    5. PV Überschuss zum betreiben von 1 Heizstab
      paul53 @Spidermike last edited by
      @spidermike sagte: ist das jetzt was schlimmes oder egal?
      Auf die Funktion dieses Skriptes hat es keinen Einfluss.
        Spidermike @paul53 last edited by
        @paul53 sagte in PV Überschuss zum betreiben von 1 Heizstab:
        perfekt, nochmals vielen Dank an Euch
        werde mich jetzt mal an mein Garagentorprojekt mit dem Wled heranmachen damit das mal endlich zum laufen kommt
          Spidermike @Spidermike last edited by
          @spidermike
          bekomme jetzt viele Log
          was ist das denn jetzt
          hs100.0
          	2022-07-24 17:01:03.310	warn	This object will not be created in future versions. Please report this to the developer.
          hs100.0
          	2022-07-24 17:01:03.309	warn	Object 192_168_178_94.ledState is invalid: Default value has to be type "string" but received type "boolean"
          hs100.0
          	2022-07-24 17:01:03.306	warn	This object will not be created in future versions. Please report this to the developer.
          hs100.0
          	2022-07-24 17:01:03.304	warn	Object 192_168_178_94.last_update is invalid: Default value has to be type "string" but received type "number"
          hs100.0
          	2022-07-24 17:01:03.198	info	Start with IP : 192.168.178.94
          hs100.0
          	2022-07-24 17:01:03.196	warn	This object will not be created in future versions. Please report this to the developer.
          hs100.0
          	2022-07-24 17:01:03.196	warn	Object 192_168_178_38.last_update is invalid: Default value has to be type "string" but received type "number"
          hs100.0
          	2022-07-24 17:01:02.934	info	Start with IP : 192.168.178.38
          hs100.0
          	2022-07-24 17:01:02.931	warn	This object will not be created in future versions. Please report this to the developer.
          hs100.0
          	2022-07-24 17:01:02.931	warn	Object 192_168_178_95.ledState is invalid: Default value has to be type "string" but received type "boolean"
          hs100.0
          	2022-07-24 17:01:02.929	warn	This object will not be created in future versions. Please report this to the developer.
          hs100.0
          	2022-07-24 17:01:02.928	warn	Object 192_168_178_95.last_update is invalid: Default value has to be type "string" but received type "number"
          hs100.0
          	2022-07-24 17:01:02.870	info	Start with IP : 192.168.178.95
          hs100.0
          	2022-07-24 17:01:02.820	info	starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
          host.raspberrypi4-iobroker
          	2022-07-24 17:01:00.691	info	instance system.adapter.hs100.0 started with pid 14007
          	2022-07-24 17:00:30.614	info	Restart adapter system.adapter.hs100.0 because enabled
          	2022-07-24 17:00:30.614	error	instance system.adapter.hs100.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          	2022-07-24 17:00:30.613	error	Caught by controller[7]: }
          	2022-07-24 17:00:30.613	error	Caught by controller[7]: port: 9999
          	2022-07-24 17:00:30.613	error	Caught by controller[7]: address: '192.168.178.94',
          	2022-07-24 17:00:30.613	error	Caught by controller[7]: syscall: 'connect',
          	2022-07-24 17:00:30.613	error	Caught by controller[7]: code: 'ECONNREFUSED',
          	2022-07-24 17:00:30.613	error	Caught by controller[7]: errno: -111,
          	2022-07-24 17:00:30.612	error	Caught by controller[7]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
          	2022-07-24 17:00:30.612	error	Caught by controller[7]: [3kw Heizstab] device.send() Error: connect ECONNREFUSED 192.168.178.94:9999
          	2022-07-24 17:00:30.612	error	Caught by controller[6]: }
          	2022-07-24 17:00:30.612	error	Caught by controller[6]: port: 9999
          	2022-07-24 17:00:30.612	error	Caught by controller[6]: address: '192.168.178.94',
