    4. Admin Upgrade auf 6.xxx Version schlägt fehl - Gelöst
    • crepp1967
      crepp1967 @Thomas Braun last edited by
      pi@iob-test1-proxmox:~$ iobroker upgrade all
      This upgrade of "vis-hqwidgets" will introduce the following changes:
      -> 1.3.0:
      Made it compatible with ioBroker.vis v2
      Would you like to upgrade vis-hqwidgets from @1.2.0 to @1.3.0 now? [(y)es, (n)o]: y
      Update vis-hqwidgets from @1.2.0 to @1.3.0
      NPM version: 8.15.0
      Installing iobroker.vis-hqwidgets@1.3.0... (System call)
      host.iob-test1-proxmox Cannot install iobroker.vis-hqwidgets@1.3.0: 217
        Thomas Braun Most Active @crepp1967 last edited by
        @crepp1967
        Vermutlich das:
        https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
        crepp1967 1 Reply Last reply Reply Quote 0
        • crepp1967
          pi@iob-test1-proxmox:~$ iobroker upgrade all --debug
          -> 1.3.0:
          NPM version: 8.15.0
          npm WARN old lockfile
          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
          npm WARN old lockfile This is a one-time fix-up, please be patient...
          • crepp1967
            crepp1967 @crepp1967 last edited by
            @crepp1967
            Er meckert aber keine Ordner an soweit ich das sehe
            • crepp1967
              @crepp1967
              Ok, er war noch nicht fertig (please be patient...) 🙂
              npm WARN old lockfile Error: git dep preparation failed
              npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
              npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
              npm WARN old lockfile     at maybeClose (node:internal/child_process:1093:16)
              npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
              npm WARN old lockfile  Could not fetch metadata for iobroker.mytime@git+ssh://git@github.com/oweitman/iobroker.mytime.git#4f0814f14bdedaedd4a4d4306edc95f8b1269d19 Error: git dep preparation failed
              npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5) {
              npm WARN old lockfile   cmd: '/usr/bin/node',
              npm WARN old lockfile   args: [
              npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
              npm WARN old lockfile     'install',
              npm WARN old lockfile     '--force',
              npm WARN old lockfile     '--cache=/home/iobroker/.npm',
              npm WARN old lockfile     '--prefer-offline=false',
              npm WARN old lockfile     '--prefer-online=false',
              npm WARN old lockfile     '--offline=false',
              npm WARN old lockfile     '--no-progress',
              npm WARN old lockfile     '--no-save',
              npm WARN old lockfile     '--no-audit',
              npm WARN old lockfile     '--include=dev',
              npm WARN old lockfile     '--include=peer',
              npm WARN old lockfile     '--include=optional',
              npm WARN old lockfile     '--no-package-lock-only',
              npm WARN old lockfile     '--no-dry-run'
              npm WARN old lockfile   ],
              npm WARN old lockfile   code: 1,
              npm WARN old lockfile   signal: null,
              npm WARN old lockfile   stdout: '',
              npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
              npm WARN old lockfile     'npm WARN old lockfile \n' +
              npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
              npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
              npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
              npm WARN old lockfile     'npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort#browser_compatibility\n' +
              npm WARN old lockfile     'npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142\n' +
              npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
              npm WARN old lockfile     'npm WARN deprecated har-validator@5.1.5: this library is no longer supported\n' +
              npm WARN old lockfile     'npm WARN deprecated json-parser@1.1.5: `json-parser` is deprecated. Please use `comment-json` instead\n' +
              npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
              npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated\n' +
              npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.0: See https://github.com/lydell/source-map-url#deprecated\n' +
              npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies\n' +
              npm WARN old lockfile     'npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)\n' +
              npm WARN old lockfile     'npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.\n' +
              npm WARN old lockfile     'npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.\n' +
              npm WARN old lockfile     'npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.\n' +
              npm WARN old lockfile     'npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142\n' +
              npm WARN old lockfile     'npm WARN deprecated @material-ui/system@4.11.3: You can now upgrade to @mui/system. See the guide: https://mui.com/guides/migration-v4/\n' +
              npm WARN old lockfile     'npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.\n' +
              npm WARN old lockfile     'npm WARN deprecated @material-ui/styles@4.11.4: You can now upgrade to @mui/styles. See the guide: https://mui.com/guides/migration-v4/\n' +
              npm WARN old lockfile     "npm WARN deprecated parcel-bundler@1.12.5: Parcel v1 is no longer maintained. Please migrate to v2, which is published under the 'parcel' package. See https://v2.parceljs.org/getting-started/migration for details.\n" +
              npm WARN old lockfile     'npm WARN deprecated @material-ui/lab@4.0.0-alpha.58: You can now upgrade to @mui/lab. See the guide: https://mui.com/guides/migration-v4/\n' +
