    self.tcp.connect(host,port)
                                    log("FLH: Connected:"+str(self.tcp.connected()),3)
                                    var get_req = "GET "+get+" HTTP/1.0\r\n"
                            		get_req += string.format("Range: bytes=%d-\r\n", pos)
                            		get_req += string.format("HOST: %s:%s\r\n\r\n",host,port)
                                    self.tcp.write(get_req)
                                    var a = self.tcp.available()
                                    i = 1
                                    while a==0 && i<5
                                      tasmota.delay(100*i)
                                      tasmota.yield()
                                      i += 1
                                      log("FLH: Retry "+str(i),3)
                                    end
                                    if a==0
                                        log("FLH: Nothing available to read!",3)
                                        return
                                    end
                                    var b = self.tcp.readbytes()
                                    i = 0
                                    var end_headers = false;
                                    var headers
                                    while i<size(b) && headers==nil
                                        if b[i..(i+3)]==bytes().fromstring("\r\n\r\n")
                                            headers = b[0..(i+3)].asstring()
                                            self.flash_buff = b[(i+4)..]
                                        else
                                            i += 1
                                        end
                                    end
                                    #print(headers)
                            		# check http respose for code 200/206
                                    if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0
                                        log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3)
                            		else
                                        log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3)
                            			print(headers)
                            			return -1
                                    end
                            		# only set flash size if pos is zero
                            		if pos == 0
                            			# check http respose for content-length
                            			var tag = "Content-Length: "
                            			i = string.find(headers,tag)
                            			if (i>0)
                            				var i2 = string.find(headers,"\r\n",i)
                            				var s = headers[i+size(tag)..i2-1]
                            				self.flash_size=int(s)
                            			end
                            			log("FLH: Flash file size: "+str(self.flash_size),3)
                            		end
                                end
                                def flash_nextion(url)
                                    self.flash_size = 0
                                    var res = self.open_url_at(url, 0)
                            		if res != -1
                            			self.begin_nextion_flash()
                            		end
                                end
                                def init()
                                    log("NXP: Initializing Driver")
                                    self.flash_mode = 0
                                end
                            end
                            var nextion = Nextion()
                            tasmota.add_driver(nextion)
                            def get_current_version(cmd, idx, payload, payload_json)
                            	import string
                            	var version_of_this_script = 4
                            	var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script)
                            end
                            tasmota.add_cmd('GetDriverVersion', get_current_version)
                            def update_berry_driver(cmd, idx, payload, payload_json)
                            	def task()
                            		import string
                            		var cl = webclient()
                            		cl.begin(payload)
                            		var r = cl.GET()
                            		if r == 200
                            			print("Sucessfully downloaded nspanel-lovelace-ui berry driver")
                            		else
                            			print("Error while downloading nspanel-lovelace-ui berry driver")
                            		end
                            		r = cl.write_file("autoexec.be")
                            		if r < 0
                            			print("Error while writeing nspanel-lovelace-ui berry driver")
                            		else
                            			print("Sucessfully written nspanel-lovelace-ui berry driver")
                            			var s = load('autoexec.be')
                            			if s == true
                            				var jm = string.format("{\"nlui_driver_update\":\"%s\"}", "succeeded")
                            			else
                            				var jm = string.format("{\"nlui_driver_update\":\"%s\"}", "failed")
                            			end
                            		end
                            	end
                            	tasmota.set_timer(0,task)
                            	tasmota.resp_cmnd_done()
                            end
                            tasmota.add_cmd('UpdateDriverVersion', update_berry_driver)
                            def flash_nextion(cmd, idx, payload, payload_json)
                                def task()
                                    nextion.flash_nextion(payload)
                                end
                            end
                            def send_cmd(cmd, idx, payload, payload_json)
                                nextion.sendnx(payload)
                            end
                            def send_cmd2(cmd, idx, payload, payload_json)
                                nextion.send(payload)
                            end
                            tasmota.add_cmd('Nextion', send_cmd)
                            tasmota.add_cmd('CustomSend', send_cmd2)
                            tasmota.add_cmd('FlashNextion', flash_nextion)
                            MQTT-Settings:
                            Sonstige Einstellungen/Vorlage
                            {"NAME":"NSPanel","GPIO":[0,0,0,0,3872,0,0,0,0,0,32,0,0,0,0,225,0,480,224,1,0,0,0,33,0,0,0,0,0,0,0,0,0,0,4736,0],"FLAG":0,"BASE":1}
                            • Armilar
                              autexec.be:
                              # based on;
                              # based on;
                              # Example Flash
                                  var flash_mode
                                  var flash_size
                                  var flash_written
                                  var flash_buff
                                  var flash_offset
                                  var awaiting_offset