          	2022-07-24 17:00:30.612	error	Caught by controller[6]: syscall: 'connect',
          	2022-07-24 17:00:30.611	error	Caught by controller[6]: code: 'ECONNREFUSED',
          	2022-07-24 17:00:30.611	error	Caught by controller[6]: errno: -111,
          	2022-07-24 17:00:30.611	error	Caught by controller[6]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
          	2022-07-24 17:00:30.611	error	Caught by controller[6]: TCP 192.168.178.94:9999 Error: connect ECONNREFUSED 192.168.178.94:9999
          	2022-07-24 17:00:30.611	error	Caught by controller[5]: }
          	2022-07-24 17:00:30.611	error	Caught by controller[5]: port: 9999
          	2022-07-24 17:00:30.610	error	Caught by controller[5]: address: '192.168.178.94',
          	2022-07-24 17:00:30.610	error	Caught by controller[5]: syscall: 'connect',
          	2022-07-24 17:00:30.610	error	Caught by controller[5]: code: 'ECONNREFUSED',
          	2022-07-24 17:00:30.610	error	Caught by controller[5]: errno: -111,
          	2022-07-24 17:00:30.610	error	Caught by controller[5]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
          	2022-07-24 17:00:30.610	error	Caught by controller[5]: [3kw Heizstab] device.send() Error: connect ECONNREFUSED 192.168.178.94:9999
          	2022-07-24 17:00:30.609	error	Caught by controller[4]: }
          	2022-07-24 17:00:30.609	error	Caught by controller[4]: port: 9999
          	2022-07-24 17:00:30.609	error	Caught by controller[4]: address: '192.168.178.94',
          	2022-07-24 17:00:30.609	error	Caught by controller[4]: syscall: 'connect',
          	2022-07-24 17:00:30.609	error	Caught by controller[4]: code: 'ECONNREFUSED',
          	2022-07-24 17:00:30.609	error	Caught by controller[4]: errno: -111,
          	2022-07-24 17:00:30.608	error	Caught by controller[4]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
          	2022-07-24 17:00:30.608	error	Caught by controller[4]: TCP 192.168.178.94:9999 Error: connect ECONNREFUSED 192.168.178.94:9999
          	2022-07-24 17:00:30.608	error	Caught by controller[3]: at processTimers (internal/timers.js:500:7)
          	2022-07-24 17:00:30.608	error	Caught by controller[3]: at listOnTimeout (internal/timers.js:557:17)
          	2022-07-24 17:00:30.608	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
          	2022-07-24 17:00:30.607	error	Caught by controller[3]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
          	2022-07-24 17:00:30.607	error	Caught by controller[3]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
          	2022-07-24 17:00:30.607	error	Caught by controller[2]: at processTimers (internal/timers.js:500:7)
          	2022-07-24 17:00:30.607	error	Caught by controller[2]: at listOnTimeout (internal/timers.js:557:17)
          	2022-07-24 17:00:30.607	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
          	2022-07-24 17:00:30.607	error	Caught by controller[2]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
          	2022-07-24 17:00:30.606	error	Caught by controller[2]: [3kw Heizstab] device.send() Error: TCP Timeout after 10000ms
          	2022-07-24 17:00:30.606	error	Caught by controller[1]: at processTimers (internal/timers.js:500:7)
          	2022-07-24 17:00:30.606	error	Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
          	2022-07-24 17:00:30.606	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
          	2022-07-24 17:00:30.606	error	Caught by controller[1]: 192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
          	2022-07-24 17:00:30.606	error	Caught by controller[1]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
          	2022-07-24 17:00:30.605	error	Caught by controller[0]: at processTimers (internal/timers.js:500:7)
          	2022-07-24 17:00:30.605	error	Caught by controller[0]: at listOnTimeout (internal/timers.js:557:17)
          	2022-07-24 17:00:30.605	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36)