              npm WARN old lockfile     'npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.\n' +
              npm WARN old lockfile     'npm WARN deprecated @material-ui/core@4.11.4: You can now upgrade to @mui/material. See the guide: https://mui.com/guides/migration-v4/\n' +
              npm WARN old lockfile     'npm WARN deprecated @material-ui/icons@4.11.2: You can now upgrade to @mui/icons. See the guide: https://mui.com/guides/migration-v4/\n' +
              npm WARN old lockfile     'npm ERR! code 1\n' +
              npm WARN old lockfile     'npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneobk4GU/node_modules/deasync\n' +
              npm WARN old lockfile     'npm ERR! command failed\n' +
              npm WARN old lockfile     'npm ERR! command sh /tmp/install-84fea94e.sh\n' +
              npm WARN old lockfile     'npm ERR! node:internal/modules/cjs/loader:959\n' +
              npm WARN old lockfile     'npm ERR!   throw err;\n' +
              npm WARN old lockfile     'npm ERR!   ^\n' +
              npm WARN old lockfile     'npm ERR! \n' +
              npm WARN old lockfile     "npm ERR! Error: Cannot find module 'object-assign'\n" +
              npm WARN old lockfile     'npm ERR! Require stack:\n' +
              npm WARN old lockfile     'npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js\n' +
              npm WARN old lockfile     'npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js\n' +
              npm WARN old lockfile     'npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js\n' +
              npm WARN old lockfile     'npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js\n' +
              npm WARN old lockfile     'npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js\n' +
              npm WARN old lockfile     'npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js\n' +
              npm WARN old lockfile     'npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)\n' +
              npm WARN old lockfile     'npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)\n' +
              npm WARN old lockfile     'npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)\n' +
              npm WARN old lockfile     'npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)\n' +
              npm WARN old lockfile     'npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)\n' +
              npm WARN old lockfile     'npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)\n' +
              npm WARN old lockfile     'npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)\n' +
              npm WARN old lockfile     'npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32)\n' +
              npm WARN old lockfile     'npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:839:12)\n' +
              npm WARN old lockfile     'npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19) {\n' +
              npm WARN old lockfile     "npm ERR!   code: 'MODULE_NOT_FOUND',\n" +
              npm WARN old lockfile     'npm ERR!   requireStack: [\n' +
              npm WARN old lockfile     "npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',\n" +
              npm WARN old lockfile     "npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',\n" +
              npm WARN old lockfile     "npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',\n" +
              npm WARN old lockfile     "npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',\n" +
              npm WARN old lockfile     "npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',\n" +
              npm WARN old lockfile     "npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'\n" +
              npm WARN old lockfile     'npm ERR!   ]\n' +
              npm WARN old lockfile     'npm ERR! }\n' +
              npm WARN old lockfile     'npm ERR! Build failed\n' +
              npm WARN old lockfile     '\n' +
              npm WARN old lockfile     'npm ERR! A complete log of this run can be found in:\n' +
              npm WARN old lockfile     'npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T09_40_03_317Z-debug-0.log\n'
              npm WARN old lockfile }
              npm ERR! code ENOTEMPTY
              npm ERR! syscall rename
              npm ERR! path /opt/iobroker/node_modules/iobroker.backitup
              npm ERR! dest /opt/iobroker/node_modules/.iobroker.backitup-ZZHwpo6A
              npm ERR! errno -39
              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.backitup' -> '/opt/iobroker/node_modules/.iobroker.backitup-ZZHwpo6A'
              npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T09_39_52_308Z-debug-0.log
              mikeal created this issue in request/request
              open Request’s Past, Present and Future #3142
              Qix- created this issue in visionmedia/debug
              closed ReDos Vulnerability Regression Visibility Notice #797
              crepp1967 Thomas Braun 2 Replies Last reply Reply Quote 0
              • crepp1967
                @crepp1967
                Mit diesem Befehl kann ich die alten Ordner löschen?
                for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                Wo muss ich stehen ? /opt/iobroker ?
                  @crepp1967 sagte in Admin Upgrade auf 6.xxx Version schlägt fehl:
                  Egal. Der Befehl läuft (mittlerweile) immer automatisch im richtigen Verzeichnis.
                  • crepp1967
                    Es hat funktioniert, Vielen Dank für Deine schnelle Hilfe!
                      @crepp1967 sagte in Admin Upgrade auf 6.xxx Version schlägt fehl - Gelöst:
                      Übrigens: Solange im Terminal nicht wieder der LoginPrompt erscheint läuft das Kommando noch. Grundsätzlich immer unter Linux.
                      • crepp1967
                        Ja, theoretisch wusste ich das - war bloß zu fix ...
                        amin
                        454