                                  var tcp
                                  var ser
                                  var last_per
                              	var url
                                  def split_55(b)
                                    var ret = []
                                    var s = size(b)
                                    while i > 0
                                      end
                                      i -= 1
                                    end
                                    ret.push(b)
                                    return ret
                                  end
                                    var crc = 0xFFFF
                                      crc = crc ^ data[i]
                                      for j:0..7
                                        if crc & 1
                                        else
                                          crc = crc >> 1
                                        end
                                      end
                                    end
                                    return crc
                                  end
                                  def encode(payload)
                                    var b = bytes()
                                    b += self.header
                                    return b
                                  end
                                      return b
                                  end
                                  def sendnx(payload)
                                      import string
                                  end
                                  def send(payload)
                                      else
                                      end
                                  end
                                      self.ser.write(b)
                                  end
                                  def screeninit()
                                  end
                                  def write_block()
                                      import string
                                          else
                                              tasmota.delay(50)
                                          end
                                      end
                                      var to_write
                                      else
                                      end
                                          self.last_per = per
                                      end
                                      if size(to_write)>0
                                      end
                                          self.flash_mode = 0
                              			self.ser = nil
                              			tasmota.gc()
                                      end
                                  end
                                  def every_100ms()
                                      import string
                                          if size(msg) > 0
                              						end
                                                      self.write_block()
                                                      self.write_block()
                                                  else
                                                  end
                                              else
                                                      msg = msg_list[i]
                                                      if size(msg) > 0
                                                              self.screeninit()
                                                          else
                                                          end
                                                      end
                                                  end
                                              end
                                          end
                                      end
                                  end
                                      self.flash_mode = 1
                                  end
                              		self.url = url
                                      import string
                                      var host
                                      var port
                                      var sa
                                      if i<0
                                          port = 80
                                          host = sa[0]
                                      else
                                          host = sa[0]
                                          port = int(sa[0])
                                      end
                                      var get = sa[1]
                                      i = 1
                                      while a==0 && i<5
                                        tasmota.yield()
                                        i += 1
                                      end
                                      if a==0
                                          return
                                      end
                                      i = 0
                                      var headers
                                          else
                                              i += 1
                                          end
                                      end
                                      #print(headers)
                              		else
                              			print(headers)
                              			return -1
                                      end
                              		if pos == 0
                              			if (i>0)
                              			end
                              		end
                                  end
                                      self.flash_size = 0
                              		if res != -1
                              		end
                                  end
                                  def init()
                                      self.flash_mode = 0
                                  end
                              end
                              	import string
                              end
                              	def task()
                              		import string
                              		cl.begin(payload)
                              		var r = cl.GET()
                              		if r == 200
                              		else
                              		end
                              		if r < 0
                              		else
                              			if s == true
                              			else
                              			end
                              		end
                              	end
                              end
                                  def task()
                                  end
                              end
                              end
                              end
                              MQTT-Settings:
                              Das mqtt.1. muss in beide Richtungen kommunizieren. RESULT funktioniert. Teste es doch bitte so wie beschrieben. Deinen Mosquitto kannst du anschließend immer noch bemühen.