          	2022-07-24 17:00:30.605	error	Caught by controller[0]: 192.168.178.94:9999 {"system":{"get_sysinfo":{}}}
          	2022-07-24 17:00:30.604	error	Caught by controller[0]: TCP 192.168.178.94:9999 Error: TCP Timeout after 10000ms
          hs100.0
          	2022-07-24 17:00:30.132	error	Exception-Code: ECONNREFUSED: connect ECONNREFUSED 192.168.178.94:9999
          hs100.0
          	2022-07-24 17:00:30.131	error	Error: connect ECONNREFUSED 192.168.178.94:9999 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
          hs100.0
          	2022-07-24 17:00:30.131	error	unhandled promise rejection: connect ECONNREFUSED 192.168.178.94:9999
          hs100.0
          	2022-07-24 17:00:30.130	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          hs100.0
          	2022-07-24 17:00:30.049	error	Exception-Code: ECONNREFUSED: connect ECONNREFUSED 192.168.178.94:9999
          hs100.0
          	2022-07-24 17:00:30.048	error	Error: connect ECONNREFUSED 192.168.178.94:9999 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
          hs100.0
          	2022-07-24 17:00:30.047	error	unhandled promise rejection: connect ECONNREFUSED 192.168.178.94:9999
          hs100.0
          	2022-07-24 17:00:30.046	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          hs100.0
          	2022-07-24 17:00:30.033	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          hs100.0
          	2022-07-24 17:00:30.031	info	terminating
          hs100.0
          	2022-07-24 17:00:30.030	info	cleaned everything up...
          hs100.0
          	2022-07-24 17:00:30.027	warn	Info Message setDevice: Error: TCP Timeout after 10000ms192.168.178.94:9999 {"system":{"get_sysinfo":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
          hs100.0
          	2022-07-24 17:00:30.020	error	TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
          hs100.0
          	2022-07-24 17:00:30.020	error	Error: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
          hs100.0
          	2022-07-24 17:00:30.019	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.94:9999 {"emeter":{"get_realtime":{}}}
          hs100.0
          	2022-07-24 17:00:30.018	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            Homoran Global Moderator Administrators @Spidermike last edited by
            @spidermike was soll das mit dem bisherigen Thema zu tun haben?
            S D 2 Replies Last reply Reply Quote 0
              Diamand2k22 @Homoran last edited by Diamand2k22
              finde das Blockly Klasse und habe es erfolgreich bei mir im Einsatz.
              Konstellation ist 2x E-Heizkörper die je nach Heizstufe zuschalten.
              Beide Geräte haben eine Leistung von 800W. Somit funktioniert das ganze recht gut.
              Frage von meiner Seite wäre, wie kann ich das Skript um eine 3. Heizstufe aufbohren, aber wenn der Verbraucher dann nicht 800 W hat sondern 2400W hat ?
              Diamand
                paul53 @Diamand2k22 last edited by paul53
                @diamand2k22 sagte: wie kann ich das Skript um eine 3. Heizstufe aufbohren, aber wenn der Verbraucher dann nicht 800 W hat sondern 2400W hat ?
                Wieso nur 3 Stufen?
                1. Stufe: Stab 1
                2. Stufe: Stab 1+2
                3. Stufe: Stab 3
                4. Stufe: Stab 3 + 1
                5. Stufe: Stab 3 + 1 + 2
                Jede Stufe unterscheidet sich um 800 W, also ist es wohl nicht so schwierig, das anzupassen?
                  Diamand2k22 @paul53 last edited by
                  @paul53 said in PV Überschuss zum betreiben von 1 Heizstab:
                  Wieso nur 3 Stufen?
                  1. Stufe: Stab 1
                  2. Stufe: Stab 1+2
                  3. Stufe: Stab 3
                  ok, dann ist Stufe 5 die 2400W
                    @diamand2k22 sagte: dann ist Stufe 5 die 2400W
                    Nein, Stufe 5 ist 4000 W.