                              • Andreas_Z
                                @armilar
                                Habe ich, MQTT.2 ist als Server (mit anderem Port) konfiguriert und identischem Resultat, es wird nichts auf dem Display angezeigt:
                                mqtt.2	2022-09-23 19:32:17.692	info	Client [NSPanel_1] publishOnSubscribe send all known states
                                mqtt.2	2022-09-23 19:32:17.691	info	Client [NSPanel_1] publishOnSubscribe send all known states
                                mqtt.2	2022-09-23 19:32:17.689	info	Client [NSPanel_1] publishOnSubscribe send all known states
                                mqtt.2	2022-09-23 19:32:17.492	info	Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.2\.cmnd\.NSPanel_1_fb(\..*)?/
                                mqtt.2	2022-09-23 19:32:17.492	info	Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb(\..*)?/
                                mqtt.2	2022-09-23 19:32:17.491	info	Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.2\.SmartHome\.tasmotas\.cmnd(\..*)?/
                                mqtt.2	2022-09-23 19:32:17.490	info	Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd(\..*)?/
                                mqtt.2	2022-09-23 19:32:17.489	info	Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.2\.SmartHome\.NSPanel_1\.cmnd(\..*)?/
                                mqtt.2	2022-09-23 19:32:17.489	info	Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd(\..*)?/
                                mqtt.2	2022-09-23 19:32:17.454	info	Client [NSPanel_1] connected with secret 1663954337450_1441
                                mqtt.2	2022-09-23 19:32:07.977	info	Client [NSPanel_1] connection closed: closed
                                javascript.0	2022-09-23 19:30:27.658	info	script.js.common.NSPanel_1: registered 12 subscriptions, 6 schedules, 0 messages, 0 logs and 0 file subscriptions
                                javascript.0	2022-09-23 19:30:27.636	info	script.js.common.NSPanel_1: TypeScript compilation successful
                                javascript.0	2022-09-23 19:30:25.964	info	script.js.common.NSPanel_1: compiling TypeScript source...
                                javascript.0	2022-09-23 19:30:25.924	debug	File /home/Javascript/common/NSPanel_1.ts change
                                javascript.0	2022-09-23 19:30:25.924	info	Stop script script.js.common.NSPanel_1
                                javascript.0	2022-09-23 19:30:25.917	debug	Update /home/Javascript/common/NSPanel_1.ts on disk
                                Werte im Script habe ich auf MQTT.2 geändert gehabt.
                                • Armilar
                                  @armilar
                                  So und jetzt bitte mal die mqtt-Einstellungen aus dem mqtt.2. und aus Tasmota posten. Ich denke wir finden den Fehler noch
                                  • Andreas_Z
                                    @armilar
                                    By the way, Respekt und dank für deine Geduld 👍
                                    • Armilar
                                      @armilar
                                      Denke ich habe was ... Bitte nach und nach..
                                      Haken "unbedingt" raus... und raus lassen
                                      Haken rein...
                                      Setze mal höher
                                      Wärst so ziemlich der erste bei dem es nicht funktioniert. Können wir irgendwie nicht auf uns sitzen lassen... 😉
                                      und zum Schluss noch die beiden Zeilen aktualisieren, falls noch nicht geschehen...
                                          panelRecvTopic: 'mqtt.2.SmartHome.NSPanel_1.tele.RESULT',       // anpassen
                                          panelSendTopic: 'mqtt.2.SmartHome.NSPanel_1.cmnd.CustomSend',   // anpassen
                                      • Andreas_Z
                                        @armilar Alles Umgesetzt, ohne Erfolg, was aber bisher immer passiert (Mit Mosqitto und über Iobroker Intern MQTT), wenn ich das Script neu gestartet oder geändert habe, das "This is taking longer ....." verschwindet für einen Moment und erscheint danach wieder, also scheint es ja doch eine Gewisse Kommunikation zu geben
                                        Armilar K 2 Replies Last reply Reply Quote 0
                                        • Armilar
                                          Okay ich gebe auf. Kannst noch mal versuchen die IP im Broker auf den Server zusetzten und beide Kisten iobroker und Panel durchstarten. Mehr geht eigentlich nicht...
                                          • Armilar
                                            Armilar Most Active Forum Testing @Kuckuckmann last edited by Armilar
                                            @kuckuckmann (nur für deine Tests)
                                            lovelace ui nspanel sonoff
                                            271
                                            7719
                                            6616828