                      Diamand2k22 @paul53 last edited by Diamand2k22
                      stimmt, zu blöd zum Rechnen 😄 ....
                        Diamand2k22 @Diamand2k22 last edited by
                        aber ich glaube wir haben aneinander vorbei geredet 😄 der Ablauf soll folgender sein:
                        Überschuss >800W -> Heistab 1 ein (Heistufe 1)
                        Danach Überschuss wieder > 800W Heizstab 2 ein (Heizstufe 2)
                        danach Überschuss >2400 W Poolheizung ein (Heizstufe 3)
                        aber Heizstab 1 und Heizstab 2 sollen weiterlaufen und der Pool schaltet sich bei Überschuss >2400W noch dazu.
                        Wenn der Überschuss wieder weniger wird, schaltet sich alles in umgekehrter Reihenfolge wieder ab.
                          @diamand2k22 sagte: aber Heizstab 1 und Heizstab 2 sollen weiterlaufen
                          Dann gibt es einen Leistungssprung von 2400 W (1600 auf 4000 W), der nicht mehr per einfacher Stufenschaltung zu behandeln ist.
                          Übrigens: Wie hast Du mit zwei 800 W Heizungen 3 Stufen gebildet?
                            @diamand2k22 sagte:
                              hier mal das aktuelle Blockly
                                @diamand2k22 sagte: das aktuelle Blockly
                                Das funktioniert so nicht. Ändere bei Skriptstart die Ermittlung der Leistungsstufe so wie hier gezeigt.
                                Außerdem wird, wenn die Leistungsstufe 2 erreicht ist, ein höherer Grenzwert (-2400) für weiteres Hochschalten benötigt.
                                Wozu dienen cntEin und cntAus, die nirgends ausgewertet werden?
                                  ich habe es wie von dir beschrieben angepasst.
                                  cnt werden ausgewertet, siehe Markierung!
                                  jetzt habe ich noch das Thema mit der Leistungsstufe 2400W.
                                  Muss ich mal sehen wie ich das hin bekomm...
                                    @diamand2k22 sagte: Thema mit der Leistungsstufe 2400W.
                                    Wie gezeigt.
                                    @diamand2k22 sagte in PV Überschuss zum betreiben von 1 Heizstab:
                                    Ach ja, das dient zur Verzögerung (Anpassung an das Verhalten des Smartmeters).
                                      danke das funktioniert!
                                      Wie müsste ich das Blockly noch anpassen, wenn die Leistungsstufe 3 nochmal eine E-Heizung mit 600W sind und dann die Leistungsstufe 4 der Pool mit den 2400W.
                                      Wie sieht dann das setzten des Startwertes oben aus?
                                      Danke und
                                      paul53 A 2 Replies Last reply Reply Quote 0
                                        @diamand2k22 sagte: Leistungsstufe 3 nochmal eine E-Heizung mit 600W sind und dann die Leistungsstufe 4 der Pool mit den 2400W.
                                          Danke dir, jetzt kann ich beliebig viele Verbraucher der Reihe nach dazu oder abschalten am Überschuss orientiert, das ist perfekt.
                                            Hodde @paul53 last edited by
                                            @spidermike Hi Mike, mein Heizstab ist gerade im Anflug. Du hast da genau das schon aufgebaut was ich in den nächsten Wochen schaffen will. Wärst du bitte so nett und wüdest deinen finalen code posten?👏 Das würde mich und bestimmt einige andere um Tage beschleunigen. 🚀
                                            Meine 18.5 kWp Anlage mit 2 SMA WR und einem HM 2 liefert mir schon alles was man an Daten braucht (über Modbus) in den IoB. Das nutze ich in meiner Hausbussteurung (Beckhoff Cx9010) bereits als Anzeigeoption.
                                            Danke für die coole Vorarbeit.
                                            Hodde
                                            144
                                            15998
